Description
while converting an onnx model to tensorrt engine, I’m getting following myelin error. Can you guide what can be the issue?
(I’m using ngc tensorrt container in docker)
Error:
[08/10/2020-09:55:04] [V] [TRT] Builder timing cache: created 31 entries, 4 hit(s)
[08/10/2020-09:55:04] [E] [TRT] ../builder/myelin/codeGenerator.cpp (396) - Myelin Error in compileGraph: 64 (myelinProgramAnalysisError : Mistmatched number of elements in op lambda_1_1/Reshape_11_reshape _ reshape_(Unnamed Layer_ 355) [Constant](Unnamed Layer 356) [Constant](Unnamed Layer 374) [Constant](Unnamed Layer 349) [Constant] _ (Unnamed Layer_ 350) [Shuffle](Unnamed Layer 346) [Constant] _ (Unnamed Layer_ 347) [Shuffle]lambda_1_1/sub_8_lambda_1_1/sub_9_lambda_1_1/mul_11_lambda_1_1/ExpandDims_4_lambda_1_1/mul_15_lambda_1_1/sub_6_lambda_1_1/sub_7_lambda_1_1/mul_10_lambda_1_1/ExpandDims_3_lambda_1_1/mul_14_lambda_1_1/sub_5_lambda_1_1/sub_4_lambda_1_1/mul_9_lambda_1_1/ExpandDims_2_lambda_1_1/mul_13_lambda_1_1/sub_2_lambda_1_1/sub_3_lambda_1_1/mul_8_lambda_1_1/ExpandDims_1_lambda_1_1/mul_12_lambda_1_1/AddN_sum_lambda_1_1/AddN_sum_1_lambda_1_1/AddN_sum_2_lambda_1_1/Reshape_11_reshape _ reshape_fc_9_Add2_Relu_Transpose4(Unnamed Layer_ 366) [Constant] _ (Unnamed Layer_ 367) [Shuffle]lstm_10(Unnamed Layer_ 370) [Constant] _ (Unnamed Layer_ 371) [Shuffle]lstm_10_1(Unnamed Layer_ 412) [Constant](Unnamed Layer 413) [Constant](Unnamed Layer 431) [Constant]Transpose6(Unnamed Layer_ 423) [Constant] _ (Unnamed Layer_ 424) [Shuffle]lstm_10_back(Unnamed Layer_ 427) [Constant] _ (Unnamed Layer_ 428) [Shuffle]lstm_10_back_1(Unnamed Layer_ 432) [TripLimit](Unnamed Layer 433) [Iterator]lstm_10_back_2(Unnamed Layer_ 441) [Recurrence](Unnamed Layer 439) [Shuffle](Unnamed Layer 443) [Matrix Multiply](Unnamed Layer 442) [Matrix Multiply](Unnamed Layer 444) [ElementWise](Unnamed Layer 445) [ElementWise](Unnamed Layer 446) [Slice](Unnamed Layer 449) [Slice](Unnamed Layer 452) [Slice](Unnamed Layer 458) [Slice](Unnamed Layer 448) [Activation](Unnamed Layer 451) [Activation](Unnamed Layer 454) [Activation](Unnamed Layer 460) [Activation](Unnamed Layer 456) [ElementWise](Unnamed Layer 455) [ElementWise](Unnamed Layer 457) [ElementWise](Unnamed Layer 461) [Activation](Unnamed Layer 462) [ElementWise](Unnamed Layer 466) [LoopOutput](Unnamed Layer 375) [TripLimit](Unnamed Layer 376) [Iterator]lstm_10_2(Unnamed Layer_ 384) [Recurrence](Unnamed Layer 382) [Shuffle](Unnamed Layer 386) [Matrix Multiply](Unnamed Layer 385) [Matrix Multiply](Unnamed Layer 387) [ElementWise](Unnamed Layer 388) [ElementWise](Unnamed Layer 389) [Slice](Unnamed Layer 392) [Slice](Unnamed Layer 395) [Slice](Unnamed Layer 401) [Slice](Unnamed Layer 391) [Activation](Unnamed Layer 394) [Activation](Unnamed Layer 397) [Activation](Unnamed Layer 403) [Activation](Unnamed Layer 399) [ElementWise](Unnamed Layer 398) [ElementWise](Unnamed Layer 400) [ElementWise](Unnamed Layer 404) [Activation](Unnamed Layer 405) [ElementWise](Unnamed Layer 409) [LoopOutput](Unnamed Layer 478) [Constant](Unnamed Layer 479) [Constant](Unnamed Layer 489) [Constant] _ (Unnamed Layer_ 490) [Shuffle]lstm_11(Unnamed Layer_ 493) [Constant] _ (Unnamed Layer_ 494) [Shuffle]lstm_11_1_Squeeze2_Squeeze3_Add1(Unnamed Layer_ 539) [Constant](Unnamed Layer 540) [Constant](Unnamed Layer 550) [Constant] _ (Unnamed Layer_ 551) [Shuffle]lstm_11_back(Unnamed Layer_ 554) [Constant] _ (Unnamed Layer_ 555) [Shuffle]lstm_11_back_1(Unnamed Layer_ 562) [Iterator](Unnamed Layer 561) [TripLimit]lstm_11_back_2(Unnamed Layer_ 570) [Recurrence](Unnamed Layer 568) [Shuffle](Unnamed Layer 572) [Matrix Multiply](Unnamed Layer 571) [Matrix Multiply](Unnamed Layer 573) [ElementWise](Unnamed Layer 574) [ElementWise](Unnamed Layer 575) [Slice](Unnamed Layer 578) [Slice](Unnamed Layer 581) [Slice](Unnamed Layer 587) [Slice](Unnamed Layer 577) [Activation](Unnamed Layer 580) [Activation](Unnamed Layer 583) [Activation](Unnamed Layer 589) [Activation](Unnamed Layer 585) [ElementWise](Unnamed Layer 584) [ElementWise](Unnamed Layer 586) [ElementWise](Unnamed Layer 590) [Activation](Unnamed Layer 591) [ElementWise](Unnamed Layer 597) [LoopOutput]Squeeze1(Unnamed Layer_ 501) [Iterator](Unnamed Layer 500) [TripLimit]lstm_11_2(Unnamed Layer_ 509) [Recurrence](Unnamed Layer 507) [Shuffle](Unnamed Layer 511) [Matrix Multiply](Unnamed Layer 510) [Matrix Multiply](Unnamed Layer 512) [ElementWise](Unnamed Layer 513) [ElementWise](Unnamed Layer 514) [Slice](Unnamed Layer 517) [Slice](Unnamed Layer 520) [Slice](Unnamed Layer 526) [Slice](Unnamed Layer 516) [Activation](Unnamed Layer 519) [Activation](Unnamed Layer 522) [Activation](Unnamed Layer 528) [Activation](Unnamed Layer 524) [ElementWise](Unnamed Layer 523) [ElementWise](Unnamed Layer 525) [ElementWise](Unnamed Layer 529) [Activation](Unnamed Layer 530) [ElementWise](Unnamed Layer 536) [LoopOutput]Squeeze_concatenate_TransposeFanIn_succ_0(Unnamed Layer_ 610) [Constant] _ (Unnamed Layer_ 611) [Shuffle]fc_12(Unnamed Layer_ 613) [Constant] _ (Unnamed Layer_ 614) [Shuffle]Add(Unnamed Layer_ 624) [Shuffle]Softmax(Unnamed Layer_ 626) [Shuffle]fc_12_1/Identity_0_cropping__reshape input tensor lambda_1_1/AddN_0’(Unnamed Layer_ 355) [Constant](Unnamed Layer 356) [Constant](Unnamed Layer 374) [Constant](Unnamed Layer 349) [Constant] _ (Unnamed Layer_ 350) [Shuffle](Unnamed Layer 346) [Constant] _ (Unnamed Layer_ 347) [Shuffle]lambda_1_1/sub_8_lambda_1_1/sub_9_lambda_1_1/mul_11_lambda_1_1/ExpandDims_4_lambda_1_1/mul_15_lambda_1_1/sub_6_lambda_1_1/sub_7_lambda_1_1/mul_10_lambda_1_1/ExpandDims_3_lambda_1_1/mul_14_lambda_1_1/sub_5_lambda_1_1/sub_4_lambda_1_1/mul_9_lambda_1_1/ExpandDims_2_lambda_1_1/mul_13_lambda_1_1/sub_2_lambda_1_1/sub_3_lambda_1_1/mul_8_lambda_1_1/ExpandDims_1_lambda_1_1/mul_12_lambda_1_1/AddN_sum_lambda_1_1/AddN_sum_1_lambda_1_1/AddN_sum_2_lambda_1_1/Reshape_11_reshape _ reshape_fc_9_Add2_Relu_Transpose4(Unnamed Layer_ 366) [Constant] _ (Unnamed Layer_ 367) [Shuffle]lstm_10(Unnamed Layer_ 370) [Constant] _ (Unnamed Layer_ 371) [Shuffle]lstm_10_1(Unnamed Layer_ 412) [Constant](Unnamed Layer 413) [Constant](Unnamed Layer 431) [Constant]Transpose6(Unnamed Layer_ 423) [Constant] _ (Unnamed Layer_ 424) [Shuffle]lstm_10_back(Unnamed Layer_ 427) [Constant] _ (Unnamed Layer_ 428) [Shuffle]lstm_10_back_1(Unnamed Layer_ 432) [TripLimit](Unnamed Layer 433) [Iterator]lstm_10_back_2(Unnamed Layer_ 441) [Recurrence](Unnamed Layer 439) [Shuffle](Unnamed Layer 443) [Matrix Multiply](Unnamed Layer 442) [Matrix Multiply](Unnamed Layer 444) [ElementWise](Unnamed Layer 445) [ElementWise](Unnamed Layer 446) [Slice](Unnamed Layer 449) [Slice](Unnamed Layer 452) [Slice](Unnamed Layer 458) [Slice](Unnamed Layer 448) [Activation](Unnamed Layer 451) [Activation](Unnamed Layer 454) [Activation](Unnamed Layer 460) [Activation](Unnamed Layer 456) [ElementWise](Unnamed Layer 455) [ElementWise](Unnamed Layer 457) [ElementWise](Unnamed Layer 461) [Activation](Unnamed Layer 462) [ElementWise](Unnamed Layer 466) [LoopOutput](Unnamed Layer 375) [TripLimit](Unnamed Layer 376) [Iterator]lstm_10_2(Unnamed Layer_ 384) [Recurrence](Unnamed Layer 382) [Shuffle](Unnamed Layer 386) [Matrix Multiply](Unnamed Layer 385) [Matrix Multiply](Unnamed Layer 387) [ElementWise](Unnamed Layer 388) [ElementWise](Unnamed Layer 389) [Slice](Unnamed Layer 392) [Slice](Unnamed Layer 395) [Slice](Unnamed Layer 401) [Slice](Unnamed Layer 391) [Activation](Unnamed Layer 394) [Activation](Unnamed Layer 397) [Activation](Unnamed Layer 403) [Activation](Unnamed Layer 399) [ElementWise](Unnamed Layer 398) [ElementWise](Unnamed Layer 400) [ElementWise](Unnamed Layer 404) [Activation](Unnamed Layer 405) [ElementWise](Unnamed Layer 409) [LoopOutput](Unnamed Layer 478) [Constant](Unnamed Layer 479) [Constant](Unnamed Layer 489) [Constant] _ (Unnamed Layer_ 490) [Shuffle]lstm_11(Unnamed Layer_ 493) [Constant] _ (Unnamed Layer_ 494) [Shuffle]lstm_11_1_Squeeze2_Squeeze3_Add1(Unnamed Layer_ 539) [Constant](Unnamed Layer 540) [Constant](Unnamed Layer 550) [Constant] _ (Unnamed Layer_ 551) [Shuffle]lstm_11_back(Unnamed Layer_ 554) [Constant] _ (Unnamed Layer_ 555) [Shuffle]lstm_11_back_1(Unnamed Layer_ 562) [Iterator](Unnamed Layer 561) [TripLimit]lstm_11_back_2(Unnamed Layer_ 570) [Recurrence](Unnamed Layer 568) [Shuffle](Unnamed Layer 572) [Matrix Multiply](Unnamed Layer 571) [Matrix Multiply](Unnamed Layer 573) [ElementWise](Unnamed Layer 574) [ElementWise](Unnamed Layer 575) [Slice](Unnamed Layer 578) [Slice](Unnamed Layer 581) [Slice](Unnamed Layer 587) [Slice](Unnamed Layer 577) [Activation](Unnamed Layer 580) [Activation](Unnamed Layer 583) [Activation](Unnamed Layer 589) [Activation](Unnamed Layer 585) [ElementWise](Unnamed Layer 584) [ElementWise](Unnamed Layer 586) [ElementWise](Unnamed Layer 590) [Activation](Unnamed Layer 591) [ElementWise](Unnamed Layer 597) [LoopOutput]Squeeze1(Unnamed Layer_ 501) [Iterator](Unnamed Layer 500) [TripLimit]lstm_11_2(Unnamed Layer_ 509) [Recurrence](Unnamed Layer 507) [Shuffle](Unnamed Layer 511) [Matrix Multiply](Unnamed Layer 510) [Matrix Multiply](Unnamed Layer 512) [ElementWise](Unnamed Layer 513) [ElementWise](Unnamed Layer 514) [Slice](Unnamed Layer 517) [Slice](Unnamed Layer 520) [Slice](Unnamed Layer 526) [Slice](Unnamed Layer 516) [Activation](Unnamed Layer 519) [Activation](Unnamed Layer 522) [Activation](Unnamed Layer 528) [Activation](Unnamed Layer 524) [ElementWise](Unnamed Layer 523) [ElementWise](Unnamed Layer 525) [ElementWise](Unnamed Layer 529) [Activation](Unnamed Layer 530) [ElementWise](Unnamed Layer 536) [LoopOutput]Squeeze_concatenate_TransposeFanIn_succ_0(Unnamed Layer_ 610) [Constant] _ (Unnamed Layer_ 611) [Shuffle]fc_12(Unnamed Layer_ 613) [Constant] _ (Unnamed Layer_ 614) [Shuffle]Add(Unnamed Layer_ 624) [Shuffle]Softmax(Unnamed Layer_ 626) [Shuffle]fc_12_1/Identity_0_cropping shape [350,512] and specified output shape [350,50,3584]
[08/10/2020-11:19:44] [V] [TRT] Builder timing cache: created 31 entries, 4 hit(s)
[08/10/2020-11:19:44] [E] [TRT] ../builder/myelin/codeGenerator.cpp (396) - Myelin Error in compileGraph: 64 ()
[08/10/2020-09:55:04] [E] Engine creation failed
[08/10/2020-09:55:04] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec # trtexec --onnx=keras-recognize-model.onnx --explicitBatch --verbose
root@33bbf7f1ec89:/workspace#
Environment
TensorRT Version: 7.1
GPU Type: T4
CUDA Version: 11.0
Operating System + Version: Ubuntu 18.04
Python Version (if applicable): 3
TensorFlow Version (if applicable): 2.2.0
Relevant Files
Here’s my model file:
Steps To Reproduce
trtexec --onnx=keras-recognize-model.onnx --verbose --explicitBatch
