I’m working on a distributed computing system for video rendering and live multiple stream video. I know that the raspberry pi module has the Turing Board and I’m interested in finding out if there is a similar solution for the Jetson Nano. I’ve looked into the Pico Cluster but would be more interested in a smaller form factor than 5 dev modules stacked together. Any suggestions?
Hi klnaber7,
I haven’t seen any yet. You may probably consider to use the devkits than use the modules in small quantities.
