I plugged usb power supply of 5v with 2amps adapter. I dont know issue is on power supply but its automatically turns off. Again only if i remove and replug the supply it turned again. Then after sometimes its turning off
Again same problem occuring at different instant. While running the testing code, imagenet-camera.cpp, while loading the networks first time. It shutdows automatically… Please help me to fix this issue
Hi sanjay.nafil,
Issue seems similar with below one, please take a look if can help: [url]https://devtalk.nvidia.com/default/topic/1056534/jetson-nano/jeston-nano-use-more-power-failed/[/url]
