I installed OFED_MLNX, Accelio and nbdx packages. My card is Connect X3 PRO.
I can see /dev/nbdx0 from client and issue READ/WRITE I/O against /dev/nbdx0.
However, I got different data when I read back the data I had written onto /dev/nbdx0.
You wouldn’t notice this problem if you just run “fio” test, because “fio” does not check data integrity by default.
Anyone has seen this problem?
Thanks,
Ted
