Ncu do not execute application
Whatever executable is, the same result is returned by the command ncu executable
==WARNING== No kernels were profiled.
==WARNING== Profiling kernels launched by child processes requires the --target-processes all option.
ncu version: nsight-compute-2021.2.2, which is patched by patchelf to fit the system and the package may have been patched before my patch.
cuda version: 11.4.1
gpu: A100
Hi, @lichangkai225
Sorry for the issue you met.
Can you clarify the driver/os you use?
Also how do you install the package and NCU ?
If it is bundled with the cuda, then for 11.4.1, it should be 2021.2.1.
Not sure why you get 2021.2.2.
Hi, @lichangkai225
Is your problem solved now ? Can you use latest NCU to have a try ? Getting Started with Nsight Compute | NVIDIA Developer
