Hi, I’m hoping someone can help me.
I need to enable a connected HMD (Vive or Index) as a monitor. When the device is connected with open source nouveau drivers, xrandr shows it as disconnected and non-desktop 1 which is the expected behavior.
However if I use proprietary drivers, xrandr does not show anything except my primary monitor. But, nvidia-xconfig still sees the HMD.
Thanks for your help in advacne.
Some more details:
- GTX 1060
- Ubuntu 20.04
- Tried default nouveau, default proprietary, as well as graphics-ppa 440, 455, and the new 460 proprietary.
proprietary:
xrandrdoes not detect the HMD (output at the end)- SteamVR works fine
- Monado works fine
nvidia-xconfigdetects the HMD (output at the end)
nouveau
xrandrdetects the display asnon-desktopwhich I can then enable with--set non-desktop 0, which is what I’d like to be able to do with Nvidia’s drivers.
Nvidia Proprietary Driver:
$ nvidia-xconfig --query-gpu-info
Number of GPUs: 1
GPU #0:
Name : GeForce GTX 1060 6GB
UUID : GPU-24bd7b56-f200-00aa-5e64-939807a69dcc
PCI BusID : PCI:1:0:0
Number of Display Devices: 2
Display Device 0 (TV-1):
EDID Name : HTC Corporation HTC-VIVE
Minimum HorizSync : 1.000 kHz
Maximum HorizSync : 255.000 kHz
Minimum VertRefresh : 20 Hz
Maximum VertRefresh : 120 Hz
Maximum PixelClock : 297.000 MHz
Maximum Width : 2160 pixels
Maximum Height : 1200 pixels
Preferred Width : 2160 pixels
Preferred Height : 1200 pixels
Preferred VertRefresh : 90 Hz
Display Device 1 (TV-2):
EDID Name : LG Electronics LG Ultra HD
Minimum HorizSync : 30.000 kHz
Maximum HorizSync : 135.000 kHz
Minimum VertRefresh : 56 Hz
Maximum VertRefresh : 61 Hz
Maximum PixelClock : 560.000 MHz
Maximum Width : 3840 pixels
Maximum Height : 2160 pixels
Preferred Width : 3840 pixels
Preferred Height : 2160 pixels
Preferred VertRefresh : 60 Hz
Physical Width : 600 mm
Physical Height : 340 mm
$ xrandr --verbose
Screen 0: minimum 8 x 8, current 3840 x 2160, maximum 32767 x 32767
DVI-D-0 disconnected (normal left inverted right x axis y axis)
Identifier: 0x1bd
Timestamp: 28320
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
0 1
CscMatrix: 65536 0 0 0 0 65536 0 0 0 0 65536 0
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorType: DVI-D
ConnectorNumber: 0
_ConnectorLocation: 0
non-desktop: 0
supported: 0, 1
HDMI-0 disconnected (normal left inverted right x axis y axis)
Identifier: 0x1be
Timestamp: 28320
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorType: HDMI
ConnectorNumber: 3
_ConnectorLocation: 3
non-desktop: 0
supported: 0, 1
DP-0 connected primary 3840x2160+0+0 (0x1c0) normal (normal left inverted right x axis y axis) 600mm x 340mm
Identifier: 0x1bf
Timestamp: 28320
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1 2 3
filter:
_MUTTER_PRESENTATION_OUTPUT: 0
0 1
EDID:
00ffffffffffff001e6d095b46a30700
041b0104b53c22789e3035a7554ea326
0f50542108007140818081c0a9c0d1c0
8100010101014dd000a0f0703e803020
650c58542100001a286800a0f0703e80
0890650c58542100001a000000fd0038
3d1e8738000a202020202020000000fc
004c4720556c7472612048440a2001ac
02031171449004030123090707830100
00023a801871382d40582c4500585421
00001e565e00a0a0a029503020350058
542100001a0000000000000000000000
00000000000000000000000000000000
000000000000000000000000000000c8
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: DisplayPort
supported: DisplayPort
ConnectorType: DisplayPort
ConnectorNumber: 4
_ConnectorLocation: 4
non-desktop: 0
supported: 0, 1
3840x2160 (0x1c0) 533.250MHz +HSync -VSync *current +preferred
h: width 3840 start 3888 end 3920 total 4000 skew 0 clock 133.31KHz
v: height 2160 start 2214 end 2219 total 2222 clock 60.00Hz
3840x2160 (0x1c1) 266.640MHz +HSync -VSync
h: width 3840 start 3848 end 3992 total 4000 skew 0 clock 66.66KHz
v: height 2160 start 2214 end 2219 total 2222 clock 30.00Hz
2560x1440 (0x1c2) 241.500MHz +HSync -VSync
h: width 2560 start 2608 end 2640 total 2720 skew 0 clock 88.79KHz
v: height 1440 start 1443 end 1448 total 1481 clock 59.95Hz
1920x1080 (0x1c3) 148.500MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x1c4) 148.350MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1600x900 (0x1c5) 108.000MHz +HSync +VSync
h: width 1600 start 1624 end 1704 total 1800 skew 0 clock 60.00KHz
v: height 900 start 901 end 904 total 1000 clock 60.00Hz
1280x1024 (0x1c6) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1280x800 (0x1c7) 83.500MHz -HSync +VSync
h: width 1280 start 1352 end 1480 total 1680 skew 0 clock 49.70KHz
v: height 800 start 803 end 809 total 831 clock 59.81Hz
1280x720 (0x1c8) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x1c9) 74.180MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1152x864 (0x1ca) 81.750MHz -HSync +VSync
h: width 1152 start 1216 end 1336 total 1520 skew 0 clock 53.78KHz
v: height 864 start 867 end 871 total 897 clock 59.96Hz
1024x768 (0x1cb) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x1cc) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
720x480 (0x1cd) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
640x480 (0x1ce) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
640x480 (0x1cf) 25.170MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.46KHz
v: height 480 start 490 end 492 total 525 clock 59.93Hz
DP-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x1d0
Timestamp: 28320
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorNumber: 4
non-desktop: 0
supported: 0, 1
DVI-D-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x1d1
Timestamp: 28320
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorNumber: 2
_ConnectorLocation: 2
non-desktop: 0
supported: 0, 1
