Greetings,
I recently installed EndeavourOS on a HP Omen en0xxx gaming laptop with a nvidia 1660ti mobile with KDE, and I attempted to use xrandr to enable my second monitor since it isn’t showing up on the gui, and got the error: “xrandr: Configure crtc 4 failed” when running xrandr --auto, since at the time it the second monitor showed up when running xrandr. I found a forum post and installed optimus-manager and switched to hybrid. After that KDE no longer detected the second monitor. I attempted to use xrandr to add a mode for my second monitor, but after attempting to do the switch I got the same error message again. This is a fresh install of endeavouros and I do not know what is going wrong. I would appreciate any help.
lspci -k
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
Subsystem: Hewlett-Packard Company Device 8786
lspci: Unable to load libkmod resources: error -2
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
Subsystem: Advanced Micro Devices, Inc. [AMD] Device 1453
Kernel driver in use: pcieport
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
Subsystem: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller
Kernel driver in use: piix4_smbus
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
Subsystem: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 3
Kernel driver in use: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 7
01:00.0 VGA compatible controller: NVIDIA Corporation TU116M [GeForce GTX 1660 Ti Mobile] (rev a1)
DeviceName: NVIDIA Graphics Device
Kernel driver in use: nouveau
01:00.1 Audio device: NVIDIA Corporation TU116 High Definition Audio Controller (rev a1)
Kernel driver in use: snd_hda_intel
01:00.2 USB controller: NVIDIA Corporation TU116 USB 3.1 Host Controller (rev a1)
Kernel driver in use: xhci_hcd
01:00.3 Serial bus controller: NVIDIA Corporation TU116 USB Type-C UCSI Controller (rev a1)
Kernel driver in use: nvidia-gpu
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 16)
DeviceName: OnBoard Enthernets
Kernel driver in use: r8169
03:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
DeviceName: Intel Wireless LAN + BT
Subsystem: Intel Corporation Wi-Fi 6 AX200NGW
Kernel driver in use: iwlwifi
04:00.0 SD Host controller: Genesys Logic, Inc GL9750 SD Host Controller (rev 01)
DeviceName: Realtek PCIE CardReader
Kernel driver in use: sdhci-pci
05:00.0 Non-Volatile memory controller: Sandisk Corp WD Blue SN550 NVMe SSD (rev 01)
Subsystem: Sandisk Corp WD Blue SN550 NVMe SSD
Kernel driver in use: nvme
06:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
Subsystem: Samsung Electronics Co Ltd SSD 970 EVO
07:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Renoir (rev c6)
DeviceName: Onboard IGD
Kernel driver in use: amdgpu
07:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
Kernel driver in use: ccp
07:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
07:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
07:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor (rev 01)
Kernel driver in use: snd_rn_pci_acp3x
07:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
08:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
Kernel driver in use: ahci
08:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
xrandr --verbose
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+0 (0x44) normal (normal left inverted right x axis y axis) 344mm x 194mm
Identifier: 0x42
Timestamp: 2026239
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1 2 3
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
00ffffffffffff0009e5df0800000000
251d0104a52213780754a5a7544c9b26
0f505400000001010101010101010101
010101010101988980a0703860403020
360058c21000001a0000000000000000
00000000000000000000000000fe0042
4f452043510a202020202020000000fe
004e5631353646484d2d4e59340a00fd
HDCP Content Type: HDCP Type0
supported: HDCP Type0, HDCP Type1
Content Protection: Undesired
supported: Undesired, Desired, Enabled
vrr_capable: 0
range: (0, 1)
abm level: 0
range: (0, 4)
max bpc: 16
range: (8, 16)
underscan vborder: 0
range: (0, 128)
underscan hborder: 0
range: (0, 128)
underscan: off
supported: off, on, auto
scaling mode: None
supported: None, Full, Center, Full aspect
link-status: Good
supported: Good, Bad
CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
0 1
CONNECTOR_ID: 78
supported: 78
non-desktop: 0
range: (0, 1)
1920x1080 (0x44) 352.240MHz +HSync -VSync *current +preferred
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 169.35KHz
v: height 1080 start 1083 end 1089 total 1176 clock 144.00Hz
1920x1080 (0x45) 356.375MHz -HSync +VSync DoubleScan
h: width 1920 start 2080 end 2288 total 2656 skew 0 clock 134.18KHz
v: height 1080 start 1081 end 1084 total 1118 clock 60.01Hz
1920x1080 (0x46) 266.500MHz +HSync -VSync DoubleScan
h: width 1920 start 1944 end 1960 total 2000 skew 0 clock 133.25KHz
v: height 1080 start 1081 end 1084 total 1111 clock 59.97Hz
1920x1080 (0x47) 173.000MHz -HSync +VSync
h: width 1920 start 2048 end 2248 total 2576 skew 0 clock 67.16KHz
v: height 1080 start 1083 end 1088 total 1120 clock 59.96Hz
1920x1080 (0x48) 138.500MHz +HSync -VSync
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 66.59KHz
v: height 1080 start 1083 end 1088 total 1111 clock 59.93Hz
1680x1050 (0x49) 352.240MHz +HSync -VSync
h: width 1680 start 1968 end 2000 total 2080 skew 0 clock 169.35KHz
v: height 1050 start 1083 end 1089 total 1176 clock 144.00Hz
1680x1050 (0x4a) 146.250MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1680x1050 (0x4b) 119.000MHz +HSync -VSync
h: width 1680 start 1728 end 1760 total 1840 skew 0 clock 64.67KHz
v: height 1050 start 1053 end 1059 total 1080 clock 59.88Hz
1400x1050 (0x4c) 155.800MHz +HSync +VSync
h: width 1400 start 1464 end 1784 total 1912 skew 0 clock 81.49KHz
v: height 1050 start 1052 end 1064 total 1090 clock 74.76Hz
1400x1050 (0x4d) 122.000MHz +HSync +VSync
h: width 1400 start 1488 end 1640 total 1880 skew 0 clock 64.89KHz
v: height 1050 start 1052 end 1064 total 1082 clock 59.98Hz
1600x900 (0x4e) 246.000MHz -HSync +VSync DoubleScan
h: width 1600 start 1728 end 1900 total 2200 skew 0 clock 111.82KHz
v: height 900 start 901 end 904 total 932 clock 59.99Hz
1600x900 (0x4f) 186.500MHz +HSync -VSync DoubleScan
h: width 1600 start 1624 end 1640 total 1680 skew 0 clock 111.01KHz
v: height 900 start 901 end 904 total 926 clock 59.94Hz
1600x900 (0x50) 118.250MHz -HSync +VSync
h: width 1600 start 1696 end 1856 total 2112 skew 0 clock 55.99KHz
v: height 900 start 903 end 908 total 934 clock 59.95Hz
1600x900 (0x51) 97.500MHz +HSync -VSync
h: width 1600 start 1648 end 1680 total 1760 skew 0 clock 55.40KHz
v: height 900 start 903 end 908 total 926 clock 59.82Hz
1280x1024 (0x52) 352.240MHz +HSync -VSync
h: width 1280 start 1968 end 2000 total 2080 skew 0 clock 169.35KHz
v: height 1024 start 1083 end 1089 total 1176 clock 144.00Hz
1280x1024 (0x53) 157.500MHz +HSync +VSync
h: width 1280 start 1344 end 1504 total 1728 skew 0 clock 91.15KHz
v: height 1024 start 1025 end 1028 total 1072 clock 85.02Hz
1280x1024 (0x54) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x55) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1440x900 (0x56) 352.240MHz +HSync -VSync
h: width 1440 start 1968 end 2000 total 2080 skew 0 clock 169.35KHz
v: height 900 start 1083 end 1089 total 1176 clock 144.00Hz
1400x900 (0x57) 103.500MHz -HSync +VSync
h: width 1400 start 1480 end 1624 total 1848 skew 0 clock 56.01KHz
v: height 900 start 903 end 913 total 934 clock 59.96Hz
1400x900 (0x58) 86.500MHz +HSync -VSync
h: width 1400 start 1448 end 1480 total 1560 skew 0 clock 55.45KHz
v: height 900 start 903 end 913 total 926 clock 59.88Hz
1280x960 (0x59) 148.500MHz +HSync +VSync
h: width 1280 start 1344 end 1504 total 1728 skew 0 clock 85.94KHz
v: height 960 start 961 end 964 total 1011 clock 85.00Hz
1280x960 (0x5a) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1440x810 (0x5b) 198.125MHz -HSync +VSync DoubleScan
h: width 1440 start 1548 end 1704 total 1968 skew 0 clock 100.67KHz
v: height 810 start 811 end 814 total 839 clock 60.00Hz
1440x810 (0x5c) 151.875MHz +HSync -VSync DoubleScan
h: width 1440 start 1464 end 1480 total 1520 skew 0 clock 99.92KHz
v: height 810 start 811 end 814 total 833 clock 59.97Hz
1368x768 (0x5d) 85.250MHz -HSync +VSync
h: width 1368 start 1440 end 1576 total 1784 skew 0 clock 47.79KHz
v: height 768 start 771 end 781 total 798 clock 59.88Hz
1368x768 (0x5e) 72.250MHz +HSync -VSync
h: width 1368 start 1416 end 1448 total 1528 skew 0 clock 47.28KHz
v: height 768 start 771 end 781 total 790 clock 59.85Hz
1280x800 (0x5f) 352.240MHz +HSync -VSync
v: height 800 start 1083 end 1089 total 1176 clock 144.00Hz
1280x800 (0x60) 174.250MHz -HSync +VSync DoubleScan
h: width 1280 start 1380 end 1516 total 1752 skew 0 clock 99.46KHz
v: height 800 start 801 end 804 total 829 clock 59.99Hz
1280x800 (0x61) 134.250MHz +HSync -VSync DoubleScan
h: width 1280 start 1304 end 1320 total 1360 skew 0 clock 98.71KHz
v: height 800 start 801 end 804 total 823 clock 59.97Hz
1280x800 (0x62) 83.500MHz -HSync +VSync
h: width 1280 start 1352 end 1480 total 1680 skew 0 clock 49.70KHz
v: height 800 start 803 end 809 total 831 clock 59.81Hz
1280x800 (0x63) 71.000MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 49.31KHz
v: height 800 start 803 end 809 total 823 clock 59.91Hz
1152x864 (0x64) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1280x720 (0x65) 352.240MHz +HSync -VSync
v: height 720 start 1083 end 1089 total 1176 clock 144.00Hz
1280x720 (0x66) 156.125MHz -HSync +VSync DoubleScan
h: width 1280 start 1376 end 1512 total 1744 skew 0 clock 89.52KHz
v: height 720 start 721 end 724 total 746 clock 60.00Hz
1280x720 (0x67) 120.750MHz +HSync -VSync DoubleScan
h: width 1280 start 1304 end 1320 total 1360 skew 0 clock 88.79KHz
v: height 720 start 721 end 724 total 740 clock 59.99Hz
1280x720 (0x68) 74.500MHz -HSync +VSync
h: width 1280 start 1344 end 1472 total 1664 skew 0 clock 44.77KHz
v: height 720 start 723 end 728 total 748 clock 59.86Hz
1280x720 (0x69) 63.750MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 44.27KHz
v: height 720 start 723 end 728 total 741 clock 59.74Hz
1024x768 (0x6a) 352.240MHz +HSync -VSync
h: width 1024 start 1968 end 2000 total 2080 skew 0 clock 169.35KHz
v: height 768 start 1083 end 1089 total 1176 clock 144.00Hz
1024x768 (0x6b) 194.020MHz -HSync +VSync DoubleScan
h: width 1024 start 1108 end 1220 total 1416 skew 0 clock 137.02KHz
v: height 768 start 768 end 770 total 806 clock 85.00Hz
1024x768 (0x6c) 170.240MHz -HSync +VSync DoubleScan
h: width 1024 start 1108 end 1220 total 1416 skew 0 clock 120.23KHz
v: height 768 start 768 end 770 total 801 clock 75.05Hz
1024x768 (0x6d) 133.475MHz -HSync +VSync DoubleScan
h: width 1024 start 1100 end 1212 total 1400 skew 0 clock 95.34KHz
v: height 768 start 768 end 770 total 794 clock 60.04Hz
1024x768 (0x6e) 94.500MHz +HSync +VSync
h: width 1024 start 1072 end 1168 total 1376 skew 0 clock 68.68KHz
v: height 768 start 769 end 772 total 808 clock 85.00Hz
1024x768 (0x6f) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x70) 75.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.48KHz
v: height 768 start 771 end 777 total 806 clock 70.07Hz
1024x768 (0x71) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
1024x768i (0x72) 44.900MHz +HSync +VSync Interlace
h: width 1024 start 1032 end 1208 total 1264 skew 0 clock 35.52KHz
v: height 768 start 768 end 776 total 817 clock 86.96Hz
960x720 (0x73) 170.675MHz -HSync +VSync DoubleScan
h: width 960 start 1036 end 1144 total 1328 skew 0 clock 128.52KHz
v: height 720 start 720 end 722 total 756 clock 85.00Hz
960x720 (0x74) 148.500MHz -HSync +VSync DoubleScan
h: width 960 start 1032 end 1144 total 1320 skew 0 clock 112.50KHz
v: height 720 start 720 end 722 total 750 clock 75.00Hz
960x720 (0x75) 117.000MHz -HSync +VSync DoubleScan
h: width 960 start 1024 end 1128 total 1300 skew 0 clock 90.00KHz
v: height 720 start 720 end 722 total 750 clock 60.00Hz
928x696 (0x76) 144.000MHz -HSync +VSync DoubleScan
h: width 928 start 992 end 1104 total 1280 skew 0 clock 112.50KHz
v: height 696 start 696 end 698 total 750 clock 75.00Hz
928x696 (0x77) 109.150MHz -HSync +VSync DoubleScan
h: width 928 start 976 end 1088 total 1264 skew 0 clock 86.35KHz
v: height 696 start 696 end 698 total 719 clock 60.05Hz
896x672 (0x78) 130.500MHz -HSync +VSync DoubleScan
h: width 896 start 944 end 1052 total 1228 skew 0 clock 106.27KHz
v: height 672 start 672 end 674 total 708 clock 75.05Hz
896x672 (0x79) 102.400MHz -HSync +VSync DoubleScan
h: width 896 start 960 end 1060 total 1224 skew 0 clock 83.66KHz
v: height 672 start 672 end 674 total 697 clock 60.01Hz
1024x576 (0x7a) 98.500MHz -HSync +VSync DoubleScan
h: width 1024 start 1092 end 1200 total 1376 skew 0 clock 71.58KHz
v: height 576 start 577 end 580 total 597 clock 59.95Hz
1024x576 (0x7b) 78.375MHz +HSync -VSync DoubleScan
h: width 1024 start 1048 end 1064 total 1104 skew 0 clock 70.99KHz
v: height 576 start 577 end 580 total 592 clock 59.96Hz
1024x576 (0x7c) 46.500MHz -HSync +VSync
h: width 1024 start 1064 end 1160 total 1296 skew 0 clock 35.88KHz
v: height 576 start 579 end 584 total 599 clock 59.90Hz
1024x576 (0x7d) 42.000MHz +HSync -VSync
h: width 1024 start 1072 end 1104 total 1184 skew 0 clock 35.47KHz
v: height 576 start 579 end 584 total 593 clock 59.82Hz
960x600 (0x7e) 96.625MHz -HSync +VSync DoubleScan
h: width 960 start 1028 end 1128 total 1296 skew 0 clock 74.56KHz
v: height 600 start 601 end 604 total 622 clock 59.93Hz
960x600 (0x7f) 77.000MHz +HSync -VSync DoubleScan
h: width 960 start 984 end 1000 total 1040 skew 0 clock 74.04KHz
v: height 600 start 601 end 604 total 617 clock 60.00Hz
832x624 (0x80) 57.284MHz -HSync -VSync
h: width 832 start 864 end 928 total 1152 skew 0 clock 49.73KHz
v: height 624 start 625 end 628 total 667 clock 74.55Hz
960x540 (0x81) 86.500MHz -HSync +VSync DoubleScan
h: width 960 start 1024 end 1124 total 1288 skew 0 clock 67.16KHz
v: height 540 start 541 end 544 total 560 clock 59.96Hz
960x540 (0x82) 69.250MHz +HSync -VSync DoubleScan
h: width 960 start 984 end 1000 total 1040 skew 0 clock 66.59KHz
v: height 540 start 541 end 544 total 555 clock 59.99Hz
960x540 (0x83) 40.750MHz -HSync +VSync
h: width 960 start 992 end 1088 total 1216 skew 0 clock 33.51KHz
v: height 540 start 543 end 548 total 562 clock 59.63Hz
960x540 (0x84) 37.250MHz +HSync -VSync
h: width 960 start 1008 end 1040 total 1120 skew 0 clock 33.26KHz
v: height 540 start 543 end 548 total 556 clock 59.82Hz
800x600 (0x85) 352.240MHz +HSync -VSync
h: width 800 start 1968 end 2000 total 2080 skew 0 clock 169.35KHz
v: height 600 start 1083 end 1089 total 1176 clock 144.00Hz
800x600 (0x86) 114.750MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 106.25KHz
v: height 600 start 600 end 602 total 625 clock 85.00Hz
800x600 (0x87) 101.250MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 93.75KHz
v: height 600 start 600 end 602 total 625 clock 75.00Hz
800x600 (0x88) 94.500MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 87.50KHz
v: height 600 start 600 end 602 total 625 clock 70.00Hz
800x600 (0x89) 87.750MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 81.25KHz
v: height 600 start 600 end 602 total 625 clock 65.00Hz
800x600 (0x8a) 81.000MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 75.00KHz
v: height 600 start 600 end 602 total 625 clock 60.00Hz
800x600 (0x8b) 56.300MHz +HSync +VSync
h: width 800 start 832 end 896 total 1048 skew 0 clock 53.72KHz
v: height 600 start 601 end 604 total 631 clock 85.14Hz
800x600 (0x8c) 50.000MHz +HSync +VSync
h: width 800 start 856 end 976 total 1040 skew 0 clock 48.08KHz
v: height 600 start 637 end 643 total 666 clock 72.19Hz
800x600 (0x8d) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x8e) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x8f) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
840x525 (0x90) 73.125MHz -HSync +VSync DoubleScan
h: width 840 start 892 end 980 total 1120 skew 0 clock 65.29KHz
v: height 525 start 526 end 529 total 544 clock 60.01Hz
840x525 (0x91) 59.500MHz +HSync -VSync DoubleScan
h: width 840 start 864 end 880 total 920 skew 0 clock 64.67KHz
v: height 525 start 526 end 529 total 540 clock 59.88Hz
864x486 (0x92) 32.500MHz -HSync +VSync
h: width 864 start 888 end 968 total 1072 skew 0 clock 30.32KHz
v: height 486 start 489 end 494 total 506 clock 59.92Hz
864x486 (0x93) 30.500MHz +HSync -VSync
h: width 864 start 912 end 944 total 1024 skew 0 clock 29.79KHz
v: height 486 start 489 end 494 total 500 clock 59.57Hz
700x525 (0x94) 77.900MHz +HSync +VSync DoubleScan
h: width 700 start 732 end 892 total 956 skew 0 clock 81.49KHz
v: height 525 start 526 end 532 total 545 clock 74.76Hz
700x525 (0x95) 61.000MHz +HSync +VSync DoubleScan
h: width 700 start 744 end 820 total 940 skew 0 clock 64.89KHz
v: height 525 start 526 end 532 total 541 clock 59.98Hz
800x450 (0x96) 59.125MHz -HSync +VSync DoubleScan
h: width 800 start 848 end 928 total 1056 skew 0 clock 55.99KHz
v: height 450 start 451 end 454 total 467 clock 59.95Hz
800x450 (0x97) 48.750MHz +HSync -VSync DoubleScan
h: width 800 start 824 end 840 total 880 skew 0 clock 55.40KHz
v: height 450 start 451 end 454 total 463 clock 59.82Hz
640x512 (0x98) 78.750MHz +HSync +VSync DoubleScan
h: width 640 start 672 end 752 total 864 skew 0 clock 91.15KHz
v: height 512 start 512 end 514 total 536 clock 85.02Hz
640x512 (0x99) 67.500MHz +HSync +VSync DoubleScan
h: width 640 start 648 end 720 total 844 skew 0 clock 79.98KHz
v: height 512 start 512 end 514 total 533 clock 75.02Hz
640x512 (0x9a) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 664 end 720 total 844 skew 0 clock 63.98KHz
v: height 512 start 512 end 514 total 533 clock 60.02Hz
700x450 (0x9b) 51.750MHz -HSync +VSync DoubleScan
h: width 700 start 740 end 812 total 924 skew 0 clock 56.01KHz
v: height 450 start 451 end 456 total 467 clock 59.96Hz
700x450 (0x9c) 43.250MHz +HSync -VSync DoubleScan
h: width 700 start 724 end 740 total 780 skew 0 clock 55.45KHz
v: height 450 start 451 end 456 total 463 clock 59.88Hz
640x480 (0x9d) 352.240MHz +HSync -VSync
h: width 640 start 1968 end 2000 total 2080 skew 0 clock 169.35KHz
v: height 480 start 1083 end 1089 total 1176 clock 144.00Hz
640x480 (0x9e) 74.250MHz +HSync +VSync DoubleScan
h: width 640 start 672 end 752 total 864 skew 0 clock 85.94KHz
v: height 480 start 480 end 482 total 505 clock 85.09Hz
640x480 (0x9f) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 688 end 744 total 900 skew 0 clock 60.00KHz
v: height 480 start 480 end 482 total 500 clock 60.00Hz
640x480 (0xa0) 36.000MHz -HSync -VSync
h: width 640 start 696 end 752 total 832 skew 0 clock 43.27KHz
v: height 480 start 481 end 484 total 509 clock 85.01Hz
640x480 (0xa1) 31.500MHz -HSync -VSync
h: width 640 start 664 end 704 total 832 skew 0 clock 37.86KHz
v: height 480 start 489 end 492 total 520 clock 72.81Hz
640x480 (0xa2) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0xa3) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
720x405 (0xa4) 22.500MHz -HSync +VSync
h: width 720 start 744 end 808 total 896 skew 0 clock 25.11KHz
v: height 405 start 408 end 413 total 422 clock 59.51Hz
720x405 (0xa5) 21.750MHz +HSync -VSync
h: width 720 start 768 end 800 total 880 skew 0 clock 24.72KHz
v: height 405 start 408 end 413 total 419 clock 58.99Hz
720x400 (0xa6) 35.500MHz -HSync +VSync
h: width 720 start 756 end 828 total 936 skew 0 clock 37.93KHz
v: height 400 start 401 end 404 total 446 clock 85.04Hz
684x384 (0xa7) 42.625MHz -HSync +VSync DoubleScan
h: width 684 start 720 end 788 total 892 skew 0 clock 47.79KHz
v: height 384 start 385 end 390 total 399 clock 59.88Hz
684x384 (0xa8) 36.125MHz +HSync -VSync DoubleScan
h: width 684 start 708 end 724 total 764 skew 0 clock 47.28KHz
v: height 384 start 385 end 390 total 395 clock 59.85Hz
640x400 (0xa9) 41.750MHz -HSync +VSync DoubleScan
h: width 640 start 676 end 740 total 840 skew 0 clock 49.70KHz
v: height 400 start 401 end 404 total 415 clock 59.88Hz
640x400 (0xaa) 35.500MHz +HSync -VSync DoubleScan
h: width 640 start 664 end 680 total 720 skew 0 clock 49.31KHz
v: height 400 start 401 end 404 total 411 clock 59.98Hz
640x400 (0xab) 31.500MHz -HSync +VSync
h: width 640 start 672 end 736 total 832 skew 0 clock 37.86KHz
v: height 400 start 401 end 404 total 445 clock 85.08Hz
576x432 (0xac) 54.000MHz +HSync +VSync DoubleScan
h: width 576 start 608 end 672 total 800 skew 0 clock 67.50KHz
v: height 432 start 432 end 434 total 450 clock 75.00Hz
640x360 (0xad) 37.250MHz -HSync +VSync DoubleScan
h: width 640 start 672 end 736 total 832 skew 0 clock 44.77KHz
v: height 360 start 361 end 364 total 374 clock 59.86Hz
640x360 (0xae) 31.875MHz +HSync -VSync DoubleScan
h: width 640 start 664 end 680 total 720 skew 0 clock 44.27KHz
v: height 360 start 361 end 364 total 370 clock 59.83Hz
640x360 (0xaf) 18.000MHz -HSync +VSync
h: width 640 start 664 end 720 total 800 skew 0 clock 22.50KHz
v: height 360 start 363 end 368 total 376 clock 59.84Hz
640x360 (0xb0) 17.750MHz +HSync -VSync
h: width 640 start 688 end 720 total 800 skew 0 clock 22.19KHz
v: height 360 start 363 end 368 total 374 clock 59.32Hz
640x350 (0xb1) 31.500MHz +HSync -VSync
v: height 350 start 382 end 385 total 445 clock 85.08Hz
512x384 (0xb2) 47.250MHz +HSync +VSync DoubleScan
h: width 512 start 536 end 584 total 688 skew 0 clock 68.68KHz
v: height 384 start 384 end 386 total 404 clock 85.00Hz
512x384 (0xb3) 39.375MHz +HSync +VSync DoubleScan
h: width 512 start 520 end 568 total 656 skew 0 clock 60.02KHz
v: height 384 start 384 end 386 total 400 clock 75.03Hz
512x384 (0xb4) 37.500MHz -HSync -VSync DoubleScan
h: width 512 start 524 end 592 total 664 skew 0 clock 56.48KHz
v: height 384 start 385 end 388 total 403 clock 70.07Hz
512x384 (0xb5) 32.500MHz -HSync -VSync DoubleScan
h: width 512 start 524 end 592 total 672 skew 0 clock 48.36KHz
v: height 384 start 385 end 388 total 403 clock 60.00Hz
512x384i (0xb6) 22.450MHz +HSync +VSync Interlace DoubleScan
h: width 512 start 516 end 604 total 632 skew 0 clock 35.52KHz
v: height 384 start 384 end 388 total 408 clock 87.06Hz
512x288 (0xb7) 23.250MHz -HSync +VSync DoubleScan
h: width 512 start 532 end 580 total 648 skew 0 clock 35.88KHz
v: height 288 start 289 end 292 total 299 clock 60.00Hz
512x288 (0xb8) 21.000MHz +HSync -VSync DoubleScan
h: width 512 start 536 end 552 total 592 skew 0 clock 35.47KHz
v: height 288 start 289 end 292 total 296 clock 59.92Hz
416x312 (0xb9) 28.642MHz -HSync -VSync DoubleScan
h: width 416 start 432 end 464 total 576 skew 0 clock 49.73KHz
v: height 312 start 312 end 314 total 333 clock 74.66Hz
480x270 (0xba) 20.375MHz -HSync +VSync DoubleScan
h: width 480 start 496 end 544 total 608 skew 0 clock 33.51KHz
v: height 270 start 271 end 274 total 281 clock 59.63Hz
480x270 (0xbb) 18.625MHz +HSync -VSync DoubleScan
h: width 480 start 504 end 520 total 560 skew 0 clock 33.26KHz
v: height 270 start 271 end 274 total 278 clock 59.82Hz
400x300 (0xbc) 28.150MHz +HSync +VSync DoubleScan
h: width 400 start 416 end 448 total 524 skew 0 clock 53.72KHz
v: height 300 start 300 end 302 total 315 clock 85.27Hz
400x300 (0xbd) 25.000MHz +HSync +VSync DoubleScan
h: width 400 start 428 end 488 total 520 skew 0 clock 48.08KHz
v: height 300 start 318 end 321 total 333 clock 72.19Hz
400x300 (0xbe) 24.750MHz +HSync +VSync DoubleScan
h: width 400 start 408 end 448 total 528 skew 0 clock 46.88KHz
v: height 300 start 300 end 302 total 312 clock 75.12Hz
400x300 (0xbf) 20.000MHz +HSync +VSync DoubleScan
h: width 400 start 420 end 484 total 528 skew 0 clock 37.88KHz
v: height 300 start 300 end 302 total 314 clock 60.32Hz
400x300 (0xc0) 18.000MHz +HSync +VSync DoubleScan
h: width 400 start 412 end 448 total 512 skew 0 clock 35.16KHz
v: height 300 start 300 end 301 total 312 clock 56.34Hz
432x243 (0xc1) 16.250MHz -HSync +VSync DoubleScan
h: width 432 start 444 end 484 total 536 skew 0 clock 30.32KHz
v: height 243 start 244 end 247 total 253 clock 59.92Hz
432x243 (0xc2) 15.250MHz +HSync -VSync DoubleScan
h: width 432 start 456 end 472 total 512 skew 0 clock 29.79KHz
v: height 243 start 244 end 247 total 250 clock 59.57Hz
320x240 (0xc3) 18.000MHz -HSync -VSync DoubleScan
h: width 320 start 348 end 376 total 416 skew 0 clock 43.27KHz
v: height 240 start 240 end 242 total 254 clock 85.18Hz
320x240 (0xc4) 15.750MHz -HSync -VSync DoubleScan
h: width 320 start 332 end 352 total 416 skew 0 clock 37.86KHz
v: height 240 start 244 end 246 total 260 clock 72.81Hz
320x240 (0xc5) 15.750MHz -HSync -VSync DoubleScan
h: width 320 start 328 end 360 total 420 skew 0 clock 37.50KHz
v: height 240 start 240 end 242 total 250 clock 75.00Hz
320x240 (0xc6) 12.587MHz -HSync -VSync DoubleScan
h: width 320 start 328 end 376 total 400 skew 0 clock 31.47KHz
v: height 240 start 245 end 246 total 262 clock 60.05Hz
360x202 (0xc7) 11.250MHz -HSync +VSync DoubleScan
h: width 360 start 372 end 404 total 448 skew 0 clock 25.11KHz
v: height 202 start 204 end 206 total 211 clock 59.51Hz
360x202 (0xc8) 10.875MHz +HSync -VSync DoubleScan
h: width 360 start 384 end 400 total 440 skew 0 clock 24.72KHz
v: height 202 start 204 end 206 total 209 clock 59.13Hz
360x200 (0xc9) 17.750MHz -HSync +VSync DoubleScan
h: width 360 start 378 end 414 total 468 skew 0 clock 37.93KHz
v: height 200 start 200 end 202 total 223 clock 85.04Hz
320x200 (0xca) 15.750MHz -HSync +VSync DoubleScan
h: width 320 start 336 end 368 total 416 skew 0 clock 37.86KHz
v: height 200 start 200 end 202 total 222 clock 85.27Hz
320x180 (0xcb) 9.000MHz -HSync +VSync DoubleScan
h: width 320 start 332 end 360 total 400 skew 0 clock 22.50KHz
v: height 180 start 181 end 184 total 188 clock 59.84Hz
320x180 (0xcc) 8.875MHz +HSync -VSync DoubleScan
h: width 320 start 344 end 360 total 400 skew 0 clock 22.19KHz
v: height 180 start 181 end 184 total 187 clock 59.32Hz
320x175 (0xcd) 15.750MHz +HSync -VSync DoubleScan
v: height 175 start 191 end 192 total 222 clock 85.27Hz
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x100
Timestamp: 2026239
Subpixel: unknown
Clones:
CRTCs: 4 5 6 7
filter:
PRIME Synchronization: 1
supported: 0, 1
dithering depth: auto
supported: auto, 6 bpc, 8 bpc
dithering mode: auto
supported: auto, off, static 2x2, dynamic 2x2, temporal
scaling mode: None
color vibrance: 150
range: (0, 200)
vibrant hue: 90
range: (0, 180)
range: (0, 128)
range: (0, 128)
underscan: off
supported: auto, off, on
link-status: Good
0 1
CONNECTOR_ID: 101
supported: 101
non-desktop: 0
range: (0, 1)
1920x1080_60.00 (0x7a3) 173.000MHz -HSync +VSync
DP-1-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x101
Timestamp: 2026239
Subpixel: unknown
Clones:
CRTCs: 4 5 6 7
filter:
supported: 0, 1
scaling mode: None
color vibrance: 150
range: (0, 200)
vibrant hue: 90
range: (0, 180)
range: (0, 128)
range: (0, 128)
underscan: off
link-status: Good
0 1
CONNECTOR_ID: 103
supported: 103
non-desktop: 0
range: (0, 1)
DP-1-2 disconnected (normal left inverted right x axis y axis)
Identifier: 0x102
Timestamp: 2026239
Subpixel: unknown
Clones:
CRTCs: 4 5 6 7
filter:
supported: 0, 1
scaling mode: None
color vibrance: 150
range: (0, 200)
vibrant hue: 90
range: (0, 180)
range: (0, 128)
range: (0, 128)
underscan: off
link-status: Good
0 1
CONNECTOR_ID: 106
supported: 106
non-desktop: 0
range: (0, 1)
inxi -FAZ
System:
Kernel: 6.1.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=9183dc03-b8d4-48c4-88e0-4659dda865a0 rw rootflags=subvol=@
nowatchdog nvme_load=YES resume=UUID=a3e8acf7-4262-49e2-bedf-737bf729e265
loglevel=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Distro: EndeavourOS base: Arch Linux
Machine:
Type: Laptop System: HP product: OMEN Laptop 15-en0xxx v: N/A
serial: Chassis: type: 10 serial:
Mobo: HP model: 8786 v: 22.25 serial: UEFI: AMI
v: F.01 date: 04/15/2020
Battery:
ID-1: BAT0 charge: 56.2 Wh (100.0%) condition: 56.2/56.2 Wh (100.0%)
volts: 12.7 min: 11.6 model: Hewlett-Packard Primary type: Li-ion serial: N/A
status: full cycles: 505
Memory:
RAM: total: 14.99 GiB used: 4.36 GiB (29.1%)
RAM Report: permissions: Unable to run dmidecode. Root privileges required.
CPU:
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600103
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1493 high: 2900 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 2900
3: 1400 4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400
12: 1400 13: 1400 14: 1400 15: 1397 16: 1400 bogomips: 92624
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy
constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe
msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae
pat pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Vulnerabilities:
Type: itlb_multihit status: Not affected
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: mmio_stale_data status: Not affected
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via
prctl
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer
sanitization
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Hewlett-Packard
driver: nouveau v: kernel alternate: nvidia_drm,nvidia non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s ports: active: none off: HDMI-A-1
empty: DP-1,DP-2 bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-2: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: none bus-ID: 07:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 40.0 C
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD Camera
type: USB driver: uvcvideo bus-ID: 3-3:2 chip-ID: 05c8:03df class-ID: 0e02
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia dri: radeonsi,nouveau gpu: amdgpu,nouveau
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22")
s-diag: 582mm (22.93")
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 142
size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.2 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.49 6.1.3-zen1-1-zen) direct render: Yes
Audio:
Device-1: NVIDIA TU116 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: speed: Unknown lanes: 63 link-max:
gen: 6 speed: 64 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 07:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k6.1.3-zen1-1-zen running: yes
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.63 running: yes
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eno1 state: down mac:
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel modules: wl pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723
class-ID: 0280
IF: wlan0 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: dynamic noprefixroute scope: global
IP v6: type: noprefixroute scope: link
WAN IP:
Bluetooth:
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:3
chip-ID: 8087:0029 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Logical:
Message: No logical block device data found.
RAID:
Message: No RAID data found.
Drives:
Local Storage: total: 2.75 TiB used: 6.63 GiB (0.2%)
SMART Message: Unable to run smartctl. Root privileges required.
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital
model: WDBA3V0010BNC-WRSN size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial:
rev: 211210WD temp: 29.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: MZVLB1T0HBLR-000H1
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: rev: HPS0NEXF temp: 31.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Extreme 55AE
size: 931.48 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: rev: 3000 scheme: GPT
SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
Message: No optical or floppy data found.
Partition:
ID-1: / raw-size: 914.04 GiB size: 914.04 GiB (100.00%) used: 6.63 GiB (0.7%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: endeavouros
uuid: 9183dc03-b8d4-48c4-88e0-4659dda865a0
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 608 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 26E8-0162
ID-3: /home raw-size: 914.04 GiB size: 914.04 GiB (100.00%)
used: 6.63 GiB (0.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: endeavouros uuid: 9183dc03-b8d4-48c4-88e0-4659dda865a0
ID-4: /var/cache raw-size: 914.04 GiB size: 914.04 GiB (100.00%)
ID-5: /var/log raw-size: 914.04 GiB size: 914.04 GiB (100.00%)
Swap:
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 16.49 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: a3e8acf7-4262-49e2-bedf-737bf729e265
Unmounted:
ID-1: /dev/nvme1n1p1 maj-min: 259:5 size: 300 MiB fs: vfat label: NO_LABEL
uuid: 57CB-CE88
ID-2: /dev/nvme1n1p2 maj-min: 259:6 size: 937.01 GiB fs: btrfs label: N/A
uuid: 68a8ec22-f354-4803-9d37-38992aa7bc9c
ID-3: /dev/nvme1n1p3 maj-min: 259:7 size: 16.56 GiB fs: swap label: swap
uuid: 8fc6e39b-149e-4e2b-a555-ae6d6c647f56
ID-4: /dev/sda1 maj-min: 8:1 size: 931.48 GiB fs: exfat label: Extreme SSD
uuid: EC66-5ED8
USB:
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Cheng Uei Precision Industry (Foxlink) HP Wide
Vision HD Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 05c8:03df class-ID: 0e02
Device-2: 3-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0029
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 4-1:2 info: SanDisk Extreme 55AE type: Mass Storage driver: uas
interfaces: 1 rev: 3.2 speed: 10 Gb/s power: 896mA chip-ID: 0781:55ae
class-ID: 0806 serial:
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: Primax HP Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 0461:4d0f class-ID: 0301
Device-2: 5-2:3 info: Corsair K95 RGB PLATINUM XT Mechanical Gaming
Keyboard type: Keyboard,HID,Mouse driver: hid-generic,usbhid interfaces: 4
rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b89 class-ID: 0301
serial:
Hub-6: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Sensors:
System Temperatures: cpu: 60.1 C mobo: N/A
Fan Speeds (RPM): fan-1: 0 fan-2: 0
GPU: device: nouveau temp: N/A device: amdgpu temp: 39.0 C
Info:
Processes: 347 Uptime: 47m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1058
libs: 231 tools: paru,yay Shell: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.24
