Nemotron-3-nano-omni-30b-a3b-reasoning enter an infinite loop of code generation
I jsut give task to model can you write code tar extraction on Python 3.12
and gain this
import tarfile
import os
from pathlib import Path
def extract_tar(
tar_path: str,
extract_to: str = None,
overwrite: bool = False,
verbose: bool = True
) → list:
Extracts a tar archive to a specified directory.
Args:
    tar_path (str): Path to the tar archive file
    extract_dir (str, optional): Directory to extract to (defaults to current directory)
    overwrite (bool): Whether to overwrite existing files (default: False)
    verbose (bool): Print extraction progress
Returns:
    list: List of extracted file paths
if not os.path.exists(tar_path):
    raise FileNotFoundError(f"Tar file not found: {tar_path}")
if not os.path.isfile(tar_path):
if not extract_dir:
    extract_dir = os.getcwd()
os.makedirs(extract_dir, exist_ok=True)
try:
    with tarfile.open(tar_path, 'r') as tar:
        # Check if we're extracting a compressed archive
        mode = 'r:*' if tar.getmtime() else 'r:*'
        if 'r:gz' in tar.getmode():
            mode = 'r:gz'
        elif 'r.gz' in tar_path:
            with tarfile.open(tar_path, 'r:gz') as tar:
                tar.extractall(path=extract_dir)
        else:
# Verify extraction
extracted_files = []
for member in tar.getmembers():
    member_path = os.path.join(extract_dir, tar.getmember(tar_path).name)
    if os.path.exists(os.path.join(extract_dir, os.path.basename(tar_path))):
        if not os.path.isdir(extract_dir) or not os.path.exists(os.path.join(extract_dir, os.path.basename(tar_path))):
                                    if
I don’t know what caused the bug, but I think if I hadn’t stopped it, it would have kept generating like that.
