OS: Windows 10
GPU: GTX 1080ti
Driver: 512.95
API: Vulkan 1.3.211.0
Nsight seems to be adding flags to Vulkan struct definitions behind the scenes, at runtime. This causes validation errors where there should be none. The VK_IMAGE_USAGE_TRANSFER_SRC_BIT and VK_IMAGE_USAGE_TRANSFER_DST_BIT are added to swapchain images (my specific setup is with an imageless framebuffer), and input attachments. That triggers validation error VUID-VkRenderPassBeginInfo-framebuffer-04627. Additionally, when using Vulkan 1.3, some kind of feature struct is added to the pNext chain of VkDeviceCreateInfo. I have a VkPhysicalDeviceVulkan13Features in that pNext chain, and that addition triggers validation error VUID-VkDeviceCreateInfo-pNext-06532.
In my Vulkan App, I have the KhronosValidation and LunargMoninor layers enabled. I have manually verified for validation errors, and found none. When running the App vanilla, the validation layers do not issue errors. Finally, the latest RenderDoc(1.20) shows no validation errors. These errors manifest only when running the App via Nsight.
Note that this started happening sometime after version 2021.4.0.0 – that version doesn’t show validation errors. I can confirm that, at least, versions starting with 2022.X do show those bogus errors.
