With ‘Collect Vulkan trace’ enabled in Nsight 2020.1.1, I have the Vulkan validation error:
ERROR(validation): [0][VUID-vkGetDeviceQueue-queueIndex-00385] : vkGetDeviceQueue: queueIndex (=1) is not less than the number of queues requested from queueFamilyIndex (=0) when the device was created (i.e. is not less than 1). The Vulkan spec states: queueIndex must be less than the number of queues created for the specified queue family index when device was created, via the queueCount member of the VkDeviceQueueCreateInfo structure (https://www.khronos.org/registry/vulkan/specs/1.1-extensions/html/vkspec.html#VUID-vkGetDeviceQueue-queueIndex-00385)
I do not have this error when launching from Visual Studio 2017, nor when launching my app as standalone .exe.
I tried adding one more queue when creating the device with vkCreateDevice by passing:
{sType=VK_STRUCTURE_TYPE_DEVICE_CREATE_INFO (3) pNext=0x0000000000000000 flags=0 ...} VkDeviceCreateInfo
sType VK_STRUCTURE_TYPE_DEVICE_CREATE_INFO (3) VkStructureType
pNext 0x0000000000000000 const void *
flags 0 unsigned int
queueCreateInfoCount 2 unsigned int
pQueueCreateInfos 0x000002ce3e8eccb0 {sType=VK_STRUCTURE_TYPE_DEVICE_QUEUE_CREATE_INFO (2) pNext=0x0000000000000000 flags=...} const VkDeviceQueueCreateInfo *
enabledLayerCount 0 unsigned int
ppEnabledLayerNames 0x0000000000000000 {???} const char * const *
enabledExtensionCount 1 unsigned int
ppEnabledExtensionNames 0x000002ce39552680 {0x00007ff625505420 "VK_KHR_swapchain"} const char * const *
pEnabledFeatures 0x0000000000000000 <NULL> const VkPhysicalDeviceFeatures *
But same error.
Thank you!
