CONFIG_NF_TABLES is currently not set in the JetPack 5.0 DP kernel configuration.
This makes using legacy iptables currently necessary.
Can add manually?
Adding it manually is indeed functional as expected. This is more a request on changing the default if that’s considered a reasonable course of action to do.
(notably to better support future OS releases. Ubuntu 22.04 uses nft iptables by default)
Will suggest to add it as default for future release.
