Hi! I have a Jetson Nano with the JetPack 4.2.2 and I want to install the NGC cli.
I followed the instructions for linux that is showed here: NVIDIA NGC
However, when I tried to run
ngc config set
I got this:
ngc: cannot execute binary file: Exec format error
What am I doing wrong?
Regards.
kayccc
2
Hi jdsastoqueb,
Please follow this page for using the container on Jetson if can help:
https://github.com/NVIDIA/nvidia-docker/wiki/NVIDIA-Container-Runtime-on-Jetson
This error indicates you are using the binary which compiled with different architecture.
Please noticed that Jetson is an ARM system while NGC only support x86 environment currently.
Not sure which use case do you want from NGC.
For nvdocker, you can try to install the container shared in comment#2.
