How to install NGC CLI for Jetson Nano with Jetpack 4.6.4
I am using a Jetson Nano with JetPack 4.6.4. I found this guide. But, instructions here are for Jetpack 4.2.2. Where can i find instructions for Jetpack 4.6.4?
Thanks in advance for all the help you offer.
What do you mean by NGC CLI?
Do you want to run a Jetson container on an x86 machine through qemu?
I mean NGC command line interface by NGC CLI. Please see here.
I have read from a couple of guides and tutorials, for being able to use or train models from NGC registry i would need NGC CLI and specifically using ngc registry command to get models and notebooks provided on NGC.
I am using a Jetson Nano with JetPack 4.6.4 and i want to install NGC Command Line Interface for being able to download, train and use HeartRateNet model provided by NGC for deploying with Deepstream SDK.
Please check if you can use the “ARM64 Linux” tool on Jetson:
https://ngc.nvidia.com/setup/installers/cli
Thank you for the link.
I was able to find complete steps to download and install the NGC through there and managed to install NGC.
You can close the topic if you would like,
Kindest regards.
