ngc docker pull failing
I’ve been trying to pull 18.09-py3 to dgx-1 system and receive error each time
“filesystem layer verification failed for digest sha256: […]”
Tried multiple image versions 18.07, .08, -py2, and on multiple local machines.
All fail at some point with error like this.
Any advice how to determine if the problem is on my side or NGC repo side?
Can you please try relogin to nvcr.io with your NGC api key and retry?
Any changes?
If that doesn’t help, please tell us what OS and docker version you use.
I tried the pull outside company firewall and it worked, so it looks like this is an issue on my side.
Thanks for your help.
