I am trying to play a video using nvgstplayer-1.0 through the hdmi cable, the video is working but no audio. Here is my pipeline:
nvgstplayer-1.0 -i test.mp4 --loop-forever --svs=nvoverlaysink --sas=alsasink device=plughw:0,3
Any suggestions ?
Here is the output:
Cannot open display specified with DISPLAY environment variable
Runtime Commands:
q quit the application
h print help
Up Key, ] goto next track
c restart current track
Down Key, [ goto previous track
spos query for position
sdur query for duration
s<val> seek to <val> position in seconds, eg "s5.120"
v<val> seek to <val> percent of the duration, eg "v54"
f<val> seek by <val> seconds, relative to current position eg "f23.901"
Left Key, < seek backwards by 10 seconds
Right Key, > seek forward by 10 seconds
p pause playback
r start/resume the playback
z stop the playback
i:<val> enter a single URI
1 r
** Message: 19:45:33.308: <main:3983> iterating...
** Message: 19:45:33.309: <goto_next_track:910> uriCount: 0, uriTotal: 1
** Message: 19:45:33.315: <on_input:576> pausing
** Message: 19:45:33.520: <cb_newpad:2077> creating the pipe for "video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, parsed=(boolean)true, level=(string)3.1, profile=(string)high, width=(int)1280, height=(int)720, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8"
Opening in BLOCKING MODE
** Message: 19:45:33.630: <cb_newpad:2077> creating the pipe for "audio/x-raw, layout=(string)interleaved, format=(string)F32LE"
** (nvgstplayer-1.0:10114): CRITICAL **: 19:45:33.631: <create_audio_pipeline:1944> failed to create element: sas
** (nvgstplayer-1.0:10114): WARNING **: 19:45:33.631: <cb_newpad:2229> decoder pipeline for "audio/x-raw" not created <1>
** (nvgstplayer-1.0:10114): CRITICAL **: 19:45:33.631: <cb_newpad:2232> failed to create/activate the decode pipeline
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
^CUser Interrupted..
Handling the interrupt ...
Playback completed!
Application will now exit!
Note I have the UI disabled using:
sudo systemctl set-default multi-user.target
But the video is working just fine, no audio only.
