The nvgstplayer local playback on R32.5
I use the nvgstplayer-1.0 command on new version R32.5 to play the file with h263, and find that is doesn;t support,
like :
Is there any patch like that?
The source code of nvgstplayer-1.0 is public. You can download it from
https://developer.nvidia.com/embedded/l4t/r32_release_v5.1/r32_release_v5.1/sources/t210/public_sources.tbz2
The patch is in r32.5 already and it should use software decoder for h263 stream. A bit strange you still hit the issue. You may build the app and check further.
