I wanted to follow-up on the following thread:
The reason for no data previously received was that the CSI sensor had continuous CSI clock, but my own CSI driver wasn’t configured properly.
I have fixed the CSI driver, and now I can see the FS and FE.
But the data still can’t be received.
Here are the trace logs:
# tracer: nop
# entries-in-buffer/entries-written: 933/933 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
v4l2-ctl-8635 [002] .... 505.448396: tegra_channel_open: vi-output, ov5693 30-0036
v4l2-ctl-8635 [000] .... 505.457769: tegra_channel_set_power: ov5693 30-0036 : 0x1
v4l2-ctl-8635 [000] .... 505.457813: camera_common_s_power: status : 0x1
v4l2-ctl-8635 [000] .... 505.468076: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
v4l2-ctl-8635 [000] .... 505.468083: csi_s_power: enable : 0x1
v4l2-ctl-8635 [000] .... 505.475085: tegra_channel_capture_setup: vnc_id 0 W 2048 H 128 fmt c4
v4l2-ctl-8635 [000] .... 505.496514: tegra_channel_set_stream: enable : 0x1
kworker/0:1-808 [000] .... 505.502446: rtos_queue_peek_from_isr_failed: tstamp:16117279144 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 505.502460: rtcpu_start: tstamp:16117281047
kworker/0:1-808 [000] .... 505.502464: rtos_queue_send_from_isr_failed: tstamp:16117418493 queue:0x0bcb41f8
kworker/0:1-808 [000] .... 505.502467: rtos_queue_send_from_isr_failed: tstamp:16117418795 queue:0x0bcb8a60
kworker/0:1-808 [000] .... 505.502468: rtos_queue_send_from_isr_failed: tstamp:16117419093 queue:0x0bcba5e0
kworker/0:1-808 [000] .... 505.502469: rtos_queue_send_from_isr_failed: tstamp:16117419390 queue:0x0bcbb3a0
kworker/0:1-808 [000] .... 505.502470: rtos_queue_send_from_isr_failed: tstamp:16117419687 queue:0x0bcbc160
kworker/0:1-808 [000] .... 505.502473: rtcpu_string: tstamp:16117420546 id:0x04010000 str:"Configuring VI GoS.
kworker/0:1-808 [000] .... 505.502534: rtcpu_string: tstamp:16117420911 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:1-808 [000] .... 505.502542: rtcpu_string: tstamp:16117421333 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:1-808 [000] .... 505.502552: rtcpu_string: tstamp:16117421833 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:1-808 [000] .... 505.502559: rtcpu_string: tstamp:16117422239 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:1-808 [000] .... 505.502566: rtcpu_string: tstamp:16117422644 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:1-808 [000] .... 505.502573: rtcpu_string: tstamp:16117423048 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:1-808 [000] .... 505.502580: rtcpu_string: tstamp:16117434115 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol versi"
kworker/0:1-808 [000] .... 505.502581: rtcpu_string: tstamp:16117434381 id:0x04010000 str:"on 2.2
kworker/0:1-808 [000] .... 505.502588: rtos_queue_send_from_isr_failed: tstamp:16117466461 queue:0x0bcb41f8
kworker/0:1-808 [000] .... 505.502589: rtos_queue_send_from_isr_failed: tstamp:16117466816 queue:0x0bcb8a60
kworker/0:1-808 [000] .... 505.502589: rtos_queue_send_from_isr_failed: tstamp:16117467125 queue:0x0bcba5e0
kworker/0:1-808 [000] .... 505.502590: rtos_queue_send_from_isr_failed: tstamp:16117467418 queue:0x0bcbb3a0
kworker/0:1-808 [000] .... 505.502590: rtos_queue_send_from_isr_failed: tstamp:16117467716 queue:0x0bcbc160
kworker/0:1-808 [000] .... 505.502591: rtcpu_string: tstamp:16117469237 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
v4l2-ctl-8635 [000] .... 505.517198: tegra_channel_set_stream: 15a00000.nvcsi--1 : 0x1
v4l2-ctl-8635 [000] .... 505.517202: csi_s_stream: enable : 0x1
v4l2-ctl-8635 [000] .... 505.517211: tegra_channel_set_stream: ov5693 30-0036 : 0x1
kworker/0:1-808 [000] .... 505.558436: rtcpu_vinotify_event: tstamp:16117746780 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:17542856928 data:0x10000000
kworker/0:1-808 [000] .... 505.558439: rtcpu_vinotify_event: tstamp:16117746936 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:17542863872 data:0x31000001
kworker/0:1-808 [000] .... 505.558440: rtcpu_vinotify_event: tstamp:16117747111 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17542864864 data:0x07020001
kworker/0:1-808 [000] .... 505.558441: rtcpu_vinotify_event: tstamp:16117747257 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:17542937056 data:0x10000000
kworker/0:1-808 [000] .... 505.558442: rtcpu_vinotify_event: tstamp:16117747427 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:17542944096 data:0x31000002
kworker/0:1-808 [000] .... 505.558444: rtos_queue_send_from_isr_failed: tstamp:16118119761 queue:0x0bcb41f8
kworker/0:1-808 [000] .... 505.558446: rtos_queue_send_from_isr_failed: tstamp:16118119921 queue:0x0bcb8a60
kworker/0:1-808 [000] .... 505.558447: rtos_queue_send_from_isr_failed: tstamp:16118120084 queue:0x0bcba5e0
kworker/0:1-808 [000] .... 505.558448: rtos_queue_send_from_isr_failed: tstamp:16118120241 queue:0x0bcbb3a0
kworker/0:1-808 [000] .... 505.558449: rtos_queue_send_from_isr_failed: tstamp:16118120398 queue:0x0bcbc160
kworker/0:1-808 [000] .... 505.558452: rtcpu_nvcsi_intr: tstamp:16118122977 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/0:1-808 [000] .... 505.558459: rtos_queue_send_from_isr_failed: tstamp:16118537379 queue:0x0bcb41f8
kworker/0:1-808 [000] .... 505.558460: rtos_queue_send_from_isr_failed: tstamp:16118537541 queue:0x0bcb8a60
kworker/0:1-808 [000] .... 505.558461: rtos_queue_send_from_isr_failed: tstamp:16118537721 queue:0x0bcba5e0
kworker/0:1-808 [000] .... 505.558462: rtos_queue_send_from_isr_failed: tstamp:16118537878 queue:0x0bcbb3a0
kworker/0:1-808 [000] .... 505.558463: rtos_queue_send_from_isr_failed: tstamp:16118538035 queue:0x0bcbc160
kworker/0:1-808 [000] .... 505.558465: rtcpu_vinotify_event: tstamp:16118685780 tag:FS channel:0x00 frame:0 vi_tstamp:16118524829 data:0x00000010
kworker/0:1-808 [000] .... 505.558465: rtcpu_vinotify_event: tstamp:16118685957 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:16118524830 data:0x00000000
kworker/0:1-808 [000] .... 505.558466: rtcpu_vinotify_event: tstamp:16118686108 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:16118527032 data:0x00000001
kworker/0:1-808 [000] .... 505.558467: rtcpu_vinotify_event: tstamp:16118686287 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17576659200 data:0x08020001
kworker/0:1-808 [000] .... 505.558468: rtcpu_vinotify_event: tstamp:16118686435 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:16118527189 data:0x00000200
kworker/0:1-808 [000] .... 505.558469: rtcpu_vinotify_event: tstamp:16118686609 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17576664672 data:0x01020001
kworker/0:1-808 [000] .... 505.558470: rtcpu_vinotify_event: tstamp:16118805649 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:16118805038 data:0x007f0202
kworker/0:1-808 [000] .... 505.558471: rtcpu_vinotify_event: tstamp:16118805823 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17585555808 data:0x01020001
kworker/0:1-808 [000] .... 505.558472: rtcpu_vinotify_event: tstamp:16118805971 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:16118805053 data:0x00000000
kworker/0:1-808 [000] .... 505.558473: rtcpu_vinotify_event: tstamp:16118806138 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17585556384 data:0x02020001
kworker/0:1-808 [000] .... 505.558474: rtcpu_vinotify_event: tstamp:16118806286 tag:FE channel:0x00 frame:0 vi_tstamp:16118805084 data:0x00000020
kworker/0:1-808 [000] .... 505.558475: rtcpu_vinotify_event: tstamp:16119092745 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:16118805084 data:0x00000000
kworker/0:1-808 [000] .... 505.558502: rtcpu_vinotify_event: tstamp:16119092894 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17585559008 data:0x07020002
kworker/0:1-808 [000] .... 505.558503: rtcpu_vinotify_event: tstamp:16119093065 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:17585567936 data:0x10000000
kworker/0:1-808 [000] .... 505.558504: rtcpu_vinotify_event: tstamp:16119093209 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:17585573376 data:0x31000003
kworker/0:1-808 [000] .... 505.614459: rtos_queue_send_from_isr_failed: tstamp:16119790557 queue:0x0bcb41f8
kworker/0:1-808 [000] .... 505.614463: rtos_queue_send_from_isr_failed: tstamp:16119790740 queue:0x0bcb8a60
kworker/0:1-808 [000] .... 505.614464: rtos_queue_send_from_isr_failed: tstamp:16119790902 queue:0x0bcba5e0
kworker/0:1-808 [000] .... 505.614465: rtos_queue_send_from_isr_failed: tstamp:16119791059 queue:0x0bcbb3a0
kworker/0:1-808 [000] .... 505.614466: rtos_queue_send_from_isr_failed: tstamp:16119791213 queue:0x0bcbc160
kworker/0:1-808 [000] .... 505.614468: rtcpu_vinotify_event: tstamp:16120031758 tag:FS channel:0x00 frame:0 vi_tstamp:16119774816 data:0x00000010
kworker/0:1-808 [000] .... 505.614471: rtcpu_vinotify_event: tstamp:16120031912 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:16119774816 data:0x00000000
kworker/0:1-808 [000] .... 505.614472: rtcpu_vinotify_event: tstamp:16120032089 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:16119777019 data:0x00000001
kworker/0:1-808 [000] .... 505.614472: rtcpu_vinotify_event: tstamp:16120032239 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17616658752 data:0x08020002
kworker/0:1-808 [000] .... 505.614473: rtcpu_vinotify_event: tstamp:16120032417 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:16119777175 data:0x00000200
kworker/0:1-808 [000] .... 505.614474: rtcpu_vinotify_event: tstamp:16120032566 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17616664256 data:0x01020002
kworker/0:1-808 [000] .... 505.614474: rtcpu_vinotify_event: tstamp:16120055630 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:16120055025 data:0x007f0202
kworker/0:1-808 [000] .... 505.614475: rtcpu_vinotify_event: tstamp:16120055778 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17625555392 data:0x01020002
kworker/0:1-808 [000] .... 505.614475: rtcpu_vinotify_event: tstamp:16120055950 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:16120055040 data:0x00000000
kworker/0:1-808 [000] .... 505.614476: rtcpu_vinotify_event: tstamp:16120056097 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17625555936 data:0x02020002
kworker/0:1-808 [000] .... 505.614476: rtcpu_vinotify_event: tstamp:16120056268 tag:FE channel:0x00 frame:0 vi_tstamp:16120055070 data:0x00000020
kworker/0:1-808 [000] .... 505.614477: rtcpu_vinotify_event: tstamp:16120056416 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:16120055071 data:0x00000000
kworker/0:1-808 [000] .... 505.614478: rtcpu_vinotify_event: tstamp:16120344721 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17625558560 data:0x07020003
kworker/0:1-808 [000] .... 505.614478: rtcpu_vinotify_event: tstamp:16120344869 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:17625570592 data:0x10000000
kworker/0:1-808 [000] .... 505.614479: rtcpu_vinotify_event: tstamp:16120345041 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:17625574496 data:0x31000004
kworker/0:1-808 [000] .... 505.614480: rtos_queue_send_from_isr_failed: tstamp:16121038860 queue:0x0bcb41f8
kworker/0:1-808 [000] .... 505.614481: rtos_queue_send_from_isr_failed: tstamp:16121039043 queue:0x0bcb8a60
kworker/0:1-808 [000] .... 505.614482: rtos_queue_send_from_isr_failed: tstamp:16121039206 queue:0x0bcba5e0
kworker/0:1-808 [000] .... 505.614483: rtos_queue_send_from_isr_failed: tstamp:16121039363 queue:0x0bcbb3a0
kworker/0:1-808 [000] .... 505.614484: rtos_queue_send_from_isr_failed: tstamp:16121039517 queue:0x0bcbc160
kworker/0:1-808 [000] .... 505.670407: rtcpu_vinotify_event: tstamp:16121283743 tag:FS channel:0x00 frame:0 vi_tstamp:16121024802 data:0x00000010
kworker/0:1-808 [000] .... 505.670409: rtcpu_vinotify_event: tstamp:16121283921 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:16121024802 data:0x00000000
kworker/0:1-808 [000] .... 505.670411: rtcpu_vinotify_event: tstamp:16121284071 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:16121027005 data:0x00000001
kworker/0:1-808 [000] .... 505.670412: rtcpu_vinotify_event: tstamp:16121284246 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17656658304 data:0x08020003
kworker/0:1-808 [000] .... 505.670413: rtcpu_vinotify_event: tstamp:16121284394 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:16121027162 data:0x00000200
kworker/0:1-808 [000] .... 505.670413: rtcpu_vinotify_event: tstamp:16121284569 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17656663808 data:0x01020003
kworker/0:1-808 [000] .... 505.670414: rtcpu_vinotify_event: tstamp:16121305665 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:16121305011 data:0x007f0202
kworker/0:1-808 [000] .... 505.670414: rtcpu_vinotify_event: tstamp:16121305837 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17665554976 data:0x01020003
kworker/0:1-808 [000] .... 505.670415: rtcpu_vinotify_event: tstamp:16121305985 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:16121305026 data:0x00000000
kworker/0:1-808 [000] .... 505.670416: rtcpu_vinotify_event: tstamp:16121306155 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17665555520 data:0x02020003
kworker/0:1-808 [000] .... 505.670416: rtcpu_vinotify_event: tstamp:16121306303 tag:FE channel:0x00 frame:0 vi_tstamp:16121305057 data:0x00000020
kworker/0:1-808 [000] .... 505.670417: rtcpu_vinotify_event: tstamp:16121306473 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:16121305057 data:0x00000000
kworker/0:1-808 [000] .... 505.670420: rtcpu_vinotify_event: tstamp:16121306618 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17665557440 data:0x07020004
kworker/0:1-808 [000] .... 505.670425: rtcpu_vinotify_event: tstamp:16121596701 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:17665567360 data:0x10000000
kworker/0:1-808 [000] .... 505.670425: rtcpu_vinotify_event: tstamp:16121596849 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:17665572832 data:0x31000005
kworker/0:1-808 [000] .... 505.670433: rtos_queue_peek_from_isr_failed: tstamp:16122279499 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 505.670435: rtos_queue_send_from_isr_failed: tstamp:16122288883 queue:0x0bcb41f8
kworker/0:1-808 [000] .... 505.670437: rtos_queue_send_from_isr_failed: tstamp:16122289045 queue:0x0bcb8a60
kworker/0:1-808 [000] .... 505.670438: rtos_queue_send_from_isr_failed: tstamp:16122289209 queue:0x0bcba5e0
kworker/0:1-808 [000] .... 505.670439: rtos_queue_send_from_isr_failed: tstamp:16122289364 queue:0x0bcbb3a0
kworker/0:1-808 [000] .... 505.670440: rtos_queue_send_from_isr_failed: tstamp:16122289520 queue:0x0bcbc160
kworker/0:1-808 [000] .... 505.670441: rtcpu_vinotify_event: tstamp:16122535719 tag:FS channel:0x00 frame:0 vi_tstamp:16122274788 data:0x00000010
kworker/0:1-808 [000] .... 505.670442: rtcpu_vinotify_event: tstamp:16122535876 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:16122274788 data:0x00000000
kworker/0:1-808 [000] .... 505.670442: rtcpu_vinotify_event: tstamp:16122536054 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:16122276991 data:0x00000001
kworker/0:1-808 [000] .... 505.670443: rtcpu_vinotify_event: tstamp:16122536203 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17696657888 data:0x08020004
kworker/0:1-808 [000] .... 505.670443: rtcpu_vinotify_event: tstamp:16122536377 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:16122277148 data:0x00000200
kworker/0:1-808 [000] .... 505.670444: rtcpu_vinotify_event: tstamp:16122536525 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17696663360 data:0x01020004
kworker/0:1-808 [000] .... 505.670445: rtcpu_vinotify_event: tstamp:16122555859 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:16122554997 data:0x007f0202
kworker/0:1-808 [000] .... 505.670445: rtcpu_vinotify_event: tstamp:16122556007 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17705554528 data:0x01020004
kworker/0:1-808 [000] .... 505.670446: rtcpu_vinotify_event: tstamp:16122556180 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:16122555013 data:0x00000000
kworker/0:1-808 [000] .... 505.670447: rtcpu_vinotify_event: tstamp:16122556326 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17705555104 data:0x02020004
kworker/0:1-808 [000] .... 505.670447: rtcpu_vinotify_event: tstamp:16122556497 tag:FE channel:0x00 frame:0 vi_tstamp:16122555044 data:0x00000020
kworker/0:1-808 [000] .... 505.670448: rtcpu_vinotify_event: tstamp:16122556645 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:16122555044 data:0x00000000
kworker/0:1-808 [000] .... 505.670448: rtcpu_vinotify_event: tstamp:16122556816 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17705556992 data:0x07020005
kworker/0:1-808 [000] .... 505.670449: rtcpu_vinotify_event: tstamp:16122556963 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:17705563712 data:0x10000000
kworker/0:1-808 [000] .... 505.670450: rtcpu_vinotify_event: tstamp:16122848761 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:17705574944 data:0x31000006
kworker/0:1-808 [000] .... 505.726413: rtos_queue_send_from_isr_failed: tstamp:16123538261 queue:0x0bcb41f8
kworker/0:1-808 [000] .... 505.726416: rtos_queue_send_from_isr_failed: tstamp:16123538423 queue:0x0bcb8a60
kworker/0:1-808 [000] .... 505.726417: rtos_queue_send_from_isr_failed: tstamp:16123538585 queue:0x0bcba5e0
kworker/0:1-808 [000] .... 505.726418: rtos_queue_send_from_isr_failed: tstamp:16123538741 queue:0x0bcbb3a0
kworker/0:1-808 [000] .... 505.726419: rtos_queue_send_from_isr_failed: tstamp:16123538900 queue:0x0bcbc160
kworker/0:1-808 [000] .... 505.726421: rtcpu_vinotify_event: tstamp:16123787842 tag:FS channel:0x00 frame:0 vi_tstamp:16123524774 data:0x00000010
kworker/0:1-808 [000] .... 505.726423: rtcpu_vinotify_event: tstamp:16123788018 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:16123524775 data:0x00000000
kworker/0:1-808 [000] .... 505.726423: rtcpu_vinotify_event: tstamp:16123788170 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:16123526972 data:0x00000001
kworker/0:1-808 [000] .... 505.726424: rtcpu_vinotify_event: tstamp:16123788345 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17736657312 data:0x08020005
kworker/0:1-808 [000] .... 505.726425: rtcpu_vinotify_event: tstamp:16123788493 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:16123527129 data:0x00000200
kworker/0:1-808 [000] .... 505.726426: rtcpu_vinotify_event: tstamp:16123788669 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17736662816 data:0x01020005
kworker/0:1-808 [000] .... 505.726426: rtcpu_vinotify_event: tstamp:16123805898 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:16123804984 data:0x007f0202
kworker/0:1-808 [000] .... 505.726427: rtcpu_vinotify_event: tstamp:16123806072 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17745554080 data:0x01020005
kworker/0:1-808 [000] .... 505.726427: rtcpu_vinotify_event: tstamp:16123806217 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:16123805000 data:0x00000000
kworker/0:1-808 [000] .... 505.726428: rtcpu_vinotify_event: tstamp:16123806387 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17745554656 data:0x02020005
kworker/0:1-808 [000] .... 505.726429: rtcpu_vinotify_event: tstamp:16123806535 tag:FE channel:0x00 frame:0 vi_tstamp:16123805030 data:0x00000020
kworker/0:1-808 [000] .... 505.726430: rtcpu_vinotify_event: tstamp:16123806704 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:16123805030 data:0x00000000
kworker/0:1-808 [000] .... 505.726430: rtcpu_vinotify_event: tstamp:16123806851 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17745556576 data:0x07020006
kworker/0:1-808 [000] .... 505.726431: rtcpu_vinotify_event: tstamp:16123807023 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:17745561472 data:0x10000000
kworker/0:1-808 [000] .... 505.726431: rtcpu_vinotify_event: tstamp:16123807169 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:17745565376 data:0x31000007
kworker/0:1-808 [000] .... 505.782414: rtcpu_vinotify_event: tstamp:16124789372 tag:FS channel:0x00 frame:0 vi_tstamp:16124774761 data:0x00000010
kworker/0:1-808 [000] .... 505.782416: rtcpu_vinotify_event: tstamp:16124789542 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:16124774761 data:0x00000000
kworker/0:1-808 [000] .... 505.782417: rtos_queue_send_from_isr_failed: tstamp:16124789717 queue:0x0bcb41f8
kworker/0:1-808 [000] .... 505.782420: rtos_queue_send_from_isr_failed: tstamp:16124789886 queue:0x0bcb8a60
kworker/0:1-808 [000] .... 505.782422: rtos_queue_send_from_isr_failed: tstamp:16124790054 queue:0x0bcba5e0
kworker/0:1-808 [000] .... 505.782423: rtos_queue_send_from_isr_failed: tstamp:16124790216 queue:0x0bcbb3a0
kworker/0:1-808 [000] .... 505.782424: rtos_queue_send_from_isr_failed: tstamp:16124790378 queue:0x0bcbc160
kworker/0:1-808 [000] .... 505.782425: rtcpu_vinotify_event: tstamp:16124790609 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:16124776959 data:0x00000001
kworker/0:1-808 [000] .... 505.782426: rtcpu_vinotify_event: tstamp:16124790760 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17776656864 data:0x08020006
kworker/0:1-808 [000] .... 505.782426: rtcpu_vinotify_event: tstamp:16124790935 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:16124777116 data:0x00000200
kworker/0:1-808 [000] .... 505.782427: rtcpu_vinotify_event: tstamp:16124791085 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17776662368 data:0x01020006
kworker/0:1-808 [000] .... 505.782428: rtcpu_vinotify_event: tstamp:16125102428 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:16125054970 data:0x007f0202
kworker/0:1-808 [000] .... 505.782428: rtcpu_vinotify_event: tstamp:16125102581 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17785553632 data:0x01020006
kworker/0:1-808 [000] .... 505.782429: rtcpu_vinotify_event: tstamp:16125102755 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:16125054986 data:0x00000000
kworker/0:1-808 [000] .... 505.782430: rtcpu_vinotify_event: tstamp:16125102904 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17785554208 data:0x02020006
kworker/0:1-808 [000] .... 505.782430: rtcpu_vinotify_event: tstamp:16125103075 tag:FE channel:0x00 frame:0 vi_tstamp:16125055016 data:0x00000020
kworker/0:1-808 [000] .... 505.782431: rtcpu_vinotify_event: tstamp:16125103227 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:16125055017 data:0x00000000
kworker/0:1-808 [000] .... 505.782431: rtcpu_vinotify_event: tstamp:16125103400 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17785556128 data:0x07020007
kworker/0:1-808 [000] .... 505.782432: rtcpu_vinotify_event: tstamp:16125103546 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:17785560896 data:0x10000000
kworker/0:1-808 [000] .... 505.782433: rtcpu_vinotify_event: tstamp:16125103716 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:17785564768 data:0x31000008
kworker/0:1-808 [000] .... 505.782433: rtcpu_vinotify_event: tstamp:16126025290 tag:FS channel:0x00 frame:0 vi_tstamp:16126024747 data:0x00000010
kworker/0:1-808 [000] .... 505.782435: rtos_queue_send_from_isr_failed: tstamp:16126038201 queue:0x0bcb41f8
kworker/0:1-808 [000] .... 505.782436: rtos_queue_send_from_isr_failed: tstamp:16126038366 queue:0x0bcb8a60
kworker/0:1-808 [000] .... 505.782437: rtos_queue_send_from_isr_failed: tstamp:16126038550 queue:0x0bcba5e0
kworker/0:1-808 [000] .... 505.782438: rtos_queue_send_from_isr_failed: tstamp:16126038707 queue:0x0bcbb3a0
kworker/0:1-808 [000] .... 505.782439: rtos_queue_send_from_isr_failed: tstamp:16126038863 queue:0x0bcbc160
kworker/0:1-808 [000] .... 505.782440: rtcpu_vinotify_event: tstamp:16126323101 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:16126024747 data:0x00000000
kworker/0:1-808 [000] .... 505.782441: rtcpu_vinotify_event: tstamp:16126323254 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:16126026950 data:0x00000001
kworker/0:1-808 [000] .... 505.782441: rtcpu_vinotify_event: tstamp:16126323432 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17816656608 data:0x08020007
kworker/0:1-808 [000] .... 505.782442: rtcpu_vinotify_event: tstamp:16126323579 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:16126027107 data:0x00000200
kworker/0:1-808 [000] .... 505.782442: rtcpu_vinotify_event: tstamp:16126323752 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17816662048 data:0x01020007
kworker/0:1-808 [000] .... 505.782443: rtcpu_vinotify_event: tstamp:16126323896 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:16126304957 data:0x007f0202
kworker/0:1-808 [000] .... 505.782444: rtcpu_vinotify_event: tstamp:16126324066 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17825553216 data:0x01020007
kworker/0:1-808 [000] .... 505.782444: rtcpu_vinotify_event: tstamp:16126324211 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:16126304973 data:0x00000000
kworker/0:1-808 [000] .... 505.782445: rtcpu_vinotify_event: tstamp:16126324382 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17825553792 data:0x02020007
kworker/0:1-808 [000] .... 505.782445: rtcpu_vinotify_event: tstamp:16126324532 tag:FE channel:0x00 frame:0 vi_tstamp:16126305003 data:0x00000020
kworker/0:1-808 [000] .... 505.782446: rtcpu_vinotify_event: tstamp:16126324704 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:16126305003 data:0x00000000
kworker/0:1-808 [000] .... 505.782446: rtcpu_vinotify_event: tstamp:16126324849 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:17825555680 data:0x07020008
kworker/0:1-808 [000] .... 505.782447: rtcpu_vinotify_event: tstamp:16126325019 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:17825561664 data:0x10000000
kworker/0:1-808 [000] .... 505.782448: rtcpu_vinotify_event: tstamp:16126325164 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:17825565568 data:0x31000009
kworker/0:1-808 [000] .... 505.838398: rtcpu_vinotify_event: tstamp:16127275277 tag:FS channel:0x00 frame:0 vi_tstamp:16127274734 data:0x00000010
kworker/0:1-808 [000] .... 505.838400: rtcpu_vinotify_event: tstamp:16127275430 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:16127274734 data:0x00000000
kworker/0:1-808 [000] .... 505.838408: rtos_queue_peek_from_isr_failed: tstamp:16127279504 queue:0x0bcbcf78
kworker/0:1-808 [000] .... 505.838411: rtos_queue_send_from_isr_failed: tstamp:16127289565 queue:0x0bcb41f8
kworker/0:1-808 [000] .... 505.838413: rtos_queue_send_from_isr_failed: tstamp:16127289726 queue:0x0bcb8a60
kworker/0:1-808 [000] .... 505.838414: rtos_queue_send_from_isr_failed: tstamp:16127289888 queue:0x0bcba5e0
kworker/0:1-808 [000] .... 505.838415: rtos_queue_send_from_isr_failed: tstamp:16127290045 queue:0x0bcbb3a0
kworker/0:1-808 [000] .... 505.838416: rtos_queue_send_from_isr_failed: tstamp:16127290201 queue:0x0bcbc160
Is there any indication for the reason from the trace ?
Regards,
Ron
