NX CSI input err
Hello:
I use NX CSI to input.
One is lt6911(HDMI to CSI) and other is lt9211(RGB to CSI).
These two chips is set i2c to configure,than can output csi signal.
I use in Jetson nano is ok.
So I want to transplant to Jetson NX.
The lt6911 transplant is OK,I use qv4l2 app to see the picture.
But lt9211 is err.
dmesg is
[ 382.170039] tegra194-vi5 15c10000.vi: corr_err: discarding frame 14842, flags: 32, err_data 160
     lt9211 driver i write is run success in jetson nano.
     In NX,i only modify DT.
host1x {
	vi@15c10000 {
		num-channels = <2>;
		ports {
			#address-cells = <1>;
			#size-cells = <0>;
			vi_port0: port@0 {
				reg = <0>;
				vi_in0: endpoint {
					port-index = <0>;
					bus-width = <4>;
					remote-endpoint = <&csi_out0>;
			vi_port1: port@1 {
				reg = <1>;
				vi_in1: endpoint {
					port-index = <4>;
					bus-width = <4>;
					remote-endpoint = <&csi_out1>;
	nvcsi@15a00000 {
		num-channels = <2>;
		#size-cells = <0>;
		csi_chan0: channel@0 {
			reg = <0>;
			ports {
				#size-cells = <0>;
				csi_chan0_port0: port@0 {
					reg = <0>;
					csi_in0: endpoint@0 {
						port-index = <0>;
						bus-width = <4>;
						remote-endpoint = <&lt9211_vga_out0>;
				csi_chan0_port1: port@1 {
					reg = <1>;
					csi_out0: endpoint@1 {
						remote-endpoint = <&vi_in0>;
		csi_chan1: channel@1 {
			reg = <1>;
			ports {
				#size-cells = <0>;
				csi_chan1_port0: port@0 {
					reg = <0>;
					csi_in1: endpoint@0 {
						port-index = <4>;
						bus-width = <4>;
						remote-endpoint = <&lt6911_hdmi_out0>;
				csi_chan1_port1: port@1 {
					reg = <1>;
					csi_out1: endpoint@1 {
						remote-endpoint = <&vi_in1>;
tcp: tegra-camera-platform {
compatible = “nvidia, tegra-camera-platform”;
	* Physical settings to calculate max ISO BW
	* num_csi_lanes = <>;
	* Total number of CSI lanes when all cameras are active
	* max_lane_speed = <>;
	* Max lane speed in Kbit/s
	* min_bits_per_pixel = <>;
	* Min bits per pixel
	* vi_peak_byte_per_pixel = <>;
	* Max byte per pixel for the VI ISO case
	* vi_bw_margin_pct = <>;
	* Vi bandwidth margin in percentage
	* max_pixel_rate = <>;
	* Max pixel rate in Kpixel/s for the ISP ISO case
	* isp_peak_byte_per_pixel = <>;
	* Max byte per pixel for the ISP ISO case
	* isp_bw_margin_pct = <>;
	* Isp bandwidth margin in percentage
	num_csi_lanes = <8>;
	max_lane_speed = <2500000>;
	min_bits_per_pixel = <10>;
	vi_peak_byte_per_pixel = <2>;
	vi_bw_margin_pct = <25>;
	max_pixel_rate = <240000>;
	isp_peak_byte_per_pixel = <5>;
	isp_bw_margin_pct = <25>;
	 * The general guideline for naming badge_info contains 3 parts, and is as follows,
	 * The first part is the camera_board_id for the module; if the module is in a FFD
	 * platform, then use the platform name for this part.
	 * The second part contains the position of the module, ex. "rear" or "front".
	 * The third part contains the last 6 characters of a part number which is found
	 * in the module's specsheet from the vendor.
	modules {
		cam_module0: module0 {
			badge = "porg_lt9211";
			position = "front";
			orientation = "1";
			cam_module0_drivernode0: drivernode0 {
				pcl_id = "v4l2_sensor";
				devname = "lt9211 1-002d";
				proc-device-tree = "/proc/device-tree/i2c@c240000/lt9211@2d";
		cam_module1: module1 {
			badge = "porg_lt6911";
			position = "rear";
			orientation = "1";
			cam_module1_drivernode0: drivernode0 {
				devname = "lt6911 8-002b";
				proc-device-tree = "/proc/device-tree/i2c@31e0000/lt6911@2b";
I am remove imx219 from DT.
Install of my increase。
I am sure I2c address is configure OK.
Because the two chips is bound ok.And my driver can use i2c to read data from these two chips.
Please get the trace log to check if can get more inforamtion.
https://elinux.org/Jetson_TX2_Camera_BringUp
hello,
> root@nx-desktop:/home/nx# cat /sys/kernel/debug/tracing/trace
tracer: nop
entries-in-buffer/entries-written: 3326/3326 #P:2
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
 kworker/0:0-4     [000] ....  1533.131401: rtos_queue_peek_from_isr_failed: tstamp:48353935133 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1533.299410: rtos_queue_peek_from_isr_failed: tstamp:48358935133 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1533.467391: rtos_queue_peek_from_isr_failed: tstamp:48363935129 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1533.635392: rtos_queue_peek_from_isr_failed: tstamp:48368935129 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1533.803411: rtos_queue_peek_from_isr_failed: tstamp:48373935134 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1533.915397: rtos_queue_peek_from_isr_failed: tstamp:48378935132 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1534.083390: rtos_queue_peek_from_isr_failed: tstamp:48383935129 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1534.251392: rtos_queue_peek_from_isr_failed: tstamp:48388935133 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1534.419400: rtos_queue_peek_from_isr_failed: tstamp:48393935129 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1534.587392: rtos_queue_peek_from_isr_failed: tstamp:48398935132 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1534.755399: rtos_queue_peek_from_isr_failed: tstamp:48403935129 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1534.923392: rtos_queue_peek_from_isr_failed: tstamp:48408935132 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1535.035437: rtos_queue_peek_from_isr_failed: tstamp:48413935129 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1535.203392: rtos_queue_peek_from_isr_failed: tstamp:48418935132 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1535.371391: rtos_queue_peek_from_isr_failed: tstamp:48423935133 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1535.539402: rtos_queue_peek_from_isr_failed: tstamp:48428935129 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1535.707392: rtos_queue_peek_from_isr_failed: tstamp:48433935133 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1535.875397: rtos_queue_peek_from_isr_failed: tstamp:48438935130 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1536.043393: rtos_queue_peek_from_isr_failed: tstamp:48443935130 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1536.155395: rtos_queue_peek_from_isr_failed: tstamp:48448935133 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1536.323399: rtos_queue_peek_from_isr_failed: tstamp:48453935145 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1536.491397: rtos_queue_peek_from_isr_failed: tstamp:48458935130 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1536.659393: rtos_queue_peek_from_isr_failed: tstamp:48463935130 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1536.827395: rtos_queue_peek_from_isr_failed: tstamp:48468935130 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1536.995402: rtos_queue_peek_from_isr_failed: tstamp:48473935132 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1537.163397: rtos_queue_peek_from_isr_failed: tstamp:48478935133 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1537.275397: rtos_queue_peek_from_isr_failed: tstamp:48483935132 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1537.443395: rtos_queue_peek_from_isr_failed: tstamp:48488935130 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1537.611395: rtos_queue_peek_from_isr_failed: tstamp:48493935133 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1537.779403: rtos_queue_peek_from_isr_failed: tstamp:48498935129 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1537.947397: rtos_queue_peek_from_isr_failed: tstamp:48503935132 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1538.115393: rtos_queue_peek_from_isr_failed: tstamp:48508935133 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1538.283398: rtos_queue_peek_from_isr_failed: tstamp:48513935130 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1538.395403: rtos_queue_peek_from_isr_failed: tstamp:48518935129 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1538.395406: rtos_queue_peek_from_isr_failed: tstamp:48518942825 queue:0x0bcbcf78
       qv4l2-7939  [000] ....  1573.908445: tegra_channel_capture_setup: vnc_id 0 W 1024 H 768 fmt 13
       qv4l2-7939  [001] ....  1573.915300: tegra_channel_set_stream: enable : 0x1
       qv4l2-7939  [001] ....  1573.917007: tegra_channel_set_stream: 15a00000.nvcsi--2 : 0x1
       qv4l2-7939  [001] ....  1573.917011: csi_s_stream: enable : 0x1
       qv4l2-7939  [001] ....  1573.917044: tegra_channel_set_stream: lt9211 1-002d : 0x1
 kworker/0:0-4     [000] ....  1573.959434: rtos_queue_peek_from_isr_failed: tstamp:49628927717 queue:0x0bcbcf78
 kworker/0:0-4     [000] ....  1573.959440: rtcpu_start: tstamp:49628929459
 kworker/0:0-4     [000] ....  1573.959441: rtos_queue_send_from_isr_failed: tstamp:49628938595 queue:0x0bcb41f8
 kworker/0:0-4     [000] ....  1573.959442: rtos_queue_send_from_isr_failed: tstamp:49628938747 queue:0x0bcb8a60
 kworker/0:0-4     [000] ....  1573.959443: rtos_queue_send_from_isr_failed: tstamp:49628938896 queue:0x0bcba5e0
 kworker/0:0-4     [000] ....  1573.959444: rtos_queue_send_from_isr_failed: tstamp:49628939041 queue:0x0bcbb3a0
 kworker/0:0-4     [000] ....  1573.959444: rtos_queue_send_from_isr_failed: tstamp:49628939188 queue:0x0bcbc160
 kworker/0:0-4     [000] ....  1573.959446: rtcpu_string: tstamp:49628939660 id:0x04010000 str:"Configuring VI GoS.
kworker/0:0-4 [000] … 1573.959477: rtcpu_string: tstamp:49628939836 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:0-4 [000] … 1573.959486: rtcpu_string: tstamp:49628940094 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:0-4 [000] … 1573.959493: rtcpu_string: tstamp:49628940363 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:0-4 [000] … 1573.959500: rtcpu_string: tstamp:49628940596 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:0-4 [000] … 1573.959507: rtcpu_string: tstamp:49628940828 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:0-4 [000] … 1573.959514: rtcpu_string: tstamp:49628941060 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:0-4 [000] … 1573.959521: rtcpu_string: tstamp:49628942380 id:0x04010000 str:“vi5_hwinit: firmware CL2018101701 protocol versi”
kworker/0:0-4 [000] … 1573.959523: rtcpu_string: tstamp:49628942498 id:0x04010000 str:"on 2.2
kworker/0:0-4 [000] … 1573.959530: rtos_queue_send_from_isr_failed: tstamp:49628958403 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1573.959531: rtos_queue_send_from_isr_failed: tstamp:49628958577 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1573.959531: rtos_queue_send_from_isr_failed: tstamp:49628958731 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1573.959532: rtos_queue_send_from_isr_failed: tstamp:49628958879 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1573.959533: rtos_queue_send_from_isr_failed: tstamp:49628959026 queue:0x0bcbc160
kworker/0:0-4 [000] … 1573.959533: rtcpu_string: tstamp:49628959878 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/0:0-4 [000] … 1573.959542: rtos_queue_send_from_isr_failed: tstamp:49629118255 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1573.959543: rtos_queue_send_from_isr_failed: tstamp:49629118407 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1573.959544: rtos_queue_send_from_isr_failed: tstamp:49629118560 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1573.959544: rtos_queue_send_from_isr_failed: tstamp:49629118707 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1573.959545: rtos_queue_send_from_isr_failed: tstamp:49629118852 queue:0x0bcbc160
kworker/0:0-4 [000] … 1573.959547: rtcpu_vinotify_error: tstamp:49629127340 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:49629125206 data:0x00000001
kworker/0:0-4 [000] … 1573.959549: rtcpu_vinotify_event: tstamp:49629301238 tag:FE channel:0x00 frame:1824 vi_tstamp:49628960475 data:0x00000020
kworker/0:0-4 [000] … 1573.959550: rtcpu_vinotify_event: tstamp:49629301383 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50528465024 data:0x10000000
kworker/0:0-4 [000] … 1573.959551: rtcpu_vinotify_event: tstamp:49629301545 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50528473408 data:0x31000001
kworker/0:0-4 [000] … 1573.959551: rtcpu_vinotify_event: tstamp:49629301684 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50528475552 data:0x07020001
kworker/0:0-4 [000] … 1573.959552: rtcpu_vinotify_event: tstamp:49629301842 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50528503008 data:0x10000000
kworker/0:0-4 [000] … 1573.959553: rtcpu_vinotify_event: tstamp:49629301981 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50528511424 data:0x31000002
kworker/0:0-4 [000] … 1573.959553: rtcpu_vinotify_event: tstamp:49629302146 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:49629125206 data:0x00000001
kworker/0:0-4 [000] … 1573.959561: rtcpu_vinotify_event: tstamp:49629676982 tag:FS channel:0x00 frame:25287 vi_tstamp:49629432123 data:0x00000010
kworker/0:0-4 [000] … 1573.959561: rtcpu_vinotify_event: tstamp:49629677146 tag:ATOMP_FS channel:0x00 frame:25287 vi_tstamp:49629432125 data:0x00000000
kworker/0:0-4 [000] … 1573.959562: rtcpu_vinotify_event: tstamp:49629677284 tag:CHANSEL_PXL_SOF channel:0x23 frame:25287 vi_tstamp:49629448281 data:0x00000001
kworker/0:0-4 [000] … 1573.959563: rtcpu_vinotify_event: tstamp:49629677444 tag:RESERVED_19 channel:0x23 frame:199 vi_tstamp:50544055968 data:0x08020001
kworker/0:0-4 [000] … 1573.959564: rtcpu_vinotify_error: tstamp:49629950768 tag:CSIMUX_FRAME channel:0x00 frame:25287 vi_tstamp:49629947104 data:0x00000220
kworker/0:0-4 [000] … 1573.959564: rtcpu_vinotify_event: tstamp:49629951178 tag:CHANSEL_PXL_EOF channel:0x23 frame:25287 vi_tstamp:49629944118 data:0x02ff0002
kworker/0:0-4 [000] … 1573.959565: rtcpu_vinotify_event: tstamp:49629951336 tag:ATOMP_FRAME_DONE channel:0x23 frame:25287 vi_tstamp:49629944140 data:0x00000000
kworker/0:0-4 [000] … 1573.959566: rtcpu_vinotify_event: tstamp:49629951475 tag:RESERVED_19 channel:0x23 frame:199 vi_tstamp:50559925248 data:0x02020001
kworker/0:0-4 [000] … 1573.959566: rtcpu_vinotify_event: tstamp:49629951631 tag:CSIMUX_FRAME channel:0x00 frame:25287 vi_tstamp:49629947104 data:0x00000220
kworker/0:0-4 [000] … 1573.959567: rtcpu_vinotify_event: tstamp:49629951771 tag:ATOMP_FE channel:0x00 frame:25287 vi_tstamp:49629947106 data:0x00000000
kworker/0:0-4 [000] … 1573.959568: rtos_queue_send_from_isr_failed: tstamp:49629965553 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1573.959569: rtos_queue_send_from_isr_failed: tstamp:49629965706 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1573.959569: rtos_queue_send_from_isr_failed: tstamp:49629965858 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1573.959570: rtos_queue_send_from_isr_failed: tstamp:49629966016 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1573.959571: rtos_queue_send_from_isr_failed: tstamp:49629966161 queue:0x0bcbc160
kworker/0:0-4 [000] … 1573.959572: rtcpu_vinotify_event: tstamp:49630315129 tag:RESERVED_19 channel:0x23 frame:199 vi_tstamp:50560033600 data:0x00020001
kworker/0:0-4 [000] … 1573.959573: rtcpu_vinotify_event: tstamp:49630315271 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50560048384 data:0x07020002
kworker/0:0-4 [000] … 1573.959573: rtcpu_vinotify_event: tstamp:49630315435 tag:FS channel:0x00 frame:25288 vi_tstamp:49629952919 data:0x00000010
kworker/0:0-4 [000] … 1573.959574: rtcpu_vinotify_event: tstamp:49630315577 tag:ATOMP_FS channel:0x00 frame:25288 vi_tstamp:49629952921 data:0x00000000
kworker/0:0-4 [000] … 1573.959575: rtcpu_vinotify_event: tstamp:49630315736 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50560257312 data:0x10000000
kworker/0:0-4 [000] … 1573.959575: rtcpu_vinotify_event: tstamp:49630315872 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50560277888 data:0x31000003
kworker/0:0-4 [000] … 1573.959576: rtcpu_vinotify_event: tstamp:49630316029 tag:CHANSEL_PXL_SOF channel:0x23 frame:25288 vi_tstamp:49629969077 data:0x00000001
kworker/0:0-4 [000] … 1573.959577: rtcpu_vinotify_event: tstamp:49630316164 tag:RESERVED_19 channel:0x23 frame:200 vi_tstamp:50560721440 data:0x08020002
kworker/0:0-4 [000] … 1574.015443: rtcpu_vinotify_error: tstamp:49630471411 tag:CSIMUX_FRAME channel:0x00 frame:25288 vi_tstamp:49630467900 data:0x00000220
kworker/0:0-4 [000] … 1574.015449: rtcpu_vinotify_event: tstamp:49630475774 tag:CHANSEL_PXL_EOF channel:0x23 frame:25288 vi_tstamp:49630464913 data:0x02ff0002
kworker/0:0-4 [000] … 1574.015450: rtcpu_vinotify_event: tstamp:49630475915 tag:ATOMP_FRAME_DONE channel:0x23 frame:25288 vi_tstamp:49630464935 data:0x00000000
kworker/0:0-4 [000] … 1574.015451: rtcpu_vinotify_event: tstamp:49630476073 tag:RESERVED_19 channel:0x23 frame:200 vi_tstamp:50576590752 data:0x02020002
kworker/0:0-4 [000] … 1574.015452: rtcpu_vinotify_event: tstamp:49630476212 tag:CSIMUX_FRAME channel:0x00 frame:25288 vi_tstamp:49630467900 data:0x00000220
kworker/0:0-4 [000] … 1574.015453: rtcpu_vinotify_event: tstamp:49630476374 tag:ATOMP_FE channel:0x00 frame:25288 vi_tstamp:49630467902 data:0x00000000
kworker/0:0-4 [000] … 1574.015453: rtcpu_vinotify_event: tstamp:49630476509 tag:RESERVED_19 channel:0x23 frame:200 vi_tstamp:50576694976 data:0x00020002
kworker/0:0-4 [000] … 1574.015455: rtcpu_vinotify_event: tstamp:49630476668 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50576709472 data:0x07020003
kworker/0:0-4 [000] … 1574.015456: rtcpu_vinotify_event: tstamp:49630476806 tag:FS channel:0x00 frame:25289 vi_tstamp:49630473715 data:0x00000010
kworker/0:0-4 [000] … 1574.015462: rtos_queue_send_from_isr_failed: tstamp:49630510837 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.015463: rtos_queue_send_from_isr_failed: tstamp:49630510994 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.015464: rtos_queue_send_from_isr_failed: tstamp:49630511148 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.015464: rtos_queue_send_from_isr_failed: tstamp:49630511295 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.015465: rtos_queue_send_from_isr_failed: tstamp:49630511440 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.015466: rtcpu_vinotify_event: tstamp:49630841274 tag:ATOMP_FS channel:0x00 frame:25289 vi_tstamp:49630473717 data:0x00000000
kworker/0:0-4 [000] … 1574.015466: rtcpu_vinotify_event: tstamp:49630841414 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50576932544 data:0x10000000
kworker/0:0-4 [000] … 1574.015467: rtcpu_vinotify_event: tstamp:49630841575 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50576953120 data:0x31000004
kworker/0:0-4 [000] … 1574.015468: rtcpu_vinotify_event: tstamp:49630841710 tag:CHANSEL_PXL_SOF channel:0x23 frame:25289 vi_tstamp:49630489873 data:0x00000001
kworker/0:0-4 [000] … 1574.015469: rtcpu_vinotify_event: tstamp:49630841865 tag:RESERVED_19 channel:0x23 frame:201 vi_tstamp:50577386912 data:0x08020003
kworker/0:0-4 [000] … 1574.015469: rtcpu_vinotify_error: tstamp:49630992227 tag:CSIMUX_FRAME channel:0x00 frame:25289 vi_tstamp:49630988696 data:0x00000220
kworker/0:0-4 [000] … 1574.015470: rtcpu_vinotify_event: tstamp:49630997864 tag:CHANSEL_PXL_EOF channel:0x23 frame:25289 vi_tstamp:49630985709 data:0x02ff0002
kworker/0:0-4 [000] … 1574.015471: rtcpu_vinotify_event: tstamp:49630998042 tag:ATOMP_FRAME_DONE channel:0x23 frame:25289 vi_tstamp:49630985732 data:0x00000000
kworker/0:0-4 [000] … 1574.015472: rtcpu_vinotify_event: tstamp:49630998180 tag:RESERVED_19 channel:0x23 frame:201 vi_tstamp:50593256192 data:0x02020003
kworker/0:0-4 [000] … 1574.015472: rtcpu_vinotify_event: tstamp:49630998337 tag:CSIMUX_FRAME channel:0x00 frame:25289 vi_tstamp:49630988696 data:0x00000220
kworker/0:0-4 [000] … 1574.015473: rtcpu_vinotify_event: tstamp:49630998477 tag:ATOMP_FE channel:0x00 frame:25289 vi_tstamp:49630988698 data:0x00000000
kworker/0:0-4 [000] … 1574.015474: rtcpu_vinotify_event: tstamp:49630998634 tag:RESERVED_19 channel:0x23 frame:201 vi_tstamp:50593360480 data:0x00020003
kworker/0:0-4 [000] … 1574.015474: rtcpu_vinotify_event: tstamp:49630998769 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50593374944 data:0x07020004
kworker/0:0-4 [000] … 1574.015475: rtcpu_vinotify_event: tstamp:49630998925 tag:FS channel:0x00 frame:25290 vi_tstamp:49630994511 data:0x00000010
kworker/0:0-4 [000] … 1574.015476: rtcpu_vinotify_event: tstamp:49630999063 tag:ATOMP_FS channel:0x00 frame:25290 vi_tstamp:49630994513 data:0x00000000
kworker/0:0-4 [000] … 1574.015477: rtcpu_vinotify_event: tstamp:49630999220 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50593559808 data:0x10000000
kworker/0:0-4 [000] … 1574.015477: rtcpu_vinotify_event: tstamp:49630999356 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50593582496 data:0x31000005
kworker/0:0-4 [000] … 1574.015478: rtos_queue_send_from_isr_failed: tstamp:49631003314 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.015479: rtos_queue_send_from_isr_failed: tstamp:49631003467 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.015479: rtos_queue_send_from_isr_failed: tstamp:49631003617 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.015480: rtos_queue_send_from_isr_failed: tstamp:49631003764 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.015481: rtos_queue_send_from_isr_failed: tstamp:49631003909 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.015482: rtcpu_vinotify_event: tstamp:49631366751 tag:CHANSEL_PXL_SOF channel:0x23 frame:25290 vi_tstamp:49631010669 data:0x00000001
kworker/0:0-4 [000] … 1574.015483: rtcpu_vinotify_event: tstamp:49631366893 tag:RESERVED_19 channel:0x23 frame:202 vi_tstamp:50594052416 data:0x08020004
kworker/0:0-4 [000] … 1574.015484: rtcpu_vinotify_error: tstamp:49631513001 tag:CSIMUX_FRAME channel:0x00 frame:25290 vi_tstamp:49631509492 data:0x00000220
kworker/0:0-4 [000] … 1574.015484: rtos_queue_send_from_isr_failed: tstamp:49631523652 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.015485: rtos_queue_send_from_isr_failed: tstamp:49631523805 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.015486: rtos_queue_send_from_isr_failed: tstamp:49631523957 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.015486: rtos_queue_send_from_isr_failed: tstamp:49631524102 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.015487: rtos_queue_send_from_isr_failed: tstamp:49631524246 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.015488: rtcpu_vinotify_event: tstamp:49631742488 tag:CHANSEL_PXL_EOF channel:0x23 frame:25290 vi_tstamp:49631506506 data:0x02ff0002
kworker/0:0-4 [000] … 1574.015489: rtcpu_vinotify_event: tstamp:49631742629 tag:ATOMP_FRAME_DONE channel:0x23 frame:25290 vi_tstamp:49631506529 data:0x00000000
kworker/0:0-4 [000] … 1574.015490: rtcpu_vinotify_event: tstamp:49631742790 tag:RESERVED_19 channel:0x23 frame:202 vi_tstamp:50609921664 data:0x02020004
kworker/0:0-4 [000] … 1574.015490: rtcpu_vinotify_event: tstamp:49631742926 tag:CSIMUX_FRAME channel:0x00 frame:25290 vi_tstamp:49631509492 data:0x00000220
kworker/0:0-4 [000] … 1574.015491: rtcpu_vinotify_event: tstamp:49631743086 tag:ATOMP_FE channel:0x00 frame:25290 vi_tstamp:49631509494 data:0x00000000
kworker/0:0-4 [000] … 1574.015492: rtcpu_vinotify_event: tstamp:49631743220 tag:RESERVED_19 channel:0x23 frame:202 vi_tstamp:50610025984 data:0x00020004
kworker/0:0-4 [000] … 1574.015492: rtcpu_vinotify_event: tstamp:49631743377 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50610040416 data:0x07020005
kworker/0:0-4 [000] … 1574.015493: rtcpu_vinotify_event: tstamp:49631743514 tag:FS channel:0x00 frame:25291 vi_tstamp:49631515307 data:0x00000010
kworker/0:0-4 [000] … 1574.015494: rtcpu_vinotify_event: tstamp:49631743673 tag:ATOMP_FS channel:0x00 frame:25291 vi_tstamp:49631515309 data:0x00000000
kworker/0:0-4 [000] … 1574.015495: rtcpu_vinotify_event: tstamp:49631743807 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50610212576 data:0x10000000
kworker/0:0-4 [000] … 1574.015495: rtcpu_vinotify_event: tstamp:49631743966 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50610240576 data:0x31000006
kworker/0:0-4 [000] … 1574.015496: rtcpu_vinotify_event: tstamp:49631744101 tag:CHANSEL_PXL_SOF channel:0x23 frame:25291 vi_tstamp:49631531465 data:0x00000001
kworker/0:0-4 [000] … 1574.015497: rtcpu_vinotify_event: tstamp:49631744258 tag:RESERVED_19 channel:0x23 frame:203 vi_tstamp:50610717888 data:0x08020005
kworker/0:0-4 [000] … 1574.015498: rtcpu_vinotify_event: tstamp:49632029546 tag:CHANSEL_PXL_EOF channel:0x23 frame:25291 vi_tstamp:49632027302 data:0x02ff0002
kworker/0:0-4 [000] … 1574.015498: rtcpu_vinotify_error: tstamp:49632033805 tag:CSIMUX_FRAME channel:0x00 frame:25291 vi_tstamp:49632030289 data:0x00000220
kworker/0:0-4 [000] … 1574.015499: rtos_queue_send_from_isr_failed: tstamp:49632043996 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.015500: rtos_queue_send_from_isr_failed: tstamp:49632044149 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.015500: rtos_queue_send_from_isr_failed: tstamp:49632044299 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.015501: rtos_queue_send_from_isr_failed: tstamp:49632044445 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.015502: rtos_queue_send_from_isr_failed: tstamp:49632044591 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.071503: rtcpu_vinotify_event: tstamp:49632381221 tag:ATOMP_FRAME_DONE channel:0x23 frame:25291 vi_tstamp:49632027324 data:0x00000000
kworker/0:0-4 [000] … 1574.071508: rtcpu_vinotify_event: tstamp:49632381362 tag:RESERVED_19 channel:0x23 frame:203 vi_tstamp:50626591296 data:0x02020005
kworker/0:0-4 [000] … 1574.071509: rtcpu_vinotify_event: tstamp:49632381528 tag:CSIMUX_FRAME channel:0x00 frame:25291 vi_tstamp:49632030289 data:0x00000220
kworker/0:0-4 [000] … 1574.071509: rtcpu_vinotify_event: tstamp:49632381671 tag:ATOMP_FE channel:0x00 frame:25291 vi_tstamp:49632030290 data:0x00000000
kworker/0:0-4 [000] … 1574.071510: rtcpu_vinotify_event: tstamp:49632381829 tag:RESERVED_19 channel:0x23 frame:203 vi_tstamp:50626691424 data:0x00020005
kworker/0:0-4 [000] … 1574.071511: rtcpu_vinotify_event: tstamp:49632381964 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50626705856 data:0x07020006
kworker/0:0-4 [000] … 1574.071511: rtcpu_vinotify_event: tstamp:49632382120 tag:FS channel:0x00 frame:25292 vi_tstamp:49632036103 data:0x00000010
kworker/0:0-4 [000] … 1574.071512: rtcpu_vinotify_event: tstamp:49632382262 tag:ATOMP_FS channel:0x00 frame:25292 vi_tstamp:49632036106 data:0x00000000
kworker/0:0-4 [000] … 1574.071513: rtcpu_vinotify_event: tstamp:49632382419 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50626887424 data:0x10000000
kworker/0:0-4 [000] … 1574.071514: rtcpu_vinotify_event: tstamp:49632382554 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50626908000 data:0x31000007
kworker/0:0-4 [000] … 1574.071514: rtcpu_vinotify_event: tstamp:49632382710 tag:CHANSEL_PXL_SOF channel:0x23 frame:25292 vi_tstamp:49632052261 data:0x00000001
kworker/0:0-4 [000] … 1574.071515: rtcpu_vinotify_event: tstamp:49632382845 tag:RESERVED_19 channel:0x23 frame:204 vi_tstamp:50627383328 data:0x08020006
kworker/0:0-4 [000] … 1574.071516: rtcpu_vinotify_error: tstamp:49632554753 tag:CSIMUX_FRAME channel:0x00 frame:25292 vi_tstamp:49632551084 data:0x00000220
kworker/0:0-4 [000] … 1574.071517: rtcpu_vinotify_event: tstamp:49632555198 tag:CHANSEL_PXL_EOF channel:0x23 frame:25292 vi_tstamp:49632548098 data:0x02ff0002
kworker/0:0-4 [000] … 1574.071518: rtcpu_vinotify_event: tstamp:49632555334 tag:ATOMP_FRAME_DONE channel:0x23 frame:25292 vi_tstamp:49632548121 data:0x00000000
kworker/0:0-4 [000] … 1574.071519: rtcpu_vinotify_event: tstamp:49632555492 tag:RESERVED_19 channel:0x23 frame:204 vi_tstamp:50643252608 data:0x02020006
kworker/0:0-4 [000] … 1574.071520: rtcpu_vinotify_event: tstamp:49632555627 tag:CSIMUX_FRAME channel:0x00 frame:25292 vi_tstamp:49632551084 data:0x00000220
kworker/0:0-4 [000] … 1574.071522: rtos_queue_send_from_isr_failed: tstamp:49632564917 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.071523: rtos_queue_send_from_isr_failed: tstamp:49632565070 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.071524: rtos_queue_send_from_isr_failed: tstamp:49632565221 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.071524: rtos_queue_send_from_isr_failed: tstamp:49632565368 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.071525: rtos_queue_send_from_isr_failed: tstamp:49632565513 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.071562: rtcpu_vinotify_event: tstamp:49632906683 tag:ATOMP_FE channel:0x00 frame:25292 vi_tstamp:49632551086 data:0x00000000
kworker/0:0-4 [000] … 1574.071582: rtcpu_vinotify_event: tstamp:49632906841 tag:RESERVED_19 channel:0x23 frame:204 vi_tstamp:50643360960 data:0x00020006
kworker/0:0-4 [000] … 1574.071582: rtcpu_vinotify_event: tstamp:49632907008 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50643375744 data:0x07020007
kworker/0:0-4 [000] … 1574.071583: rtcpu_vinotify_event: tstamp:49632907146 tag:FS channel:0x00 frame:25293 vi_tstamp:49632556900 data:0x00000010
kworker/0:0-4 [000] … 1574.071584: rtcpu_vinotify_event: tstamp:49632907306 tag:ATOMP_FS channel:0x00 frame:25293 vi_tstamp:49632556902 data:0x00000000
kworker/0:0-4 [000] … 1574.071585: rtcpu_vinotify_event: tstamp:49632907441 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50643575936 data:0x10000000
kworker/0:0-4 [000] … 1574.071585: rtcpu_vinotify_event: tstamp:49632907598 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50643598592 data:0x31000008
kworker/0:0-4 [000] … 1574.071586: rtcpu_vinotify_event: tstamp:49632907733 tag:CHANSEL_PXL_SOF channel:0x23 frame:25293 vi_tstamp:49632573057 data:0x00000001
kworker/0:0-4 [000] … 1574.071587: rtcpu_vinotify_event: tstamp:49632907895 tag:RESERVED_19 channel:0x23 frame:205 vi_tstamp:50644048800 data:0x08020007
kworker/0:0-4 [000] … 1574.071588: rtcpu_vinotify_error: tstamp:49633075574 tag:CSIMUX_FRAME channel:0x00 frame:25293 vi_tstamp:49633071880 data:0x00000220
kworker/0:0-4 [000] … 1574.071588: rtcpu_vinotify_event: tstamp:49633076021 tag:CHANSEL_PXL_EOF channel:0x23 frame:25293 vi_tstamp:49633068894 data:0x02ff0002
kworker/0:0-4 [000] … 1574.071589: rtcpu_vinotify_event: tstamp:49633076196 tag:ATOMP_FRAME_DONE channel:0x23 frame:25293 vi_tstamp:49633068917 data:0x00000000
kworker/0:0-4 [000] … 1574.071590: rtcpu_vinotify_event: tstamp:49633076334 tag:RESERVED_19 channel:0x23 frame:205 vi_tstamp:50659918112 data:0x02020007
kworker/0:0-4 [000] … 1574.071590: rtcpu_vinotify_event: tstamp:49633076491 tag:CSIMUX_FRAME channel:0x00 frame:25293 vi_tstamp:49633071880 data:0x00000220
kworker/0:0-4 [000] … 1574.071591: rtcpu_vinotify_event: tstamp:49633076632 tag:ATOMP_FE channel:0x00 frame:25293 vi_tstamp:49633071882 data:0x00000000
kworker/0:0-4 [000] … 1574.071592: rtcpu_vinotify_event: tstamp:49633076789 tag:RESERVED_19 channel:0x23 frame:205 vi_tstamp:50660022368 data:0x00020007
kworker/0:0-4 [000] … 1574.071593: rtcpu_vinotify_event: tstamp:49633076924 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50660036832 data:0x07020008
kworker/0:0-4 [000] … 1574.071593: rtos_queue_send_from_isr_failed: tstamp:49633086409 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.071594: rtos_queue_send_from_isr_failed: tstamp:49633086562 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.071595: rtos_queue_send_from_isr_failed: tstamp:49633086715 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.071596: rtos_queue_send_from_isr_failed: tstamp:49633086860 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.071596: rtos_queue_send_from_isr_failed: tstamp:49633087005 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.071598: rtcpu_vinotify_event: tstamp:49633432707 tag:FS channel:0x00 frame:25294 vi_tstamp:49633077696 data:0x00000010
kworker/0:0-4 [000] … 1574.071599: rtcpu_vinotify_event: tstamp:49633432852 tag:ATOMP_FS channel:0x00 frame:25294 vi_tstamp:49633077698 data:0x00000000
kworker/0:0-4 [000] … 1574.071600: rtcpu_vinotify_event: tstamp:49633433017 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50660249184 data:0x10000000
kworker/0:0-4 [000] … 1574.071601: rtcpu_vinotify_event: tstamp:49633433156 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50660271904 data:0x31000009
kworker/0:0-4 [000] … 1574.071602: rtcpu_vinotify_event: tstamp:49633433315 tag:CHANSEL_PXL_SOF channel:0x23 frame:25294 vi_tstamp:49633093853 data:0x00000001
kworker/0:0-4 [000] … 1574.071602: rtcpu_vinotify_event: tstamp:49633433450 tag:RESERVED_19 channel:0x23 frame:206 vi_tstamp:50660714304 data:0x08020008
kworker/0:0-4 [000] … 1574.071603: rtcpu_vinotify_error: tstamp:49633596189 tag:CSIMUX_FRAME channel:0x00 frame:25294 vi_tstamp:49633592676 data:0x00000220
kworker/0:0-4 [000] … 1574.071604: rtcpu_vinotify_event: tstamp:49633600912 tag:CHANSEL_PXL_EOF channel:0x23 frame:25294 vi_tstamp:49633589690 data:0x02ff0002
kworker/0:0-4 [000] … 1574.071605: rtcpu_vinotify_event: tstamp:49633601068 tag:ATOMP_FRAME_DONE channel:0x23 frame:25294 vi_tstamp:49633589712 data:0x00000000
kworker/0:0-4 [000] … 1574.071605: rtcpu_vinotify_event: tstamp:49633601226 tag:RESERVED_19 channel:0x23 frame:206 vi_tstamp:50676583552 data:0x02020008
kworker/0:0-4 [000] … 1574.071606: rtcpu_vinotify_event: tstamp:49633601362 tag:CSIMUX_FRAME channel:0x00 frame:25294 vi_tstamp:49633592676 data:0x00000220
kworker/0:0-4 [000] … 1574.071607: rtcpu_vinotify_event: tstamp:49633601519 tag:ATOMP_FE channel:0x00 frame:25294 vi_tstamp:49633592678 data:0x00000000
kworker/0:0-4 [000] … 1574.071608: rtcpu_vinotify_event: tstamp:49633601654 tag:RESERVED_19 channel:0x23 frame:206 vi_tstamp:50676687872 data:0x00020008
kworker/0:0-4 [000] … 1574.071608: rtcpu_vinotify_event: tstamp:49633601810 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50676702336 data:0x07020009
kworker/0:0-4 [000] … 1574.071609: rtcpu_vinotify_event: tstamp:49633601947 tag:FS channel:0x00 frame:25295 vi_tstamp:49633598492 data:0x00000010
kworker/0:0-4 [000] … 1574.071610: rtcpu_vinotify_event: tstamp:49633602104 tag:ATOMP_FS channel:0x00 frame:25295 vi_tstamp:49633598494 data:0x00000000
kworker/0:0-4 [000] … 1574.071610: rtcpu_vinotify_event: tstamp:49633602238 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50676878560 data:0x10000000
kworker/0:0-4 [000] … 1574.071624: rtos_queue_send_from_isr_failed: tstamp:49633605762 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.071625: rtos_queue_send_from_isr_failed: tstamp:49633605914 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.071626: rtos_queue_send_from_isr_failed: tstamp:49633606068 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.071626: rtos_queue_send_from_isr_failed: tstamp:49633606215 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.071627: rtos_queue_send_from_isr_failed: tstamp:49633606361 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.071630: rtos_queue_peek_from_isr_failed: tstamp:49633928101 queue:0x0bcbcf78
kworker/0:0-4 [000] … 1574.127497: rtcpu_vinotify_event: tstamp:49633958779 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50676963904 data:0x3100000a
kworker/0:0-4 [000] … 1574.127502: rtcpu_vinotify_event: tstamp:49633958922 tag:CHANSEL_PXL_SOF channel:0x23 frame:25295 vi_tstamp:49633614650 data:0x00000001
kworker/0:0-4 [000] … 1574.127503: rtcpu_vinotify_event: tstamp:49633959083 tag:RESERVED_19 channel:0x23 frame:207 vi_tstamp:50677379776 data:0x08020009
kworker/0:0-4 [000] … 1574.127505: rtcpu_vinotify_error: tstamp:49634116987 tag:CSIMUX_FRAME channel:0x00 frame:25295 vi_tstamp:49634113473 data:0x00000220
kworker/0:0-4 [000] … 1574.127508: rtos_queue_send_from_isr_failed: tstamp:49634126049 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.127510: rtos_queue_send_from_isr_failed: tstamp:49634126203 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.127511: rtos_queue_send_from_isr_failed: tstamp:49634126356 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.127512: rtos_queue_send_from_isr_failed: tstamp:49634126502 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.127514: rtos_queue_send_from_isr_failed: tstamp:49634126650 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.127515: rtcpu_vinotify_event: tstamp:49634138315 tag:CHANSEL_PXL_EOF channel:0x23 frame:25295 vi_tstamp:49634110486 data:0x02ff0002
kworker/0:0-4 [000] … 1574.127516: rtcpu_vinotify_event: tstamp:49634138477 tag:ATOMP_FRAME_DONE channel:0x23 frame:25295 vi_tstamp:49634110509 data:0x00000000
kworker/0:0-4 [000] … 1574.127517: rtcpu_vinotify_event: tstamp:49634138616 tag:RESERVED_19 channel:0x23 frame:207 vi_tstamp:50693249056 data:0x02020009
kworker/0:0-4 [000] … 1574.127518: rtcpu_vinotify_event: tstamp:49634138775 tag:CSIMUX_FRAME channel:0x00 frame:25295 vi_tstamp:49634113473 data:0x00000220
kworker/0:0-4 [000] … 1574.127519: rtcpu_vinotify_event: tstamp:49634138919 tag:ATOMP_FE channel:0x00 frame:25295 vi_tstamp:49634113475 data:0x00000000
kworker/0:0-4 [000] … 1574.127521: rtcpu_vinotify_event: tstamp:49634139076 tag:RESERVED_19 channel:0x23 frame:207 vi_tstamp:50693353408 data:0x00020009
kworker/0:0-4 [000] … 1574.127522: rtcpu_vinotify_event: tstamp:49634139211 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50693367904 data:0x0702000a
kworker/0:0-4 [000] … 1574.127523: rtcpu_vinotify_event: tstamp:49634139369 tag:FS channel:0x00 frame:25296 vi_tstamp:49634119288 data:0x00000010
kworker/0:0-4 [000] … 1574.127539: rtcpu_vinotify_event: tstamp:49634139511 tag:ATOMP_FS channel:0x00 frame:25296 vi_tstamp:49634119290 data:0x00000000
kworker/0:0-4 [000] … 1574.127541: rtcpu_vinotify_event: tstamp:49634139668 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50693537376 data:0x10000000
kworker/0:0-4 [000] … 1574.127542: rtcpu_vinotify_event: tstamp:49634139804 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50693557920 data:0x3100000b
kworker/0:0-4 [000] … 1574.127543: rtcpu_vinotify_event: tstamp:49634139961 tag:CHANSEL_PXL_SOF channel:0x23 frame:25296 vi_tstamp:49634135446 data:0x00000001
kworker/0:0-4 [000] … 1574.127544: rtcpu_vinotify_event: tstamp:49634140097 tag:RESERVED_19 channel:0x23 frame:208 vi_tstamp:50694045280 data:0x0802000a
kworker/0:0-4 [000] … 1574.127547: rtcpu_vinotify_event: tstamp:49634637515 tag:CHANSEL_PXL_EOF channel:0x23 frame:25296 vi_tstamp:49634631282 data:0x02ff0002
kworker/0:0-4 [000] … 1574.127549: rtcpu_vinotify_event: tstamp:49634637654 tag:ATOMP_FRAME_DONE channel:0x23 frame:25296 vi_tstamp:49634631305 data:0x00000000
kworker/0:0-4 [000] … 1574.127550: rtcpu_vinotify_event: tstamp:49634637813 tag:RESERVED_19 channel:0x23 frame:208 vi_tstamp:50709914528 data:0x0202000a
kworker/0:0-4 [000] … 1574.127551: rtcpu_vinotify_error: tstamp:49634638639 tag:CSIMUX_FRAME channel:0x00 frame:25296 vi_tstamp:49634634268 data:0x00000220
kworker/0:0-4 [000] … 1574.127552: rtos_queue_send_from_isr_failed: tstamp:49634653984 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.127553: rtos_queue_send_from_isr_failed: tstamp:49634654139 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.127554: rtos_queue_send_from_isr_failed: tstamp:49634654294 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.127556: rtos_queue_send_from_isr_failed: tstamp:49634654441 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.127557: rtos_queue_send_from_isr_failed: tstamp:49634654587 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.127558: rtcpu_vinotify_event: tstamp:49635010190 tag:CSIMUX_FRAME channel:0x00 frame:25296 vi_tstamp:49634634268 data:0x00000220
kworker/0:0-4 [000] … 1574.127560: rtcpu_vinotify_event: tstamp:49635010354 tag:ATOMP_FE channel:0x00 frame:25296 vi_tstamp:49634634271 data:0x00000000
kworker/0:0-4 [000] … 1574.127561: rtcpu_vinotify_event: tstamp:49635010496 tag:RESERVED_19 channel:0x23 frame:208 vi_tstamp:50710022912 data:0x0002000a
kworker/0:0-4 [000] … 1574.127562: rtcpu_vinotify_event: tstamp:49635010657 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50710037376 data:0x0702000b
kworker/0:0-4 [000] … 1574.127563: rtcpu_vinotify_event: tstamp:49635010794 tag:FS channel:0x00 frame:25297 vi_tstamp:49634640084 data:0x00000010
kworker/0:0-4 [000] … 1574.127564: rtcpu_vinotify_event: tstamp:49635010954 tag:ATOMP_FS channel:0x00 frame:25297 vi_tstamp:49634640086 data:0x00000000
kworker/0:0-4 [000] … 1574.127565: rtcpu_vinotify_event: tstamp:49635011089 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50710231264 data:0x10000000
kworker/0:0-4 [000] … 1574.127567: rtcpu_vinotify_event: tstamp:49635011247 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50710253952 data:0x3100000c
kworker/0:0-4 [000] … 1574.127568: rtcpu_vinotify_event: tstamp:49635011382 tag:CHANSEL_PXL_SOF channel:0x23 frame:25297 vi_tstamp:49634656242 data:0x00000001
kworker/0:0-4 [000] … 1574.127569: rtcpu_vinotify_event: tstamp:49635011540 tag:RESERVED_19 channel:0x23 frame:209 vi_tstamp:50710710720 data:0x0802000b
kworker/0:0-4 [000] … 1574.127570: rtcpu_vinotify_event: tstamp:49635154325 tag:CHANSEL_PXL_EOF channel:0x23 frame:25297 vi_tstamp:49635152078 data:0x02ff0002
kworker/0:0-4 [000] … 1574.127571: rtcpu_vinotify_event: tstamp:49635154486 tag:ATOMP_FRAME_DONE channel:0x23 frame:25297 vi_tstamp:49635152101 data:0x00000000
kworker/0:0-4 [000] … 1574.127572: rtcpu_vinotify_event: tstamp:49635154622 tag:RESERVED_19 channel:0x23 frame:209 vi_tstamp:50726580000 data:0x0202000b
kworker/0:0-4 [000] … 1574.127574: rtcpu_vinotify_error: tstamp:49635158608 tag:CSIMUX_FRAME channel:0x00 frame:25297 vi_tstamp:49635155065 data:0x00000220
kworker/0:0-4 [000] … 1574.127575: rtos_queue_send_from_isr_failed: tstamp:49635170920 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.127576: rtos_queue_send_from_isr_failed: tstamp:49635171073 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.127577: rtos_queue_send_from_isr_failed: tstamp:49635171226 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.127578: rtos_queue_send_from_isr_failed: tstamp:49635171373 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.127579: rtos_queue_send_from_isr_failed: tstamp:49635171519 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.127581: rtcpu_vinotify_event: tstamp:49635498853 tag:CSIMUX_FRAME channel:0x00 frame:25297 vi_tstamp:49635155065 data:0x00000220
kworker/0:0-4 [000] … 1574.127582: rtcpu_vinotify_event: tstamp:49635499001 tag:ATOMP_FE channel:0x00 frame:25297 vi_tstamp:49635155066 data:0x00000000
kworker/0:0-4 [000] … 1574.127583: rtcpu_vinotify_event: tstamp:49635499166 tag:RESERVED_19 channel:0x23 frame:209 vi_tstamp:50726684256 data:0x0002000b
kworker/0:0-4 [000] … 1574.127584: rtcpu_vinotify_event: tstamp:49635499304 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50726698720 data:0x0702000c
kworker/0:0-4 [000] … 1574.127585: rtcpu_vinotify_event: tstamp:49635499463 tag:FS channel:0x00 frame:25298 vi_tstamp:49635160880 data:0x00000010
kworker/0:0-4 [000] … 1574.127586: rtcpu_vinotify_event: tstamp:49635499605 tag:ATOMP_FS channel:0x00 frame:25298 vi_tstamp:49635160882 data:0x00000000
kworker/0:0-4 [000] … 1574.127588: rtcpu_vinotify_event: tstamp:49635499764 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50726869760 data:0x10000000
kworker/0:0-4 [000] … 1574.127589: rtcpu_vinotify_event: tstamp:49635499900 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50726892416 data:0x3100000d
kworker/0:0-4 [000] … 1574.127590: rtcpu_vinotify_event: tstamp:49635500055 tag:CHANSEL_PXL_SOF channel:0x23 frame:25298 vi_tstamp:49635177038 data:0x00000001
kworker/0:0-4 [000] … 1574.127591: rtcpu_vinotify_event: tstamp:49635500190 tag:RESERVED_19 channel:0x23 frame:210 vi_tstamp:50727376192 data:0x0802000c
kworker/0:0-4 [000] … 1574.127592: rtcpu_vinotify_error: tstamp:49635679529 tag:CSIMUX_FRAME channel:0x00 frame:25298 vi_tstamp:49635675861 data:0x00000220
kworker/0:0-4 [000] … 1574.127593: rtcpu_vinotify_event: tstamp:49635679972 tag:CHANSEL_PXL_EOF channel:0x23 frame:25298 vi_tstamp:49635672875 data:0x02ff0002
kworker/0:0-4 [000] … 1574.127595: rtcpu_vinotify_event: tstamp:49635680108 tag:ATOMP_FRAME_DONE channel:0x23 frame:25298 vi_tstamp:49635672897 data:0x00000000
kworker/0:0-4 [000] … 1574.127596: rtcpu_vinotify_event: tstamp:49635680267 tag:RESERVED_19 channel:0x23 frame:210 vi_tstamp:50743245504 data:0x0202000c
kworker/0:0-4 [000] … 1574.127597: rtcpu_vinotify_event: tstamp:49635680403 tag:CSIMUX_FRAME channel:0x00 frame:25298 vi_tstamp:49635675861 data:0x00000220
kworker/0:0-4 [000] … 1574.127598: rtcpu_vinotify_event: tstamp:49635680565 tag:ATOMP_FE channel:0x00 frame:25298 vi_tstamp:49635675862 data:0x00000000
kworker/0:0-4 [000] … 1574.127599: rtcpu_vinotify_event: tstamp:49635680698 tag:RESERVED_19 channel:0x23 frame:210 vi_tstamp:50743349760 data:0x0002000c
kworker/0:0-4 [000] … 1574.127600: rtos_queue_send_from_isr_failed: tstamp:49635690980 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.127601: rtos_queue_send_from_isr_failed: tstamp:49635691132 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.127603: rtos_queue_send_from_isr_failed: tstamp:49635691286 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.127604: rtos_queue_send_from_isr_failed: tstamp:49635691432 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.127605: rtos_queue_send_from_isr_failed: tstamp:49635691578 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.187424: rtcpu_vinotify_event: tstamp:49636024308 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50743368640 data:0x0702000d
kworker/0:0-4 [000] … 1574.187428: rtcpu_vinotify_event: tstamp:49636024451 tag:FS channel:0x00 frame:25299 vi_tstamp:49635681676 data:0x00000010
kworker/0:0-4 [000] … 1574.187430: rtcpu_vinotify_event: tstamp:49636024613 tag:ATOMP_FS channel:0x00 frame:25299 vi_tstamp:49635681679 data:0x00000000
kworker/0:0-4 [000] … 1574.187431: rtcpu_vinotify_event: tstamp:49636024749 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50743570624 data:0x10000000
kworker/0:0-4 [000] … 1574.187432: rtcpu_vinotify_event: tstamp:49636024906 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50743593312 data:0x3100000e
kworker/0:0-4 [000] … 1574.187433: rtcpu_vinotify_event: tstamp:49636025041 tag:CHANSEL_PXL_SOF channel:0x23 frame:25299 vi_tstamp:49635697834 data:0x00000001
kworker/0:0-4 [000] … 1574.187434: rtcpu_vinotify_event: tstamp:49636025198 tag:RESERVED_19 channel:0x23 frame:211 vi_tstamp:50744041664 data:0x0802000d
kworker/0:0-4 [000] … 1574.187436: rtcpu_vinotify_error: tstamp:49636200171 tag:CSIMUX_FRAME channel:0x00 frame:25299 vi_tstamp:49636196657 data:0x00000220
kworker/0:0-4 [000] … 1574.187437: rtcpu_vinotify_event: tstamp:49636204495 tag:CHANSEL_PXL_EOF channel:0x23 frame:25299 vi_tstamp:49636193671 data:0x02ff0002
kworker/0:0-4 [000] … 1574.187439: rtcpu_vinotify_event: tstamp:49636204657 tag:ATOMP_FRAME_DONE channel:0x23 frame:25299 vi_tstamp:49636193694 data:0x00000000
kworker/0:0-4 [000] … 1574.187441: rtcpu_vinotify_event: tstamp:49636204796 tag:RESERVED_19 channel:0x23 frame:211 vi_tstamp:50759910976 data:0x0202000d
kworker/0:0-4 [000] … 1574.187442: rtcpu_vinotify_event: tstamp:49636204954 tag:CSIMUX_FRAME channel:0x00 frame:25299 vi_tstamp:49636196657 data:0x00000220
kworker/0:0-4 [000] … 1574.187443: rtcpu_vinotify_event: tstamp:49636205095 tag:ATOMP_FE channel:0x00 frame:25299 vi_tstamp:49636196659 data:0x00000000
kworker/0:0-4 [000] … 1574.187444: rtcpu_vinotify_event: tstamp:49636205252 tag:RESERVED_19 channel:0x23 frame:211 vi_tstamp:50760015232 data:0x0002000d
kworker/0:0-4 [000] … 1574.187446: rtcpu_vinotify_event: tstamp:49636205389 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50760029696 data:0x0702000e
kworker/0:0-4 [000] … 1574.187447: rtcpu_vinotify_event: tstamp:49636205544 tag:FS channel:0x00 frame:25300 vi_tstamp:49636202472 data:0x00000010
kworker/0:0-4 [000] … 1574.187480: rtcpu_vinotify_event: tstamp:49636205680 tag:ATOMP_FS channel:0x00 frame:25300 vi_tstamp:49636202474 data:0x00000000
kworker/0:0-4 [000] … 1574.187483: rtos_queue_send_from_isr_failed: tstamp:49636209097 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.187485: rtos_queue_send_from_isr_failed: tstamp:49636209250 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.187486: rtos_queue_send_from_isr_failed: tstamp:49636209399 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.187487: rtos_queue_send_from_isr_failed: tstamp:49636209547 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.187488: rtos_queue_send_from_isr_failed: tstamp:49636209692 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.187490: rtcpu_vinotify_event: tstamp:49636550405 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50760238912 data:0x10000000
kworker/0:0-4 [000] … 1574.187491: rtcpu_vinotify_event: tstamp:49636550545 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50760268832 data:0x3100000f
kworker/0:0-4 [000] … 1574.187492: rtcpu_vinotify_event: tstamp:49636550705 tag:CHANSEL_PXL_SOF channel:0x23 frame:25300 vi_tstamp:49636218630 data:0x00000001
kworker/0:0-4 [000] … 1574.187494: rtcpu_vinotify_event: tstamp:49636550840 tag:RESERVED_19 channel:0x23 frame:212 vi_tstamp:50760707136 data:0x0802000e
kworker/0:0-4 [000] … 1574.187495: rtcpu_vinotify_error: tstamp:49636720963 tag:CSIMUX_FRAME channel:0x00 frame:25300 vi_tstamp:49636717453 data:0x00000220
kworker/0:0-4 [000] … 1574.187525: rtos_queue_send_from_isr_failed: tstamp:49636729983 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.187526: rtos_queue_send_from_isr_failed: tstamp:49636730151 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.187527: rtos_queue_send_from_isr_failed: tstamp:49636730304 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.187528: rtos_queue_send_from_isr_failed: tstamp:49636730451 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.187529: rtos_queue_send_from_isr_failed: tstamp:49636730597 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.187531: rtcpu_vinotify_event: tstamp:49636742293 tag:CHANSEL_PXL_EOF channel:0x23 frame:25300 vi_tstamp:49636714467 data:0x02ff0002
kworker/0:0-4 [000] … 1574.187532: rtcpu_vinotify_event: tstamp:49636742453 tag:ATOMP_FRAME_DONE channel:0x23 frame:25300 vi_tstamp:49636714489 data:0x00000000
kworker/0:0-4 [000] … 1574.187533: rtcpu_vinotify_event: tstamp:49636742612 tag:RESERVED_19 channel:0x23 frame:212 vi_tstamp:50776576480 data:0x0202000e
kworker/0:0-4 [000] … 1574.187534: rtcpu_vinotify_event: tstamp:49636742752 tag:CSIMUX_FRAME channel:0x00 frame:25300 vi_tstamp:49636717453 data:0x00000220
kworker/0:0-4 [000] … 1574.187535: rtcpu_vinotify_event: tstamp:49636742913 tag:ATOMP_FE channel:0x00 frame:25300 vi_tstamp:49636717455 data:0x00000000
kworker/0:0-4 [000] … 1574.187536: rtcpu_vinotify_event: tstamp:49636743049 tag:RESERVED_19 channel:0x23 frame:212 vi_tstamp:50776680672 data:0x0002000e
kworker/0:0-4 [000] … 1574.187537: rtcpu_vinotify_event: tstamp:49636743206 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50776695168 data:0x0702000f
kworker/0:0-4 [000] … 1574.187539: rtcpu_vinotify_event: tstamp:49636743342 tag:FS channel:0x00 frame:25301 vi_tstamp:49636723268 data:0x00000010
kworker/0:0-4 [000] … 1574.187540: rtcpu_vinotify_event: tstamp:49636743501 tag:ATOMP_FS channel:0x00 frame:25301 vi_tstamp:49636723270 data:0x00000000
kworker/0:0-4 [000] … 1574.187541: rtcpu_vinotify_event: tstamp:49636743637 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50776876448 data:0x10000000
kworker/0:0-4 [000] … 1574.187542: rtcpu_vinotify_event: tstamp:49636743796 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50776899136 data:0x31000010
kworker/0:0-4 [000] … 1574.187543: rtcpu_vinotify_event: tstamp:49636743931 tag:CHANSEL_PXL_SOF channel:0x23 frame:25301 vi_tstamp:49636739427 data:0x00000001
kworker/0:0-4 [000] … 1574.187545: rtcpu_vinotify_event: tstamp:49637113892 tag:RESERVED_19 channel:0x23 frame:213 vi_tstamp:50777376736 data:0x0802000f
kworker/0:0-4 [000] … 1574.187547: rtcpu_vinotify_error: tstamp:49637241772 tag:CSIMUX_FRAME channel:0x00 frame:25301 vi_tstamp:49637238249 data:0x00000220
kworker/0:0-4 [000] … 1574.187548: rtos_queue_send_from_isr_failed: tstamp:49637250526 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.187549: rtos_queue_send_from_isr_failed: tstamp:49637250678 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.187550: rtos_queue_send_from_isr_failed: tstamp:49637250832 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.187551: rtos_queue_send_from_isr_failed: tstamp:49637250979 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.187552: rtos_queue_send_from_isr_failed: tstamp:49637251125 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.187554: rtcpu_vinotify_event: tstamp:49637489088 tag:CHANSEL_PXL_EOF channel:0x23 frame:25301 vi_tstamp:49637235263 data:0x02ff0002
kworker/0:0-4 [000] … 1574.187555: rtcpu_vinotify_event: tstamp:49637489251 tag:ATOMP_FRAME_DONE channel:0x23 frame:25301 vi_tstamp:49637235285 data:0x00000000
kworker/0:0-4 [000] … 1574.187556: rtcpu_vinotify_event: tstamp:49637489394 tag:RESERVED_19 channel:0x23 frame:213 vi_tstamp:50793241920 data:0x0202000f
kworker/0:0-4 [000] … 1574.187557: rtcpu_vinotify_event: tstamp:49637489552 tag:CSIMUX_FRAME channel:0x00 frame:25301 vi_tstamp:49637238249 data:0x00000220
kworker/0:0-4 [000] … 1574.187558: rtcpu_vinotify_event: tstamp:49637489693 tag:ATOMP_FE channel:0x00 frame:25301 vi_tstamp:49637238251 data:0x00000000
kworker/0:0-4 [000] … 1574.187559: rtcpu_vinotify_event: tstamp:49637489850 tag:RESERVED_19 channel:0x23 frame:213 vi_tstamp:50793346176 data:0x0002000f
kworker/0:0-4 [000] … 1574.187561: rtcpu_vinotify_event: tstamp:49637489985 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50793360672 data:0x07020010
kworker/0:0-4 [000] … 1574.187562: rtcpu_vinotify_event: tstamp:49637490142 tag:FS channel:0x00 frame:25302 vi_tstamp:49637244065 data:0x00000010
kworker/0:0-4 [000] … 1574.187563: rtcpu_vinotify_event: tstamp:49637490282 tag:ATOMP_FS channel:0x00 frame:25302 vi_tstamp:49637244066 data:0x00000000
kworker/0:0-4 [000] … 1574.187564: rtcpu_vinotify_event: tstamp:49637490439 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50793536896 data:0x10000000
kworker/0:0-4 [000] … 1574.187565: rtcpu_vinotify_event: tstamp:49637490574 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50793557472 data:0x31000011
kworker/0:0-4 [000] … 1574.187566: rtcpu_vinotify_event: tstamp:49637490731 tag:CHANSEL_PXL_SOF channel:0x23 frame:25302 vi_tstamp:49637260222 data:0x00000001
kworker/0:0-4 [000] … 1574.187567: rtcpu_vinotify_event: tstamp:49637490867 tag:RESERVED_19 channel:0x23 frame:214 vi_tstamp:50794038080 data:0x08020010
kworker/0:0-4 [000] … 1574.243423: rtcpu_vinotify_event: tstamp:49637758250 tag:CHANSEL_PXL_EOF channel:0x23 frame:25302 vi_tstamp:49637756059 data:0x02ff0002
kworker/0:0-4 [000] … 1574.243428: rtcpu_vinotify_event: tstamp:49637758407 tag:ATOMP_FRAME_DONE channel:0x23 frame:25302 vi_tstamp:49637756082 data:0x00000000
kworker/0:0-4 [000] … 1574.243429: rtcpu_vinotify_error: tstamp:49637762546 tag:CSIMUX_FRAME channel:0x00 frame:25302 vi_tstamp:49637759045 data:0x00000220
kworker/0:0-4 [000] … 1574.243432: rtos_queue_send_from_isr_failed: tstamp:49637771641 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.243433: rtos_queue_send_from_isr_failed: tstamp:49637771794 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.243435: rtos_queue_send_from_isr_failed: tstamp:49637771947 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.243466: rtos_queue_send_from_isr_failed: tstamp:49637772095 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.243467: rtos_queue_send_from_isr_failed: tstamp:49637772240 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.243471: rtcpu_vinotify_event: tstamp:49638127816 tag:RESERVED_19 channel:0x23 frame:214 vi_tstamp:50809911520 data:0x02020010
kworker/0:0-4 [000] … 1574.243473: rtcpu_vinotify_event: tstamp:49638127957 tag:CSIMUX_FRAME channel:0x00 frame:25302 vi_tstamp:49637759045 data:0x00000220
kworker/0:0-4 [000] … 1574.243474: rtcpu_vinotify_event: tstamp:49638128122 tag:ATOMP_FE channel:0x00 frame:25302 vi_tstamp:49637759047 data:0x00000000
kworker/0:0-4 [000] … 1574.243475: rtcpu_vinotify_event: tstamp:49638128259 tag:RESERVED_19 channel:0x23 frame:214 vi_tstamp:50810011648 data:0x00020010
kworker/0:0-4 [000] … 1574.243476: rtcpu_vinotify_event: tstamp:49638128416 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50810026144 data:0x07020011
kworker/0:0-4 [000] … 1574.243477: rtcpu_vinotify_event: tstamp:49638128551 tag:FS channel:0x00 frame:25303 vi_tstamp:49637764861 data:0x00000010
kworker/0:0-4 [000] … 1574.243479: rtcpu_vinotify_event: tstamp:49638128708 tag:ATOMP_FS channel:0x00 frame:25303 vi_tstamp:49637764862 data:0x00000000
kworker/0:0-4 [000] … 1574.243480: rtcpu_vinotify_event: tstamp:49638128842 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50810207808 data:0x10000000
kworker/0:0-4 [000] … 1574.243481: rtcpu_vinotify_event: tstamp:49638129000 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50810230496 data:0x31000012
kworker/0:0-4 [000] … 1574.243482: rtcpu_vinotify_event: tstamp:49638129133 tag:CHANSEL_PXL_SOF channel:0x23 frame:25303 vi_tstamp:49637781019 data:0x00000001
kworker/0:0-4 [000] … 1574.243507: rtcpu_vinotify_event: tstamp:49638129290 tag:RESERVED_19 channel:0x23 frame:215 vi_tstamp:50810703616 data:0x08020011
kworker/0:0-4 [000] … 1574.243509: rtcpu_vinotify_error: tstamp:49638283511 tag:CSIMUX_FRAME channel:0x00 frame:25303 vi_tstamp:49638279842 data:0x00000220
kworker/0:0-4 [000] … 1574.243511: rtcpu_vinotify_event: tstamp:49638283962 tag:CHANSEL_PXL_EOF channel:0x23 frame:25303 vi_tstamp:49638276855 data:0x02ff0002
kworker/0:0-4 [000] … 1574.243512: rtcpu_vinotify_event: tstamp:49638284137 tag:ATOMP_FRAME_DONE channel:0x23 frame:25303 vi_tstamp:49638276878 data:0x00000000
kworker/0:0-4 [000] … 1574.243513: rtcpu_vinotify_event: tstamp:49638284273 tag:RESERVED_19 channel:0x23 frame:215 vi_tstamp:50826572864 data:0x02020011
kworker/0:0-4 [000] … 1574.243514: rtcpu_vinotify_event: tstamp:49638284430 tag:CSIMUX_FRAME channel:0x00 frame:25303 vi_tstamp:49638279842 data:0x00000220
kworker/0:0-4 [000] … 1574.243515: rtcpu_vinotify_event: tstamp:49638284570 tag:ATOMP_FE channel:0x00 frame:25303 vi_tstamp:49638279843 data:0x00000000
kworker/0:0-4 [000] … 1574.243517: rtos_queue_send_from_isr_failed: tstamp:49638293082 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.243518: rtos_queue_send_from_isr_failed: tstamp:49638293235 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.243519: rtos_queue_send_from_isr_failed: tstamp:49638293388 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.243520: rtos_queue_send_from_isr_failed: tstamp:49638293534 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.243521: rtos_queue_send_from_isr_failed: tstamp:49638293679 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.243524: rtcpu_vinotify_event: tstamp:49638653883 tag:RESERVED_19 channel:0x23 frame:215 vi_tstamp:50826681248 data:0x00020011
kworker/0:0-4 [000] … 1574.243525: rtcpu_vinotify_event: tstamp:49638654023 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50826696064 data:0x07020012
kworker/0:0-4 [000] … 1574.243526: rtcpu_vinotify_event: tstamp:49638654186 tag:FS channel:0x00 frame:25304 vi_tstamp:49638285656 data:0x00000010
kworker/0:0-4 [000] … 1574.243527: rtcpu_vinotify_event: tstamp:49638654329 tag:ATOMP_FS channel:0x00 frame:25304 vi_tstamp:49638285659 data:0x00000000
kworker/0:0-4 [000] … 1574.243529: rtcpu_vinotify_event: tstamp:49638654486 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50826898624 data:0x10000000
kworker/0:0-4 [000] … 1574.243530: rtcpu_vinotify_event: tstamp:49638654621 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50826921344 data:0x31000013
kworker/0:0-4 [000] … 1574.243531: rtcpu_vinotify_event: tstamp:49638654776 tag:CHANSEL_PXL_SOF channel:0x23 frame:25304 vi_tstamp:49638301815 data:0x00000001
kworker/0:0-4 [000] … 1574.243532: rtcpu_vinotify_event: tstamp:49638654911 tag:RESERVED_19 channel:0x23 frame:216 vi_tstamp:50827369056 data:0x08020012
kworker/0:0-4 [000] … 1574.243533: rtcpu_vinotify_error: tstamp:49638804176 tag:CSIMUX_FRAME channel:0x00 frame:25304 vi_tstamp:49638800637 data:0x00000220
kworker/0:0-4 [000] … 1574.243535: rtcpu_vinotify_event: tstamp:49638808468 tag:CHANSEL_PXL_EOF channel:0x23 frame:25304 vi_tstamp:49638797651 data:0x02ff0002
kworker/0:0-4 [000] … 1574.243536: rtcpu_vinotify_event: tstamp:49638808608 tag:ATOMP_FRAME_DONE channel:0x23 frame:25304 vi_tstamp:49638797674 data:0x00000000
kworker/0:0-4 [000] … 1574.243537: rtcpu_vinotify_event: tstamp:49638808768 tag:RESERVED_19 channel:0x23 frame:216 vi_tstamp:50843238368 data:0x02020012
kworker/0:0-4 [000] … 1574.243538: rtcpu_vinotify_event: tstamp:49638808905 tag:CSIMUX_FRAME channel:0x00 frame:25304 vi_tstamp:49638800637 data:0x00000220
kworker/0:0-4 [000] … 1574.243539: rtcpu_vinotify_event: tstamp:49638809062 tag:ATOMP_FE channel:0x00 frame:25304 vi_tstamp:49638800639 data:0x00000000
kworker/0:0-4 [000] … 1574.243540: rtcpu_vinotify_event: tstamp:49638809196 tag:RESERVED_19 channel:0x23 frame:216 vi_tstamp:50843342592 data:0x00020012
kworker/0:0-4 [000] … 1574.243542: rtcpu_vinotify_event: tstamp:49638809354 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50843357056 data:0x07020013
kworker/0:0-4 [000] … 1574.243544: rtcpu_vinotify_event: tstamp:49638809490 tag:FS channel:0x00 frame:25305 vi_tstamp:49638806452 data:0x00000010
kworker/0:0-4 [000] … 1574.243545: rtos_queue_send_from_isr_failed: tstamp:49638813407 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.243546: rtos_queue_send_from_isr_failed: tstamp:49638813560 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.243547: rtos_queue_send_from_isr_failed: tstamp:49638813712 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.243549: rtos_queue_send_from_isr_failed: tstamp:49638813858 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.243550: rtos_queue_send_from_isr_failed: tstamp:49638814005 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.243553: rtos_queue_peek_from_isr_failed: tstamp:49638928101 queue:0x0bcbcf78
kworker/0:0-4 [000] … 1574.243554: rtcpu_vinotify_event: tstamp:49639179359 tag:ATOMP_FS channel:0x00 frame:25305 vi_tstamp:49638806455 data:0x00000000
kworker/0:0-4 [000] … 1574.243555: rtcpu_vinotify_event: tstamp:49639179500 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50843563904 data:0x10000000
kworker/0:0-4 [000] … 1574.243556: rtcpu_vinotify_event: tstamp:49639179662 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50843595968 data:0x31000014
kworker/0:0-4 [000] … 1574.243557: rtcpu_vinotify_event: tstamp:49639179799 tag:CHANSEL_PXL_SOF channel:0x23 frame:25305 vi_tstamp:49638822611 data:0x00000001
kworker/0:0-4 [000] … 1574.243559: rtcpu_vinotify_event: tstamp:49639179958 tag:RESERVED_19 channel:0x23 frame:217 vi_tstamp:50844034528 data:0x08020013
kworker/0:0-4 [000] … 1574.299427: rtcpu_vinotify_error: tstamp:49639324972 tag:CSIMUX_FRAME channel:0x00 frame:25305 vi_tstamp:49639321434 data:0x00000220
kworker/0:0-4 [000] … 1574.299431: rtcpu_vinotify_event: tstamp:49639330438 tag:CHANSEL_PXL_EOF channel:0x23 frame:25305 vi_tstamp:49639318447 data:0x02ff0002
kworker/0:0-4 [000] … 1574.299433: rtcpu_vinotify_event: tstamp:49639330600 tag:ATOMP_FRAME_DONE channel:0x23 frame:25305 vi_tstamp:49639318470 data:0x00000000
kworker/0:0-4 [000] … 1574.299434: rtcpu_vinotify_event: tstamp:49639330739 tag:RESERVED_19 channel:0x23 frame:217 vi_tstamp:50859903776 data:0x02020013
kworker/0:0-4 [000] … 1574.299435: rtcpu_vinotify_event: tstamp:49639330914 tag:CSIMUX_FRAME channel:0x00 frame:25305 vi_tstamp:49639321434 data:0x00000220
kworker/0:0-4 [000] … 1574.299437: rtcpu_vinotify_event: tstamp:49639331056 tag:ATOMP_FE channel:0x00 frame:25305 vi_tstamp:49639321435 data:0x00000000
kworker/0:0-4 [000] … 1574.299438: rtcpu_vinotify_event: tstamp:49639331213 tag:RESERVED_19 channel:0x23 frame:217 vi_tstamp:50860008096 data:0x00020013
kworker/0:0-4 [000] … 1574.299439: rtcpu_vinotify_event: tstamp:49639331349 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50860022528 data:0x07020014
kworker/0:0-4 [000] … 1574.299440: rtcpu_vinotify_event: tstamp:49639331506 tag:FS channel:0x00 frame:25306 vi_tstamp:49639327249 data:0x00000010
kworker/0:0-4 [000] … 1574.299441: rtcpu_vinotify_event: tstamp:49639331644 tag:ATOMP_FS channel:0x00 frame:25306 vi_tstamp:49639327251 data:0x00000000
kworker/0:0-4 [000] … 1574.299442: rtcpu_vinotify_event: tstamp:49639331801 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50860200480 data:0x10000000
kworker/0:0-4 [000] … 1574.299443: rtcpu_vinotify_event: tstamp:49639331938 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50860226336 data:0x31000015
kworker/0:0-4 [000] … 1574.299446: rtos_queue_send_from_isr_failed: tstamp:49639333930 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.299447: rtos_queue_send_from_isr_failed: tstamp:49639334083 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.299448: rtos_queue_send_from_isr_failed: tstamp:49639334233 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.299450: rtos_queue_send_from_isr_failed: tstamp:49639334381 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.299451: rtos_queue_send_from_isr_failed: tstamp:49639334526 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.299455: rtcpu_vinotify_event: tstamp:49639705461 tag:CHANSEL_PXL_SOF channel:0x23 frame:25306 vi_tstamp:49639343407 data:0x00000001
kworker/0:0-4 [000] … 1574.299481: rtcpu_vinotify_event: tstamp:49639705604 tag:RESERVED_19 channel:0x23 frame:218 vi_tstamp:50860699968 data:0x08020014
kworker/0:0-4 [000] … 1574.299482: rtcpu_vinotify_error: tstamp:49639845739 tag:CSIMUX_FRAME channel:0x00 frame:25306 vi_tstamp:49639842230 data:0x00000220
kworker/0:0-4 [000] … 1574.299484: rtos_queue_send_from_isr_failed: tstamp:49639854797 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.299485: rtos_queue_send_from_isr_failed: tstamp:49639854967 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.299486: rtos_queue_send_from_isr_failed: tstamp:49639855120 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.299487: rtos_queue_send_from_isr_failed: tstamp:49639855267 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.299488: rtos_queue_send_from_isr_failed: tstamp:49639855413 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.299490: rtcpu_vinotify_event: tstamp:49640081208 tag:CHANSEL_PXL_EOF channel:0x23 frame:25306 vi_tstamp:49639839244 data:0x02ff0002
kworker/0:0-4 [000] … 1574.299491: rtcpu_vinotify_event: tstamp:49640081349 tag:ATOMP_FRAME_DONE channel:0x23 frame:25306 vi_tstamp:49639839266 data:0x00000000
kworker/0:0-4 [000] … 1574.299492: rtcpu_vinotify_event: tstamp:49640081513 tag:RESERVED_19 channel:0x23 frame:218 vi_tstamp:50876569312 data:0x02020014
kworker/0:0-4 [000] … 1574.299493: rtcpu_vinotify_event: tstamp:49640081650 tag:CSIMUX_FRAME channel:0x00 frame:25306 vi_tstamp:49639842230 data:0x00000220
kworker/0:0-4 [000] … 1574.299495: rtcpu_vinotify_event: tstamp:49640081812 tag:ATOMP_FE channel:0x00 frame:25306 vi_tstamp:49639842231 data:0x00000000
kworker/0:0-4 [000] … 1574.299496: rtcpu_vinotify_event: tstamp:49640081947 tag:RESERVED_19 channel:0x23 frame:218 vi_tstamp:50876673536 data:0x00020014
kworker/0:0-4 [000] … 1574.299497: rtcpu_vinotify_event: tstamp:49640082104 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50876688000 data:0x07020015
kworker/0:0-4 [000] … 1574.299498: rtcpu_vinotify_event: tstamp:49640082240 tag:FS channel:0x00 frame:25307 vi_tstamp:49639848045 data:0x00000010
kworker/0:0-4 [000] … 1574.299499: rtcpu_vinotify_event: tstamp:49640082397 tag:ATOMP_FS channel:0x00 frame:25307 vi_tstamp:49639848047 data:0x00000000
kworker/0:0-4 [000] … 1574.299500: rtcpu_vinotify_event: tstamp:49640082546 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50876872768 data:0x10000000
kworker/0:0-4 [000] … 1574.299502: rtcpu_vinotify_event: tstamp:49640082703 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50876895456 data:0x31000016
kworker/0:0-4 [000] … 1574.299503: rtcpu_vinotify_event: tstamp:49640082837 tag:CHANSEL_PXL_SOF channel:0x23 frame:25307 vi_tstamp:49639864203 data:0x00000001
kworker/0:0-4 [000] … 1574.299504: rtcpu_vinotify_event: tstamp:49640082995 tag:RESERVED_19 channel:0x23 frame:219 vi_tstamp:50877365472 data:0x08020015
kworker/0:0-4 [000] … 1574.299505: rtcpu_vinotify_event: tstamp:49640362238 tag:CHANSEL_PXL_EOF channel:0x23 frame:25307 vi_tstamp:49640360040 data:0x02ff0002
kworker/0:0-4 [000] … 1574.299506: rtcpu_vinotify_error: tstamp:49640366567 tag:CSIMUX_FRAME channel:0x00 frame:25307 vi_tstamp:49640363026 data:0x00000220
kworker/0:0-4 [000] … 1574.299507: rtos_queue_send_from_isr_failed: tstamp:49640375754 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.299508: rtos_queue_send_from_isr_failed: tstamp:49640375924 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.299510: rtos_queue_send_from_isr_failed: tstamp:49640376076 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.299511: rtos_queue_send_from_isr_failed: tstamp:49640376222 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.299512: rtos_queue_send_from_isr_failed: tstamp:49640376368 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.299513: rtcpu_vinotify_event: tstamp:49640719355 tag:ATOMP_FRAME_DONE channel:0x23 frame:25307 vi_tstamp:49640360062 data:0x00000000
kworker/0:0-4 [000] … 1574.299515: rtcpu_vinotify_event: tstamp:49640719495 tag:RESERVED_19 channel:0x23 frame:219 vi_tstamp:50893238912 data:0x02020015
kworker/0:0-4 [000] … 1574.299516: rtcpu_vinotify_event: tstamp:49640719658 tag:CSIMUX_FRAME channel:0x00 frame:25307 vi_tstamp:49640363026 data:0x00000220
kworker/0:0-4 [000] … 1574.299517: rtcpu_vinotify_event: tstamp:49640719804 tag:ATOMP_FE channel:0x00 frame:25307 vi_tstamp:49640363028 data:0x00000000
kworker/0:0-4 [000] … 1574.299518: rtcpu_vinotify_event: tstamp:49640719963 tag:RESERVED_19 channel:0x23 frame:219 vi_tstamp:50893339008 data:0x00020015
kworker/0:0-4 [000] … 1574.299519: rtcpu_vinotify_event: tstamp:49640720099 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50893353536 data:0x07020016
kworker/0:0-4 [000] … 1574.299520: rtcpu_vinotify_event: tstamp:49640720256 tag:FS channel:0x00 frame:25308 vi_tstamp:49640368841 data:0x00000010
kworker/0:0-4 [000] … 1574.299522: rtcpu_vinotify_event: tstamp:49640720398 tag:ATOMP_FS channel:0x00 frame:25308 vi_tstamp:49640368843 data:0x00000000
kworker/0:0-4 [000] … 1574.299546: rtcpu_vinotify_event: tstamp:49640720557 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50893528384 data:0x10000000
kworker/0:0-4 [000] … 1574.299547: rtcpu_vinotify_event: tstamp:49640720690 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50893551040 data:0x31000017
kworker/0:0-4 [000] … 1574.299548: rtcpu_vinotify_event: tstamp:49640720846 tag:CHANSEL_PXL_SOF channel:0x23 frame:25308 vi_tstamp:49640384999 data:0x00000001
kworker/0:0-4 [000] … 1574.299549: rtcpu_vinotify_event: tstamp:49640720981 tag:RESERVED_19 channel:0x23 frame:220 vi_tstamp:50894030976 data:0x08020016
kworker/0:0-4 [000] … 1574.299550: rtcpu_vinotify_error: tstamp:49640887537 tag:CSIMUX_FRAME channel:0x00 frame:25308 vi_tstamp:49640883822 data:0x00000220
kworker/0:0-4 [000] … 1574.299551: rtcpu_vinotify_event: tstamp:49640887966 tag:CHANSEL_PXL_EOF channel:0x23 frame:25308 vi_tstamp:49640880836 data:0x02ff0002
kworker/0:0-4 [000] … 1574.299553: rtcpu_vinotify_event: tstamp:49640888104 tag:ATOMP_FRAME_DONE channel:0x23 frame:25308 vi_tstamp:49640880858 data:0x00000000
kworker/0:0-4 [000] … 1574.299554: rtcpu_vinotify_event: tstamp:49640888262 tag:RESERVED_19 channel:0x23 frame:220 vi_tstamp:50909900256 data:0x02020016
kworker/0:0-4 [000] … 1574.299555: rtcpu_vinotify_event: tstamp:49640888396 tag:CSIMUX_FRAME channel:0x00 frame:25308 vi_tstamp:49640883822 data:0x00000220
kworker/0:0-4 [000] … 1574.299556: rtos_queue_send_from_isr_failed: tstamp:49640898790 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.299557: rtos_queue_send_from_isr_failed: tstamp:49640898943 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.299558: rtos_queue_send_from_isr_failed: tstamp:49640899096 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.299559: rtos_queue_send_from_isr_failed: tstamp:49640899241 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.299560: rtos_queue_send_from_isr_failed: tstamp:49640899386 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.355421: rtcpu_vinotify_event: tstamp:49641245389 tag:ATOMP_FE channel:0x00 frame:25308 vi_tstamp:49640883824 data:0x00000000
kworker/0:0-4 [000] … 1574.355425: rtcpu_vinotify_event: tstamp:49641245531 tag:RESERVED_19 channel:0x23 frame:220 vi_tstamp:50910008576 data:0x00020016
kworker/0:0-4 [000] … 1574.355426: rtcpu_vinotify_event: tstamp:49641245696 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50910023360 data:0x07020017
kworker/0:0-4 [000] … 1574.355428: rtcpu_vinotify_event: tstamp:49641245835 tag:FS channel:0x00 frame:25309 vi_tstamp:49640889637 data:0x00000010
kworker/0:0-4 [000] … 1574.355429: rtcpu_vinotify_event: tstamp:49641245995 tag:ATOMP_FS channel:0x00 frame:25309 vi_tstamp:49640889638 data:0x00000000
kworker/0:0-4 [000] … 1574.355430: rtcpu_vinotify_event: tstamp:49641246130 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50910219232 data:0x10000000
kworker/0:0-4 [000] … 1574.355431: rtcpu_vinotify_event: tstamp:49641246287 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50910241920 data:0x31000018
kworker/0:0-4 [000] … 1574.355432: rtcpu_vinotify_event: tstamp:49641246421 tag:CHANSEL_PXL_SOF channel:0x23 frame:25309 vi_tstamp:49640905795 data:0x00000001
kworker/0:0-4 [000] … 1574.355433: rtcpu_vinotify_event: tstamp:49641246579 tag:RESERVED_19 channel:0x23 frame:221 vi_tstamp:50910696416 data:0x08020017
kworker/0:0-4 [000] … 1574.355435: rtcpu_vinotify_error: tstamp:49641408287 tag:CSIMUX_FRAME channel:0x00 frame:25309 vi_tstamp:49641404618 data:0x00000220
kworker/0:0-4 [000] … 1574.355436: rtcpu_vinotify_event: tstamp:49641408739 tag:CHANSEL_PXL_EOF channel:0x23 frame:25309 vi_tstamp:49641401631 data:0x02ff0002
kworker/0:0-4 [000] … 1574.355437: rtcpu_vinotify_event: tstamp:49641408903 tag:ATOMP_FRAME_DONE channel:0x23 frame:25309 vi_tstamp:49641401654 data:0x00000000
kworker/0:0-4 [000] … 1574.355439: rtcpu_vinotify_event: tstamp:49641409040 tag:RESERVED_19 channel:0x23 frame:221 vi_tstamp:50926565728 data:0x02020017
kworker/0:0-4 [000] … 1574.355440: rtcpu_vinotify_event: tstamp:49641409196 tag:CSIMUX_FRAME channel:0x00 frame:25309 vi_tstamp:49641404618 data:0x00000220
kworker/0:0-4 [000] … 1574.355441: rtcpu_vinotify_event: tstamp:49641409337 tag:ATOMP_FE channel:0x00 frame:25309 vi_tstamp:49641404620 data:0x00000000
kworker/0:0-4 [000] … 1574.355442: rtcpu_vinotify_event: tstamp:49641409493 tag:RESERVED_19 channel:0x23 frame:221 vi_tstamp:50926669984 data:0x00020017
kworker/0:0-4 [000] … 1574.355443: rtcpu_vinotify_event: tstamp:49641409629 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50926684448 data:0x07020018
kworker/0:0-4 [000] … 1574.355471: rtos_queue_send_from_isr_failed: tstamp:49641418218 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.355473: rtos_queue_send_from_isr_failed: tstamp:49641418371 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.355474: rtos_queue_send_from_isr_failed: tstamp:49641418525 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.355475: rtos_queue_send_from_isr_failed: tstamp:49641418673 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.355476: rtos_queue_send_from_isr_failed: tstamp:49641418818 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.355480: rtcpu_vinotify_event: tstamp:49641771409 tag:FS channel:0x00 frame:25310 vi_tstamp:49641410434 data:0x00000010
kworker/0:0-4 [000] … 1574.355482: rtcpu_vinotify_event: tstamp:49641771554 tag:ATOMP_FS channel:0x00 frame:25310 vi_tstamp:49641410435 data:0x00000000
kworker/0:0-4 [000] … 1574.355483: rtcpu_vinotify_event: tstamp:49641771718 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50926891456 data:0x10000000
kworker/0:0-4 [000] … 1574.355485: rtcpu_vinotify_event: tstamp:49641771856 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50926915104 data:0x31000019
kworker/0:0-4 [000] … 1574.355486: rtcpu_vinotify_event: tstamp:49641772015 tag:CHANSEL_PXL_SOF channel:0x23 frame:25310 vi_tstamp:49641426592 data:0x00000001
kworker/0:0-4 [000] … 1574.355487: rtcpu_vinotify_event: tstamp:49641772152 tag:RESERVED_19 channel:0x23 frame:222 vi_tstamp:50927361888 data:0x08020018
kworker/0:0-4 [000] … 1574.355514: rtcpu_vinotify_error: tstamp:49641928922 tag:CSIMUX_FRAME channel:0x00 frame:25310 vi_tstamp:49641925414 data:0x00000220
kworker/0:0-4 [000] … 1574.355515: rtcpu_vinotify_event: tstamp:49641933485 tag:CHANSEL_PXL_EOF channel:0x23 frame:25310 vi_tstamp:49641922428 data:0x02ff0002
kworker/0:0-4 [000] … 1574.355516: rtcpu_vinotify_event: tstamp:49641933625 tag:ATOMP_FRAME_DONE channel:0x23 frame:25310 vi_tstamp:49641922451 data:0x00000000
kworker/0:0-4 [000] … 1574.355517: rtcpu_vinotify_event: tstamp:49641933783 tag:RESERVED_19 channel:0x23 frame:222 vi_tstamp:50943231200 data:0x02020018
kworker/0:0-4 [000] … 1574.355518: rtcpu_vinotify_event: tstamp:49641933921 tag:CSIMUX_FRAME channel:0x00 frame:25310 vi_tstamp:49641925414 data:0x00000220
kworker/0:0-4 [000] … 1574.355520: rtcpu_vinotify_event: tstamp:49641934080 tag:ATOMP_FE channel:0x00 frame:25310 vi_tstamp:49641925416 data:0x00000000
kworker/0:0-4 [000] … 1574.355521: rtcpu_vinotify_event: tstamp:49641934215 tag:RESERVED_19 channel:0x23 frame:222 vi_tstamp:50943335424 data:0x00020018
kworker/0:0-4 [000] … 1574.355522: rtcpu_vinotify_event: tstamp:49641934372 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:50943349888 data:0x07020019
kworker/0:0-4 [000] … 1574.355523: rtcpu_vinotify_event: tstamp:49641934508 tag:FS channel:0x00 frame:25311 vi_tstamp:49641931229 data:0x00000010
kworker/0:0-4 [000] … 1574.355524: rtcpu_vinotify_event: tstamp:49641934664 tag:ATOMP_FS channel:0x00 frame:25311 vi_tstamp:49641931231 data:0x00000000
kworker/0:0-4 [000] … 1574.355525: rtcpu_vinotify_event: tstamp:49641934800 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50943521664 data:0x10000000
kworker/0:0-4 [000] … 1574.355527: rtos_queue_send_from_isr_failed: tstamp:49641937637 queue:0x0bcb41f8
kworker/0:0-4 [000] … 1574.355528: rtos_queue_send_from_isr_failed: tstamp:49641937789 queue:0x0bcb8a60
kworker/0:0-4 [000] … 1574.355529: rtos_queue_send_from_isr_failed: tstamp:49641937940 queue:0x0bcba5e0
kworker/0:0-4 [000] … 1574.355530: rtos_queue_send_from_isr_failed: tstamp:49641938088 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 1574.355531: rtos_queue_send_from_isr_failed: tstamp:49641938233 queue:0x0bcbc160
kworker/0:0-4 [000] … 1574.355533: rtcpu_vinotify_event: tstamp:49642296920 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:50943606048 data:0x3100001a
kworker/0:0-4 [000] … 1574.355534: rtcpu_vinotify_event: tstamp:49642297060 tag:CHANSEL_PXL_SOF channel:0x23 frame:25311 vi_tstamp:49641947387 data:0x00000001
kworker/0:0-4 [000] … 1574.355535: rtcpu_vinotify_event: tstamp:49642297221 tag:RESERVED_19 channel:0x23 frame:223 vi_tstamp:50944027392 data:0x08020019
The log show the FE_FRAME_ID_FAULT of CSIMUX_FRAME, Frame ID of FE packet mismatches ID of FS packet.
Thank you.
Can give me some advices.
Should i change my driver?Or other adjustment。
But I use this driver success run in jetson nano.
I think the jetson Nano didn’t check the frame ID however the TX2/Xavier/NX these chips are check the frame ID.
You may consult with vendor to have the frame ID of the FE package to match the frame ID of the FS package.
Thank you for help.
I have solved this problem.
I shield the frame ID check.Because of my lt9211limited.
Could you share your lt6911 driver for Jetson Nano please ?
I have been looking for it for weeks and weeks but it seems completely inaccessible on the Internet !
