L4T 32.6.1
Jetpack 4.6.1
Jetson NX SOM with our customization carrier board
Connect DELL 27# monitor S2721QS , no display after boot logo
SSH into system
user@linux:~$ xrandr --verbose
Screen 0: minimum 8 x 8, current 3840 x 2160, maximum 32767 x 32767
HDMI-0 connected primary 3840x2160+0+0 (0x145) normal (normal left inverted right x axis y axis) 600mm x 340mm
Identifier: 0x144
Timestamp: 7231
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
00ffffffffffff0010ac97a14c554f30
211e0103803c2278ea5095a8544ea526
0f5054a54b00714f8180a9c0a940d1c0
e1000101010108e80030f2705a80b058
8a0055502100001e000000ff00364d44
393531330a2020202020000000fc0044
454c4c20533237323151530a000000fd
00283c82893c000a20202020202001b8
020345f1546101020304050607101112
1415161f20215d5e5f23090707830100
006d030c002000384420006003020167
d85dc401788001e40f010000681a0000
0101283ce6565e00a0a0a02950302035
0055502100001a000000000000000000
00000000000000000000000000000000
0000000000000000000000000000001e
TegraOverlayBlendmode: Opaque
supported: Opaque, SourceAlphaBlend, PremultSourceAlphaBlend
TegraOverlayPriority: 255
range: (0, 255)
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorType: HDMI
3840x2160 (0x14e) 594.177MHz +HSync +VSync +preferred
h: width 3840 start 4016 end 4104 total 4400 skew 0 clock 135.04KHz
v: height 2160 start 2168 end 2178 total 2250 clock 60.02Hz
3840x2160 (0x14f) 593.824MHz +HSync +VSync
h: width 3840 start 4016 end 4104 total 4400 skew 0 clock 134.96KHz
v: height 2160 start 2168 end 2178 total 2250 clock 59.98Hz
3840x2160 (0x145) 297.000MHz +HSync +VSync *current
h: width 3840 start 4016 end 4104 total 4400 skew 0 clock 67.50KHz
v: height 2160 start 2168 end 2178 total 2250 clock 30.00Hz
3840x2160 (0x151) 296.735MHz +HSync +VSync
h: width 3840 start 4016 end 4104 total 4400 skew 0 clock 67.44KHz
v: height 2160 start 2168 end 2178 total 2250 clock 29.97Hz
3840x2160 (0x152) 297.000MHz +HSync +VSync
h: width 3840 start 4896 end 4984 total 5280 skew 0 clock 56.25KHz
v: height 2160 start 2168 end 2178 total 2250 clock 25.00Hz
3840x2160 (0x153) 297.000MHz +HSync +VSync
h: width 3840 start 5116 end 5204 total 5500 skew 0 clock 54.00KHz
v: height 2160 start 2168 end 2178 total 2250 clock 24.00Hz
3840x2160 (0x154) 296.735MHz +HSync +VSync
h: width 3840 start 5116 end 5204 total 5500 skew 0 clock 53.95KHz
v: height 2160 start 2168 end 2178 total 2250 clock 23.98Hz
2560x1440 (0x18d) 241.545MHz +HSync -VSync
h: width 2560 start 2608 end 2640 total 2720 skew 0 clock 88.80KHz
v: height 1440 start 1443 end 1448 total 1481 clock 59.96Hz
2048x1280 (0x18e) 220.653MHz -HSync -VSync
h: width 2048 start 2190 end 2412 total 2776 skew 0 clock 79.49KHz
v: height 1280 start 1281 end 1284 total 1325 clock 59.99Hz
1920x1080 (0x155) 148.500MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x156) 148.367MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.44KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.95Hz
1920x1080 (0x157) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1920x1080 (0x15a) 74.250MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 28.12KHz
v: height 1080 start 1084 end 1089 total 1125 clock 25.00Hz
1920x1080 (0x15b) 74.250MHz +HSync +VSync
h: width 1920 start 2558 end 2602 total 2750 skew 0 clock 27.00KHz
v: height 1080 start 1084 end 1089 total 1125 clock 24.00Hz
1920x1080 (0x15c) 74.178MHz +HSync +VSync
h: width 1920 start 2558 end 2602 total 2750 skew 0 clock 26.97KHz
v: height 1080 start 1084 end 1089 total 1125 clock 23.98Hz
1600x1200 (0x18f) 162.022MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 75.01KHz
v: height 1200 start 1201 end 1204 total 1250 clock 60.01Hz
1600x900 (0x190) 108.003MHz +HSync +VSync
h: width 1600 start 1624 end 1704 total 1800 skew 0 clock 60.00KHz
v: height 900 start 901 end 904 total 1000 clock 60.00Hz
1280x1024 (0x191) 135.007MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.03Hz
1280x1024 (0x15d) 107.968MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.96KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.00Hz
1280x720 (0x15f) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x160) 74.178MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1152x864 (0x192) 108.003MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1024x768 (0x193) 78.752MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x162) 65.002MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.01Hz
800x600 (0x194) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x163) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
720x576 (0x164) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x480 (0x165) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
720x400 (0x195) 26.171MHz -HSync -VSync
h: width 720 start 737 end 808 total 896 skew 0 clock 29.21KHz
v: height 400 start 401 end 404 total 417 clock 70.04Hz
640x480 (0x196) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x166) 25.174MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
DP-0 disconnected (normal left inverted right x axis y axis)
Identifier: 0x167
Timestamp: 7231
Subpixel: unknown
Clones:
CRTCs: 1
filter:
range: (0, 255)
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: DisplayPort
supported: DisplayPort
ConnectorType: DisplayPort
user@linux:~$ xrandr --output HDMI-0 --mode 1920x1080 --rate 60.00
can display
user@linux:~$ xrandr --output HDMI-0 --mode 3840x2160 --rate 30.00
can display
user@linux:~$ xrandr --output HDMI-0 --mode 3840x2160 --rate 59.98
cannot display
user@linux:~$ xrandr --output HDMI-0 --mode 3840x2160 --rate 60.02
cannot display
we check the mode, this two-mode line seems not to conform with the CEA-861G (should be 594MHZ instead of 594.177, or 593.824)
, could you help explain fundamental why the NVIDIA Jeston display driver can not
the output that timming?
