I’m currently using the jetson nano develop kit and I’m trying to set up HDMI as DP.
(tegra-p3448-0000-p3449-0000-b00.dtb)
What I modified was after uploading the image in the tutorial to SDCARD, I changed boot/dtb to dts.
In the source, sor1 was changed to the following and connected to FDT boot/dtb/new.dtb.
I confirmed that it is set to DP-0 and DP-1 in xrandr, and now when I connect the DP port to another carrier board, there is no output. Can you tell me what part I am missing?
sor1 {
compatible = “nvidia,tegra210-sor1”;
reg = <0x0 0x54580000 0x0 0x40000>;
reg-names = “sor”;
interrupts = <0x0 0x4c 0x4>;
status = “okay”;
nvidia,sor-ctrlnum = <0x1>;
nvidia,dpaux = <0x75>;
nvidia,xbar-ctrl = <0x0 0x1 0x2 0x3 0x4>;
clocks = <0x26 0x16f 0x26 0xde 0x26 0x16e 0x26 0xb7 0x26 0x12f 0x26 0xf3 0x26 0xca 0x26 0x7d 0x26 0x6f 0x26 0x80>;
clock-names = “sor1_ref”, “sor_safe”, “sor1_pad_clkout”, “sor1”, “pll_dp”, “pll_p”, “maud”, “hda”, “hda2codec_2x”, “hda2hdmi”;
resets = <0x26 0xb7 0x26 0x7d 0x26 0x6f 0x26 0x80>;
reset-names = “sor1”, “hda_rst”, “hda2codec_2x_rst”, “hda2hdmi_rst”;
nvidia,ddc-i2c-bus = <0x76>;
nvidia,hpd-gpio = <0x5b 0xe1 0x1>;
nvidia,active-panel = <0x77>;
nvidia,sor1-output-type = “dp”;
linux,phandle = <0x6a>;
phandle = <0x6a>;
hdmi-display {
compatible = "hdmi,display";
status = "disabled";
generic-infoframe-type = <0x87>;
linux,phandle = <0x104>;
phandle = <0x104>;
disp-default-out {
nvidia,out-xres = <0x1000>;
nvidia,out-yres = <0x870>;
nvidia,out-type = <0x1>;
nvidia,out-flags = <0x2>;
nvidia,out-parent-clk = "pll_d2";
nvidia,out-align = <0x0>;
nvidia,out-order = <0x0>;
dp-display {
compatible = "dp, display";
status = "okay";
nvidia,is_ext_dp_panel = <0x1>;
linux,phandle = <0x77>;
phandle = <0x77>;
disp-default-out {
nvidia,out-type = <0x3>;
nvidia,out-flags = <0x0>;
nvidia,out-pins = <0x1 0x0 0x2 0x0 0x3 0x0 0x0 0x1>;
nvidia,out-parent-clk = "pll_d2_out0";
dp-lt-settings {
lt-setting@0 {
nvidia,drive-current = <0x0 0x0 0x0 0x0>;
nvidia,lane-preemphasis = <0x0 0x0 0x0 0x0>;
nvidia,post-cursor = <0x0 0x0 0x0 0x0>;
nvidia,tx-pu = <0x0>;
nvidia,load-adj = <0x3>;
lt-setting@1 {
nvidia,load-adj = <0x4>;
lt-setting@2 {
nvidia,lane-preemphasis = <0x1 0x1 0x1 0x1>;
nvidia,load-adj = <0x6>;
prod-settings {
#prod-cells = <0x3>;
prod_list_hdmi_soc = "prod_c_hdmi_0m_54m", "prod_c_hdmi_54m_111m", "prod_c_hdmi_111m_223m", "prod_c_hdmi_223m_300m", "prod_c_hdmi_300m_600m";
prod_list_hdmi_board = "prod_c_hdmi_0m_54m", "prod_c_hdmi_54m_75m", "prod_c_hdmi_75m_150m", "prod_c_hdmi_150m_300m", "prod_c_hdmi_300m_600m";
prod {
prod = <0x3a0 0x1 0x1 0x5c 0xf000700 0x1000000 0x60 0xf01f00 0x300f80 0x68 0xf000000 0xe000000 0x138 0xffffffff 0x3c3c3c3c 0x148 0xffffffff 0x0 0x170 0x40ff00 0x401000>;
prod_c_hdmi_0m_54m {
prod = <0x3a0 0x2 0x2 0x5c 0xf000700 0x5000310 0x60 0xf01f00 0x1100 0x68 0xf000000 0x8000000 0x138 0xffffffff 0x2d2f2f2f 0x148 0xffffffff 0x0 0x170 0xf040ff00 0x80406600>;
prod_c_hdmi_54m_111m {
prod = <0x3a0 0x2 0x2 0x5c 0xf000700 0x1000100 0x60 0xf01f00 0x401380 0x68 0xf000000 0x8000000 0x138 0xffffffff 0x333a3a3a 0x148 0xffffffff 0x0 0x170 0x40ff00 0x404000>;
prod_c_hdmi_111m_223m {
prod = <0x3a0 0x2 0x0 0x5c 0xf000700 0x1000300 0x60 0xff0fe0ff 0x401380 0x68 0xf000000 0x8000000 0x138 0xffffffff 0x333a3a3a 0x148 0xffffffff 0x0 0x170 0x40ff00 0x406600>;
prod_c_hdmi_223m_300m {
prod = <0x3a0 0x2 0x0 0x5c 0xf000700 0x1000300 0x60 0xf01f00 0x401380 0x68 0xf000000 0xa000000 0x138 0xffffffff 0x333f3f3f 0x148 0xffffffff 0x171717 0x170 0x40ff00 0x406600>;
prod_c_hdmi_300m_600m {
prod = <0x3a0 0x2 0x2 0x5c 0xf000700 0x5000310 0x60 0xf01f00 0x300f00 0x68 0xf000000 0x8000000 0x138 0xffffffff 0x30353537 0x148 0xffffffff 0x0 0x170 0x40ff00 0x406000>;
prod_c_54M {
prod = <0x3a0 0x2 0x2 0x5c 0xf000700 0x1000000 0x60 0xf01f00 0x401380 0x68 0xf000000 0x8000000 0x138 0xffffffff 0x333a3a3a 0x148 0xffffffff 0x0 0x170 0x40ff00 0x401000>;
prod_c_75M {
prod_c_150M {
prod_c_300M {
prod_c_600M {
prod = <0x3a0 0x2 0x2 0x5c 0xf000700 0x1000300 0x60 0xf01f00 0x401380 0x68 0xf000000 0x8000000 0x138 0xffffffff 0x333f3f3f 0x148 0xffffffff 0x0 0x170 0x40ff00 0x406600>;
prod_c_dp {
prod = <0x5c 0xf000f10 0x1000310 0x60 0x3f00100 0x400100 0x68 0x2000 0x2000 0x70 0xffffffff 0x0 0x180 0x1 0x1>;
prod_c_hdmi_54m_75m {
prod = <0x3a0 0x2 0x2 0x5c 0xf000700 0x5000310 0x60 0xf01f00 0x301500 0x68 0xf000000 0x8000000 0x138 0xffffffff 0x2d303030 0x148 0xffffffff 0x0 0x170 0xf040ff00 0x80406600>;
prod_c_hdmi_75m_150m {
prod = <0x3a0 0x2 0x0 0x5c 0xf000700 0x1000300 0x60 0xf01f00 0x309300 0x68 0xf000000 0x8000000 0x138 0xffffffff 0x2d303030 0x148 0xffffffff 0x0 0x170 0xf040ff00 0x80406600>;
prod_c_hdmi_150m_300m {
prod = <0x3a0 0x2 0x0 0x5c 0xf000700 0x1000300 0x60 0xf01f00 0x309300 0x68 0xf000000 0x8000000 0x138 0xffffffff 0x2d303430 0x148 0xffffffff 0x0 0x170 0xf040ff00 0x80406600>;
