Please provide the following info (tick the boxes after creating this topic): Software Version
[*] DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
[*] 1.9.1.10844
other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
Hello
After flashing ORIN with SDKManager, I can’t see GUI on display(My device is p3710 )
I tried follow jobs
Check display cable and monitor : my cables and monitor are working well on my PC.
Re-flashing SDK with SDKManager : I tried re-flashing 3 times include remove my download SDK files.
remove gdm and re-install gdm.
and “service gdm3 status” returned
nvidia@tegra-ubuntu:~$ sudo service gdm status
[sudo] password for nvidia:
● gdm.service - GNOME Display Manager
Loaded: loaded (/lib/systemd/system/gdm.service; static; vendor preset: enabled)
Active: active (running) since Fri 2022-10-21 03:08:59 UTC; 2 months 29 days ago
Main PID: 2110 (gdm3)
Tasks: 3 (limit: 33726)
Memory: 5.2M
CGroup: /system.slice/gdm.service
└─2110 /usr/sbin/gdm3
Oct 21 03:08:49 tegra-ubuntu systemd[1]: Starting GNOME Display Manager...
Oct 21 03:08:59 tegra-ubuntu systemd[1]: Started GNOME Display Manager.
Oct 21 03:08:59 tegra-ubuntu gdm-launch-environment][2114]: pam_unix(gdm-launch-environment:session): session opened for user gdm by (uid=0)
Oct 21 03:08:59 tegra-ubuntu gdm-launch-environment][2114]: pam_unix(gdm-launch-environment:session): session closed for user gdm
Oct 21 03:08:59 tegra-ubuntu gdm3[2110]: GdmDisplay: Session never registered, failing
Oct 21 03:08:59 tegra-ubuntu gdm-launch-environment][2220]: pam_unix(gdm-launch-environment:session): session opened for user gdm by (uid=0)
and the demsg printed out following Xorg error log
Cables
3.1 DP out - HDMI in Cable
3.2 DP out - mini HDMI in Cable
as a result with 1.1 ORIN case, ONLY 2.4-3.2 combination is WORKING.
And with 1.2 Desktop PC case, whole combinations are WORKING WELL. It means other monitors and cables have no problem.
But in 1.1 + 2.4 + 3.2 case, Xorg fail problem is also happend but display is working.
Also service gdm status command show some problem, but anyway it works…
Active: active (running) since Fri 2023-01-27 04:25:31 UTC; 15min ago
Process: 1583 ExecStartPre=/usr/share/gdm/generate-config (code=exited, status=0/SUCCESS)
Process: 1589 ExecStartPre=/usr/lib/gdm3/gdm-wait-for-drm (code=exited, status=0/SUCCESS)
Main PID: 1645 (gdm3)
Memory: 5.7M
└─1645 /usr/sbin/gdm3
Jan 27 04:25:20 tegra-ubuntu systemd[1]: Starting GNOME Display Manager...
Jan 27 04:25:31 tegra-ubuntu systemd[1]: Started GNOME Display Manager.
Jan 27 04:25:31 tegra-ubuntu gdm-autologin][1649]: PAM unable to dlopen(pam_gnome_keyring.so): /lib/security/pam_gnome_keyring.so: cannot open shared object file: No such file or directory
Jan 27 04:25:31 tegra-ubuntu gdm-autologin][1649]: PAM adding faulty module: pam_gnome_keyring.so
Jan 27 04:25:31 tegra-ubuntu gdm-autologin][1649]: pam_unix(gdm-autologin:session): session opened for user nvidia by (uid=0)
Are there any specifications for nvidia display accessories?
sudo x11vnc -display :0 -noxrecord -noxfixes -noxdamage -forever -loop –
nopw
30/01/2023 11:03:41 x11vnc version: 0.9.16 lastmod: 2019-01-05 pid: 2891
No protocol specified
30/01/2023 11:03:41 XOpenDisplay(":0") failed.
30/01/2023 11:03:41 Trying again with XAUTHLOCALHOSTNAME=localhost ...
I just conntected to ORIN via SSH, there is no other user
nvidia@tegra-ubuntu:~$ w
11:08:06 up 10 min, 1 user, load average: 0.58, 0.67, 0.41
USER TTY FROM LOGIN@ IDLE JCPU PCPU WHAT
nvidia ttyS2 - 10:58 0.00s 0.12s 0.01s w
