Even though this hasn’t been replied to in months, I thought this might help, the contents of /proc/asound/codec#0 and codec#3 with nouveau drivers (and working hdmi audio) are below:
cat /proc/asound/card0/codec#0
Codec: Realtek ALC888
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0888
Subsystem Id: 0x10ec0000
Revision Id: 0x100001
No Modem Function Group found
Default PCM:
rates [0x560]: 44100 48000 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3
Power: setting=D0, actual=D0
GPIO: io=3, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x11: Stereo
Device: name=“ALC888 Analog”, type=“Audio”, device=0
Converter: stream=8, channel=0
PCM:
formats [0x1]: PCM
Node 0x03 [Audio Output] wcaps 0x11: Stereo
PCM:
formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x11: Stereo
PCM:
formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x11: Stereo
PCM:
formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x211: Stereo Digital
Control: name=“IEC958 Playback Con Mask”, index=16, device=0
Control: name=“IEC958 Playback Pro Mask”, index=16, device=0
Control: name=“IEC958 Playback Default”, index=16, device=0
Control: name=“IEC958 Playback Switch”, index=16, device=0
Control: name=“IEC958 Default PCM Playback Switch”, index=0, device=0
Device: name=“ALC888 Digital”, type=“SPDIF”, device=1
Digital: Enabled
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
rates [0x5e0]: 44100 48000 88200 96000 192000
bits [0x1e]: 16 20 24 32
formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10011b: Stereo Amp-In
Control: name=“Capture Volume”, index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name=“Capture Switch”, index=0, device=0
Amp-In caps: ofs=0x0b, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x12 0x12]
Converter: stream=4, channel=0
SDI-Select: 0
PCM:
rates [0x160]: 44100 48000 96000
bits [0x6]: 16 20
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10011b: Stereo Amp-In
Control: name=“Capture Volume”, index=1, device=0
Control: name=“Capture Switch”, index=1, device=0
Device: name=“ALC888 Alt Analog”, type=“Audio”, device=2
Amp-In vals: [0x80 0x80]
Converter: stream=0, channel=0
SDI-Select: 0
PCM:
bits [0x6]: 16 20
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Audio Input] wcaps 0x100391: Stereo Digital
Control: name=“IEC958 Capture Switch”, index=0, device=0
Control: name=“IEC958 Capture Default”, index=0, device=0
SDI-Select: 0
Digital:
PCM:
formats [0x1]: PCM
Unsolicited: tag=00, enabled=0
Connection: 1
0x1f
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name=“Front Mic Playback Volume”, index=0, device=0
ControlAmp: chs=3, dir=In, idx=1, ofs=0
Control: name=“Front Mic Playback Switch”, index=0, device=0
Control: name=“Rear Mic Playback Volume”, index=0, device=0
Control: name=“Rear Mic Playback Switch”, index=0, device=0
Control: name=“Line Playback Volume”, index=0, device=0
ControlAmp: chs=3, dir=In, idx=2, ofs=0
Control: name=“Line Playback Switch”, index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 10
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name=“Front Playback Volume”, index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x00 0x00] [0x00 0x00]
Amp-Out caps: ofs=0x1f, nsteps=0x1f, stepsize=0x05, mute=0
Amp-Out vals: [0x1f 0x1f]
Connection: 2
0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name=“Surround Playback Volume”, index=0, device=0
Connection: 2
0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name=“Center Playback Volume”, index=0, device=0
ControlAmp: chs=1, dir=Out, idx=0, ofs=0
Control: name=“LFE Playback Volume”, index=0, device=0
ControlAmp: chs=2, dir=Out, idx=0, ofs=0
Connection: 2
0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name=“Side Playback Volume”, index=0, device=0
Connection: 2
0x05 0x0b
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Control: name=“Front Playback Switch”, index=0, device=0
Control: name=“Line Out Front Jack”, index=0, device=0
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x0000003e: IN OUT HP Detect Trigger
Pin Default 0x01014410: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Green
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x40: OUT
Unsolicited: tag=05, enabled=1
Connection: 5
0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x15 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Control: name=“Surround Playback Switch”, index=0, device=0
Control: name=“Line Out Surround Jack”, index=0, device=0
Pin Default 0x01011412: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0x1, Sequence = 0x2
Pin-ctls: 0x40: OUT
Unsolicited: tag=06, enabled=1
Connection: 5
0x0c 0x0d* 0x0e 0x0f 0x26
Node 0x16 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Control: name=“Center Playback Switch”, index=0, device=0
Control: name=“LFE Playback Switch”, index=0, device=0
Control: name=“Line Out CLFE Jack”, index=0, device=0
Pincap 0x00000036: IN OUT Detect Trigger
Pin Default 0x01016411: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Orange
DefAssociation = 0x1, Sequence = 0x1
Pin-ctls: 0x40: OUT
Unsolicited: tag=07, enabled=1
Connection: 5
0x0c 0x0d 0x0e* 0x0f 0x26
Node 0x17 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Control: name=“Side Playback Switch”, index=0, device=0
Control: name=“Line Out Side Jack”, index=0, device=0
Pin Default 0x01012414: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Grey
DefAssociation = 0x1, Sequence = 0x4
Pin-ctls: 0x40: OUT
Unsolicited: tag=08, enabled=1
Connection: 5
0x0c 0x0d 0x0e 0x0f* 0x26
Node 0x18 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Control: name=“Rear Mic Boost Volume”, index=0, device=0
Control: name=“Rear Mic Jack”, index=0, device=0
Amp-Out vals: [0x80 0x80]
Pincap 0x0000373e: IN OUT HP Detect Trigger
Vref caps: HIZ 50 GRD 80 100
Pin Default 0x01a19c40: [Jack] Mic at Ext Rear
Conn = 1/8, Color = Pink
DefAssociation = 0x4, Sequence = 0x0
Pin-ctls: 0x21: IN VREF_50
Unsolicited: tag=03, enabled=1
Connection: 5
Node 0x19 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Control: name=“Front Mic Boost Volume”, index=0, device=0
Control: name=“Front Mic Jack”, index=0, device=0
Pin Default 0x02a19c50: [Jack] Mic at Ext Front
DefAssociation = 0x5, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=02, enabled=1
Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Control: name=“Line Boost Volume”, index=0, device=0
Control: name=“Line Jack”, index=0, device=0
Pin Default 0x0181344f: [Jack] Line In at Ext Rear
Conn = 1/8, Color = Blue
DefAssociation = 0x4, Sequence = 0xf
Pin-ctls: 0x20: IN VREF_HIZ
Unsolicited: tag=04, enabled=1
Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Control: name=“Headphone Playback Switch”, index=0, device=0
Control: name=“Front Headphone Jack”, index=0, device=0
Pin Default 0x02214c20: [Jack] HP Out at Ext Front
DefAssociation = 0x2, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP VREF_HIZ
Unsolicited: tag=01, enabled=1
Connection: 5
0x0c 0x0d 0x0e 0x0f 0x26*
Node 0x1c [Pin Complex] wcaps 0x400001: Stereo
Pincap 0x00000020: IN
Pin Default 0x593301f0: [N/A] CD at Int ATAPI
Conn = ATAPI, Color = Unknown
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1d [Pin Complex] wcaps 0x400000: Mono
Pin Default 0x4005e601: [N/A] Line Out at Ext N/A
Conn = Optical, Color = White
DefAssociation = 0x0, Sequence = 0x1
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400300: Mono Digital
Control: name=“SPDIF Phantom Jack”, index=0, device=0
Pincap 0x00000010: OUT
Pin Default 0x014b5130: [Jack] SPDIF Out at Ext Rear
Conn = Comb, Color = Red
DefAssociation = 0x3, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Pin Complex] wcaps 0x400200: Mono Digital
Control: name=“SPDIF In Phantom Jack”, index=0, device=0
Pin Default 0x01c47160: [Jack] SPDIF In at Ext Rear
Conn = RCA, Color = Yellow
DefAssociation = 0x6, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=17
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 11
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0b
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 11
Node 0x24 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x25 [Audio Output] wcaps 0x11: Stereo
PCM:
formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name=“Headphone Playback Volume”, index=0, device=0
Connection: 2
0x25 0x0b
cat /proc/asound/card0/codec#3
Codec: Nvidia MCP77/78 HDMI
Address: 3
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x10de0002
Subsystem Id: 0x10de0101
Revision Id: 0x100000
Default PCM:
N/A
Power: setting=UNKNOWN, actual=UNKNOWN, Error, Clock-stop-OK, Setting-reset
GPIO: io=255, o=255, i=255, unsolicited=1, wake=1
Is it possible to override the value of these files as provided by NVidia with the values above ? Otherwise, can we get an update on a status of this issue?
I’d rather not have to choose between using my video card for graphics acceleration or enabling HDMI audio output…
