I just installed the latest driver–NVIDIA-Linux-x86_64-440.36.run on my Dell with GeForce GTX 1050 Ti.
It appears to have successfully installed.
cat /etc/redhat-release
Fedora release 29 (Twenty Nine)
lspci -k | grep -EA3 'VGA|3D|Display'
00:02.0 Display controller: Intel Corporation UHD Graphics 630 (Desktop)
Subsystem: Dell Device 0859
Kernel driver in use: i915
Kernel modules: i915
01:00.0 VGA compatible controller: NVIDIA Corporation GP107 [GeForce GTX 1050 Ti] (rev a1)
Subsystem: Dell Device 3512
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
cat /etc/modprobe.d/blacklist.conf
blacklist nouveau
My graphics card has one HDMI cable connecting it to my scaler (iScan Duo). My scaler offers a wide range of audio processing which is a primary reason for the purchase.
When settings is set to stereo the scaler displays LPCM 2-Channel.
The other options displayed in Gnome settings are 5.1 and 7.1–both of which have full HW & SW support but the output doesn’t work correctly. At the moment the key thing missing is the center channel.
Can someone please give me some clues on how to troubleshoot? I am happy to provide any additional detail requested.
cat /proc/asound/card1/codec#0
Codec: Nvidia GPU 80 HDMI/DP
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x10de0080
Subsystem Id: 0x10283512
Revision Id: 0x100100
No Modem Function Group found
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x04 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Control: name="IEC958 Playback Con Mask", index=0, device=0
Control: name="IEC958 Playback Pro Mask", index=0, device=0
Control: name="IEC958 Playback Default", index=0, device=0
Control: name="IEC958 Playback Switch", index=0, device=0
Pincap 0x09000094: OUT Detect HBR HDMI DP
Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
DefAssociation = 0xf, Sequence = 0x0
Pin-ctls: 0x00:
Unsolicited: tag=01, enabled=1
Connection: 4
0x0a* 0x0b 0x0c 0x0d
Node 0x05 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Control: name="IEC958 Playback Con Mask", index=1, device=0
Control: name="IEC958 Playback Pro Mask", index=1, device=0
Control: name="IEC958 Playback Default", index=1, device=0
Control: name="IEC958 Playback Switch", index=1, device=0
Pin-ctls: 0x00:
Unsolicited: tag=02, enabled=1
Connection: 4
Node 0x06 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Control: name="IEC958 Playback Con Mask", index=2, device=0
Control: name="IEC958 Playback Pro Mask", index=2, device=0
Control: name="IEC958 Playback Default", index=2, device=0
Control: name="IEC958 Playback Switch", index=2, device=0
Pin-ctls: 0x00:
Unsolicited: tag=03, enabled=1
Connection: 4
Node 0x07 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin Default 0x585600f0: [N/A] Digital Out at Int HDMI
Pin-ctls: 0x00:
Unsolicited: tag=00, enabled=0
Connection: 4
Node 0x08 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Connection: 4
Node 0x09 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Connection: 4
Node 0x0a [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Converter: stream=0, channel=0
Digital: Enabled GenLevel
Digital category: 0x2
IEC Coding Type: 0x0
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0xe]: 16 20 24
formats [0x5]: PCM AC3
Node 0x0b [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
Digital category: 0x0
PCM:
Node 0x0c [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0d [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
nvidia-bug-report.log.gz (1.17 MB)
