Audio over DP and HDMI work fine on Windows 11 with my DELL G15 Ryzen 7 5800H NVIDIA RTX 3060 notebook and monitor with speakers.
However, on Linux it doesn’t display the neither HDMI nor DP output options when attached to the same monitor mentioned above.
OS - Ubuntu 22.04
Kernel - 5.15.0-39
Driver - 510.73.05
Setup - Laptop with an external Monitor over DP connected (also tried HDMI)
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 0: ALC3254 Analog [ALC3254 Analog]
Subdevices: 0/1
lspci | grep -i audio
01:00.1 Audio device: NVIDIA Corporation Device 228e (rev a1)
06:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor (rev 01)
06:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
lspci | grep -i nvidia
01:00.0 VGA compatible controller: NVIDIA Corporation GA106M [GeForce RTX 3060 Mobile / Max-Q] (rev a1)
aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
default
Playback/recording through the PulseAudio sound server
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pulse
PulseAudio Sound Server
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
hw:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
Direct hardware device without any conversions
hw:CARD=NVidia,DEV=7
HDA NVidia, HDMI 1
hw:CARD=NVidia,DEV=8
HDA NVidia, HDMI 2
hw:CARD=NVidia,DEV=9
HDA NVidia, HDMI 3
hw:CARD=NVidia,DEV=10
HDA NVidia, HDMI 4
plughw:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
Hardware device with all software conversions
plughw:CARD=NVidia,DEV=7
HDA NVidia, HDMI 1
plughw:CARD=NVidia,DEV=8
HDA NVidia, HDMI 2
plughw:CARD=NVidia,DEV=9
HDA NVidia, HDMI 3
plughw:CARD=NVidia,DEV=10
HDA NVidia, HDMI 4
hdmi:CARD=NVidia,DEV=0
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
HDA NVidia, HDMI 1
HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
HDA NVidia, HDMI 2
HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
HDA NVidia, HDMI 3
HDMI Audio Output
hdmi:CARD=NVidia,DEV=4
HDA NVidia, HDMI 4
HDMI Audio Output
dmix:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
Direct sample mixing device
dmix:CARD=NVidia,DEV=7
HDA NVidia, HDMI 1
dmix:CARD=NVidia,DEV=8
HDA NVidia, HDMI 2
dmix:CARD=NVidia,DEV=9
HDA NVidia, HDMI 3
dmix:CARD=NVidia,DEV=10
HDA NVidia, HDMI 4
usbstream:CARD=NVidia
HDA NVidia
USB Stream Output
hw:CARD=Generic,DEV=0
HD-Audio Generic, ALC3254 Analog
plughw:CARD=Generic,DEV=0
sysdefault:CARD=Generic
Default Audio Device
front:CARD=Generic,DEV=0
Front output / input
surround21:CARD=Generic,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Generic,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Generic,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Generic,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Generic,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Generic,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
dmix:CARD=Generic,DEV=0
usbstream:CARD=Generic
HD-Audio Generic
USB Stream Output
usbstream:CARD=acp
acp
USB Stream Output
I’ve tried solution proposed on thread “No option for audio over DisplayPort / HDMI” by user xKGx, but it didn’t work.
nvidia-bug-report.log.gz (395.7 KB)
