I have a laptop with a GeForce GTX 1070 Mobile running Ubuntu 22.04. I’m able to output video, but not audio over HDMI to my TV.
The odd thing is that when the TV is off but plugged in to the HDMI port, the HDMI audio appears connected and – as far as I can tell – working as expected. As soon as I turn the TV on it disappears, and does not reappear until I physically unplug the HDMI and plug it back in (or reboot).
I am NOT able force audio to the TV using aplay or speaker-test and specifying the card/device IDs.
The solution in this thread – changing udev rules to stop the audio device from being powered off – sounded promising but didn’t do anything.
I’ve tried driver versions 545, 510, and 470 with no noticeable differences.
The problem does NOT occur with the nouveau driver.
It also does not occur when using a different laptop with Windows, or a third laptop running Linux Mint with a much older NVIDIA card (a GeForce GT 520M, if I remember correctly).
And it does not occur with an older TV of the same brand, but everything else unchanged (same laptop, OS, drivers, HDMI cable).
Bug report log:
Processing: nvidia-bug-report.log.gz…
Bug report log (TV plugged in to HDMI, but before turning it on):
Processing: nvidia-bug-report.tvoff.log.gz…
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC1220 Analog [ALC1220 Analog]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC1220 Digital [ALC1220 Digital]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
aplay -l (TV off but plugged in to HDMI)
Subdevices: 0/1
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [M60-C3]
Subdevices: 0/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
pacmd list-cards
2 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 7
properties:
alsa.card = "1"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xa5080000 irq 17"
alsa.driver_name = "snd_hda_intel"
device.bus_path = "pci-0000:01:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
device.bus = "pci"
device.vendor.id = "10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "10f0"
device.product.name = "GP104 High Definition Audio Controller"
device.string = "1"
device.description = "GP104 High Definition Audio Controller"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
off: Off (priority 0, available: unknown)
active profile: <off>
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
device.icon_name = "video-display"
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
index: 1
owner module: 8
properties:
alsa.card = "0"
alsa.card_name = "HDA Intel PCH"
alsa.long_card_name = "HDA Intel PCH at 0xa5610000 irq 144"
device.bus_path = "pci-0000:00:1f.3"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.vendor.name = "Intel Corporation"
device.product.id = "a348"
device.product.name = "Cannon Lake PCH cAVS"
device.form_factor = "internal"
device.string = "0"
device.description = "Built-in Audio"
profiles:
input:analog-stereo: Analog Stereo Input (priority 32833, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 39268, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 39333, available: unknown)
output:iec958-stereo: Digital Stereo (IEC958) Output (priority 38268, available: unknown)
output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (priority 38333, available: unknown)
active profile: <output:analog-stereo+input:analog-stereo>
sinks:
alsa_output.pci-0000_00_1f.3.analog-stereo/#0: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1f.3.analog-stereo.monitor/#0: Monitor of Built-in Audio Analog Stereo
alsa_input.pci-0000_00_1f.3.analog-stereo/#1: Built-in Audio Analog Stereo
ports:
analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
properties:
device.icon_name = "audio-input-microphone"
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
properties:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
device.icon_name = "audio-speakers"
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
device.icon_name = "audio-headphones"
iec958-stereo-output: Digital Output (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
properties:
pacmd list-cards (TV off but plugged in to HDMI)
index: 0
owner module: 7
properties:
alsa.card = "1"
device.bus = "pci"
device.string = "1"
profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 38668, available: unknown)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 33568, available: unknown)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 33568, available: unknown)
active profile: <output:hdmi-stereo>
sinks:
alsa_output.pci-0000_01_00.1.hdmi-stereo/#0: GP104 High Definition Audio Controller Digital Stereo (HDMI)
sources:
alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor/#0: Monitor of GP104 High Definition Audio Controller Digital Stereo (HDMI)
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: yes)
properties:
device.product.name = "M60-C3
properties:
properties:
properties:
index: 1
owner module: 8
properties:
alsa.card = "0"
device.bus = "pci"
device.string = "0"
profiles:
sinks:
alsa_output.pci-0000_00_1f.3.analog-stereo/#1: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1f.3.analog-stereo.monitor/#1: Monitor of Built-in Audio Analog Stereo
alsa_input.pci-0000_00_1f.3.analog-stereo/#2: Built-in Audio Analog Stereo
ports:
properties:
properties:
properties:
properties:
properties:
cat /proc/asound/card1/eld#0.0
monitor_present 1
eld_valid 0
codec_pin_nid 0x5
codec_dev_id 0x0
codec_cvt_nid 0xa
cat /proc/asound/card1/eld#0.0 (TV off but plugged in to HDMI)
monitor_present 1
eld_valid 1
codec_pin_nid 0x5
codec_dev_id 0x0
codec_cvt_nid 0xa
monitor_name M60-C3
connection_type HDMI
eld_version [0x2] CEA-861D or below
edid_version [0x3] CEA-861-B, C or D
manufacture_id 0x3a59
product_id 0x1015
port_id 0x100
support_hdcp 0
support_ai 0
audio_sync_delay 256
speakers [0x1] FL/FR
sad_count 2
sad0_coding_type [0x1] LPCM
sad0_channels 2
sad0_rates [0xe0] 32000 44100 48000
sad0_bits [0xa0000] 16 24
sad1_coding_type [0x2] AC-3
sad1_channels 6
sad1_rates [0x14e0] 32000 44100 48000 96000 192000
sad1_max_bitrate 640000
