I am running a fresh install of Ubuntu 16.04.6 (edited) on an ASUS X512FL laptop, with secure boot turned off in the BIOS settings, and with two graphic cards:
- Intel
- NVIDIA MX250
user@laptop:~$ sudo lshw -C display
[sudo] password for user:
*-display
description: VGA compatible controller
product: Intel Corporation
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:130 memory:b2000000-b2ffffff memory:90000000-9fffffff ioport:5000(size=64) memory:c0000-dffff
*-display
description: 3D controller
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:02:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list rom
configuration: driver=nouveau latency=0
resources: irq:129 memory:b3000000-b3ffffff memory:a0000000-afffffff memory:b0000000-b1ffffff ioport:4000(size=128) memory:b4000000-b407ffff
I can’t seem to get the NVIDIA MX250 working (“nvidia-smi” not working) no matter what solutions I tried.
- I tried installing the open source driver from the "Additional Drivers" tab in the "Software & Updates". However, after restarting the Ubuntu won't boot and it stucks at the boot page. It shows message along this line:
The system is running in low-graphics mode Your screen, graphics cards, and input device settings could not be detected correctly. You will need to configure these yourself.
It seems that there is no “proprietary driver” listed here and I doubt this is the cause of the problem.
Figure: https://drive.google.com/file/d/1eDHeJ5PGAD_RZWue-7Dw4P0mU56jVtSB/view?usp=sharing - I tried running the following command but still it doesn't solve the problem. The result is the same with the above method.
user@laptop:~$ sudo apt-get purge nvidia* user@laptop:~$ sudo add-apt-repository ppa:graphics-drivers/ppa user@laptop:~$ sudo apt-get update user@laptop:~$ sudo ubuntu-drivers devices == /sys/devices/pci0000:00/0000:00:1c.4/0000:02:00.0 == modalias : pci:v000010DEd00001D13sv00001043sd00001FBEbc03sc02i00 vendor : NVIDIA Corporation driver : nvidia-430 - third-party free recommended driver : xserver-xorg-video-nouveau - distro free builtin driver : nvidia-418 - third-party free user@laptop:~$ sudo ubuntu-drivers autoinstall ...
Question
Does anyone have the same issue with NVIDIA MX250? Could you please instruct me on how to get the MX250 up and running on Ubuntu 16.04?
