I encountered an issue while setting up the official Isaac ROS 3.2 development environment on Ubuntu 22.04.
The repository key provided by:
https://isaac.download.nvidia.com/isaac-ros/repos.key
has the fingerprint:
428F5D2ACFBC9AA1F8EAC84658F4DA023E691207
However, the Release/InRelease file for the Isaac ROS 3.2 repository appears to be signed with a different key:
BBE5EA6DE681BCAB
As a result, apt reports:
NO_PUBKEY BBE5EA6DE681BCAB
This prevents users from installing Isaac ROS packages using the official instructions.
Environment:
- Ubuntu 22.04.4 LTS
- ROS 2 Humble
- x86_64
- NVIDIA RTX 3060 Laptop GPU
Hello @hoseahao,
Welcome to the Isaac ROS forum and thanks for the post!
I checked the current Isaac ROS apt repo and latest public NGC image. The missing BBE5EA6DE681BCAB key is present and apt update succeeds, so this looks like a stale local keyring/cache issue rather than a current Isaac ROS container or repo issue.
Please redo the “Configure Isaac ROS Apt Repository” step from Isaac ROS Getting Started guide, making sure the correct platform/release tab is selected.
After refreshing the keyring, verify that the keyring contains 9EEB 7195 A4BD 947C 5726 66F9 BBE5 EA6D E681 BCAB with this command: gpg --show-keys --with-fingerprint /usr/share/keyrings/nvidia-isaac-ros.gpg
Then run:
sudo apt-get update
If this happens during Docker build, please rebuild without the cached layer, for example with docker build --no-cache, or otherwise invalidate the layer that downloads repos.key.
Similar issue already resolved on GitHub — see #224.
