No resnet18_vehicletypenet_pruned.onnx_b16_gpu0_int8.engine generated in DS7.1
Right now I have found an issue with DS7.1 deepstream-test2.
It should have following three egine file:
  • samples/models/Primary_Detector/resnet18_trafficcamnet_pruned.onnx_b1_gpu0_int8.engine
  • samples/models/Secondary_VehicleMake/resnet18_vehiclemakenet_pruned.onnx_b16_gpu0_int8.engine
  • samples/models/Secondary_VehicleTypes/resnet18_vehicletypenet_pruned.onnx_b16_gpu0_int8.engine
BUT, two of engine files are generated automaticly. There is no samples/models/Secondary_VehicleTypes/resnet18_vehicletypenet_pruned.onnx_b16_gpu0_int8.engine file
So it take a long time to launch test2 code, with following warnings:
WARNING: Deserialize engine failed because file path: /home/daniel/Work/jetson-fpv/utils/deepstream/samples/models/Secondary_VehicleTypes/resnet18_vehicletypenet_pruned.onnx_b16_gpu0_int8.engine open error
0:00:00.221537306 26352 0xaaaadeb46160 WARN                 nvinfer gstnvinfer.cpp:681:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2080> [UID = 3]: deserialize engine from file :/home/daniel/Work/jetson-fpv/utils/deepstream/samples/models/Secondary_VehicleTypes/resnet18_vehicletypenet_pruned.onnx_b16_gpu0_int8.engine failed
0:00:00.221582267 26352 0xaaaadeb46160 WARN                 nvinfer gstnvinfer.cpp:681:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2185> [UID = 3]: deserialize backend context from engine from file :/home/daniel/Work/jetson-fpv/utils/deepstream/samples/models/Secondary_VehicleTypes/resnet18_vehicletypenet_pruned.onnx_b16_gpu0_int8.engine failed, try rebuild
0:00:00.221598171 26352 0xaaaadeb46160 INFO                 nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2106> [UID = 3]: Trying to create engine from model files
WARNING: INT8 calibration file not specified. Trying FP16 mode.
WARNING: [TRT]: DLA requests all profiles have same min, max, and opt value. All dla layers are falling back to GPU
^C^C^C0:02:18.111540483 26352 0xaaaadeb46160 INFO                 nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2138> [UID = 3]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-7.1/samples/models/Secondary_VehicleTypes/resnet18_vehicletypenet_pruned.onnx_b16_gpu0_fp16.engine successfully
And I found there are calibration files there:
$ ls samples/models/Secondary_VehicleTypes/
cal_trt.bin  labels.txt  resnet18_vehicletypenet_pruned.onnx  resnet18_vehicletypenet_pruned.onnx_b16_gpu0_fp16.engine
Software part of jetson-stats 4.3.1 - (c) 2024, Raffaello Bonghi
Model: NVIDIA Jetson Orin Nano Developer Kit - Jetpack 6.2 [L4T 36.4.3]
NV Power Mode[0]: 15W
Serial Number: [XXX Show with: jetson_release -s XXX]
Hardware:
 - P-Number: p3767-0005
 - Module: NVIDIA Jetson Orin Nano (Developer kit)
Platform:
 - Distribution: Ubuntu 22.04 Jammy Jellyfish
 - Release: 5.15.148-tegra
jtop:
 - Version: 4.3.1
 - Service: Active
Libraries:
 - CUDA: 12.6.68
 - cuDNN: 9.3.0.75
 - TensorRT: 10.3.0.30
 - VPI: 3.2.4
 - OpenCV: 4.11.0 - with CUDA: YES
DeepStream C/C++ SDK version: 7.1
Python Environment:
Python 3.10.12
    GStreamer:                   YES (1.20.3)
  NVIDIA CUDA:                   YES (ver 12.6, CUFFT CUBLAS FAST_MATH)
         OpenCV version: 4.11.0  CUDA True
           YOLO version: 8.3.68
         PYCUDA version: 2024.1.2
          Torch version: 2.5.1+l4t36.4
    Torchvision version: 0.20.0
 DeepStream SDK version: 1.2.0
onnxruntime     version: 1.20.1
onnxruntime-gpu version: 1.19.2
FPV Environment:
MSPOSD version: c28d645 20250205_151537
Could you attach your command? I have tried on my board, the engine file can be generated normally.
./deepstream-test2-app dstest2_config.yml
ls /opt/nvidia/deepstream/deepstream/samples/models/Secondary_VehicleTypes/
cal_trt.bin  resnet18_vehicletypenet_pruned.onnx
labels.txt   resnet18_vehicletypenet_pruned.onnx_b16_gpu0_int8.engine
see below:
git clone https://github.com/SnapDragonfly/jetson-fpv.git
cd jetson-fpv/utils/deepstream
ln -sf /opt/nvidia/deepstream/deepstream/samples/ samples
cd ../../
python3 ./utils/deepstream/deepstream_NvDCF.py -i file:///home/daniel/Work/jetson-fpv/utils/deepstream/samples/streams/sample_1080p_h264.mp4
It’s using dstest2_* configuration filese, which only adjust file path only. It should work as expected, except those warnings.
daniel@daniel-nvidia:~/Work/jetson-fpv$ python3 ./utils/deepstream/deepstream_NvDCF.py -i file:///home/daniel/Work/jetson-fpv/utils/deepstream/samples/streams/sample_1080p_h264.mp4
Current working directory: /home/daniel/Work/jetson-fpv
New working directory: /home/daniel/Work/jetson-fpv/utils/deepstream
{'input': ['file:///home/daniel/Work/jetson-fpv/utils/deepstream/samples/streams/sample_1080p_h264.mp4'], 'input_codec': 'h264', 'no_display': False, 'file_loop': False, 'silent': False}
Creating Pipeline
Creating streamux
Creating source_bin  0
Creating source bin
source-bin-00
Creating Pgie
Creating tiler
Creating nvvidconv
Creating nvosd
Is it Integrated GPU? : 1
Creating nv3dsink
Adding elements to Pipeline
Now playing...
0 :  file:///home/daniel/Work/jetson-fpv/utils/deepstream/samples/streams/sample_1080p_h264.mp4
Starting pipeline
Setting min object dimensions as 16x16 instead of 1x1 to support VIC compute mode.
0:00:00.214201723 29011 0xaaaada4bc440 WARN                 nvinfer gstnvinfer.cpp:681:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2080> [UID = 3]: deserialize engine from file :/home/daniel/Work/jetson-fpv/utils/deepstream/samples/models/Secondary_VehicleTypes/resnet18_vehicletypenet_pruned.onnx_b16_gpu0_int8.engine failed
0:00:00.214239611 29011 0xaaaada4bc440 WARN                 nvinfer gstnvinfer.cpp:681:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2185> [UID = 3]: deserialize backend context from engine from file :/home/daniel/Work/jetson-fpv/utils/deepstream/samples/models/Secondary_VehicleTypes/resnet18_vehicletypenet_pruned.onnx_b16_gpu0_int8.engine failed, try rebuild
0:00:00.214256634 29011 0xaaaada4bc440 INFO                 nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2106> [UID = 3]: Trying to create engine from model files
It seems that you are using different version from mine DS7.1 on Jetpack 6.2 L4T36.4.3
daniel@daniel-nvidia:/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test2$ deepstream-app dstest2_config.** ERROR: <main:655>: Specify config file with -c option
Quitting
App run failed
Update: @yuweiw We are using python demos from here GitHub - NVIDIA-AI-IOT/deepstream_python_apps at cb7fd9c8aa012178527e0cb84f91d1f5a0ad37ff
@yuweiw Sorry, this is my mistake.
I have found the issue here: the path of calib file is wrong .sample should be sample
