No ROS2 Publish Clock Node
Isaac Sim Version
4.5.0
Operating System
Ubuntu 22.04
The Isaac Sim 4.5.0 ROS2 Clock tutorials mention a ROS2 Publish Clock node, but that node is not available/listed in Isaac Sim 4.5.0 ActionGraph.Nodes list.
Is this a known bug or is there a way to import additional library OmniGraph nodes?
“ROS2 Publish Clock” is available in Window->Graph Editors->Action Graph on my system. Did you enable the ROS Bridge Extension as described in ROS and ROS 2 Installation — Isaac Sim Documentation?
Yes, the ROS Bridge Extension is enabled, and I can see other ROS nodes. I completely uninstalled 4.0.0 according to the published documentation and then installed 4.5.0, and the Isaac Sim window shows 4.5.0.
Could you provide a full log?
What would you like logs of? I upgraded to 4.5.0 months ago. I can provide the isaac sim startup logs
That will be good.
isaac-sim.sh_logs.txt (47.2 KB)
Thank you for looking into this, please let me know if there are any additional logs you’d like to see.
I didn’t find this message in your log file:
2025-04-23 05:37:39 [11,949ms] [Info] [omni.ext.plugin] [ext: isaacsim.ros2.bridge-4.1.15] started, startup time: 198 (ms)
You may need to carefully follow the instructures in ROS and ROS 2 Installation — Isaac Sim Documentation to ensure everything is set up properly.
