I tried the deepstream-test5 on my Jetson nano with the given config files. I am working with Deeepstream 5.
As a result a got video with bounding boxes of the classes but text labels were absent. By the way, I had no problems with the text labels when run the deepstream-test1, they were as they had to be - at the upper left corner of the bounding boxes. I guess I missed some parameters in the config files of the deepstream-test5. I did not change any input (the config files, models or video). Please, advise.
Hi
Can you specify details how can repro your issue?
The osd result when I run deepstream-test5 is here
As you see there are no labels neither for cars nor for persons.
I have the config files as follows:
# Copyright (c) 2018-2020 NVIDIA Corporation. All rights reserved.
# NVIDIA Corporation and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA Corporation is strictly prohibited.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=2
columns=2
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
uri=file://../../../../../samples/streams/sample_1080p_h264.mp4
num-sources=2
gpu-id=0
nvbuf-memory-type=0
[source1]
enable=1
type=3
num-sources=2
gpu-id=0
nvbuf-memory-type=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=4
codec=1
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvoverlaysink 6=MsgConvBroker
type=1
msg-conv-config=dstest5_msgconv_sample_config.txt
#(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
#(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
#(256): PAYLOAD_RESERVED - Reserved type
#(257): PAYLOAD_CUSTOM - Custom schema payload
msg-conv-payload-type=0
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_kafka_proto.so
#Provide your msg-broker-conn-str here
msg-broker-conn-str=;;
topic=
#Optional:
#msg-broker-config=../../deepstream-test4/cfg_kafka.txt
[sink2]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
## only SW mpeg4 is supported right now.
codec=3
sync=1
bitrate=2000000
output-file=out.mp4
source-id=0
# sink type = 6 by default creates msg converter + broker.
# To use multiple brokers use this group for converter and use
# sink type = 6 with disable-msgconv = 1
[message-converter]
enable=0
# Name of library having custom implementation.
#msg-conv-msg2p-lib=
# Id of component in case only selected message to parse.
#msg-conv-comp-id=
# Configure this group to enable cloud message consumer.
[message-consumer0]
enable=0
conn-str=;
config-file=
subscribe-topic-list=;;
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=4
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
# attach-sys-ts-as-ntp=1
[primary-gie]
enable=1
gpu-id=0
batch-size=4
## 0=FP32, 1=INT8, 2=FP16 mode
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;1;1;1
bbox-border-color3=0;1;0;1
nvbuf-memory-type=0
interval=0
gie-unique-id=1
model-engine-file=../../../../../samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
labelfile-path=../../../../../samples/models/Primary_Detector/labels.txt
config-file=../../../../../samples/configs/deepstream-app/config_infer_primary.txt
#infer-raw-output-dir=../../../../../samples/primary_detector_raw_output/
[tracker]
enable=1
tracker-width=600
tracker-height=288
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
#ll-config-file required for DCF/IOU only
#ll-config-file=tracker_config.yml
#ll-config-file=iou_config.txt
gpu-id=0
#enable-batch-process applicable to DCF only
enable-batch-process=0
[tests]
file-loop=0
Please add -t, --tiledtext // Display Bounding box labels in tiled mode
to your commands.
Thank you for your reply.
Yes, I tried options like these:
./deepstream-test5-app -c configs/test5_config_file_src_infer.txt -p 0 --tiledtext
./deepstream-test5-app -c configs/test5_config_file_src_infer.txt -p 0 -t
./deepstream-test5-app -c configs/test5_config_file_src_infer.txt -p 0 -t --tiledtext
There were no labels just bboxes were displayed.
Could you check the deepstream-test5-app on your side?
May I know below info you are running with, and please add the info when you create one topic.
• DeepStream Version
• TensorRT Version
Please add below change to test5 sample
sources/apps/sample_apps/deepstream-test5/deepstream_test5_app_main.c
and run with option -t added.
in main function, around 1514 line, just add with + mark line.
+if(!show_bbox_text)
GstElement *nvosd = appCtx[0]->pipeline.instance_bins[0].osd_bin.nvosd;
g_object_set (G_OBJECT (nvosd), “display-text”, FALSE, NULL);
Is seems this snippet code was in place:
* Loop function to check keyboard inputs and status of each pipeline.
static gboolean
event_thread_func (gpointer arg)
guint i;
gboolean ret = TRUE;
// Check if all instances have quit
for (i = 0; i < num_instances; i++) {
if (!appCtx[i]->quit)
break;
if (i == num_instances) {
quit = TRUE;
g_main_loop_quit (main_loop);
return FALSE;
// Check for keyboard input
if (!kbhit ()) {
//continue;
return TRUE;
int c = fgetc (stdin);
g_print ("\n");
gint source_id;
GstElement *tiler = appCtx[0]->pipeline.tiled_display_bin.tiler;
g_object_get (G_OBJECT (tiler), "show-source", &source_id, NULL);
if (selecting) {
if (rrowsel == FALSE) {
if (c >= '0' && c <= '9') {
rrow = c - '0';
g_print ("--selecting source row %d--\n", rrow);
rrowsel = TRUE;
} else {
int tile_num_columns = appCtx[0]->config.tiled_display_config.columns;
rcol = c - '0';
selecting = FALSE;
rrowsel = FALSE;
source_id = tile_num_columns * rrow + rcol;
g_print ("--selecting source col %d sou=%d--\n", rcol, source_id);
if (source_id >= (gint) appCtx[0]->config.num_source_sub_bins) {
source_id = -1;
} else {
source_ids[0] = source_id;
appCtx[0]->show_bbox_text = TRUE;
g_object_set (G_OBJECT (tiler), "show-source", source_id, NULL);
switch (c) {
case 'h':
print_runtime_commands ();
break;
case 'p':
pause_pipeline (appCtx[i]);
break;
case 'r':
resume_pipeline (appCtx[i]);
break;
case 'q':
quit = TRUE;
ret = FALSE;
break;
case 'z':
if (source_id == -1) {
g_print ("--selecting source --\n");
selecting = TRUE;
} else {
if (!show_bbox_text)
g_object_set (G_OBJECT (nvosd), "display-text", FALSE, NULL);
g_object_set (G_OBJECT (tiler), "show-source", -1, NULL);
source_ids[0] = -1;
break;
default:
break;
return ret;
Please find attached
• Hardware Platform: Jetson Nano
• DeepStream Version: 5.0
• JetPack Version 4.4
• TensorRT Version 7
• NVIDIA GPU Driver Version (valid for GPU only) Not sure, installed recently from here https://developer.nvidia.com/embedded/jetpack
modified the comment above, please see it.
and the fix will be available in the upcoming release.
