Subject: DGX Spark (P4242) – No video output, no DRM devices detected, Secure Boot blocks driver access
Hello NVIDIA Support Team,
I am experiencing a serious issue with my new NVIDIA DGX Spark (Model: P4242, BIOS 5.36_0ACUM018, OS: DGX Spark 7.2.3, Kernel: 6.11.0-1016-nvidia aarch64).
Summary of the problem:
The system boots and is reachable via SSH.
There is no video output at any stage (no UEFI/BIOS screen, no bootloader, no Linux console), despite monitor, cable and ports being functional.
Linux reports no graphics/display devices at all:
ls /sys/class/drm/returns only:version -
/dev/dri/does not exist
This indicates that no DRM device or display controller is detected by the kernel.
Additional relevant context:
The display previously worked normally.
The system itself still boots and works over SSH.
This situation also blocks access to UEFI/BIOS, which makes it impossible to manage settings such as Secure Boot (currently enabled and blocking NVIDIA kernel modules).
From a technical perspective, the absence of any DRM devices strongly suggests either:
A hardware failure in the display subsystem (PHY/controller/power rail), or
A firmware issue causing the display controller not to enumerate at all.
Could you please advise on:
Whether DGX Spark is expected to enumerate DRM/display devices under Linux in a healthy state.
Whether this symptom is consistent with known hardware failures.
Whether this unit should be handled as an RMA case.
If useful, I can provide further logs (dmesg, full system info, etc.).
Thank you for your support.
Kind regards
