Hi all,
I use Jetson Xavier hardware platform.
The OS is Jackpet R32 4.3.
I download docker image from GitHub - dusty-nv/jetson-containers: Machine Learning Containers for NVIDIA Jetson and JetPack-L4T .
I use the dustynv/ros:galactic-ros-base-l4t-r32.4.4 docker image.
nppiMalloc_8u_C3() function return NULL when it run on the docker image.
It can’t normally return correct address.
Why nppiMalloc_8u_C3() return NULL?
Could you give me suggestion?
Following is my test code and command.
<<src/main.cpp>>
#include <stdlib.h>
#include <stdio.h>
#include "cuda_runtime.h"
#include "device_launch_parameters.h"
#include "npp.h"
int main()
int nLineStep_npp = 0;
Npp8u *pu8BGR_dev = nppiMalloc_8u_C3(800, 600, &nLineStep_npp);
if(pu8BGR_dev == NULL)
printf("pu8BGR_dev is NULL\n");
return 0;
<<package.xml>>
<?xml version="1.0"?>
<?xml-model href="http://download.ros.org/schema/package_format3.xsd" schematypens="http://www.w3.org/2001/XMLSchema"?>
<package format="3">
<name>demo</name>
<version>0.0.0</version>
<description>TODO: Package description</description>
<maintainer email="jason@todo.todo">jason</maintainer>
<license>TODO: License declaration</license>
<buildtool_depend>ament_cmake</buildtool_depend>
<depend>rclcpp</depend>
<test_depend>ament_lint_auto</test_depend>
<test_depend>ament_lint_common</test_depend>
<export>
<build_type>ament_cmake</build_type>
</export>
</package>
<<CMakeLists.txt>>
cmake_minimum_required(VERSION 3.8)
project(demo)
# Default to C++14
if(NOT CMAKE_CXX_STANDARD)
set(CMAKE_CXX_STANDARD 14)
endif()
if(CMAKE_COMPILER_IS_GNUCXX OR CMAKE_CXX_COMPILER_ID MATCHES "Clang")
add_compile_options(-Wall -Wextra -Wpedantic)
endif()
set(CMAKE_BUILD_TYPE Debug)
find_package(ament_cmake REQUIRED)
find_package(rclcpp REQUIRED)
include_directories( /usr/local/cuda-10.2/targets/aarch64-linux/include/)
find_package(CUDA REQUIRED)
add_executable(demo src/main.cpp)
target_link_libraries(demo ${CUDA_LIBRARIES} ${CUDA_TOOLKIT_ROOT_DIR}/lib64/libnppig.so ${CUDA_TOOLKIT_ROOT_DIR}/lib64/libnppisu.so ${CUDA_TOOLKIT_ROOT_DIR}/lib64/libnppidei.so)
ament_target_dependencies(demo rclcpp )
target_include_directories(demo PUBLIC
$<BUILD_INTERFACE:${CMAKE_CURRENT_SOURCE_DIR}/include>
$<INSTALL_INTERFACE:include>)
install(TARGETS
demo
DESTINATION lib/${PROJECT_NAME})
if(BUILD_TESTING)
find_package(ament_lint_auto REQUIRED)
ament_lint_auto_find_test_dependencies()
endif()
ament_package()
Following command to wait up docker image
nvidia@xavier:~/$ docker run --user $(id -u):$(id -g) --runtime nvidia -it --privileged --gpus all --rm --network host -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix -v $XAUTH:$XAUTH -e XAUTHORITY=$XAUTH dustynv/ros:galactic-ros-base-l4t-r32.4.4
build command
colcon build --packages-select demo
run result
nvidia@xavier:~/workspace/$ ros2 run demo demo
pu8BGR_dev is NULL
Best regards
-Jason
