I’m getting the error on compute 2023.2.1, driver 535, ubuntu 22.04, on a 1650 super gpu. I have managed to successfully profile the uncoalescedGlobalAccesses in extras/samples.
My log shows:
$ sudo ncu -f --set full --import-source on -o cudart.ncu-rep ./cudart
Rendering a 600x400 image with 10 samples per pixel in 8x8 blocks.
==PROF== Connected to process 12250 (/home/shihab/codes/raytracinginoneweekendincuda/cudart)
==PROF== Profiling “rand_init” - 0: 0%…50%…100% - 31 passes
==PROF== Profiling “create_world” - 1: 0%…50%…100% - 31 passes
==PROF== Profiling “render_init” - 2: 0%…50%…100% - 31 passes
==PROF== Profiling “render” - 3: err:50 | cudart| profiler| >> Sending profiler error message: Launching the workload is taking more time than expected. If this continues to hang, terminate the profile and re-try by profiling the range of all related launches using ‘–replay-mode range’. See Kernel Profiling Guide :: Nsight Compute Documentation for more details.
0%.
==WARNING== Launching the workload is taking more time than expected. If this continues to hang, terminate the profile and re-try by profiling the range of all related launches using ‘–replay-mode range’. See Kernel Profiling Guide :: Nsight Compute Documentation for more details.
err:50 | cudart| cuda| >> Failed to synchronize ctx 0x558fc96e8c20 (error = 702)
err:50 | cudart| profiler| >> Client launch function failed: UnknownError
err:50 | cudart|profiler_data_collector| >> Failed to synchronize stream (error = 702)
err:50 | cudart| profiler| >> Failed ending pass: UnknownError
err:50 | cudart| profiler_experiment| >> Failed launching for SW Counters::1
err:50 | cudart| profiler_experiment| >> Skipping OnEnd due to previous traversal error
err:50 | cudart| cuda_context_state| >> Async context error while copying!
err:50 | cudart| cuda_context_state| >> Failed to transfer context state!
err:50 | cudart| cuda_replay| >> Failed to restore
err:50 | cudart| profiler| >> Client pre iteration failed (UnknownError)
err:50 | cudart| profiler_experiment| >> Failed launching for LOP Counters::0
err:50 | cudart| profiler| >> Profile end failed (LaunchFailed)
err:20 | cudart| cuda| >> ProfileSeries returned an error: LaunchFailed
err:50 | cudart| cuda| >> executeInternal returned an error: LaunchFailed
err:50 | cudart| profiler| >> Sending profiler error message: LaunchFailed
…50%…100% - 2 passes
==ERROR== LaunchFailed
==PROF== Trying to shutdown target application
==ERROR== The application returned an error code (9).
==ERROR== An error occurred while trying to profile.
==WARNING== No source files were imported. Check that the target application was compiled with -lineinfo.
==PROF== Report: /home/shihab/codes/raytracinginoneweekendincuda/cudart.ncu-rep
