i am trying to profile an OptiX 7 Application using Nsight Compute on an Ubuntu 20.10 Machine. The CUDA code gets compiled using the cuda_compile_and_embed command from common/gdt/cmake/configure_optix.cmake · master · Ingo Wald / optix7course · GitLab. The general profiling works as expected, but I don’t get an option to attach my source code, because there seems to be no line info inside the ptx. There is no option to switch from the pure SASS like described in Nsight Compute :: Nsight Compute Documentation.
The cmake macro uses cuda_compile_ptx internally and creates as const char from the result using BIN2C. I extended this macro with the -lineinfo (cuda_compile_ptx(ptx_files ${cuda_file} OPTIONS -lineinfo) but without luck.
What am i missing ? Any help is much appreciated.
