Nsight debuger run problem
hello …
i run my code and getting correct answer but when i want to debug it by Nsight Nvidia debugger , i’ll encounter with this error :
the nsight debugger was not able to start because of the program ‘’ is invalid . please verify the output file name in visual studio , and the Nsight user properties . launch external program setting . this must be an absolute path.
i’ll be appreciate if you tell me what should i do ?
Sorry @@MIRI@@, I don’t use Nsight so don’t know. However, when I did a web search I found this link: How to specify executable for Graphics Debugging - Nsight Visual Studio Edition - NVIDIA Developer Forums. With the solution being:
You need to create a new fake visual c++ project and click on your project item [not your solution item], then you will find the Nsight Option icon in the solution explorer tab.
Configure your path and working directory, and then you can do the debug with Nsight.
  • Mat
thank you for your reply Mat …
i do the procedure but i dont find that Nsight Option icon in the solution explorer tab …
do you know that how i find it ?
Sorry, no. I don’t use Nsight myself. Maybe you can ask the question or find your answer on the Nsight User Forum? Nsight Visual Studio Edition - NVIDIA Developer Forums
  • Mat
