Nsight Systems for x86 Linux and Windows version 2018.3.1
NVIDIA Nsight Systems 2018.3.1 is now available for download!
Get it at NVIDIA Nsight Systems | NVIDIA Developer
Release Highlights
Windows
  • Preliminary support for Windows 7+ including
  • CPU core, process, and thread activity
  • CPU thread state trace
  • CPU thread blocked state backtraces
  • Direct3D 12 (single GPU only)
  • API trace
  • GPU workload trace
  • Including DXR
  • CUDA 10.0
  • NVTX
x86 Linux
  • Improved CPU-GPU correlation experience
  • Improvements to quality, usability, and scalability
If you are installing on a Linux system, by default the tool will change ownership of all the files in the installation directory. You can use the nochown switch to avoid this behavior.
Hi …
I’m tring to use Nsight Systems 2018.3.1 in Window 10.
But when i try to connect via Ethernet then i got this message.
NotFoundError (127) {
OriginalExceptionClass: class boost::exception_detail::clone_impl
OriginalFile: c:\buildagent\work\20a3cfcd1c25021d\quadd\host\analysis\basedevice.cpp
OriginalLine: 589
OriginalFunction: class boost::filesystem::path __cdecl QuadDAnalysis::BaseDevice::GetSpecialFilepath(const class boost::filesystem::path &)
Filename:
ErrorText: Installing special file failed.
I fallowed process through this link.
https://docs.nvidia.com/nsight-systems/#nsight_systems/2018.3.0-x86/05-profiling.htm%3FTocPath%3D_____5
PermitRootLogin yes
sudo firewall-cmd --list-ports
sudo firewall-cmd --permanent --addport 45555/tcp
But I still cannot connect with Tx2 Board
what should I do ?
How can I connect with my Tx2 Board ?
The Nsight Systems 2018.3.1 package is for profiling on x86 targets. To profile on Tegra targets you will need the Tegra version. You can download that package as part of JetPack - JetPack SDK | NVIDIA Developer
Let us know if that does not fix the issue.
Since you are trying to connect to the Tx2 board, you need to use Tegra version of the tool (as Holly suggested). When using the Tegra version, could you enable the verbose logging and share the log file?
To enable the logging, please rename nvlog.config.template file (in Host-x86_64 directory) and restart the tool. After you get the error message, close the tool. The nsight-sys.log file should appear in current directory (Host-x86_64). Please share this log file.
I tried to use Nsight in Linux PC and connection to Tx2 via ethernet.
And finally it works. I don’t know how to use Nsight System in Window OS.
Anyway it works :)
Thanks !!
Sorry for the difficulties, but glad you got it to work for you
