Nsight Systems stuck on the Starting the profiling
System info:
Windows 11
Nvidia Nsight System | Version: 2024.5.1.113-245134619542v0 Windows-x64.
Geforce GTX 1650
I setup a test project in Nsight Systems to experiment with profiling. But after starting the profiling, the project constantly shows “Starting Profiling…” . At the end it never starts and after canceling, Profiling canceled is showen.
What the issue with it ? Is my computer is not compatible or I am doing something wrong.
That should be compatible. Can you tell me what options you had enabled and a little bit about the application (or system-wide) you were trying to run?
@dofek for followup.
The HotKey Start/Stop option may be checked. If that is the case then you must press the hotkey to start the collection of profile data. The default hotkey is F12.
