I’m trying to convert a Directx 9 surface into an OpenGL texture using NV_DX_interop; however, it is not working on NVIDIA GPUs while it is working perfectly on Intel, so there must be something I’m doing wrong but I can’t figure out what. I created a simple application where I have an OpenGL window, and I’m sharing a directx 9 surface with an Opengl texture. At each frame, I update the directx surface by changing the blue component (so the surface goes from black to blue over 255 frames, and so on), and then I bind the OpenGL texture on a quad that I render.
Here is some part of my code (I can send the entire code if necessary) to illustrate what I’m doing:
// Once my OpenGL window is created using SDL, I create the directx surface like this:
D3DPRESENT_PARAMETERS d3dpp;
ZeroMemory(&d3dpp, sizeof(d3dpp));
d3dpp.Windowed = TRUE;
d3dpp.SwapEffect = D3DSWAPEFFECT_DISCARD;
d3dpp.hDeviceWindow = GetActiveWindow();
d3dpp.BackBufferFormat = D3DFMT_X8R8G8B8;
d3dpp.MultiSampleType = D3DMULTISAMPLE_NONE;
Direct3DCreate9Ex(D3D_SDK_VERSION, &d3d9);
d3d9->CreateDeviceEx(D3DADAPTER_DEFAULT, D3DDEVTYPE_HAL, d3dpp.hDeviceWindow, D3DCREATE_HARDWARE_VERTEXPROCESSING | D3DCREATE_PUREDEVICE | D3DCREATE_MULTITHREADED, &d3dpp, NULL, &d3d9Device);
d3d9Device->CreateOffscreenPlainSurface(width, height, D3DFMT_A8R8G8B8, D3DPOOL_DEFAULT, &sharedSurface, &sharedSurfaceHandle);
// Then I initialize my interop object like this:
interopHandle = wglDXOpenDeviceNV(d3d9Device);
glGenTextures(1, &texture);
wglDXSetResourceShareHandleNV(sharedSurface, sharedSurfaceHandle);
glSharedTextureHandle = wglDXRegisterObjectNV(interopHandle, sharedSurface, texture, GL_TEXTURE_2D, WGL_ACCESS_READ_WRITE_NV);
// Then in my rendering loop, I update the surface by locking it, updating the pixels and unlocking
// And finally I draw my quad like this
wglDXLockObjectsNV(interopHandle, 1, &glSharedTextureHandle);
glClearColor(0.0f, 0.0f, 0.0f, 1.0f);
glClear(GL_COLOR_BUFFER_BIT);
glBindTexture(GL_TEXTURE_2D, texture);
glUseProgram(program);
glUniform1i(texUniform, 0);
glBindVertexArray(vao);
glDrawArrays(GL_TRIANGLES, 0, 6);
glBindVertexArray(0);
glUseProgram(0);
glBindTexture(GL_TEXTURE_2D, 0);
SDL_GL_SwapWindow(window);
wglDXUnlockObjectsNV(interopHandle, 1, &glSharedTextureHandle);
Everything seems to be initialized properly. I do not get any DirectX or OpenGL errors. The interop object seems to be initialized properly. Again, on Intel GPUs, this code works and I can see my texture going from black to blue over and over again. On NVIDIA, I get a black texture, and it looks like a bunch of threads get created and killed, and after a few seconds, I get a “NVIDIA OpenGL Driver” popup with the message “A large number of errors have been detected. […]”. There is obviously something I’m not doing correctly but all the samples I’ve looked at over the past 3 days look similar to what I’m doing. If anyone could help, that would be great!
Thanks,
Cyril
