Nvargus cannot find camera while v4l2 works
I am working on the driver of ov428+ochta10 camera on Orin32G. Here are the dtsi file about if.
  • Copyright (c) 2017-2021, NVIDIA CORPORATION. All rights reserved.
  • This program is free software; you can redistribute it and/or modify it
  • under the terms and conditions of the GNU General Public License,
  • version 2, as published by the Free Software Foundation.
  • This program is distributed in the hope it will be useful, but WITHOUT
  • ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
  • FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
  • more details.
  • You should have received a copy of the GNU General Public License
  • along with this program. If not, see http://www.gnu.org/licenses/.
    include <t234-common-modules/tegra234-camera-ochta10-a00.dtsi>
    include “dt-bindings/clock/tegra234-clock.h”
define CAM0_RST_L TEGRA234_MAIN_GPIO(H, 6)
define CAMERA_I2C_MUX_BUS(x) (0x1E + x)
/* camera control gpio definitions */
gpio@2200000 {
camera-control-output-low {
gpio-hog;
output-low;
gpios = <CAM0_RST_L 0>;
label = “cam0-rst”;
i2c@3180000 {
	tca9546@70 {
		compatible = "nxp,pca9546";
		reg = <0x70>;
		#address-cells = <1>;
		#size-cells = <0>;
		skip_mux_detect = "yes";
		vif-supply = <&p3737_vdd_1v8_sys>;
		vcc-supply = <&p3737_vdd_1v8_sys>;
		vcc_lp = "vcc";
		force_bus_start = <CAMERA_I2C_MUX_BUS(0)>;
		vcc-pullup-supply = <&battery_reg>;
		i2c@0 {
			reg = <0>;
			i2c-mux,deselect-on-exit;
			ochta10_a@36 {
				def-addr = <0x10>;
				/* Define any required hw resources needed by driver */
				/* ie. clocks, io pins, power sources */
				clocks = <&bpmp_clks TEGRA234_CLK_EXTPERIPH1>,
						 <&bpmp_clks TEGRA234_CLK_EXTPERIPH1>;
				clock-names = "extperiph1", "pllp_grtba";
				mclk = "extperiph1";
				reset-gpios = <&tegra_main_gpio CAM0_RST_L GPIO_ACTIVE_HIGH>;
  • Copyright (c) 2016-2021, NVIDIA CORPORATION. All rights reserved.
  • more details.
tegra-capture-vi {
num-channels = <1>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
liochta10_vi_in0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&liochta10_csi_out0>;
host1x@13e00000 {
	nvcsi@15a00000 {
		num-channels = <1>;
		#size-cells = <0>;
		channel@0 {
			reg = <0>;
			ports {
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					liochta10_csi_in0: endpoint@0 {
						port-index = <0>;
						bus-width = <2>;
						remote-endpoint = <&liochta10_ochta10_out0>;
				port@1 {
					reg = <1>;
					liochta10_csi_out0: endpoint@1 {
						remote-endpoint = <&liochta10_vi_in0>;
i2c@3180000 {
	tca9546@70 {
		i2c@0 {
			ochta10_a@36 {
				compatible = "ov,ochta10";
				reg = <0x36>;
				devnode = "video0";
				/* Physical dimensions of sensor */
				physical_w = "6.0";
				physical_h = "6.0";
				sensor_model ="ochta10";
				/* Defines number of frames to be dropped by driver internally after applying */
				/* sensor crop settings. Some sensors send corrupt frames after applying */
				/* crop co-ordinates */
				post_crop_frame_drop = "0";
				/* Convert Gain to unit of dB (decibel) befor passing to kernel driver */
				//use_decibel_gain = "true";
				/* if true, delay gain setting by one frame to be in sync with exposure */
				delayed_gain = "true";
				/* enable CID_SENSOR_MODE_ID for sensor modes selection */
				use_sensor_mode_id = "true";
				/* WAR to prevent banding by reducing analog gain. Bug 2229902 */
				limit_analog_gain = "true";
				* ==== Modes ====
				* A modeX node is required to support v4l2 driver
				* implementation with NVIDIA camera software stack
				* == Signal properties ==
				* phy_mode = "";
				* PHY mode used by the MIPI lanes for this device
				* tegra_sinterface = "";
				* CSI Serial interface connected to tegra
				* Incase of virtual HW devices, use virtual
				* For SW emulated devices, use host
				* pix_clk_hz = "";
				* Sensor pixel clock used for calculations like exposure and framerate
				* readout_orientation = "0";
				* Based on camera module orientation.
				* Only change readout_orientation if you specifically
				* Program a different readout order for this mode
				* == Image format Properties ==
				* active_w = "";
				* Pixel active region width
				* active_h = "";
				* Pixel active region height
				* pixel_t = "";
				* The sensor readout pixel pattern
				* line_length = "";
				* Pixel line length (width) for sensor mode.
				* == Source Control Settings ==
				* Gain factor used to convert fixed point integer to float
				* Gain range [min_gain/gain_factor, max_gain/gain_factor]
				* Gain step [step_gain/gain_factor is the smallest step that can be configured]
				* Default gain [Default gain to be initialized for the control.
				*     use min_gain_val as default for optimal results]
				* Framerate factor used to convert fixed point integer to float
				* Framerate range [min_framerate/framerate_factor, max_framerate/framerate_factor]
				* Framerate step [step_framerate/framerate_factor is the smallest step that can be configured]
				* Default Framerate [Default framerate to be initialized for the control.
				*     use max_framerate to get required performance]
				* Exposure factor used to convert fixed point integer to float
				* For convenience use 1 sec = 1000000us as conversion factor
				* Exposure range [min_exp_time/exposure_factor, max_exp_time/exposure_factor]
				* Exposure step [step_exp_time/exposure_factor is the smallest step that can be configured]
				* Default Exposure Time [Default exposure to be initialized for the control.
				*     Set default exposure based on the default_framerate for optimal exposure settings]
				* gain_factor = ""; (integer factor used for floating to fixed point conversion)
				* min_gain_val = ""; (ceil to integer)
				* max_gain_val = ""; (ceil to integer)
				* step_gain_val = ""; (ceil to integer)
				* default_gain = ""; (ceil to integer)
				* Gain limits for mode
				* exposure_factor = ""; (integer factor used for floating to fixed point conversion)
				* min_exp_time = ""; (ceil to integer)
				* max_exp_time = ""; (ceil to integer)
				* step_exp_time = ""; (ceil to integer)
				* default_exp_time = ""; (ceil to integer)
				* Exposure Time limits for mode (sec)
				* framerate_factor = ""; (integer factor used for floating to fixed point conversion)
				* min_framerate = ""; (ceil to integer)
				* max_framerate = ""; (ceil to integer)
				* step_framerate = ""; (ceil to integer)
				* default_framerate = ""; (ceil to integer)
				* Framerate limits for mode (fps)
				* embedded_metadata_height = "";
				* Sensor embedded metadata height in units of rows.
				* If sensor does not support embedded metadata value should be 0.
				mode0 {/*mode OCHTA10_MODE_800X800_CROP_30FPS*/
					mclk_khz = "24000";
					num_lanes = "2";
					phy_mode = "DPHY";
					discontinuous_clk = "no";
					dpcm_enable = "false";
					cil_settletime = "0";
					dynamic_pixel_bit_depth = "10";
					csi_pixel_bit_depth = "10";
					mode_type = "bayer";
					pixel_phase = "bggr";
					active_w = "400";
					active_h = "400";
					line_length = "408";
					inherent_gain = "1";
					//mclk_multiplier = "1.67";
					pix_clk_hz = "18000000";
					gain_factor = "1";
					min_gain_val = "1";
					max_gain_val = "15";
					step_gain_val = "1";
					default_gain = "12";
					min_hdr_ratio = "1";
					max_hdr_ratio = "1";
					framerate_factor = "1000000";
					min_framerate = "1500000"; /* 1.5 */
					max_framerate = "30000000"; /* 30 */
					step_framerate = "1";
					default_framerate= "30000000";
					exposure_factor = "1000000";
					min_exp_time = "30"; /* us */
					max_exp_time = "33333"; /* us */
					step_exp_time = "1";
					default_exp_time = "33333";/* us */
					embedded_metadata_height = "0";
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						liochta10_ochta10_out0: endpoint {
							port-index = <0>;
							bus-width = <2>;
							remote-endpoint = <&liochta10_csi_in0>;
tegra-camera-platform {
	compatible = "nvidia, tegra-camera-platform";
	* Physical settings to calculate max ISO BW
	* num_csi_lanes = <>;
	* Total number of CSI lanes when all cameras are active
	* max_lane_speed = <>;
	* Max lane speed in Kbit/s
	* min_bits_per_pixel = <>;
	* Min bits per pixel
	* vi_peak_byte_per_pixel = <>;
	* Max byte per pixel for the VI ISO case
	* vi_bw_margin_pct = <>;
	* Vi bandwidth margin in percentage
	* max_pixel_rate = <>;
	* Max pixel rate in Kpixel/s for the ISP ISO case
	* isp_peak_byte_per_pixel = <>;
	* Max byte per pixel for the ISP ISO case
	* isp_bw_margin_pct = <>;
	* Isp bandwidth margin in percentage
	num_csi_lanes = <4>;
	max_lane_speed = <1500000>;
	min_bits_per_pixel = <10>;
	vi_peak_byte_per_pixel = <2>;
	vi_bw_margin_pct = <25>;
	isp_peak_byte_per_pixel = <5>;
	isp_bw_margin_pct = <25>;
	 * The general guideline for naming badge_info contains 3 parts, and is as follows,
	 * The first part is the camera_board_id for the module; if the module is in a FFD
	 * platform, then use the platform name for this part.
	 * The second part contains the position of the module, ex. "rear" or "front".
	 * The third part contains the last 6 characters of a part number which is found
	 * in the module's specsheet from the vender.
	modules {
		module0 {
			badge = "ochta10_bottom_liochta10";
			position = "bottom";
			orientation = "0";
			drivernode0 {
				/* Declare PCL support driver (classically known as guid)  */
				pcl_id = "v4l2_sensor";
				/* Driver v4l2 device name */
				devname = "ochta10 2-0036";
				/* Declare the device-tree hierarchy to driver instance */
				proc-device-tree = "/proc/device-tree/i2c@3180000/tca9546@70/i2c@0/ochta10_a@36";
I can get the raw image by v4l2 but the raw image seems no right.
When I try to use nvgstcapure-1.0. I get this log:
*nvidia@nvidia-desktop:~$ sudo service nvargus-daemon stop
[sudo] password for nvidia:
nvidia@nvidia-desktop:~$ 123
bash: 123: command not found
nvidia@nvidia-desktop:~$ sudo enableCamInfiniteTimeout=1 nvargus-daemon
=== NVIDIA Libargus Camera Service (0.98.3)=== Listening for connections…=== nvgstcapture-1.0[2804]: Connection established (FFFF7EB84900)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
(NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
(NvCamV4l2) Error ModuleNotPresent: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
(NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 107)
NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
NvPclStartPlatformDrivers: Failed to start module drivers
NvPclStateControllerOpen: Failed ImagerGUID 0. (error 0xA000E)
NvPclOpen: PCL Open Failed. Error: 0xf
SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 677)
SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 453)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 333)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 505)
=== nvgstcapture-1.0[2804]: CameraProvider initialized (0xffff78685d70)sudo enableCamInfiniteTimeout=1 nvargus-daemon
Have I make any misstake ?
Could be the devname incorrect.
If could be “ochta10 30-0036” confirm by v4l2-ctl --list-devices
Thanks for your reply.
It’s true that I have mistake in devname.
It can work now.
