Hi!
I am trying to run the following on a jetson orion nano with jetpack 5.1.2. Running the same code on a jetson nano with jetpack 4.6.1 worked fine. For both i am useing a arducam IMX477
running: v4l2_open(dev.name, O_RDWR) , where dev.name, is /dev/video0 , gives the following crash:
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 277)
(Argus) Error EndOfFile: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 350)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 366)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 379)
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error EndOfFile: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
ArgusV4L2_Open failed: No such file or directory
nvbufsurftransform:cuInit failed : 999
Segmentation fault (core dumped).
I have checked if /dev/video0 has any issues through: v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=10 -d /dev/video0 --verbose , which shows that the communication with the camera is ok.
Running gst-launch-1.0 nvarguscamerasrc ! "video/x-raw(memory:NVMM),width=4032,height=3040,framerate=30/1,format=NV12” ! nvvidconv “video/x-raw, format=BGRx” ! fpsdisplaysink video-sink=fakesink text-overlay=false sync=false -v on the other hand gives similar error as above. I get this error every time i try to run the code and have tried restarting the nvargus daemon, but this has not helped.
Any help would be much appreciated!
