Nvargus-Daemon for each individual CameraDevice
Is it possible to run multiple instances of nvargus-daemon, one for each camera device?
I can provide more information as needed, but basically I would like to handle failures in the camera provider by restarting instances of the daemon. I am seeing failures very similar to this topic: JP5.1 nvarguscamera doesn't recover from single NVCSI failure - #36 by JerryChang
Unlike that topic, I cannot terminate the process which has my Gstreamer pipeline. Trying to stop the pipeline from playing leads to the same errors, and trying to create a new nvarguscamerasrc fails because the resource is already owned.
By restarting a background process like the daemon, I can avoid terminating my main process with the pipeline. But restarting the nvargus-daemon causes all camera streams to be affect, and I do not want to impact the successful streams when there is a failure with one. (I am streaming 8 cameras on my custom carrier board.) Until now, I have been running without daemon doing this: Argus (Tegra Multimedia API) in multi-process mode does not terminate - #5 by ShaneCCC
I am running my pipeline on AGX Xavier with Jetpack 5.1.1. Let me know what additional information I can provide.
You can build the argus APP by DISABLE_MULTIPROCESS by below command.
cmake -DDISABLE_MULTIPROCESS=ON ..
Thank you for the quick response.
From what I understand reading these two posts…
… DISABLE_MULTIPROCESS=ON will build the Argus application so that it does not link to libnvargus_socketclient.so. I.e., the CameraProvider Argus calls will not be via socket to the Nvargus-daemon - daemon should NOT be running.
For example, with DISABLE_MULTIPROCESS=ON, CameraProvider:: createCaptureSession(CameraDevice*, Status*) would NOT be handled by the daemon, it would be directly handled by libnvargus.so. (Refer to API for CameraProvider here.)
I hope my understanding is correct.
However, what I would like is that the CameraProvider in a process calls ONE instance daemon process FOR EACH CameraDevice. For example, one daemon process handles CaptureSession instance #1, another daemon with another PID handles CaptureSession instance #2, etc.
In that case, rather than DISABLE_MULTIPROCESS=ON, I would like to build the Argus application with something like ENABLE_MULTIPROCESS_MULTIPLE_DAEMONS=ON (a hypothetical build flag).
Is something like this possible?
As I mentioned above, the reason I am wondering if this is possible is that for all releases of Jetpack 5.X.X that I have tested, the Nvargus-Daemon can have failures and needs to be restarted. I gave an example of a failure above.
If all CaptureSession instances are handled by one daemon, and the daemon fails, then all stream will fail. On the other hand, if there are multiple daemon processes, I can restart each individually, and there should be no impact on other CaptureSession instances.
I cannot build with DISABLE_MULTIPROCESS=ON because I do not want to start and terminate multiple application processes, one for each CameraDevice.
I hope this makes more sense. Please let me know if it is unclear or if you need more information.
I don’t think so.
What’s my suggest is build by DISABLE_MULTIPROCESS=ON and terminal each failed camera and restart it.
Understood that this is not possible. Thanks for letting me know.
