argus_camera app
Hi Folks,
I am looking to run argus_camera app in tegra_multimedia_api. I would like to try multisession. When I choose multisession from top menu it seems to crash. Please help.
nvidia@tegra-ubuntu:~/tegra_multimedia_api/argus/build/apps/camera/ui/camera$ ./argus_camera
Executing Argus Sample Application (argus_camera)
Argus Version: 0.96.2 (multi-process)
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 214)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 317)
(Argus) Error InvalidState: Receive thread is not running cannot send. (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 96)
(Argus) Error InvalidState:  (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 101)
My version info -
nvidia@tegra-ubuntu:~/tegra_multimedia_api/argus/build/apps/camera/ui/camera$ head -n 2 /etc/nv_tegra_release
# R28 (release), REVISION: 2.1, GCID: 11272647, BOARD: t186ref, EABI: aarch64, DATE: Thu May 17 07:29:06 UTC 2018
Hi Nvidia folks,
Please help.
THanks
Do you reproduce the issue with default camera board(ov5693)?
I am using IMX274 from Leopard.
Thanks,
hello dumbogeorge,
several questions need your feedback. thanks
  1. may I know many cameras you would like to launch?
  2. could you please verify all of them were able to access individually
  3. what were these camera sensor modes, for example, resolution and frame rate.
  4. could you please execute argus_camera service manually to gather more logs.
  1. I would like to launch two cameras.
  2. Yes - when I run ./argus_camera - I am able to increment the “device” and I see camera switch from 0 to 1 and back from 1 to 0. Individually each camera is working from ./argus_camera
  3. See 4 camera sensor modes
0: 3840x2160 @ 10bpp
1: 1920x1080 @ 10bpp
2: 1280x720 @ 10bpp
3: 12880x540 @ 10bpp
I switch to sensor mode 1. Select fps to be 30. THen I go to top menu and select Multi Session
After this I do see screen showing view from both cameras - after a sec (during this time video is very jerky, in both views) or two - the screen freezes.
Following messages would come on screen…
Nothing happens after this. When I kill the app (from its cross sign on GUI) I get -
  1. How would you like me to run and gather more logs ?
THanks
Can you also report the issue to Leopard? We have verified the app with default camera board and internal multi-camera board. The app works well. Seems not an issue in Argus SW stacks.
hello dumbogeorge,
  1. you should execute argus_daemon manually to gather more logs.
    for example,
terminal-A
$ sudo /usr/sbin/argus_daemon
terminal-B
$ ./argus_camera
  1. share some alternative ways to access dual cameras, please have a try and let us know the results.
    2.1) v4l2-ctls
$ v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap
$ v4l2-ctl -d /dev/video1 --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap
2.2) gstreamer pipeline
$ gst-launch-1.0 nvcamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM), format=I420, width=1920, height=1080, framerate=30/1" ! nvvidconv ! "video/x-raw(memory:NVMM), format=I420, width=1920, height=360, framerate=30/1" ! nvoverlaysink overlay=0 overlay-x=0 overlay-y=0 overlay-w=1920 overlay-h=360 nvcamerasrc sensor-id=1 ! "video/x-raw(memory:NVMM), format=I420, width=1920, height=1080, framerate=30/1" ! nvvidconv ! "video/x-raw(memory:NVMM), format=I420, width=1920, height=360, framerate=30/1" ! nvoverlaysink overlay=1 overlay-x=0 overlay-y=361 overlay-w=1920 overlay-h=360
2.3) MMAPI
~/tegra_multimedia_api/samples/13_multi_camera/multi_camera -n 2
Hi JerryChang
  1. I ran argus_daemon manually
Log from Terminal A where I ran the command sudo /usr/bin/argus_daemon
[code]
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp] 2/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
SCF: Error InvalidState: NonFatal ISO BW requested not set. Requested = 2147483647 Set = 4687500 (in src/services/power/PowerServiceCore.cpp, function setCameraBw(), line 653)
SCF: Error InvalidState: NonFatal ISO BW requested not set. Requested = 4294967294 Set = 4687500 (in src/services/power/PowerServiceCore.cpp, function setCameraBw(), line 653)
(NvOdmDevice) Error IoctlFailed: (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function setControlValMultiple(), line 781)
(NvOdmDevice) Error IoctlFailed: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function setDeviceControls(), line 1618)
updateOutputSettings: Set Control failed. Use cached values
SCF: Error InvalidState: NonFatal ISO BW requested not set. Requested = 6442450941 Set = 4687500 (in src/services/power/PowerServiceCore.cpp, function setCameraBw(), line 653)
(NvOdmDevice) Error IoctlFailed: (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function streamControl(), line 1642)
(NvOdmDevice) Error IoctlFailed: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function apply(), line 202)
SCF: Error InvalidState: NonFatal ISO BW requested not set. Requested = 4296443856 Set = 4687500 (in src/services/power/PowerServiceCore.cpp, function setCameraBw(), line 653)
SCF: Error InvalidState: NonFatal ISO BW requested not set. Requested = 2150436771 Set = 4687500 (in src/services/power/PowerServiceCore.cpp, function setCameraBw(), line 653)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
launchCC abort cc 104 session 0
SCF: Error Timeout: (propagating from src/api/Session.cpp, function capture(), line 830)
(Argus) Error Timeout: (propagating from src/api/ScfCaptureThread.cpp, function run(), line 109)
launchCC abort cc 105 session 0
(Argus) Error InvalidState: MetadataResult callback for unknown capture. (in src/api/CaptureSessionImpl.cpp, function metadataResult(), line 705)
launchCC abort cc 106 session 0
launchCC abort cc 107 session 0
launchCC abort cc 108 session 0
launchCC abort cc 109 session 0
launchCC abort cc 110 session 0
launchCC abort cc 111 session 0
launchCC abort cc 112 session 0
launchCC abort cc 113 session 0
launchCC abort cc 114 session 0
launchCC abort cc 115 session 0
launchCC abort cc 116 session 0
launchCC abort cc 117 session 0
launchCC abort cc 118 session 0
launchCC abort cc 119 session 0
launchCC abort cc 120 session 0
launchCC abort cc 121 session 0
launchCC abort cc 122 session 0
launchCC abort cc 123 session 0
launchCC abort cc 124 session 0
launchCC abort cc 125 session 0
launchCC abort cc 126 session 0
launchCC abort cc 127 session 0
launchCC abort cc 128 session 0
launchCC abort cc 129 session 0
launchCC abort cc 130 session 0
launchCC abort cc 131 session 0
launchCC abort cc 132 session 0
launchCC abort cc 133 session 0
launchCC abort cc 134 session 0
launchCC abort cc 135 session 0
launchCC abort cc 136 session 0
launchCC abort cc 137 session 0
launchCC abort cc 138 session 0
launchCC abort cc 139 session 0
launchCC abort cc 140 session 0
launchCC abort cc 141 session 0
launchCC abort cc 142 session 0
launchCC abort cc 143 session 0
launchCC abort cc 144 session 0
launchCC abort cc 145 session 0(Argus) Error InvalidState: MetadataResult callback for unknown capture. (in src/api/CaptureSessionImpl.cpp, function metadataResult(), line 705)
launchCC abort cc 146 session 0
launchCC abort cc 147 session 0
launchCC abort cc 148 session 0
launchCC abort cc 149 session 0
launchCC abort cc 150 session 0
launchCC abort cc 151 session 0
launchCC abort cc 152 session 0
launchCC abort cc 153 session 0
launchCC abort cc 154 session 0
launchCC abort cc 155 session 0
launchCC abort cc 156 session 0
launchCC abort cc 157 session 0
launchCC abort cc 158 session 0
launchCC abort cc 159 session 0
launchCC abort cc 160 session 0
launchCC abort cc 161 session 0
launchCC abort cc 162 session 0
launchCC abort cc 163 session 0
launchCC abort cc 164 session 0
launchCC abort cc 165 session 0
launchCC abort cc 166 session 0
launchCC abort cc 167 session 0
launchCC abort cc 168 session 0
launchCC abort cc 169 session 0
launchCC abort cc 170 session 0
launchCC abort cc 171 session 0
launchCC abort cc 172 session 0
launchCC abort cc 173 session 0
launchCC abort cc 174 session 0
launchCC abort cc 175 session 0
launchCC abort cc 176 session 0
launchCC abort cc 177 session 0
launchCC abort cc 178 session 0
launchCC abort cc 179 session 0
launchCC abort cc 180 session 0
launchCC abort cc 181 session 0
launchCC abort cc 182 session 0
launchCC abort cc 183 session 0
launchCC abort cc 184 session 0
launchCC abort cc 185 session 0
launchCC abort cc 186 session 0
launchCC abort cc 187 session 0
launchCC abort cc 188 session 0
launchCC abort cc 189 session 0
launchCC abort cc 190 session 0
launchCC abort cc 191 session 0
launchCC abort cc 192 session 0
launchCC abort cc 193 session 0
launchCC abort cc 194 session 0
launchCC abort cc 195 session 0
launchCC abort cc 196 session 0
launchCC abort cc 197 session 0
launchCC abort cc 198 session 0
launchCC abort cc 199 session 0
launchCC abort cc 200 session 0
launchCC abort cc 201 session 0
launchCC abort cc 202 session 0
launchCC abort cc 203 session 0
launchCC abort cc 204 session 0
launchCC abort cc 205 session 0
launchCC abort cc 206 session 0
launchCC abort cc 207 session 0
launchCC abort cc 208 session 0
launchCC abort cc 209 session 0
launchCC abort cc 210 session 0(Argus) Error InvalidState: MetadataResult callback for unknown capture. (in src/api/CaptureSessionImpl.cpp, function metadataResult(), line 705)
launchCC abort cc 211 session 0(Argus) Error InvalidState: MetadataResult callback for unknown capture. (in src/api/CaptureSessionImpl.cpp, function metadataResult(), line 705)
launchCC abort cc 212 session 0
launchCC abort cc 213 session 0
launchCC abort cc 214 session 0
launchCC abort cc 215 session 0
launchCC abort cc 216 session 0
launchCC abort cc 217 session 0
launchCC abort cc 218 session 0
launchCC abort cc 219 session 0(Argus) Error InvalidState: MetadataResult callback for unknown capture. (in src/api/CaptureSessionImpl.cpp, function metadataResult(), line 705)
launchCC abort cc 220 session 0
launchCC abort cc 221 session 0
launchCC abort cc 222 session 0
launchCC abort cc 223 session 0
launchCC abort cc 224 session 0
launchCC abort cc 225 session 0
launchCC abort cc 226 session 0
launchCC abort cc 227 session 0
launchCC abort cc 228 session 0
launchCC abort cc 229 session 0
launchCC abort cc 230 session 0
launchCC abort cc 231 session 0
launchCC abort cc 232 session 0
launchCC abort cc 233 session 0
launchCC abort cc 234 session 0
launchCC abort cc 235 session 0
launchCC abort cc 236 session 0
launchCC abort cc 237 session 0
launchCC abort cc 238 session 0
launchCC abort cc 239 session 0
launchCC abort cc 240 session 0
launchCC abort cc 241 session 0
launchCC abort cc 242 session 0
launchCC abort cc 243 session 0
launchCC abort cc 244 session 0
launchCC abort cc 245 session 0
launchCC abort cc 246 session 0
launchCC abort cc 247 session 0
launchCC abort cc 248 session 0
launchCC abort cc 249 session 0
launchCC abort cc 250 session 0
launchCC abort cc 251 session 0
launchCC abort cc 252 session 0
launchCC abort cc 253 session 0
launchCC abort cc 254 session 0
launchCC abort cc 255 session 0
launchCC abort cc 256 session 0
launchCC abort cc 257 session 0
launchCC abort cc 258 session 0
launchCC abort cc 259 session 0
launchCC abort cc 260 session 0
launchCC abort cc 261 session 0
launchCC abort cc 262 session 0
launchCC abort cc 263 session 0
launchCC abort cc 264 session 0
launchCC abort cc 265 session 0
launchCC abort cc 266 session 0
launchCC abort cc 267 session 0
launchCC abort cc 268 session 0
launchCC abort cc 269 session 0
launchCC abort cc 270 session 0
(Argus) Error In
Hi JerryChang
[code]
(Argus) Error
Sorry I am not able to post entire log.
  1. I do not have v4l2-ctl on my machine. How do I install it ? But I think you intent is to find out whether dual camera operation work or not. I think it does.
2.2 I do not have nvoverlaysink - so the command given by you does not work. However I ran following command , for concurrent preview of two cameras - and it worked.
gst-launch-1.0 nvcamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=1920,height=1080" !  nvvidconv flip-method=0 ! "video/x-raw, format=(string)I420" ! xvimagesink -e  nvcamerasrc sensor-id=1 ! "video/x-raw(memory:NVMM),width=1920,height=1080" !  nvvidconv flip-method=0 ! "video/x-raw, format=(string)I420" ! xvimagesink -e
2.3 The command you gave here worked successfully. I do not smell problem at driver level.
Thanks,
Hi dumbogeorge,
Which adapter board/ carrier board are you using? It must connect all 3 or 6 cameras (for 3 or 6 port adapter /carrier board) to run the Argus multi session. Otherwise, the argus will crash.
We are using your TX1/TX2 CB, and have two IMX274 on it. However the board has slots for 3 cameras.
I thought it is able to detect number of cameras attached, and would use that count to switch between them. What would it take to work with number of cameras which are present and not worry about the camera which is absent ?
THanks
Hi dumbogeorge,
We enabled all 3 cameras in the driver. It may need to disable one camera (like channel video2) to support only two cameras.
Since you got the driver source code from us, you can give it a try.
Hi Simon
My understanding is that driver is common whether we run argus or gstreamer command lines - is that right ? If so I am able to run two cameras for preview or for encode - concurrently from gstreamer command line and also from example 13, as asked by JerryChange in #8.
Why are these two cases working with the driver which has 3 cameras enabled ?
Hi dumbogeorge,
Since we enabled all three cameras, there will video0 ~ video2 under /dev even only two cameras connected. You can use the argus or gstremamer commands to run video0 or video1 separately. However, the Argus " multi session" is different. Once open it, the argus will try to open all 3 video devices. Since there is no camera for video2, the argus will crash.
Hi Simon
It turns out that it is easy to override the numbers of cameras returned by driver. When I do that the multi session example works.
THanks
Folks,
I am looking to modify argus_camera (multiSession ) example to my needs. I have two cameras in my system and would like to create two instances of following pipeline
camera ---> preview
      |---->Encoder
      |----->OpenCV Consumers (frame processing on GPU/CPU)
Aforesaid pipeline is working for two cameras without “OpenCV Consumer”. When I look to add “OpenCV Consumer” - I am getting infinitely stuck at producer/consumer connection point -
PROPAGATE_ERROR(iStream->waitUntilConnected());
I am attaching my modified code (derived from ~/tegra_multimedia_api/argus/apps/camera/modules/tasks/MultiSession.cpp. WOuld greatly appreciate help about what could be wrong about adding an additional OutputStream to the camera source
#include <sstream>
#include <iomanip>
#include "MultiSession.h"
#include "Composer.h"
#include "Dispatcher.h"
#include "Error.h"
#include "UniquePointer.h"
#include "PerfTracker.h"
namespace ArgusSamples
TaskMultiSession::TaskMultiSession(aaConfig *pConfig)
    : m_initialized(false)
    , m_running(false)
    , m_prevRunning(false)
    , m_pConfig(pConfig)
TaskMultiSession::~TaskMultiSession()
    shutdown();
TaskMultiSession::Session::Session(TaskMultiSession *ptaskMultiSession)
    m_pParent = ptaskMultiSession;
TaskMultiSession::Session::~Session()
    shutdown();
bool TaskMultiSession::Session::initialize(uint32_t deviceIndex)
    PROPAGATE_ERROR(initializePreview(deviceIndex));
    PROPAGATE_ERROR(initializeCamCapture(deviceIndex));
    PROPAGATE_ERROR(initializeEncoder(deviceIndex));
    return true;
bool TaskMultiSession::Session::start()
    Dispatcher &dispatcher = Dispatcher::getInstance();
    PROPAGATE_ERROR(startCamCapture());
    PROPAGATE_ERROR(startPreview());
    PROPAGATE_ERROR(startEncoder());
    // start the repeating burst request for the preview
    PROPAGATE_ERROR(m_perfTracker->onEvent(SESSION_EVENT_ISSUE_CAPTURE));
    PROPAGATE_ERROR(dispatcher.startRepeat(m_request.get(), m_session.get()));
    return true;
bool TaskMultiSession::Session::stop()
    PROPAGATE_ERROR(stopEncoder());
    PROPAGATE_ERROR(stopCamCapture());
    PROPAGATE_ERROR(stopPreview());
    return true;
bool TaskMultiSession::Session::shutdown()
    PROPAGATE_ERROR(shutdownEncoder());
    PROPAGATE_ERROR(shutdownCamCapture());
    PROPAGATE_ERROR(shutdownPreview());
    return true;
bool TaskMultiSession::Session::initializePreview(uint32_t deviceIndex)
    // create the perf tracker
    m_perfTracker.reset(new SessionPerfTracker());
    if (!m_perfTracker)
        ORIGINATE_ERROR("Out of memory");
    PROPAGATE_ERROR(m_perfTracker->onEvent(SESSION_EVENT_TASK_START));
    Composer &composer = Composer::getInstance();
    // create the session using the current device index
    PROPAGATE_ERROR(dispatcher.createSession(m_session, deviceIndex));
    PROPAGATE_ERROR(m_perfTracker->setSession(m_session.get()));
    // create the request
    PROPAGATE_ERROR(dispatcher.createRequest(m_request, Argus::CAPTURE_INTENT_VIDEO_RECORD,
        m_session.get()));
    // Create the preview stream
    PROPAGATE_ERROR(dispatcher.createOutputStream(m_request.get(), false,  m_outputStream,
        m_session.get()));
    // bind the preview stream to the composer
    Argus::IStream *iStream = Argus::interface_cast<Argus::IStream>(m_outputStream.get());
    if (!iStream)
        ORIGINATE_ERROR("Failed to get IStream interface");
    // Bind the stream to the composer
    PROPAGATE_ERROR(composer.bindStream(iStream->getEGLStream()));
    const Argus::Size2D<uint32_t> streamSize = iStream->getResolution();
    PROPAGATE_ERROR(composer.setStreamAspectRatio(iStream->getEGLStream(),
        (float)streamSize.width() / (float)streamSize.height()));
    // Enable the output stream
    PROPAGATE_ERROR(dispatcher.enableOutputStream(m_request.get(), m_outputStream.get()));
    return true;
bool TaskMultiSession::Session::initializeEncoder(uint32_t deviceIndex)
    // setup the video pipeline with the video stream
    m_videoPipeline = new VideoPipeline;
    if (!m_videoPipeline)
    // Create the video output stream
    PROPAGATE_ERROR(dispatcher.createOutputStream(m_request.get(), false, m_outputStreamVideoEncode,
        m_session.get()));
    Argus::Size2D<uint32_t> outputSize;
    PROPAGATE_ERROR(dispatcher.getOutputSize(&outputSize));
    // build the file name
    std::ostringstream fileName;
    fileName << dispatcher.m_outputPath.get();
    if (dispatcher.m_outputPath.get() != "/dev/null")
        fileName << "/video_" << (long) getpid() << "_s" << std::setfill('0')
                << std::setw(2) << deviceIndex << "_"
                << std::setfill('0') << std::setw(4) << deviceIndex;
    PROPAGATE_ERROR(m_videoPipeline->setupForRecording(
        Argus::interface_cast<Argus::IStream>(m_outputStreamVideoEncode)->getEGLStream(),
        outputSize.width(), outputSize.height(),
        dispatcher.m_frameRate.get(), fileName.str().c_str(), dispatcher.m_videoFormat.get(),
        dispatcher.m_videoFileType.get(), dispatcher.m_videoBitRate.get()));
    // start recording
    PROPAGATE_ERROR(m_videoPipeline->start());
    // Enable the video output stream
    PROPAGATE_ERROR(dispatcher.enableOutputStream(m_request.get(), m_outputStreamVideoEncode.get()));
    PROPAGATE_ERROR(dispatcher.message("Started preview and recording video at %dx%d, saving to '%s'\n",
        outputSize.width(), outputSize.height(), fileName.str().c_str()));
    return true;
bool TaskMultiSession::Session::initializeCamCapture(uint32_t deviceIndex)
    PROPAGATE_ERROR(dispatcher.createOutputStream(m_request.get(), false, m_outputStreamCamCapture,
        m_session.get()));
    m_camCapture2OCVConsumerCB = new aaCircularBuffer<aaEglFrameBuffer *> (CAMCAPTURE2OCVCONSUMER_BUFFER_LENGTH);
    m_camCapture = new aaCamCaptureThread(m_outputStreamCamCapture.get(),deviceIndex,m_pParent->m_pConfig);
    PROPAGATE_ERROR(dispatcher.enableOutputStream(m_request.get(), m_outputStreamCamCapture.get()));
    Argus::IStream *iStream = Argus::interface_cast<Argus::IStream>(m_outputStreamCamCapture.get());
    if (!iStream)
    PROPAGATE_ERROR(iStream->waitUntilConnected());  //******************INFINITE BLOCK HERE ****************************
    return true;
bool TaskMultiSession::Session::startCamCapture()
    PROPAGATE_ERROR(m_camCapture->initialize());
    PROPAGATE_ERROR(m_camCapture->waitRunning());
    return true;
bool TaskMultiSession::Session::startPreview()
    // activate the streams and populate the burst request array
    PROPAGATE_ERROR(composer.setStreamActive(
        Argus::interface_cast<Argus::IStream>(m_outputStream)->getEGLStream(), true));
    return true;
bool TaskMultiSession::Session::startEncoder()
    return true;
bool TaskMultiSession::Session::stopPreview()
    PROPAGATE_ERROR(m_perfTracker->onEvent(SESSION_EVENT_CLOSE_REQUESTED));
    //PROPAGATE_ERROR(dispatcher.stopRepeat(m_session.get()));
        Argus::interface_cast<Argus::IStream>(m_outputStream)->getEGLStream(), false));
    PROPAGATE_ERROR(dispatcher.waitForIdle(m_session.get()));
    PROPAGATE_ERROR(m_perfTracker->onEvent(SESSION_EVENT_FLUSH_DONE));
    return true;
bool TaskMultiSession::Session::stopEncoder()
    // stop the repeating request
    // stop recording
    PROPAGATE_ERROR(m_videoPipeline->stop());
    // Wait until all pending captures are done before destroying the stream
    PROPAGATE_ERROR(dispatcher.message("Stopped recording video\n"));
    return true;
bool TaskMultiSession::Session::stopCamCapture()
    m_camCapture->setTerminationFlags();
    return true;
bool TaskMultiSession::Session::shutdownPreview()
    if (m_request)
        if (m_outputStream)
            // destroy the producer
            PROPAGATE_ERROR_CONTINUE(dispatcher.disableOutputStream(m_request.get(),
            Argus::IStream *iStream = Argus::interface_cast<Argus::IStream>(m_outputStream);
            if (!iStream)
                REPORT_ERROR("Failed to get IStream interface");
            // disconnect the EGL stream
            iStream->disconnect();
            // unbind the EGL stream from the composer
            PROPAGATE_ERROR_CONTINUE(composer.unbindStream(iStream->getEGLStream()));
            m_outputStream.reset();
        // destroy the request
        PROPAGATE_ERROR_CONTINUE(m_request.reset());
    PROPAGATE_ERROR(m_perfTracker->onEvent(SESSION_EVENT_CLOSE_DONE));
    // Destroy the session
    m_session.reset();
    return true;
bool TaskMultiSession::Session::shutdownEncoder()
    if (m_outputStreamVideoEncode)
        // disable the output stream
        PROPAGATE_ERROR(dispatcher.disableOutputStream(m_request.get(), m_outputStreamVideoEncode.get()));
        m_outputStreamVideoEncode.reset();
    if (m_videoPipeline)
        // destroy the video pipeline
        PROPAGATE_ERROR(m_videoPipeline->destroy());
        delete m_videoPipeline;
        m_videoPipeline = NULL;
    return true;
bool TaskMultiSession::Session::shutdownCamCapture()
    PROPAGATE_ERROR(m_camCapture->shutdown());
    if (m_request)
        if (m_outputStreamCamCapture)
            Argus::IStream *iStream = Argus::interface_cast<Argus::IStream>(m_outputStreamCamCapture);
            if (!iStream)
            m_outputStreamCamCapture.reset();
    return true;
bool TaskMultiSession::initialize()
    if (m_initialized)
        return true;
    PROPAGATE_ERROR_CONTINUE(Dispatcher::getInstance().m_sensorModeValid.registerObserver(this,
        static_cast<IObserver::CallbackFunction>(&TaskMultiSession::onSensorModeValidChanged)));
    PROPAGATE_ERROR_CONTINUE(Dispatcher::getInstance().m_outputSize.registerObserver(this,
        static_cast<IObserver::CallbackFunction>(&TaskMultiSession::restartStreams)));
    m_initialized = true;
    return true;
bool TaskMultiSession::shutdown()
    if (!m_initialized)
        return true;
    // stop the preview
    PROPAGATE_ERROR(stop());
    PROPAGATE_ERROR_CONTINUE(Dispatcher::getInstance().m_outputSize.unregisterObserver(this,
    PROPAGATE_ERROR_CONTINUE(Dispatcher::getInstance().m_sensorModeValid.unregisterObserver(this,
    m_initialized = false;
    return true;
bool TaskMultiSession::shutdownSessions()
    if (!m_sessions.empty())
        // shutdown the sessions
        for (std::list<Session*>::iterator it = m_sessions.begin(); it != m_sessions.end(); ++it)
            Session *session = *it;
            PROPAGATE_ERROR_CONTINUE(session->shutdown());
            delete session;
        m_sessions.clear();
    return true;
bool TaskMultiSession::start()
    if (m_running)
        return true;
    if (m_sessions.empty())
        const uint32_t deviceCount = 2;//dispatcher.getDeviceCount();
        if (deviceCount == 0)
            ORIGINATE_ERROR("No camera devices found");
        // create a request and streams for each session
        for (uint32_t deviceIndex = 0; deviceIndex < deviceCount; ++deviceIndex)
            UniquePointer<Session> session(new Session(this));
            if (!session)
            PROPAGATE_ERROR(session->initialize(deviceIndex));
            m_sessions.push_back(session.release());
    // start the sessions
        PROPAGATE_ERROR(session->start());
    m_running = true;
    return true;
bool TaskMultiSession::stop()
    if (!m_running)
        return true;
        PROPAGATE_ERROR(session->stop());
    PROPAGATE_ERROR(shutdownSessions());
    m_running = false;
    return true;
bool TaskMultiSession::onSensorModeValidChanged(const Observed &source)
    const bool isTrue = static_cast<const Value<bool>&>(source).get();
    if (!isTrue)
        m_prevRunning = m_running;
        if (m_running)
    else if (m_prevRunning)
        m_prevRunning = false;
        PROPAGATE_ERROR(start());
    return true;
bool TaskMultiSession::restartStreams(__attribute__((unused)) const Observed &source)
    if (m_running)
    return true;
}; // namespace ArgusSamples
Hi dumbogeorge,
We tried the your code. The multisession works with two cameras. Please see below video.
Please recompile the modified code and try multisession again.
Can anyone confirm that does Xavier allow changing power modes with Leopard drivers installed. The kernels installed through JetPack are messed up.
Command to change mode: sudo nvpmodel -m 0
