in our application, we need to capture synchronized streams of three cameras. Therefore I added the three devices to a single capture session. This was working well when using L4T 24.2. Now I updated to L4T 28.1 and get some timeouts when running the three cameras. It seems that this only happens when I run them in the same capture session, because it works with three instances of argus_camera. I also did some tests with the syncSensor example in the ArgusSDK. The example was working with two cameras, so I extended the sample to work with three cameras as seen below:
* Copyright (c) 2016, NVIDIA CORPORATION. All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of NVIDIA CORPORATION nor the names of its
* contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
* EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
* PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
* OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <Argus/Argus.h>
#include <cuda.h>
#include <cudaEGL.h>
#include "CUDAHelper.h"
#include "EGLGlobal.h"
#include "Error.h"
#include "KLDistance.h"
#include "Thread.h"
// Histogram generation methods borrowed from cudaHistogram sample.
#include "../cudaHistogram/histogram.h"
using namespace Argus;
namespace ArgusSamples
* This sample opens a session with two sensors, it then using CUDA computes the histogram
* of the sensors and computes a KL distance between the two histograms. A small value near
* 0 indicates that the two images are alike. The processing of the images happens in the worker
* thread of StereoDisparityConsumerThread. While the main app thread is used to drive the captures.
// Constants.
static const uint32_t CAPTURE_TIME = 5; // In seconds.
static const Size2D<uint32_t> STREAM_SIZE(640, 480);
// Globals and derived constants.
UniqueObj<CameraProvider> g_cameraProvider;
EGLDisplayHolder g_display;
// Debug print macros.
#define PRODUCER_PRINT(...) printf("PRODUCER: " __VA_ARGS__)
#define CONSUMER_PRINT(...) printf("CONSUMER: " __VA_ARGS__)
* Argus disparity class
* This class will analyze frames from 2 synchronized sensors and compute the
* KL distance between the two images. Large values of KL indicate a large disparity
* while a value of 0.0 indicates that the images are alike.
class StereoDisparityConsumerThread : public Thread
public:
explicit StereoDisparityConsumerThread(IStream *leftStream,
IStream *rightStream,
IStream *topStream)
: m_leftStream(leftStream)
, m_rightStream(rightStream)
, m_topStream(topStream)
, m_cudaContext(0)
, m_cuStreamLeft(NULL)
, m_cuStreamRight(NULL)
, m_cuStreamTop(NULL)
~StereoDisparityConsumerThread()
private:
/** @name Thread methods */
virtual bool threadInitialize();
virtual bool threadExecute();
virtual bool threadShutdown();
IStream *m_leftStream;
IStream *m_rightStream;
IStream *m_topStream;
CUcontext m_cudaContext;
CUeglStreamConnection m_cuStreamLeft;
CUeglStreamConnection m_cuStreamRight;
CUeglStreamConnection m_cuStreamTop;
* Utility class to acquire and process an EGLStream frame from a CUDA
* consumer as long as the object is in scope.
class ScopedCudaEGLStreamFrameAcquire
public:
* Constructor blocks until a frame is acquired or an error occurs (ie. stream is
* disconnected). Caller should check which condition was satisfied using hasValidFrame().
ScopedCudaEGLStreamFrameAcquire(CUeglStreamConnection& connection);
* Destructor releases frame back to EGLStream.
~ScopedCudaEGLStreamFrameAcquire();
* Returns true if a frame was acquired (and is compatible with this consumer).
bool hasValidFrame() const;
* Use CUDA to generate a histogram from the acquired frame.
* @param[out] histogramData Output array for the histogram.
* @param[out] time Time to generate histogram, in milliseconds.
bool generateHistogram(unsigned int histogramData[HISTOGRAM_BINS], float *time);
* Returns the size (resolution) of the frame.
Size2D<uint32_t> getSize() const;
private:
* Returns whether or not the frame format is supported.
bool checkFormat() const;
CUeglStreamConnection& m_connection;
CUstream m_stream;
CUgraphicsResource m_resource;
CUeglFrame m_frame;
bool StereoDisparityConsumerThread::threadInitialize()
// Create CUDA and connect egl streams.
PROPAGATE_ERROR(initCUDA(&m_cudaContext));
CONSUMER_PRINT("Connecting CUDA consumer to left stream\n");
CUresult cuResult = cuEGLStreamConsumerConnect(&m_cuStreamLeft, m_leftStream->getEGLStream());
if (cuResult != CUDA_SUCCESS)
ORIGINATE_ERROR("Unable to connect CUDA to EGLStream as a consumer (CUresult %s)",
getCudaErrorString(cuResult));
CONSUMER_PRINT("Connecting CUDA consumer to right stream\n");
cuResult = cuEGLStreamConsumerConnect(&m_cuStreamRight, m_rightStream->getEGLStream());
CONSUMER_PRINT("Connecting CUDA consumer to top stream\n");
cuResult = cuEGLStreamConsumerConnect(&m_cuStreamTop, m_topStream->getEGLStream());
return true;
bool StereoDisparityConsumerThread::threadExecute()
CONSUMER_PRINT("Waiting for Argus producer to connect to left stream.\n");
m_leftStream->waitUntilConnected();
CONSUMER_PRINT("Waiting for Argus producer to connect to right stream.\n");
m_rightStream->waitUntilConnected();
CONSUMER_PRINT("Waiting for Argus producer to connect to top stream.\n");
m_topStream->waitUntilConnected();
CONSUMER_PRINT("Streams connected, processing frames.\n");
unsigned int histogramLeft[HISTOGRAM_BINS];
unsigned int histogramRight[HISTOGRAM_BINS];
unsigned int histogramTop[HISTOGRAM_BINS];
while (true)
ScopedCudaEGLStreamFrameAcquire left(m_cuStreamLeft);
ScopedCudaEGLStreamFrameAcquire right(m_cuStreamRight);
ScopedCudaEGLStreamFrameAcquire top(m_cuStreamTop);
if (!left.hasValidFrame() || !right.hasValidFrame() || !top.hasValidFrame())
break;
// Calculate histograms.
float time = 0.0f;
if (left.generateHistogram(histogramLeft, &time) &&
right.generateHistogram(histogramRight, &time) &&
top.generateHistogram(histogramTop, &time))
// Calculate KL distance.
float distance = 0.0f;
Size2D<uint32_t> size = right.getSize();
float dTime = computeKLDistance(histogramRight,
histogramLeft,
HISTOGRAM_BINS,
size.width() * size.height(),
&distance);
CONSUMER_PRINT("KL distance of %6.3f with %5.2f ms computing histograms and "
"%5.2f ms spent computing distance\n",
distance, time, dTime);
histogramTop,
HISTOGRAM_BINS,
&distance);
CONSUMER_PRINT("No more frames. Cleaning up.\n");
PROPAGATE_ERROR(requestShutdown());
return true;
bool StereoDisparityConsumerThread::threadShutdown()
// Disconnect from the streams.
cuEGLStreamConsumerDisconnect(&m_cuStreamLeft);
cuEGLStreamConsumerDisconnect(&m_cuStreamRight);
cuEGLStreamConsumerDisconnect(&m_cuStreamTop);
PROPAGATE_ERROR(cleanupCUDA(&m_cudaContext));
CONSUMER_PRINT("Done.\n");
return true;
ScopedCudaEGLStreamFrameAcquire::ScopedCudaEGLStreamFrameAcquire(CUeglStreamConnection& connection)
: m_connection(connection)
, m_stream(NULL)
, m_resource(0)
CUresult r = cuEGLStreamConsumerAcquireFrame(&m_connection, &m_resource, &m_stream, -1);
if (r == CUDA_SUCCESS)
cuGraphicsResourceGetMappedEglFrame(&m_frame, m_resource, 0, 0);
ScopedCudaEGLStreamFrameAcquire::~ScopedCudaEGLStreamFrameAcquire()
if (m_resource)
cuEGLStreamConsumerReleaseFrame(&m_connection, m_resource, &m_stream);
bool ScopedCudaEGLStreamFrameAcquire::hasValidFrame() const
return m_resource && checkFormat();
bool ScopedCudaEGLStreamFrameAcquire::generateHistogram(unsigned int histogramData[HISTOGRAM_BINS],
float *time)
if (!hasValidFrame() || !histogramData || !time)
ORIGINATE_ERROR("Invalid state or output parameters");
// Create surface from luminance channel.
CUDA_RESOURCE_DESC cudaResourceDesc;
memset(&cudaResourceDesc, 0, sizeof(cudaResourceDesc));
cudaResourceDesc.resType = CU_RESOURCE_TYPE_ARRAY;
cudaResourceDesc.res.array.hArray = m_frame.frame.pArray[0];
CUsurfObject cudaSurfObj = 0;
CUresult cuResult = cuSurfObjectCreate(&cudaSurfObj, &cudaResourceDesc);
ORIGINATE_ERROR("Unable to create the surface object (CUresult %s)",
// Generated the histogram.
*time += histogram(cudaSurfObj, m_frame.width, m_frame.height, histogramData);
// Destroy surface.
cuSurfObjectDestroy(cudaSurfObj);
return true;
Size2D<uint32_t> ScopedCudaEGLStreamFrameAcquire::getSize() const
if (hasValidFrame())
return Size2D<uint32_t>(m_frame.width, m_frame.height);
return Size2D<uint32_t>(0, 0);
bool ScopedCudaEGLStreamFrameAcquire::checkFormat() const
if ((m_frame.eglColorFormat != CU_EGL_COLOR_FORMAT_YUV420_PLANAR) &&
(m_frame.eglColorFormat != CU_EGL_COLOR_FORMAT_YUV420_SEMIPLANAR) &&
(m_frame.eglColorFormat != CU_EGL_COLOR_FORMAT_YUV422_PLANAR) &&
(m_frame.eglColorFormat != CU_EGL_COLOR_FORMAT_YUV422_SEMIPLANAR))
ORIGINATE_ERROR("Only YUV color formats are supported");
if (m_frame.cuFormat != CU_AD_FORMAT_UNSIGNED_INT8)
ORIGINATE_ERROR("Only 8-bit unsigned int formats are supported");
return true;
static bool execute()
// Initialize EGL.
PROPAGATE_ERROR(g_display.initialize());
// Initialize the Argus camera provider.
UniqueObj<CameraProvider> cameraProvider(CameraProvider::create());
// Get the ICameraProvider interface from the global CameraProvider.
ICameraProvider *iCameraProvider = interface_cast<ICameraProvider>(cameraProvider);
if (!iCameraProvider)
ORIGINATE_ERROR("Failed to get ICameraProvider interface");
printf("Argus Version: %s\n", iCameraProvider->getVersion().c_str());
// Get the camera devices.
std::vector<CameraDevice*> cameraDevices;
iCameraProvider->getCameraDevices(&cameraDevices);
if (cameraDevices.size() < 3)
ORIGINATE_ERROR("Must have at least 3 sensors available");
std::vector <CameraDevice*> lrCameras;
lrCameras.push_back(cameraDevices[0]); // Left Camera (the 1st camera will be used for AC)
lrCameras.push_back(cameraDevices[1]); // Right Camera
lrCameras.push_back(cameraDevices[2]); // Top Camera
// Create the capture session, AutoControl will be based on what the 1st device sees.
UniqueObj<CaptureSession> captureSession(iCameraProvider->createCaptureSession(lrCameras));
ICaptureSession *iCaptureSession = interface_cast<ICaptureSession>(captureSession);
if (!iCaptureSession)
ORIGINATE_ERROR("Failed to get capture session interface");
// Create stream settings object and set settings common to both streams.
UniqueObj<OutputStreamSettings> streamSettings(iCaptureSession->createOutputStreamSettings());
IOutputStreamSettings *iStreamSettings = interface_cast<IOutputStreamSettings>(streamSettings);
if (!iStreamSettings)
ORIGINATE_ERROR("Failed to create OutputStreamSettings");
iStreamSettings->setPixelFormat(PIXEL_FMT_YCbCr_420_888);
iStreamSettings->setResolution(STREAM_SIZE);
iStreamSettings->setEGLDisplay(g_display.get());
// Create egl streams
PRODUCER_PRINT("Creating left stream.\n");
iStreamSettings->setCameraDevice(lrCameras[0]);
UniqueObj<OutputStream> streamLeft(iCaptureSession->createOutputStream(streamSettings.get()));
IStream *iStreamLeft = interface_cast<IStream>(streamLeft);
if (!iStreamLeft)
ORIGINATE_ERROR("Failed to create left stream");
PRODUCER_PRINT("Creating right stream.\n");
iStreamSettings->setCameraDevice(lrCameras[1]);
UniqueObj<OutputStream> streamRight(iCaptureSession->createOutputStream(streamSettings.get()));
IStream *iStreamRight = interface_cast<IStream>(streamRight);
if (!iStreamRight)
ORIGINATE_ERROR("Failed to create right stream");
PRODUCER_PRINT("Creating top stream.\n");
iStreamSettings->setCameraDevice(lrCameras[2]);
UniqueObj<OutputStream> streamTop(iCaptureSession->createOutputStream(streamSettings.get()));
IStream *iStreamTop = interface_cast<IStream>(streamTop);
if (!iStreamTop)
PRODUCER_PRINT("Launching disparity checking consumer\n");
StereoDisparityConsumerThread disparityConsumer(iStreamLeft, iStreamRight, iStreamTop);
PROPAGATE_ERROR(disparityConsumer.initialize());
PROPAGATE_ERROR(disparityConsumer.waitRunning());
// Create a request
UniqueObj<Request> request(iCaptureSession->createRequest());
IRequest *iRequest = interface_cast<IRequest>(request);
if (!iRequest)
ORIGINATE_ERROR("Failed to create Request");
// Enable both streams in the request.
iRequest->enableOutputStream(streamLeft.get());
iRequest->enableOutputStream(streamRight.get());
iRequest->enableOutputStream(streamTop.get());
// Submit capture for the specified time.
PRODUCER_PRINT("Starting repeat capture requests.\n");
if (iCaptureSession->repeat(request.get()) != STATUS_OK)
ORIGINATE_ERROR("Failed to start repeat capture request for preview");
sleep(CAPTURE_TIME);
// Stop the capture requests and wait until they are complete.
iCaptureSession->stopRepeat();
iCaptureSession->waitForIdle();
// Disconnect Argus producer from the EGLStreams (and unblock consumer acquire).
PRODUCER_PRINT("Captures complete, disconnecting producer.\n");
iStreamLeft->disconnect();
iStreamRight->disconnect();
iStreamTop->disconnect();
// Wait for the consumer thread to complete.
PROPAGATE_ERROR(disparityConsumer.shutdown());
// Shut down Argus.
cameraProvider.reset();
// Cleanup the EGL display
PROPAGATE_ERROR(g_display.cleanup());
PRODUCER_PRINT("Done -- exiting.\n");
return true;
}; // namespace ArgusSamples
int main(int argc, const char *argv[])
printf("Executing Argus Sample: %s\n", basename(argv[0]));
if (!ArgusSamples::execute())
return EXIT_FAILURE;
return EXIT_SUCCESS;
When running this sample, I also get some timeouts and the application hangs. This is the output of argus_daemon:
=== Listening for connections... ===
=== Connection 7F7BA261E0 established ===
NvPclHwGetModuleList: No module data found
PCLHW_DTParser
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp] 2/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16LoadOverridesFile: looking for override file [/data/nvcam/camera_overrides.isp] 5/16LoadOverridesFile: looking for override file [/data/nvcam/settings/imx185_center_liimx185.isp] 6/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/imx185_center_liimx185.isp] 7/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/imx185_center_liimx185.isp] 8/16---- imager: No override file found. ----
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp] 2/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16LoadOverridesFile: looking for override file [/data/nvcam/camera_overrides.isp] 5/16LoadOverridesFile: looking for override file [/data/nvcam/settings/imx185_front_liimx185.isp] 6/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/imx185_front_liimx185.isp] 7/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/imx185_front_liimx185.isp] 8/16---- imager: No override file found. ----
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp] 2/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16LoadOverridesFile: looking for override file [/data/nvcam/camera_overrides.isp] 5/16LoadOverridesFile: looking for override file [/data/nvcam/settings/imx185_bottom_liimx185.isp] 6/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/imx185_bottom_liimx185.isp] 7/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/imx185_bottom_liimx185.isp] 8/16---- imager: No override file found. ----
CameraProvider result: provider=0x7f75257ff0, shim=0x7f75248320, status=0, rpc status=1, size=9
Growing thread pool to 1 threads
PowerServiceCore:handleRequests: timePassed = 1113
PowerServiceCore:handleRequests: timePassed = 1102
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
launchCC abort cc 107 session 2
SCF: Error Timeout: (propagating from src/api/Session.cpp, function capture(), line 830)
(Argus) Error Timeout: Failed to submit first capture request (propagating from src/api/CaptureSessionImpl.cpp, function submitCaptureRequests(), line 311)
(Argus) Error Timeout: (propagating from src/api/CaptureSessionImpl.cpp, function threadFunction(), line 777)
PowerServiceCore:handleRequests: timePassed = 1012
So my question is: Is this a bug or do I something wrong? As noted before, the same code was running without issues in L4T 24.2.
