Hi
I am trying to run 7 cameras streaming pipeline using deepstream.
Whenever the pipeline is initiated on a freshly booted system, it throws errors as below.
GST_ARGUS: Running with following settings:
Camera index = 4
Camera mode = 3
Output Stream W = 1936 H = 1096
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD… Exiting…
CONSUMER: Done Success
CONSUMER: ERROR OCCURRED
ERROR: nvarguscamerasrc1 TIMEOUT
debugging info: Argus Error Status
GST_ARGUS: Cleaning up
GST_ARGUS: Done Success
(Argus) Error Timeout: (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 137)
(Argus) Error Timeout: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
If the pipeline is relaunched after restarting the nvargus-daemon, the stream works flawlessly.
My Environment:
1> Hardware: Jetson Xavier AGX development board
2> Jetpack: 4.6.1
3> Gstreamer v6.0 (default as come with jetpack 4.6.1)
4> OS: Ubuntu 18.04
5> Camera modules: IMX390rcm (total 7 cameras)
My Pipeline:
gst-launch-1.0 -e
nvarguscamerasrc sensor-id=0 tnr-strength=1 tnr-mode=2 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1’ ! queue ! nvv4l2vp9enc maxperf-enable=true bitrate=4000000 ! rtpvp9pay mtu=7200 ! udpsink host=$host-ip port=5000 sync=false async=false
nvarguscamerasrc sensor-id=1 tnr-strength=1 tnr-mode=2 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1’ ! queue ! nvv4l2vp9enc maxperf-enable=true bitrate=4000000 ! rtpvp9pay mtu=7200 ! udpsink host=$host-ip port=5001 sync=false async=false
nvarguscamerasrc sensor-id=2 tnr-strength=1 tnr-mode=2 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1’ ! queue ! nvv4l2vp9enc maxperf-enable=true bitrate=4000000 ! rtpvp9pay mtu=7200 ! udpsink host=$host-ip port=5002 sync=false async=false
nvarguscamerasrc sensor-id=3 tnr-strength=1 tnr-mode=2 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1’ ! queue ! nvv4l2vp9enc maxperf-enable=true bitrate=4000000 ! rtpvp9pay mtu=7200 ! udpsink host=$host-ip port=5003 sync=false async=false
nvarguscamerasrc sensor-id=4 tnr-strength=1 tnr-mode=2 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1’ ! queue ! nvv4l2vp9enc maxperf-enable=true bitrate=4000000 ! rtpvp9pay mtu=7200 ! udpsink host=$host-ip port=5004 sync=false async=false
nvarguscamerasrc sensor-id=5 tnr-strength=1 tnr-mode=2 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1’ ! queue ! nvv4l2vp9enc maxperf-enable=true bitrate=4000000 ! rtpvp9pay mtu=7200 ! udpsink host=$host-ip port=5005 sync=false async=false
nvarguscamerasrc sensor-id=6 tnr-strength=1 tnr-mode=2 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1’ ! queue ! nvv4l2vp9enc maxperf-enable=true bitrate=4000000 ! rtpvp9pay mtu=7200 ! udpsink host=$host-ip port=5006 sync=false async=false
Description:
My pipeline is capturing inputs from 7 camera sources using nvarguscamerasrc and transmitting them to a udpsink. When the pipeline is launched for the first time, it throws error and if it is relaunched again after restarting the nvargus-daemon, it works well.
Any help in eradicating these errors will be highly appreciated.
