nvcaffe 0.17 used in two Jetson TX 2 gstreamer plugins in the same pipe crashes
When used only in one plugin, nvcaffe 0.17 works fine.
When I use it in 2 plugins in the same pipe I get
F0129 02:34:36.384413 15692 cudnn_conv_layer.cu:55] Check failed: error == cudaSuccess (4 vs. 0) unspecified launch failure
The last line below is line 55
} else {
// “old” path
for (int i = 0; i < bottom.size(); ++i) {
const Ftype* bottom_data = bottom[i]->gpu_data();
Ftype* top_data = top[i]->mutable_gpu_data();
// Forward through cuDNN in parallel over groups.
const size_t gsize = ws->size() / ws_groups();
CHECK(is_even(gsize));
for (int g = 0; g < groups(); ++g) {
void* pspace = static_cast<unsigned char*>(ws->data()) + gsize * idxg(g);
// Filters.
CUDNN_CHECK(cudnnConvolutionForward(Caffe::cudnn_handle(idxg(g)),
cudnn::dataType::one, fwd_bottom_descs_[i], bottom_data + bottom_offset_ * g,
fwd_filter_desc_, weight + this->weight_offset_ * g,
fwd_conv_descs_[i], fwd_algo_[i], pspace, gsize,
cudnn::dataType::zero, fwd_top_descs_[i], top_data + top_offset_ * g));
// NOLINT_NEXT_LINE(whitespace/operators)
for (int ig = 0; ig < ws_groups(); ++ig) {
CUDA_CHECK(cudaStreamSynchronize(Caffe::thread_stream(ig)));
Some additional information:
This happens while both plugins (gstreamer) are executing inside
Net::Forward.
I use gst-launch.
Fixed in 19.05, thank you
