Jetpack3.2 with cuda9.0 support for DeepStream SDK
I tried the above setup but getting following Gstreamer plugin issue.
(gst-plugin-scanner:27192): GStreamer-WARNING **: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvivafilter.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvivafilter.so: undefined symbol: NvBufferCreateEx
(gst-plugin-scanner:27192): GStreamer-WARNING **: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvosd.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvosd.so: undefined symbol: nvosd_init_class_clrs
(gst-plugin-scanner:27192): GStreamer-WARNING **: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so: undefined symbol: NvBufferCreateEx
(gst-plugin-scanner:27192): GStreamer-WARNING **: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvcaffegie.so': libnvcaffe_parser.so.3: cannot open shared object file: No such file or directory
(gst-plugin-scanner:27192): GStreamer-WARNING **: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvcompositor.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvcompositor.so: undefined symbol: NvBufferCreateEx
(gst-plugin-scanner:27192): GStreamer-WARNING **: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstclutter.so': /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
(gst-plugin-scanner:27192): GStreamer-WARNING **: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstclutter-3.0.so': /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
** ERROR: <create_osd_bin:62>: Failed to create 'nvosd0'
** ERROR: <create_osd_bin:100>: create_osd_bin failed
** ERROR: <create_processing_instance:890>: create_processing_instance failed
** ERROR: <create_pipeline:1024>: create_pipeline failed
** ERROR: <main:384>: Failed to create pipeline
Quitting
(nvgstiva-app:27191): GStreamer-CRITICAL **: gst_element_get_static_pad: assertion 'GST_IS_ELEMENT (element)' failed
(nvgstiva-app:27191): GStreamer-CRITICAL **: gst_pad_remove_probe: assertion 'GST_IS_PAD (pad)' failed
(nvgstiva-app:27191): GStreamer-CRITICAL **: gst_object_unref: assertion 'object != NULL' failed
App run failed
Is it because of gstreamer of beacause there is no support for cuda9.0 and Jetpack3.2?
Hi pharatekomal,
The DeepStream SDK is still limited release and only supports JetPack3.1 currently.
Okay.But the error mentioned is because of that ?
