I’m developing a camera driver for the TX2 using Jetpack 3.2.1.
My board has 2 CSI ports, I’m able to load the driver and capture using v4l2 without problems with both cameras. However, trying to capture with nvcamerasrc I got this behavior:
- Setting only 1 module in tegra-camera-platform I am able to capture with nvcamerasrc with sensor-id=0, which tells me the driver and device tree for the camera is working properly. See working tegra-camera-platform below:
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
num_csi_lanes = <4>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <160000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
modules {
module0 {
badge = "e3322_front_A815P2";
position = "front";
status = "okay";
orientation = "1";
drivernode0 {
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver v4l2 device name */
devname = "imx219 1-0010";
status = "okay";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@c240000/imx219_a@10";
2- If I add the second module for the other camera, I am not able to capture with nvcamerasrc for none of the cameras, and the nvcamera-daemon triggers an error.
This is the second module added to the tegra-camera-platform node:
module1 {
badge = "e3322_rear_A815P2";
position = "rear";
status = "okay";
orientation = "1";
drivernode0 {
devname = "imx219 1-0012";
status = "okay";
proc-device-tree = "/proc/device-tree/i2c@c240000/imx219_b@12";
And this is the error that nvcamerasrc triggers:
nvidia@tegra-ubuntu:~$ GST_DEBUG=*nv*:9 gst-launch-1.0 nvcamerasrc ! fakesink
0:00:00.017594589 2747 0x506a10 INFO nvcamerasrc gstnvcamerasrc.cpp:3504:set_fps_range:<GstNvCameraSrc@0x50a200> NvCameraSrc: Setting FPSRange : (null)
Setting pipeline to PAUSED ...
0:00:00.019046212 2747 0x506a10 INFO nvcamerasrc gstnvcamerasrc.cpp:2138:send_request_to_camera_daemon:<nvcamerasrc0> NvCameraSrc: CameraDaemon_REQ GET NUM SENSORS
0:00:00.019071785 2747 0x4c9e30 DEBUG nvcamerasrc gstnvcamerasrc.cpp:1388:gst_nvcamerasrc_response:<nvcamerasrc0> gst_nvcamerasrc_response thread
Socket read error. Camera Daemon stopped functioning.....
0:00:01.179807545 2747 0x4c9e30 DEBUG nvcamerasrc gstnvcamerasrc.cpp:1625:gst_nvcamerasrc_response:<nvcamerasrc0> gst_nvcamerasrc_response thread exiting nbytes=0
0:00:01.179857865 2747 0x506a10 DEBUG nvcamerasrc gstnvcamerasrc.cpp:2419:gst_nvcamera_socket_connect:<nvcamerasrc0> REQ_NVCAM_GET_NUM_SENSORS to camera_daemon failed
0:00:01.180113906 2747 0x506a10 DEBUG nvcamerasrc gstnvcamerasrc.cpp:3342:gst_nvcamerasrc_start:<nvcamerasrc0> start
0:00:01.180226317 2747 0x506a10 ERROR nvcamerasrc gstnvcamerasrc.cpp:2448:gst_nvcamera_open:<nvcamerasrc0> REQ_NVCAM_CREATE_SESSION to camera_daemon failed
gst_nvcamera_open() failed ret=0
ERROR: Pipeline doesn't want to pause.
Setting pipeline to NULL ...
0:00:01.180967186 2747 0x506a10 DEBUG nvcamerasrc gstnvcamerasrc.cpp:2429:gst_nvcamera_socket_disconnect:<nvcamerasrc0> REQ_NVCAM_CLOSE_SOCKET to camera_daemon failed
Freeing pipeline ...
So that, I am able to capture from only 1 camera using nvcamerasrc and both cameras are needed.
My questions are:
It looks like the nvcamera-daemon doesn’t response properly to the num sensors request. Where does this come from? Who tells the deamon the number of sensors connected?
May this problem related to the plugin manager? What is the plugin manager and how it works?
Could be there something in the default device tree causing this problem?
I would appreciate any guidance on this.
- Carlos
