I believe my error comes from not organize paths correctly. I need help on fixing so that nvcc works correctly. SEE BELOW FOR DETAILS, THANK YOU.
When I run nvcc --version, this output:
bash: /usr/local/cuda-9.0/bin/nvcc: cannot execute binary file: Exec format error
MY BASHRC LOOK LIKE THIS:
export PATH=/usr/local/cuda-9.0/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin:/usr/local/cuda/bin${LD_LIBRARY_PATH:+:{LD_LIBRARY_PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda-9.0/lib64\${LD_LIBRARY_PATH:+:{LD_LIBRARY_PATH}}
export CUDA_HOME=/usr/local/cuda-9.0
source /opt/ros/kinetic/setup.bash
export ROS_MASTER_URI=http://localhost:11311
export ROS_IP=192.168.1.47
export LD_LIBRARY_PATH=/usr/local/lib:/opt/ros/kinetic/lib:/opt/ros/kinetic/lib/aarch64-linux-gnu:/usr/local/cuda-9.0/lib64:
export LD_LIBRARY_PATH=/usr/local/lib:/opt/ros/kinetic/lib:/opt/ros/kinetic/lib/aarch64-linux-gnu:/usr/local/lib:/usr/local/cuda-9.0/lib64
