NVCC Compiler Won't Run
I installed Version 12.5. Having no problem using cuda runtime and blas. When I try to compile a simple kernel launch I get the following. I have reinstalled everything. What can I try next.
Severity Code Description Project File Line Suppression State Details
Error MSB3721 The command C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\bin\nvcc.exe -gencode=arch=compute_52,code=\sm_52,compute_52\ –use-local-env -ccbin D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64 -x cu -ID:\Craig\Visual Studio 2022\Projects\CUDAObjects\include -ID:\Craig\Visual Studio 2022\Projects\CraigsSystem\include -IC:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\include -IC:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include -IC:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include -IC:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include --keep-dir CUDAObjects\x64\Release -maxrregcount=0 --machine 64 --compile -cudart static -DNDEBUG -D_CONSOLE -D_UNICODE -DUNICODE -Xcompiler /EHsc /W3 /nologo /O2 /FS /MD -Xcompiler /FdCUDAObjects\x64\Release\vc143.pdb -o D:\Craig\Visual Studio 2022\Projects\CUDAObjects\CUDAObjects\x64\Release\CUDAInterface.cu.obj D:\Craig\Visual Studio 2022\Projects\CUDAObjects\src\CUDAInterface.cu exited with code 1. CUDAObjects D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\CUDA 12.5.targets 799
MSB3721 is a “generic” error, which indicates that a sub-tool did not run correctly, but returned an error code, when the automation system inside visual studio (VS) tried to run that tool.
The general suggestion is that more information is needed. Specifically we want to see the actual results of running the command that failed, which VS conveniently hides in its default configuration.
There are two options that I know of:
  1. Increase the verbosity of visual studio output. Google for the instruction for that, it is not unique or specific to CUDA, and the exact steps vary by VS version.
  2. Run the offending command from the command line (e.g. in a command prompt or terminal window). The offending command in this case is everything after “The command” and before “exited”. This may require setting up additional PATH variable definitions in Windows, so that the needed compilers are on the PATH.
I tried running the nvcc command line in power shell. The nvcc command started issuing error messages for each one of its arguments. The only lines in the file I am trying to compiled are include “cuda_runtime.h”
include "device_launch_parameters.h include <stdio.h> so the problem does seem to be the contents of the my .cu file. Here is the bottom one third of command output using detailed verbosity: I’ll put the rest of it in my next replies
1> Search paths being used for $(MSBuildExtensionsPath) are D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild;$(MSBuildProgramFiles32)\MSBuild
1> Trying to import D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\WebTools.Aspire\Microsoft.WebTools.Aspire.targets using extensions path D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild
1> Property reassignment: $(JsonSchemaCombinedFilePath)=“D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial\x64\Debug\CombinedComponentSchema.json” (previous value: “CUDATutorial\x64\Debug\CombinedComponentSchema.json”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\WebTools.Aspire\Microsoft.WebTools.Aspire.targets (25,5)
1> Property reassignment: $(AppSettingsJsonSchemaCombinedFilePath)=“D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial\x64\Debug\AppSettingsSchema.json” (previous value: “CUDATutorial\x64\Debug\AppSettingsSchema.json”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\WebTools.Aspire\Microsoft.WebTools.Aspire.targets (27,5)
1> Property reassignment: $(DebugType)=“” (previous value: “none”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.BuildSteps.Targets (39,5)
1> Property reassignment: $(BuildDependsOn)="
1> _PrepareForBuild;
1>
1> ResolveReferences;
1> PrepareForBuild;
1> InitializeBuildStatus;
1> BuildGenerateSources;
1> BuildCompile;
1> BuildLink;
1> ;
1> AfterBuild;
1> IncrementalClean;
1> TlogCleanup;
1> FinalizeBuildStatus;
1> " (previous value: "
1> BeforeBuild;
1> CoreBuild;
1> AfterBuild
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.BuildSteps.Targets (122,5)
1> Property reassignment: $(RebuildDependsOn)=”
1> _PrepareForRebuild;
1>
1> BeforeRebuild;
1> Clean;
1> Build;
1> AfterRebuild;
1> ;
1> BeforeRebuild;
1> Clean;
1> Build;
1> AfterRebuild;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.BuildSteps.Targets (131,5)
1> Property reassignment: $(CleanDependsOn)=”
1> _PrepareForClean;
1>
1> BeforeClean;
1> UnmanagedUnregistration;
1> CoreClean;
1> CleanReferencedProjects;
1> CleanPublishFolder;
1> AfterClean
1> ;
1> BeforeClean;
1> CoreClean;
1> AfterClean
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.BuildSteps.Targets (136,5)
1> Property reassignment: $(BeforeBuildGenerateSourcesTargets)=”
1>
1> ;
1> BeforeBuildGenerateSources;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (60,5)
1> Property reassignment: $(AfterBuildGenerateSourcesTargets)=”
1>
1> ;
1> AfterBuildGenerateSources;
1> ;
1> AfterBuildGenerateSourcesEvent;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (71,5)
1> Property reassignment: $(BuildGenerateSourcesAction)=”_BuildGenerateSourcesAction" (previous value: “Build”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (140,5)
1> Property reassignment: $(BuildCompileAction)=“_BuildCompileAction” (previous value: “Build”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (141,5)
1> Property reassignment: $(BuildLinkAction)=“_BuildLinkAction” (previous value: “Build”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (142,5)
1> Property reassignment: $(DetermineProjectTypeTargets)=“_PrepareForReferenceResolution;
1> ;
1> AddExternalIncludDirectoriesToPaths
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (249,5)
1> Property reassignment: $(ResolveReferencesDependsOn)=”_PrepareForReferenceResolution;ComputeCrtSDKReference;
1>
1> BeforeResolveReferences;
1> AssignProjectConfiguration;
1> ResolveProjectReferences;
1> FindInvalidProjectReferences;
1> ResolveNativeReferences;
1> ResolveAssemblyReferences;
1> GenerateBindingRedirects;
1> GenerateBindingRedirectsUpdateAppConfig;
1> ResolveComReferences;
1> AfterResolveReferences
1> ;
1> ResolveTestReferences
1>
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (311,5)
1> Property reassignment: $(ResolveAssemblyReferencesDependsOn)=”_PrepareForReferenceResolution;
1> GetFrameworkPaths;
1> GetReferenceAssemblyPaths;
1> PrepareForBuild;
1> ResolveSDKReferences;
1> ExpandSDKReferences;
1> ;ResolveNuGetPackageAssets” (previous value: "
1> PrepareForBuild;
1> ;ResolveNuGetPackageAssets") at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (312,5)
1> Property reassignment: $(ResolveSDKReferencesDependsOn)=“_PrepareForReferenceResolution;ComputeCrtSDKReference;
1> GetInstalledSDKLocations
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (313,5)
1> Property reassignment: $(ComputeCompileInputsTargets)=”
1>
1> ;
1> GenerateTargetFrameworkMonikerAttribute;
1> ;
1> ComputeMIDLGeneratedCompileInputs;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (639,5)
1> Property reassignment: $(ComputeLinkInputsTargets)=”
1>
1> ;
1> ComputeRCGeneratedLinkInputs;
1> ;
1> ComputeManifestGeneratedLinkerInputs;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (952,5)
1> Property reassignment: $(GetTargetPathDependsOn)=”_PrepareForReferenceResolution;GetResolvedWinMD;” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1123,5)
1> Property reassignment: $(ComputeCompileInputsTargets)="
1>
1>
1> ;
1> ;
1> ;
1> ComputeCLInputPDBName;
1> ComputeReferenceCLInput;
1> WarnCompileDuplicatedFilename
1>
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1149,5)
1>
1>
1> ;
1> ;
1> ;
1> ComputeCustomBuildOutput;
1>
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1201,5)
1> Property reassignment: $(ComputeLibInputsTargets)=”
1>
1> ;
1> ComputeRCGeneratedLibInputs;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1208,5)
1> Property reassignment: $(ComputeImpLibInputsTargets)=”
1>
1>
1> ;
1> ;
1> ComputeRCGeneratedImpLibInputs;
1> ;
1>
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1215,5)
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ComputeCLGeneratedLinkInputs;
1>
1>
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1276,5)
1>
1>
1> ;
1> ;
1> ;
1> ComputeCLGeneratedLibInputs;
1>
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1291,5)
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ComputeCLGeneratedImpLibInputs;
1>
1>
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1306,5)
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1> ComputeLinkInputsFromProject;
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1337,5)
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ComputeLibInputsFromProject;
1>
1>
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1355,5)
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1> ComputeImpLibInputsFromProject;
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1373,5)
1>
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1> ;
1> ComputeReferenceLinkInputs;
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1497,5)
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1> ComputeReferenceLibInputs;
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1535,5)
1> ComputeLibAdditionalOptions;
1>
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1>
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1592,5)
1> Property reassignment: $(GetProjectInfoForReferenceDependsOn)=”
1>
1> ;
1> AddPublicIncludeDirectoriesToProjectsInfoForReference;
1> ;
1> AddPublicBMIsToProjectsInfoForReference;
1> AddDeployRecipeFileToProjectsInfoForReference;
1> AddLibrariesToProjectsInfoForReference;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1780,5)
1> Property reassignment: $(DocumentationProjectOutputGroupDependsOn)=“ResolvedXDCMake;ComputeCLCompileGeneratedXDCFiles” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (2180,5)
1> Property reassignment: $(ContentFilesProjectOutputGroupDependsOn)=“PrepareForBuild;AssignTargetPaths;PrepareForBuild;AssignTargetPaths;MakeDirsForFxc” (previous value: “PrepareForBuild;AssignTargetPaths”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (2246,5)
1> Property reassignment: $(CustomBuildToolBeforeTargets)=”" (previous value: “Midl”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets (187,5)
1> Property reassignment: $(CustomBuildToolAfterTargets)=“” (previous value: “PreBuildEvent”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets (188,5)
1> Property reassignment: $(CustomBuildBeforeTargets)=“” (previous value: “PostBuildEvent”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets (189,5)
1> Property reassignment: $(CustomBuildAfterTargets)=“” (previous value: “BscMake”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets (190,5)
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1> ComputeStdModulesCompileInputs;
1> FixupCLCompileOptions;
1> SetModuleDependencies;
1>
1>
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets (315,5)
1> Property reassignment: $(BuildingProject)=“true” (previous value: “false”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets (2075,5)
1> Property reassignment: $(ContentFilesProjectOutputGroupDependsOn)=“PrepareForBuild;AssignTargetPaths;PrepareForBuild;AssignTargetPaths;MakeDirsForFxc;_CreateCopyFileItems;” (previous value: “PrepareForBuild;AssignTargetPaths;PrepareForBuild;AssignTargetPaths;MakeDirsForFxc”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets (2621,5)
1> Property reassignment: $(PrepareForBuildDependsOn)=”_CheckWindowsSDKInstalled;;GetFrameworkPaths;GetReferenceAssemblyPaths;AssignLinkMetadata;SetCABuildNativeEnvironmentVariables" (previous value: “;GetFrameworkPaths;GetReferenceAssemblyPaths;AssignLinkMetadata;SetCABuildNativeEnvironmentVariables”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.WindowsSDK.targets (16,5)
1> Property reassignment: $(CleanDependsOn)="
1>
1>
1> BeforeClean;
1> CoreClean;
1> AfterClean
1> ;
1> ;
1> CppClean
1>
1> BeforeClean;
1> CoreClean;
1> AfterClean
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppClean.targets (22,5)
1> Property reassignment: $(CppCleanDependsOn)=”
1> BeforeCppClean;
1> ;
1> CoreCppClean;
1> AfterCppClean;
1> ;PGInstrumentedClean" (previous value: "
1> BeforeCppClean;
1> ;
1> CoreCppClean;
1> AfterCppClean;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppClean.targets (92,5)
1> Property reassignment: $(BuildDependsOn)=“SetTelemetryEnvironmentVariables;
1>
1> PrepareForBuild;
1> BuildCompile;
1> BuildLink;
1> ;
1> AfterBuild;
1> TlogCleanup;
1>
1> PrepareForBuild;
1> BuildCompile;
1> BuildLink;
1> ;
1> AfterBuild;
1> TlogCleanup;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.DesignTime.targets (539,5)
1> Property reassignment: $(RebuildDependsOn)=“SetTelemetryEnvironmentVariables;
1>
1> BeforeRebuild;
1> Clean;
1> Build;
1> AfterRebuild;
1> ;
1>
1> BeforeRebuild;
1> Clean;
1> Build;
1> AfterRebuild;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.DesignTime.targets (540,5)
1>
1>
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1> ;
1> ;
1> ComputeCudaCompileOutput
1>
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\CUDA 12.5.targets (937,9)
1>
1>
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1>
1> ;
1> ComputeCudaCompileOutput;
1> ComputeCudaLinkOutput
1>
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1>
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\CUDA 12.5.targets (942,9)
1>
1> BeforeCppClean;
1> ;
1> CoreCppClean;
1> AfterCppClean;
1> ;PGInstrumentedClean;
1> CudaClean
1> BeforeCppClean;
1> ;
1> CoreCppClean;
1> AfterCppClean;
1> ;PGInstrumentedClean”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\CUDA 12.5.targets (982,9)
1> Overriding target “GenerateTargetFrameworkMonikerAttribute” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “GenerateTargetFrameworkMonikerAttribute” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.BuildSteps.Targets”.
1> Overriding target “Build” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “Build” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.BuildSteps.Targets”.
1> Overriding target “Rebuild” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “Rebuild” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.BuildSteps.Targets”.
1> Overriding target “AfterBuild” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “AfterBuild” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.BuildSteps.Targets”.
1> Overriding target “PrepareForBuild” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “PrepareForBuild” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1> Overriding target “GetTargetPath” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “GetTargetPath” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1> Overriding target “ComputeIntermediateSatelliteAssemblies” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “ComputeIntermediateSatelliteAssemblies” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1> Overriding target “ClCompile” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “ClCompile” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1> Overriding target “ResourceCompile” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “ResourceCompile” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1> Overriding target “Lib” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “Lib” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1> Overriding target “Link” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “Link” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1> Overriding target “AllProjectOutputGroups” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “AllProjectOutputGroups” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1> Overriding target “BuiltProjectOutputGroup” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “BuiltProjectOutputGroup” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1> Overriding target “DebugSymbolsProjectOutputGroup” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “DebugSymbolsProjectOutputGroup” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1> Overriding target “DocumentationProjectOutputGroup” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “DocumentationProjectOutputGroup” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1> Overriding target “SourceFilesProjectOutputGroup” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “SourceFilesProjectOutputGroup” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1> Overriding target “ContentFilesProjectOutputGroup” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “ContentFilesProjectOutputGroup” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1> Overriding target “AllProjectOutputGroupsDependencies” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “AllProjectOutputGroupsDependencies” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1> Overriding target “BuiltProjectOutputGroupDependencies” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “BuiltProjectOutputGroupDependencies” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1> Overriding target “DebugSymbolsProjectOutputGroupDependencies” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “DebugSymbolsProjectOutputGroupDependencies” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1> Overriding target “DocumentationProjectOutputGroupDependencies” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “DocumentationProjectOutputGroupDependencies” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1> Overriding target “PreBuildEvent” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “PreBuildEvent” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1> Overriding target “PostBuildEvent” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “PostBuildEvent” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1> Overriding target “ClCompile” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “ClCompile” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1> Overriding target “Link” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “Link” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1> Overriding target “Lib” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “Lib” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1> Overriding target “ImpLib” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “ImpLib” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1> Overriding target “Midl” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “Midl” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1> Overriding target “ResourceCompile” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “ResourceCompile” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1> Overriding target “BeforeResGen” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “BeforeResGen” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1> Overriding target “ResGen” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “ResGen” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1> Overriding target “GenerateSatelliteAssemblies” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “GenerateSatelliteAssemblies” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1> Overriding target “Manifest” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “Manifest” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1> Overriding target “XdcMake” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “XdcMake” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1> Overriding target “BscMake” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “BscMake” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1> Overriding target “ComputeMetaGenInputs” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.MetaGen.targets” with target “ComputeMetaGenInputs” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1> Overriding target “GetNativeManifest” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “GetNativeManifest” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1> Overriding target “CheckIntelEnvironmentForVCLibsoneDAL” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportBefore\Intel.Libs.oneDAL.v143.targets” with target “CheckIntelEnvironmentForVCLibsoneDAL” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.Libs.oneDAL.v143.targets”.
1> Overriding target “GetTargetPathWithTargetPlatformMoniker” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “GetTargetPathWithTargetPlatformMoniker” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.DesignTime.targets”.
1> The target “CompileDesignTime” listed in a BeforeTargets attribute at “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\WebTools.Aspire\Microsoft.WebTools.Aspire.targets (44,11)” does not exist in the project, and will be ignored.
1> The target “CompileDesignTime” listed in a BeforeTargets attribute at “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\WebTools.Aspire\Microsoft.WebTools.Aspire.targets (57,11)” does not exist in the project, and will be ignored.
1> Project file contains ToolsVersion=“15.0”. This toolset may be unknown or missing, in which case you may be able to resolve this by installing the appropriate version of MSBuild, or the build may have been forced to a particular ToolsVersion for policy reasons. Treating the project as if it had ToolsVersion=“Current”. For more information, please see MSBuild Toolset (ToolsVersion) - MSBuild | Microsoft Learn.
1> Target AddExternalIncludDirectoriesToPaths:
1> Target SetBuildDefaultEnvironmentVariables:
1> Using “SetEnv” task from assembly “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Build.CppTasks.Common.dll”.
1> Task “SetEnv”
1> PATH=D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64;D:\Windows Kits\10\bin\10.0.22621.0\x64;;C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.8 Tools\x64;D:\Windows Kits\10\bin\10.0.22621.0\x86;;C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.8 Tools;D:\Program Files\Microsoft Visual Studio\2022\Community\Common7\tools;D:\Program Files\Microsoft Visual Studio\2022\Community\Common7\ide;C:\Program Files (x86)\HTML Help Workshop;;D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64;C:\WINDOWS\Microsoft.NET\Framework64\v4.0.30319;C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319;D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin;C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319;;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\libnvvp;;;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.3\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.3\libnvvp;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\libnvvp;;;;C:\Program Files (x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\WINDOWS\System32\OpenSSH;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files\Intel\WiFi\bin;C:\Program Files\Common Files\Intel\WirelessCommon;C:\Program Files\dotnet;C:\Program Files\NVIDIA Corporation\Nsight Compute 2024.2.1;C:\Users\cpodc\AppData\Local\Programs\Python\Launcher;C:\Users\cpodc\AppData\Local\Microsoft\WindowsApps;C:\Users\cpodc.dotnet\tools;C:\Users\cpodc;C:\Users\cpodc\AppData\Local\Programs\Python\Python312;C:\Users\cpodc\AppData\Local\Programs\Python\Python312\Scripts;C:\Users\cpodc;C:\Program Files\JetBrains\PyCharm Community Edition 2023.3.3\bin;;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\libnvvp;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\bin;C:\Program Files\NVIDIA GPU ComputingToolkit\v11.8\extras\CUPTI\lib64;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\include;;
1> Done executing task “SetEnv”.
1> Task “SetEnv”
1> LIB=D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\lib\x64;;D:\Windows Kits\10\lib\10.0.22621.0\ucrt\x64;;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\UnitTest\lib;D:\Windows Kits\10\lib\10.0.22621.0\um\x64;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.8\lib\um\x64;
1> Task “SetEnv”
1> LIBPATH=D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;
1> Task “SetEnv”
1> INCLUDE=D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\include;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\include;;D:\Windows Kits\10\Include\10.0.22621.0\ucrt;;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\UnitTest\include;D:\Windows Kits\10\Include\10.0.22621.0\um;D:\Windows Kits\10\Include\10.0.22621.0\shared;D:\Windows Kits\10\Include\10.0.22621.0\winrt;D:\Windows Kits\10\Include\10.0.22621.0\cppwinrt;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.8\Include\um;
1> Task “SetEnv”
1> EXTERNAL_INCLUDE=D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\include;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\include;;D:\Windows Kits\10\Include\10.0.22621.0\ucrt;;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\UnitTest\include;D:\Windows Kits\10\Include\10.0.22621.0\um;D:\Windows Kits\10\Include\10.0.22621.0\shared;D:\Windows Kits\10\Include\10.0.22621.0\winrt;D:\Windows Kits\10\Include\10.0.22621.0\cppwinrt;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.8\Include\um;
1> Task “SetEnv”
1> VSTEL_MSBuildProjectFullPath=D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial.vcxproj
1> Target “SetUserMacroEnvironmentVariables” skipped, due to false condition; (‘@(BuildMacro)’ != ‘’ and ‘$(DesignTimeBuild)’ != ‘true’) was evaluated as (‘’ != ‘’ and ‘’ != ‘true’).
1> Target PrepareForCudaBuild:
1> Using “SanitizePaths” task from assembly “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\Nvda.Build.CudaTasks.v12.5.dll”.
1> Task “SanitizePaths”
1> Done executing task “SanitizePaths”.
1> Using “CudaSetEnvironmentVariable” task from assembly “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\Nvda.Build.CudaTasks.v12.5.dll”.
1> Task “CudaSetEnvironmentVariable”
1> Nvda.Build.CudaTasks.CudaSetEnvironmentVariable: Setting ‘CUDAFE_FLAGS’ to ‘–sdk_dir “D:\Windows Kits\10”’
1> Done executing task “CudaSetEnvironmentVariable”.
1> Target CudaBuildCore:
1> Building target “CudaBuildCore” completely.
1> Output file “D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial\x64\Debug\kernel.cu.obj” does not exist.
1> Task “Message”
1> Compiling CUDA source file kernel.cu…
1> Done executing task “Message”.
1> Task “Message” skipped, due to false condition; (‘$(__ExcludedFromBuild)’ == ‘true’) was evaluated as (‘’ == ‘true’).
1> Task “MakeDir” skipped, due to false condition; (!Exists(‘$(CompileOutDir)’)) was evaluated as (!Exists(‘D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial\x64\Debug’)).
1> Task “MakeDir” skipped, due to false condition; (‘$(__Keep)’ == ‘true’ AND !Exists(‘$(__KeepDir)’)) was evaluated as (‘false’ == ‘true’ AND !Exists(‘CUDATutorial\x64\Debug’)).
1> Initializing task factory “XamlTaskFactory” from assembly “Microsoft.Build.Tasks.v4.0, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Using “CudaCompile” task from the task factory “XamlTaskFactory”.
1> Task “CudaCompile”
1> cmd.exe /C “C:\Users\cpodc\AppData\Local\Temp\tmp6c49fcbcd8b149c5bc932efd1f8fdbc0.cmd”
1> “C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\bin\nvcc.exe” -gencode=arch=compute_52,code="sm_52,compute_52" --use-local-env -ccbin “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include” -G --keep-dir CUDATutorial\x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DWIN64 -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -Xcompiler “/FdCUDATutorial\x64\Debug\vc143.pdb” -o “D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial\x64\Debug\kernel.cu.obj” “D:\Craig\Visual Studio 2022\Projects\CUDATutorial\kernel.cu”
1> D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\CUDA 12.5.targets(799,9): error MSB3721: The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\bin\nvcc.exe” -gencode=arch=compute_52,code="sm_52,compute_52" --use-local-env -ccbin “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include” -G --keep-dir CUDATutorial\x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DWIN64 -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -Xcompiler “/FdCUDATutorial\x64\Debug\vc143.pdb” -o “D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial\x64\Debug\kernel.cu.obj” “D:\Craig\Visual Studio 2022\Projects\CUDATutorial\kernel.cu”” exited with code 1.
1> Done executing task “CudaCompile” – FAILED.
1> Done building target “CudaBuildCore” in project “CUDATutorial.vcxproj” – FAILED.
1>
1> Done building project “CUDATutorial.vcxproj” – FAILED.
1> Done executing task “MSBuild” – FAILED.
1>
1>Done building project “CUDATutorial.vcxproj” – FAILED.
1>
1>Build FAILED.
1>
1>D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\CUDA 12.5.targets(799,9): error MSB3721: The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\bin\nvcc.exe” -gencode=arch=compute_52,code="sm_52,compute_52" --use-local-env -ccbin “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include” -G --keep-dir CUDATutorial\x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DWIN64 -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -Xcompiler “/FdCUDATutorial\x64\Debug\vc143.pdb” -o “D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial\x64\Debug\kernel.cu.obj” “D:\Craig\Visual Studio 2022\Projects\CUDATutorial\kernel.cu”” exited with code 1.
1> 0 Warning(s)
1> 1 Error(s)
1>
1>Time Elapsed 00:00:00.81
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
========== Build completed at 12:05 PM and took 01.419 seconds ==========
Here is the first one third of the output:
Build started at 12:05 PM…
1>------ Build started: Project: CUDATutorial, Configuration: Debug x64 ------
1>Search paths being used for $(MSBuildExtensionsPath) are D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild;$(MSBuildProgramFiles32)\MSBuild
1>Assembly loaded during Evaluation: System.Collections.Immutable, Version=8.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (location: D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\System.Collections.Immutable.dll, MVID: 8448ed54-b238-40d8-a464-bff29b2d85b9, AppDomain: [Default])
1>Trying to import D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild$(MSBuildToolsVersion)\Microsoft.Common.props using extensions path D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild
1>Property reassignment: $(MSBuildProjectExtensionsPath)=“D:\Craig\Visual Studio 2022\Projects\CUDATutorial\obj" (previous value: “obj") at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Microsoft.Common.props (60,5)
1>Trying to import D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild$(MSBuildToolsVersion)\Imports\Microsoft.Common.props\ImportBefore* using extensions path D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild
1>Assembly loaded during Evaluation: Microsoft.IO.Redist, Version=6.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 (location: D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\Microsoft.IO.Redist.dll, MVID: d528d43e-4d35-4c28-8aa6-a5ce49a5eba7, AppDomain: [Default])
1>Property ‘VisualStudioVersion’ with value ‘17.0’ expanded from the environment.
1>The “Configuration” property is a global property, and cannot be modified.
1>The “LangID” property is a global property, and cannot be modified.
1>The “SolutionDir” property is a global property, and cannot be modified.
1>Property ‘LOCALAPPDATA’ with value ‘C:\Users\cpodc\AppData\Local’ expanded from the environment.
1>Property reassignment: $(UseDebugLibraries)=“true” (previous value: “false”) at D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial.vcxproj (20,5)
1>Property reassignment: $(CharacterSet)=“MultiByte” (previous value: “NotSet”) at D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial.vcxproj (21,5)
1>Assembly loaded during Evaluation: Microsoft.Build.Utilities.Core, Version=15.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (location: D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\Microsoft.Build.Utilities.Core.dll, MVID: ee4672b2-20ae-46af-962d-6e9317270cb4, AppDomain: [Default])
1>Property ‘PROCESSOR_ARCHITECTURE’ with value ‘AMD64’ expanded from the environment.
1>Property reassignment: $(_oneTBBSubKey)=“2021.13{AAE0F012-76E2-4A9A-8BCD-403919B64C34}” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportBefore\Intel.oneAPI.Libs.v143.props (36,9)
1>Property reassignment: $(oneTBBMajorVersion)=“2021” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportBefore\Intel.oneAPI.Libs.v143.props (37,9)
1>Property reassignment: $(WindowsSdkDir_10)=“D:\Windows Kits\10" (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.WindowsSDK.props (18,5)
1>Property reassignment: $(NETFXSDK_Version)=“4.8” (previous value: “4.8.1”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.WindowsSDK.props (46,5)
1>Property reassignment: $(NETFXKitsDir)=“C:\Program Files (x86)\Windows Kits\NETFXSDK\4.8" (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.WindowsSDK.props (51,5)
1>Property reassignment: $(NETFXSDKDir)=“C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A" (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.WindowsSDK.props (54,5)
1>Property reassignment: $(WindowsSDK_ExecutablePath_x86)=“D:\Windows Kits\10\bin\10.0.22621.0\x86;;C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.8 Tools” (previous value: “D:\Windows Kits\10\bin\10.0.22621.0\x86;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.WindowsSDK.props (209,5)
1>Property reassignment: $(WindowsSDK_ExecutablePath_x64)=“D:\Windows Kits\10\bin\10.0.22621.0\x64;;C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.8 Tools\x64” (previous value: “D:\Windows Kits\10\bin\10.0.22621.0\x64;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.WindowsSDK.props (210,5)
1>Property reassignment: $(TargetExt)=”.exe” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.Common.props (28,5)
1>Property reassignment: $(VC_ExecutablePath_Loc)=“D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;;” (previous value: “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.Common.props (88,5)
1>Property reassignment: $(VC_ExecutablePath_Loc)=“D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;;;” (previous value: “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.Common.props (89,5)
1>Property reassignment: $(VC_ExecutablePath_Loc)=“D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;;;;” (previous value: “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;;;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.Common.props (90,5)
1>Property reassignment: $(VC_ExecutablePath_Loc)=“D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;;;;;” (previous value: “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;;;;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.Common.props (91,5)
1>Property reassignment: $(VC_ExecutablePath_Loc)=“D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;;;;;;” (previous value: “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;;;;;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.Common.props (92,5)
1>Property reassignment: $(VC_ExecutablePath_Loc)=“D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;;;;;;;” (previous value: “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;;;;;;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.Common.props (93,5)
1>Property reassignment: $(VC_ExecutablePath_Loc)=“D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostArm64\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;;;;;;;;” (previous value: “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;;;;;;;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.Common.props (94,5)
1>Property reassignment: $(VC_ExecutablePath_Loc)=“D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostArm64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostArm64\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;;;;;;;;;” (previous value: “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostArm64\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;;;;;;;;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.Common.props (95,5)
1>Property reassignment: $(VC_ExecutablePath_Loc)=“D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostArm64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostArm64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostArm64\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;;;;;;;;;;” (previous value: “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostArm64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostArm64\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;;;;;;;;;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.Common.props (96,5)
1>Property reassignment: $(VC_ExecutablePath_Loc)=“D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostArm64\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostArm64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostArm64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostArm64\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;;;;;;;;;;;” (previous value: “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostArm64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostArm64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostArm64\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x86\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\arm\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\1033;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x86\1033;;;;;;;;;;;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.Common.props (97,5)
1>Property reassignment: $(MSBuild_ExecutablePath)=“D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64;C:\WINDOWS\Microsoft.NET\Framework64\v4.0.30319;C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319;D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin;C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319" (previous value: “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin;C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319") at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.Common.props (124,5)
1>Property ‘COMPUTERNAME’ with value ‘DESKTOP-C61D8Q6’ expanded from the environment.
1>Property reassignment: $(RemoteDebuggerDeployDebugCppRuntime)=“true” (previous value: “false”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.Common.props (153,5)
1>Property reassignment: $(MultiProcMaxCount)=“0” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.Common.props (214,5)
1>Property reassignment: $(EspXtensions)=“EnumIndex.dll;CppCoreCheck.dll;” (previous value: “CppCoreCheck.dll;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CodeAnalysis.Extensions.props (21,5)
1>Property reassignment: $(EspXtensions)=“HResultCheck.dll;EnumIndex.dll;CppCoreCheck.dll;” (previous value: “EnumIndex.dll;CppCoreCheck.dll;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CodeAnalysis.Extensions.props (24,5)
1>Property reassignment: $(EspXtensions)=“VariantClear.dll;HResultCheck.dll;EnumIndex.dll;CppCoreCheck.dll;” (previous value: “HResultCheck.dll;EnumIndex.dll;CppCoreCheck.dll;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CodeAnalysis.Extensions.props (27,5)
1>Property reassignment: $(ConcurrencyCheckPath)=“D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\ConcurrencyCheck.dll” (previous value: “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX86\x86\ConcurrencyCheck.dll”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CodeAnalysis.Extensions.props (31,5)
1>Property reassignment: $(ConcurrencyCheckPath)=”\ConcurrencyCheck.dll” (previous value: “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64\ConcurrencyCheck.dll”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CodeAnalysis.Extensions.props (33,5)
1>Property reassignment: $(EspXtensions)=“ConcurrencyCheck.dll;VariantClear.dll;HResultCheck.dll;EnumIndex.dll;CppCoreCheck.dll;” (previous value: “VariantClear.dll;HResultCheck.dll;EnumIndex.dll;CppCoreCheck.dll;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CodeAnalysis.Extensions.props (34,5)
1>Property reassignment: $(VC_IncludePath)=“D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\include;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\include;;D:\Windows Kits\10\Include\10.0.22621.0\ucrt;;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\UnitTest\include” (previous value: “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\include;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\include;;D:\Windows Kits\10\Include\10.0.22621.0\ucrt;;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.UnitTest.props (17,5)
1>Property reassignment: $(VC_LibraryPath_x86)=“D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x86;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x86;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\lib\x86;;D:\Windows Kits\10\lib\10.0.22621.0\ucrt\x86;;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\UnitTest\lib” (previous value: “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x86;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x86;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\lib\x86;;D:\Windows Kits\10\lib\10.0.22621.0\ucrt\x86;;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.UnitTest.props (19,5)
1>Property reassignment: $(VC_LibraryPath_x64)=“D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\lib\x64;;D:\Windows Kits\10\lib\10.0.22621.0\ucrt\x64;;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\UnitTest\lib” (previous value: “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\lib\x64;;D:\Windows Kits\10\lib\10.0.22621.0\ucrt\x64;;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.UnitTest.props (20,5)
1>Property reassignment: $(VC_LibraryPath_ARM)=“D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\ARM;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\ARM;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\lib\ARM;;D:\Windows Kits\10\lib\10.0.22621.0\ucrt\arm;;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\UnitTest\lib” (previous value: “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\ARM;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\ARM;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\lib\ARM;;D:\Windows Kits\10\lib\10.0.22621.0\ucrt\arm;;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.UnitTest.props (21,5)
1>Property reassignment: $(VC_LibraryPath_ARM64)=“D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\ARM64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\ARM64;;;D:\Windows Kits\10\lib\10.0.22621.0\ucrt\arm64;;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\UnitTest\lib” (previous value: “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\ARM64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\ARM64;;;D:\Windows Kits\10\lib\10.0.22621.0\ucrt\arm64;;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.UnitTest.props (22,5)
1>Property reassignment: $(_PropertySheetDisplayName)=“Multi-byte Character Support” (previous value: “Core Windows Libraries”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.MultiByteCharSupport.props (15,5)
1>Property reassignment: $(_PropertySheetDisplayName)=“Application” (previous value: “Multi-byte Character Support”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.Application.props (15,5)
1>Property ‘Path’ with value ‘C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\libnvvp;;;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.3\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.3\libnvvp;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\libnvvp;;;;C:\Program Files (x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\WINDOWS\System32\OpenSSH;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files\Intel\WiFi\bin;C:\Program Files\Common Files\Intel\WirelessCommon;C:\Program Files\dotnet;C:\Program Files\NVIDIA Corporation\Nsight Compute 2024.2.1;C:\Users\cpodc\AppData\Local\Programs\Python\Launcher;C:\Users\cpodc\AppData\Local\Microsoft\WindowsApps;C:\Users\cpodc.dotnet\tools;C:\Users\cpodc;C:\Users\cpodc\AppData\Local\Programs\Python\Python312;C:\Users\cpodc\AppData\Local\Programs\Python\Python312\Scripts;C:\Users\cpodc;C:\Program Files\JetBrains\PyCharm Community Edition 2023.3.3\bin;;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\libnvvp;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\bin;C:\Program Files\NVIDIA GPU ComputingToolkit\v11.8\extras\CUPTI\lib64;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\include;’ expanded from the environment.
1>Property ‘SystemRoot’ with value ‘C:\WINDOWS’ expanded from the environment.
1>Property reassignment: $(_IPP1ASubKey)=“2021.12{A60D0066-760D-4720-8EF2-6741330F23E2}” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.Libs.IPP1A.v143.props (39,5)
1>Property reassignment: $(IPP1AMajorVersion)=“2021” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.Libs.IPP1A.v143.props (40,5)
1>Property reassignment: $(_IPP1ACPPLibDir)=“C:\Program Files (x86)\Intel\oneAPI\compiler\latest\lib” (previous value: “C:\Program Files (x86)\Intel\oneAPI\ipp\2021.12....\compiler\latest\lib”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.Libs.IPP1A.v143.props (54,5)
1>Property reassignment: $(IPP1AThreadedStatic)=“0” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.Libs.IPP1A.v143.props (57,5)
1>Property reassignment: $(_oneDALSubkey)=“2024{1141C36C-4EBE-4418-ABE0-8E6995E3BE9A}” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.Libs.oneDAL.v143.props (39,5)
1>Property reassignment: $(_oneDALTBBSubKey)=“2021.13{AAE0F012-76E2-4A9A-8BCD-403919B64C34}” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.Libs.oneDAL.v143.props (40,5)
1>Property reassignment: $(oneDALIncludeDir)=“C:\Program Files (x86)\Intel\oneAPI\dal\2024.5\include;C:\Program Files (x86)\Intel\oneAPI\dal\2024.5\include\dal” (previous value: “C:\Program Files (x86)\Intel\oneAPI\dal\2024.5\include”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.Libs.oneDAL.v143.props (56,5)
1>Property reassignment: $(_oneMKLSubKey)=“2024{EC9835C7-2791-46F8-81C6-CA2FAE5D0776}” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.Libs.oneMKL.v143.props (39,5)
1>Property reassignment: $(oneMKLMajorVersion)=“2024” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.Libs.oneMKL.v143.props (41,5)
1>Property reassignment: $(oneMKLIncludeDir)=“C:\Program Files (x86)\Intel\oneAPI\mkl\2024.2\include;C:\Program Files (x86)\Intel\oneAPI\mkl\2024.2\include\fftw” (previous value: “C:\Program Files (x86)\Intel\oneAPI\mkl\2024.2\include”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.Libs.oneMKL.v143.props (53,5)
1>Property reassignment: $(oneMKLIncludeDir)=“C:\Program Files (x86)\Intel\oneAPI\mkl\2024.2\include;C:\Program Files (x86)\Intel\oneAPI\mkl\2024.2\include\fftw;C:\Program Files (x86)\Intel\oneAPI\mkl\2024.2\include\mkl\intel64” (previous value: “C:\Program Files (x86)\Intel\oneAPI\mkl\2024.2\include;C:\Program Files (x86)\Intel\oneAPI\mkl\2024.2\include\fftw”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.Libs.oneMKL.v143.props (55,5)
1>Property reassignment: $(_oneMKLOmpLibDir)=“C:\Program Files (x86)\Intel\oneAPI\compiler\latest\lib” (previous value: “C:\Program Files (x86)\Intel\oneAPI\mkl\2024.2....\compiler\latest\lib”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.Libs.oneMKL.v143.props (60,5)
1>Property reassignment: $(_EvaluatedoneTBBdpstdDir)=“C:\Program Files (x86)\Intel\oneAPI\compiler\latest\include” (previous value: “C:\Program Files (x86)\Intel\oneAPI\tbb\2021.13....\compiler\latest\include”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.Libs.oneTBB.v143.props (44,5)
1>Property reassignment: $(_DPCPPSubKey)=”{D11584AC-4AAA-477F-BCCC-1CCBF07043BD}” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.oneAPI.Libs.v143.props (78,5)
1>Property reassignment: $(IDPCInstallDir)=“C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.oneAPI.Libs.v143.props (79,5)
1>Property reassignment: $(IDPCInstallDir)=“C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2" (previous value: “C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.oneAPI.Libs.v143.props (80,5)
1>Property reassignment: $(_DPCPPPath)=“C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2....\ocloc\latest\bin;C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2\bin;C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2\lib;” (previous value: “C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2\bin;C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2\lib;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.oneAPI.Libs.v143.props (90,5)
1>Property reassignment: $(_FPGABinPath)=“C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2\opt\oclfpga\windows64\bin;C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2\opt\oclfpga\bin;” (previous value: “C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2\opt\oclfpga\bin;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.oneAPI.Libs.v143.props (94,5)
1>Property reassignment: $(_FPGABinPath)=“C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2\opt\oclfpga\llvm\aocl-bin;C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2\opt\oclfpga\windows64\bin;C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2\opt\oclfpga\bin;” (previous value: “C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2\opt\oclfpga\windows64\bin;C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2\opt\oclfpga\bin;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.oneAPI.Libs.v143.props (95,5)
1>Property reassignment: $(_FPGABinPath)=“C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2\opt\oclfpga\host\windows64\bin;C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2\opt\oclfpga\llvm\aocl-bin;C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2\opt\oclfpga\windows64\bin;C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2\opt\oclfpga\bin;” (previous value: “C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2\opt\oclfpga\llvm\aocl-bin;C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2\opt\oclfpga\windows64\bin;C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2\opt\oclfpga\bin;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.oneAPI.Libs.v143.props (96,5)
1>Property reassignment: $(_SubKey)=”{B9B24887-5588-4FB9-BF50-1008DCEBE971}” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.oneAPI.Libs.v143.props (116,5)
1>Property reassignment: $(ICInstallDir)=“C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.oneAPI.Libs.v143.props (117,5)
1>Property reassignment: $(ICInstallDir)=“C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2" (previous value: “C:\Program Files (x86)\Intel\oneAPI\compiler\2024.2”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.oneAPI.Libs.v143.props (133,5)
1>Property ‘CUDA_PATH_V12_5’ with value ‘C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5’ expanded from the environment.
1>Property reassignment: $(CudaToolkitDir)=“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\CUDA 12.5.props (23,9)
1>Property reassignment: $(CudaToolkitDir)=“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5" (previous value: “C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\CUDA 12.5.props (29,9)
1>Property reassignment: $(CudaIntDir)=“CUDATutorial\x64\Debug” (previous value: “CUDATutorial\x64\Debug") at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\CUDA 12.5.props (70,9)
1>The “SolutionExt” property is a global property, and cannot be modified.
1>Property reassignment: $(ExtensionsToDeleteOnClean)=”.cdf;.cache;.obj;.obj.enc;.ilk;.ipdb;.iobj;.resources;.tlb;.tli;.tlh;.tmp;.rsp;.pgc;.pgd;.meta;.tlog;.manifest;.res;.pch;.exp;.idb;.rep;.xdc;.pdb;_manifest.rc;.bsc;.sbr;.xml;.metagen;.bi;D:\Craig\Visual Studio 2022\Projects\CUDATutorial\x64\Debug\CUDATutorial.exe.manifest;D:\Craig\Visual Studio 2022\Projects\CUDATutorial\x64\Debug\CUDATutorial.tlb;D:\Craig\Visual Studio 2022\Projects\CUDATutorial\x64\Debug\CUDATutorial.pdb;D:\Craig\Visual Studio 2022\Projects\CUDATutorial\x64\Debug\CUDATutorial.exe;D:\Craig\Visual Studio 2022\Projects\CUDATutorial\x64\Debug\CUDATutorial.bsc;D:\Craig\Visual Studio 2022\Projects\CUDATutorial\x64\Debug\CUDATutorial.ilk;D:\Craig\Visual Studio 2022\Projects\CUDATutorial\x64\Debug\CUDATutorial.exe.intermediate.manifest;CUDATutorial\x64\Debug\CUDATutorial.vcxproj.FileListAbsolute.txt" (previous value: ".cdf;.cache;.obj;.obj.enc;.ilk;.ipdb;.iobj;.resources;.tlb;.tli;.tlh;.tmp;.rsp;.pgc;.pgd;.meta;.tlog;.manifest;.res;.pch;.exp;.idb;.rep;.xdc;.pdb;_manifest.rc;.bsc;.sbr;.xml;.metagen;.bi”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets (40,5)
1>Property reassignment: $(DebugType)=“none” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.BuildSteps.Targets (32,5)
1>Trying to import D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild$(MSBuildToolsVersion)\Microsoft.Common.targets\ImportBefore* using extensions path D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild
1>Property reassignment: $(_DocumentationFileProduced)=“false” (previous value: “true”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets (185,5)
1>The “DevEnvDir” property is a global property, and cannot be modified.
1>The “SolutionName” property is a global property, and cannot be modified.
1>The “SolutionFileName” property is a global property, and cannot be modified.
1>The “SolutionPath” property is a global property, and cannot be modified.
1>Property reassignment: $(AutoUnifyAssemblyReferences)=“false” (previous value: “true”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets (369,5)
1>Property reassignment: $(MSBuildCopyMarkerName)=“CUDATuto.7B62B336” (previous value: “CUDATutorial.vcxproj”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets (392,5)
1>Property reassignment: $(MSBuildCopyMarkerName)=“CUDATuto.7B62B336.Up2Date” (previous value: “CUDATuto.7B62B336”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets (393,5)
1>Property reassignment: $(ProcessorArchitecture)=“amd64” (previous value: “x64”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets (523,5)
1>Property ‘MSBuildExtensionsPath64’ with value ‘C:\Program Files\MSBuild’ expanded from the environment.
1>Property reassignment: $(DelaySign)=”" (previous value: “false”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets (575,5)
1>Property reassignment: $(AssemblySearchPaths)=“{CandidateAssemblyFiles};D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;” (previous value: “{CandidateAssemblyFiles}”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets (644,5)
1>Property reassignment: $(AssemblySearchPaths)=“{CandidateAssemblyFiles};D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;;{HintPathFromItem}” (previous value: “{CandidateAssemblyFiles};D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets (645,5)
1>Property reassignment: $(AssemblySearchPaths)=“{CandidateAssemblyFiles};D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;;{HintPathFromItem};{TargetFrameworkDirectory}” (previous value: “{CandidateAssemblyFiles};D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;;{HintPathFromItem}”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets (646,5)
1>Property reassignment: $(AssemblySearchPaths)=“{CandidateAssemblyFiles};D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;;{HintPathFromItem};{TargetFrameworkDirectory};{AssemblyFoldersFromConfig:D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\AssemblyFolders.config,};” (previous value: “{CandidateAssemblyFiles};D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;;{HintPathFromItem};{TargetFrameworkDirectory}”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets (647,5)
1>Property reassignment: $(AssemblySearchPaths)=“{CandidateAssemblyFiles};D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;;{HintPathFromItem};{TargetFrameworkDirectory};{AssemblyFoldersFromConfig:D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\AssemblyFolders.config,};;{Registry:Software\Microsoft,,AssemblyFoldersEx}” (previous value: “{CandidateAssemblyFiles};D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;;{HintPathFromItem};{TargetFrameworkDirectory};{AssemblyFoldersFromConfig:D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\AssemblyFolders.config,};”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets (648,5)
1>Property reassignment: $(AssemblySearchPaths)=“{CandidateAssemblyFiles};D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;;{HintPathFromItem};{TargetFrameworkDirectory};{AssemblyFoldersFromConfig:D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\AssemblyFolders.config,};;{Registry:Software\Microsoft,,AssemblyFoldersEx};{AssemblyFolders}” (previous value: “{CandidateAssemblyFiles};D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;;{HintPathFromItem};{TargetFrameworkDirectory};{AssemblyFoldersFromConfig:D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\AssemblyFolders.config,};;{Registry:Software\Microsoft,,AssemblyFoldersEx}”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets (649,5)
1>Property reassignment: $(AssemblySearchPaths)=“{CandidateAssemblyFiles};D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;;{HintPathFromItem};{TargetFrameworkDirectory};{AssemblyFoldersFromConfig:D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\AssemblyFolders.config,};;{Registry:Software\Microsoft,,AssemblyFoldersEx};{AssemblyFolders};{GAC}” (previous value: “{CandidateAssemblyFiles};D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;;{HintPathFromItem};{TargetFrameworkDirectory};{AssemblyFoldersFromConfig:D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\AssemblyFolders.config,};;{Registry:Software\Microsoft,,AssemblyFoldersEx};{AssemblyFolders}”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets (650,5)
1>Property reassignment: $(AssemblySearchPaths)=“{CandidateAssemblyFiles};D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;;{HintPathFromItem};{TargetFrameworkDirectory};{AssemblyFoldersFromConfig:D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\AssemblyFolders.config,};;{Registry:Software\Microsoft,,AssemblyFoldersEx};{AssemblyFolders};{GAC};{RawFileName}” (previous value: “{CandidateAssemblyFiles};D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;;{HintPathFromItem};{TargetFrameworkDirectory};{AssemblyFoldersFromConfig:D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\AssemblyFolders.config,};;{Registry:Software\Microsoft,,AssemblyFoldersEx};{AssemblyFolders};{GAC}”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets (651,5)
1>Property reassignment: $(AssemblySearchPaths)=“{CandidateAssemblyFiles};D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;;{HintPathFromItem};{TargetFrameworkDirectory};{AssemblyFoldersFromConfig:D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\AssemblyFolders.config,};;{Registry:Software\Microsoft,,AssemblyFoldersEx};{AssemblyFolders};{GAC};{RawFileName};D:\Craig\Visual Studio 2022\Projects\CUDATutorial\x64\Debug" (previous value: “{CandidateAssemblyFiles};D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;;{HintPathFromItem};{TargetFrameworkDirectory};{AssemblyFoldersFromConfig:D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\AssemblyFolders.config,};;{Registry:Software\Microsoft,,AssemblyFoldersEx};{AssemblyFolders};{GAC};{RawFileName}”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets (652,5)
1>Property reassignment: $(_SGenGenerateSerializationAssembliesConfig)=“Auto” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets (3880,5)
1>Property reassignment: $(_SGenGenerateSerializationAssembliesConfig)=“Off” (previous value: “Auto”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets (3881,5)
1>Property reassignment: $(_TargetsThatPrepareProjectReferences)=”
1> AssignProjectConfiguration;
1> _SplitProjectReferencesByFileExistence
1> " (previous value: “_SplitProjectReferencesByFileExistence”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets (5048,5)
1>Property reassignment: $(_CodeAnalysisTreatWarningsAsErrors)=“false” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\v17.0\CodeAnalysis\Microsoft.CodeAnalysis.targets (125,5)
1>Property reassignment: $(CAExcludePath)=“D:\Windows Kits\10\Include\10.0.22621.0\ucrt;;D:\Windows Kits\10\Include\10.0.22621.0\um;D:\Windows Kits\10\Include\10.0.22621.0\shared;D:\Windows Kits\10\Include\10.0.22621.0\winrt;D:\Windows Kits\10\Include\10.0.22621.0\cppwinrt;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.8\Include\um;” (previous value: “D:\Windows Kits\10\Include\10.0.22621.0\um;D:\Windows Kits\10\Include\10.0.22621.0\shared;D:\Windows Kits\10\Include\10.0.22621.0\winrt;D:\Windows Kits\10\Include\10.0.22621.0\cppwinrt;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.8\Include\um;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\v17.0\CodeAnalysis\Microsoft.CodeAnalysis.targets (239,5)
1>Property reassignment: $(CAExcludePath)=“D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include;D:\Windows Kits\10\Include\10.0.22621.0\ucrt;;D:\Windows Kits\10\Include\10.0.22621.0\um;D:\Windows Kits\10\Include\10.0.22621.0\shared;D:\Windows Kits\10\Include\10.0.22621.0\winrt;D:\Windows Kits\10\Include\10.0.22621.0\cppwinrt;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.8\Include\um;” (previous value: “D:\Windows Kits\10\Include\10.0.22621.0\ucrt;;D:\Windows Kits\10\Include\10.0.22621.0\um;D:\Windows Kits\10\Include\10.0.22621.0\shared;D:\Windows Kits\10\Include\10.0.22621.0\winrt;D:\Windows Kits\10\Include\10.0.22621.0\cppwinrt;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.8\Include\um;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\v17.0\CodeAnalysis\Microsoft.CodeAnalysis.targets (240,5)
1>Property reassignment: $(CAExcludePath)=“D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\include;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include;D:\Windows Kits\10\Include\10.0.22621.0\ucrt;;D:\Windows Kits\10\Include\10.0.22621.0\um;D:\Windows Kits\10\Include\10.0.22621.0\shared;D:\Windows Kits\10\Include\10.0.22621.0\winrt;D:\Windows Kits\10\Include\10.0.22621.0\cppwinrt;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.8\Include\um;” (previous value: “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include;D:\Windows Kits\10\Include\10.0.22621.0\ucrt;;D:\Windows Kits\10\Include\10.0.22621.0\um;D:\Windows Kits\10\Include\10.0.22621.0\shared;D:\Windows Kits\10\Include\10.0.22621.0\winrt;D:\Windows Kits\10\Include\10.0.22621.0\cppwinrt;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.8\Include\um;”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\v17.0\CodeAnalysis\Microsoft.CodeAnalysis.targets (241,5)
1>Property reassignment: $(PrepareForBuildDependsOn)=“;GetFrameworkPaths;GetReferenceAssemblyPaths;AssignLinkMetadata;SetCABuildNativeEnvironmentVariables” (previous value: “;GetFrameworkPaths;GetReferenceAssemblyPaths;AssignLinkMetadata”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\v17.0\CodeAnalysis\Microsoft.CodeAnalysis.targets (244,5)
1>Property reassignment: $(PrepareResourcesDependsOn)="
1> XamlMarkupCompilePass1;
1> XamlMarkupCompilePass2;
1>
1> ;
1> PrepareResourceNames;
1> ResGen;
1> CompileLicxFiles
1>
1> " (previous value: "
1> ;
1> ResGen;
1> CompileLicxFiles
1> “) at C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\Microsoft.Xaml.targets (35,5)
1>Property reassignment: $(ResolveReferencesDependsOn)=”
1>
1> BeforeResolveReferences;
1> ResolveProjectReferences;
1> FindInvalidProjectReferences;
1> ResolveNativeReferences;
1> ResolveAssemblyReferences;
1> GenerateBindingRedirects;
1> GenerateBindingRedirectsUpdateAppConfig;
1> ResolveComReferences;
1> AfterResolveReferences
1> ;
1> ResolveTestReferences
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\v17.0\TeamTest\Microsoft.TeamTest.targets (4,5)
1>Trying to import D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild$(MSBuildToolsVersion)\Microsoft.Common.targets\ImportAfter* using extensions path D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild
1>Property reassignment: $(ProjectLockFile)=“obj\project.assets.json” (previous value: “D:\Craig\Visual Studio 2022\Projects\CUDATutorial\obj\project.assets.json”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\NuGet\17.0\Microsoft.NuGet.targets (74,5)
1>Property reassignment: $(ResolveAssemblyReferencesDependsOn)=”
1> GetFrameworkPaths;
1> GetReferenceAssemblyPaths;
1> PrepareForBuild;
1> ResolveSDKReferences;
1> ExpandSDKReferences;
1> ;ResolveNuGetPackageAssets" (previous value: "
1> PrepareForBuild;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\NuGet\17.0\Microsoft.NuGet.targets (185,5)
1>Property reassignment: $(PrepareResourcesDependsOn)=“ResolveNuGetPackageAssets;
1>
1> ;
1> ResGen;
1> CompileLicxFiles
1>
1>
1> ;
1> ResGen;
1> CompileLicxFiles
1>
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\NuGet\17.0\Microsoft.NuGet.targets (186,5)
1>Trying to import D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\WebTools.Aspire\Microsoft.WebTools.Aspire.targets using extensions path D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild
1>Property reassignment: $(JsonSchemaCombinedFilePath)=“D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial\x64\Debug\CombinedComponentSchema.json” (previous value: “CUDATutorial\x64\Debug\CombinedComponentSchema.json”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\WebTools.Aspire\Microsoft.WebTools.Aspire.targets (25,5)
1>Property reassignment: $(AppSettingsJsonSchemaCombinedFilePath)=“D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial\x64\Debug\AppSettingsSchema.json” (previous value: “CUDATutorial\x64\Debug\AppSettingsSchema.json”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\WebTools.Aspire\Microsoft.WebTools.Aspire.targets (27,5)
1>Property reassignment: $(DebugType)=”” (previous value: “none”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.BuildSteps.Targets (39,5)
1>Property reassignment: $(BuildDependsOn)=”
1> _PrepareForBuild;
1>
1> ResolveReferences;
1> PrepareForBuild;
1> InitializeBuildStatus;
1> BuildGenerateSources;
1> BuildCompile;
1> BuildLink;
1> ;
1> AfterBuild;
1> IncrementalClean;
1> TlogCleanup;
1> FinalizeBuildStatus;
1> BeforeBuild;
1> CoreBuild;
1> AfterBuild
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.BuildSteps.Targets (122,5)
1>Property reassignment: $(RebuildDependsOn)=”
1> _PrepareForRebuild;
1>
1> BeforeRebuild;
1> Clean;
1> Build;
1> AfterRebuild;
1> ;
1> BeforeRebuild;
1> Clean;
1> Build;
1> AfterRebuild;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.BuildSteps.Targets (131,5)
1>Property reassignment: $(CleanDependsOn)=”
1> _PrepareForClean;
1>
1> BeforeClean;
1> UnmanagedUnregistration;
1> CoreClean;
1> CleanReferencedProjects;
1> CleanPublishFolder;
1> AfterClean
1> ;
1> BeforeClean;
1> CoreClean;
1> AfterClean
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.BuildSteps.Targets (136,5)
1>Property reassignment: $(BeforeBuildGenerateSourcesTargets)=”
1>
1> ;
1> BeforeBuildGenerateSources;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (60,5)
1>Property reassignment: $(AfterBuildGenerateSourcesTargets)=”
1>
1> ;
1> AfterBuildGenerateSources;
1> ;
1> AfterBuildGenerateSourcesEvent;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (71,5)
1>Property reassignment: $(BuildGenerateSourcesAction)=”_BuildGenerateSourcesAction" (previous value: “Build”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (140,5)
1>Property reassignment: $(BuildCompileAction)=“_BuildCompileAction” (previous value: “Build”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (141,5)
1>Property reassignment: $(BuildLinkAction)=“_BuildLinkAction” (previous value: “Build”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (142,5)
1>Property reassignment: $(DetermineProjectTypeTargets)=“_PrepareForReferenceResolution;
1> ;
1> AddExternalIncludDirectoriesToPaths
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (249,5)
1>Property reassignment: $(ResolveReferencesDependsOn)=”_PrepareForReferenceResolution;ComputeCrtSDKReference;
1>
1> ;
1>
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (311,5)
1>Property reassignment: $(ResolveAssemblyReferencesDependsOn)=”_PrepareForReferenceResolution;
1> PrepareForBuild;
1> ;ResolveNuGetPackageAssets” (previous value: "
1> PrepareForBuild;
1> ;ResolveNuGetPackageAssets") at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (312,5)
1>Property reassignment: $(ResolveSDKReferencesDependsOn)=“_PrepareForReferenceResolution;ComputeCrtSDKReference;
1> GetInstalledSDKLocations
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (313,5)
1>Property reassignment: $(ComputeCompileInputsTargets)=”
1>
1> ;
1> GenerateTargetFrameworkMonikerAttribute;
1> ;
1> ComputeMIDLGeneratedCompileInputs;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (639,5)
1>Property reassignment: $(ComputeLinkInputsTargets)=”
1>
1> ;
1> ComputeRCGeneratedLinkInputs;
1> ;
1> ComputeManifestGeneratedLinkerInputs;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (952,5)
1>Property reassignment: $(GetTargetPathDependsOn)=”_PrepareForReferenceResolution;GetResolvedWinMD;” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1123,5)
1>Property reassignment: $(ComputeCompileInputsTargets)="
1>
1>
1> ;
1> ;
1> ;
1> ComputeCLInputPDBName;
1> ComputeReferenceCLInput;
1> WarnCompileDuplicatedFilename
1>
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1149,5)
1>
1>
1> ;
1> ;
1> ;
1> ComputeCustomBuildOutput;
1>
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1201,5)
1>Property reassignment: $(ComputeLibInputsTargets)=”
1>
1> ;
1> ComputeRCGeneratedLibInputs;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1208,5)
1>Property reassignment: $(ComputeImpLibInputsTargets)=”
1>
1>
1> ;
1> ;
1> ComputeRCGeneratedImpLibInputs;
1> ;
1>
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1215,5)
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ComputeCLGeneratedLinkInputs;
1>
1>
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1276,5)
1>
1>
1> ;
1> ;
1> ;
1> ComputeCLGeneratedLibInputs;
1>
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1291,5)
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ComputeCLGeneratedImpLibInputs;
1>
1>
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1306,5)
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1> ComputeLinkInputsFromProject;
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1337,5)
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ComputeLibInputsFromProject;
1>
1>
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1355,5)
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1> ComputeImpLibInputsFromProject;
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1373,5)
1>
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1> ;
1> ComputeReferenceLinkInputs;
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1497,5)
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1> ComputeReferenceLibInputs;
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1535,5)
1> ComputeLibAdditionalOptions;
1>
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1>
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1592,5)
1>Property reassignment: $(GetProjectInfoForReferenceDependsOn)=”
1>
1> ;
1> AddPublicIncludeDirectoriesToProjectsInfoForReference;
1> ;
1> AddPublicBMIsToProjectsInfoForReference;
1> AddDeployRecipeFileToProjectsInfoForReference;
1> AddLibrariesToProjectsInfoForReference;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (1780,5)
1>Property reassignment: $(DocumentationProjectOutputGroupDependsOn)=“ResolvedXDCMake;ComputeCLCompileGeneratedXDCFiles” (previous value: “”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (2180,5)
1>Property reassignment: $(ContentFilesProjectOutputGroupDependsOn)=“PrepareForBuild;AssignTargetPaths;PrepareForBuild;AssignTargetPaths;MakeDirsForFxc” (previous value: “PrepareForBuild;AssignTargetPaths”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets (2246,5)
1>Property reassignment: $(CustomBuildToolBeforeTargets)=”" (previous value: “Midl”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets (187,5)
1>Property reassignment: $(CustomBuildToolAfterTargets)=“” (previous value: “PreBuildEvent”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets (188,5)
1>Property reassignment: $(CustomBuildBeforeTargets)=“” (previous value: “PostBuildEvent”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets (189,5)
1>Property reassignment: $(CustomBuildAfterTargets)=“” (previous value: “BscMake”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets (190,5)
Here is the middle one third of the output
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1> ComputeStdModulesCompileInputs;
1> FixupCLCompileOptions;
1> SetModuleDependencies;
1>
1>
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets (315,5)
1>Property reassignment: $(BuildingProject)=“true” (previous value: “false”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets (2075,5)
1>Property reassignment: $(ContentFilesProjectOutputGroupDependsOn)=“PrepareForBuild;AssignTargetPaths;PrepareForBuild;AssignTargetPaths;MakeDirsForFxc;_CreateCopyFileItems;” (previous value: “PrepareForBuild;AssignTargetPaths;PrepareForBuild;AssignTargetPaths;MakeDirsForFxc”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets (2621,5)
1>Property reassignment: $(PrepareForBuildDependsOn)=”_CheckWindowsSDKInstalled;;GetFrameworkPaths;GetReferenceAssemblyPaths;AssignLinkMetadata;SetCABuildNativeEnvironmentVariables" (previous value: “;GetFrameworkPaths;GetReferenceAssemblyPaths;AssignLinkMetadata;SetCABuildNativeEnvironmentVariables”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.WindowsSDK.targets (16,5)
1>Property reassignment: $(CleanDependsOn)="
1>
1>
1> BeforeClean;
1> CoreClean;
1> AfterClean
1> ;
1> ;
1> CppClean
1>
1> BeforeClean;
1> CoreClean;
1> AfterClean
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppClean.targets (22,5)
1>Property reassignment: $(CppCleanDependsOn)=”
1> BeforeCppClean;
1> ;
1> CoreCppClean;
1> AfterCppClean;
1> ;PGInstrumentedClean" (previous value: "
1> BeforeCppClean;
1> ;
1> CoreCppClean;
1> AfterCppClean;
1> ") at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppClean.targets (92,5)
1>Property reassignment: $(BuildDependsOn)="SetTelemetryEnvironmentVariables;
1>
1> PrepareForBuild;
1> BuildCompile;
1> BuildLink;
1> ;
1> AfterBuild;
1> TlogCleanup;
1>
1> PrepareForBuild;
1> BuildCompile;
1> BuildLink;
1> ;
1> AfterBuild;
1> TlogCleanup;
1> ") at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.DesignTime.targets (539,5)
1>Property reassignment: $(RebuildDependsOn)=“SetTelemetryEnvironmentVariables;
1>
1> BeforeRebuild;
1> Clean;
1> Build;
1> AfterRebuild;
1> ;
1>
1> BeforeRebuild;
1> Clean;
1> Build;
1> AfterRebuild;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.DesignTime.targets (540,5)
1>
1>
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1> ;
1> ;
1> ComputeCudaCompileOutput
1>
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1> ;
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\CUDA 12.5.targets (937,9)
1>
1>
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1>
1> ;
1> ComputeCudaCompileOutput;
1> ComputeCudaLinkOutput
1>
1>
1>
1>
1>
1> ;
1> ;
1> ;
1> ;
1> ;
1>
1> “) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\CUDA 12.5.targets (942,9)
1>
1> BeforeCppClean;
1> ;
1> CoreCppClean;
1> AfterCppClean;
1> ;PGInstrumentedClean;
1> CudaClean
1> BeforeCppClean;
1> ;
1> CoreCppClean;
1> AfterCppClean;
1> ;PGInstrumentedClean”) at D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\CUDA 12.5.targets (982,9)
1>Overriding target “GenerateTargetFrameworkMonikerAttribute” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “GenerateTargetFrameworkMonikerAttribute” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.BuildSteps.Targets”.
1>Overriding target “Build” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “Build” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.BuildSteps.Targets”.
1>Overriding target “Rebuild” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “Rebuild” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.BuildSteps.Targets”.
1>Overriding target “AfterBuild” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “AfterBuild” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.BuildSteps.Targets”.
1>Overriding target “PrepareForBuild” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “PrepareForBuild” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1>Overriding target “GetTargetPath” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “GetTargetPath” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1>Overriding target “ComputeIntermediateSatelliteAssemblies” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “ComputeIntermediateSatelliteAssemblies” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1>Overriding target “ClCompile” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “ClCompile” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1>Overriding target “ResourceCompile” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “ResourceCompile” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1>Overriding target “Lib” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “Lib” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1>Overriding target “Link” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “Link” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1>Overriding target “AllProjectOutputGroups” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “AllProjectOutputGroups” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1>Overriding target “BuiltProjectOutputGroup” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “BuiltProjectOutputGroup” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1>Overriding target “DebugSymbolsProjectOutputGroup” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “DebugSymbolsProjectOutputGroup” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1>Overriding target “DocumentationProjectOutputGroup” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “DocumentationProjectOutputGroup” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1>Overriding target “SourceFilesProjectOutputGroup” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “SourceFilesProjectOutputGroup” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1>Overriding target “ContentFilesProjectOutputGroup” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “ContentFilesProjectOutputGroup” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1>Overriding target “AllProjectOutputGroupsDependencies” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “AllProjectOutputGroupsDependencies” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1>Overriding target “BuiltProjectOutputGroupDependencies” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “BuiltProjectOutputGroupDependencies” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1>Overriding target “DebugSymbolsProjectOutputGroupDependencies” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “DebugSymbolsProjectOutputGroupDependencies” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1>Overriding target “DocumentationProjectOutputGroupDependencies” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “DocumentationProjectOutputGroupDependencies” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets”.
1>Overriding target “PreBuildEvent” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “PreBuildEvent” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1>Overriding target “PostBuildEvent” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “PostBuildEvent” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1>Overriding target “ClCompile” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “ClCompile” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1>Overriding target “Link” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “Link” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1>Overriding target “Lib” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “Lib” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1>Overriding target “ImpLib” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “ImpLib” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1>Overriding target “Midl” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “Midl” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1>Overriding target “ResourceCompile” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “ResourceCompile” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1>Overriding target “BeforeResGen” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “BeforeResGen” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1>Overriding target “ResGen” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “ResGen” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1>Overriding target “GenerateSatelliteAssemblies” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “GenerateSatelliteAssemblies” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1>Overriding target “Manifest” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “Manifest” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1>Overriding target “XdcMake” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “XdcMake” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1>Overriding target “BscMake” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppBuild.targets” with target “BscMake” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1>Overriding target “ComputeMetaGenInputs” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.MetaGen.targets” with target “ComputeMetaGenInputs” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1>Overriding target “GetNativeManifest” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “GetNativeManifest” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets”.
1>Overriding target “CheckIntelEnvironmentForVCLibsoneDAL” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportBefore\Intel.Libs.oneDAL.v143.targets” with target “CheckIntelEnvironmentForVCLibsoneDAL” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Platforms\x64\PlatformToolsets\v143\ImportAfter\Intel.Libs.oneDAL.v143.targets”.
1>Overriding target “GetTargetPathWithTargetPlatformMoniker” in project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64\Microsoft.Common.CurrentVersion.targets” with target “GetTargetPathWithTargetPlatformMoniker” from project “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.DesignTime.targets”.
1>The target “CompileDesignTime” listed in a BeforeTargets attribute at “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\WebTools.Aspire\Microsoft.WebTools.Aspire.targets (44,11)” does not exist in the project, and will be ignored.
1>The target “CompileDesignTime” listed in a BeforeTargets attribute at “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\WebTools.Aspire\Microsoft.WebTools.Aspire.targets (57,11)” does not exist in the project, and will be ignored.
1>Build started 7/26/2024 12:05:30 PM.
1>Project file contains ToolsVersion=“15.0”. This toolset may be unknown or missing, in which case you may be able to resolve this by installing the appropriate version of MSBuild, or the build may have been forced to a particular ToolsVersion for policy reasons. Treating the project as if it had ToolsVersion=“Current”. For more information, please see MSBuild Toolset (ToolsVersion) - MSBuild | Microsoft Learn.
1>Target AddExternalIncludDirectoriesToPaths:
1>Target SetBuildDefaultEnvironmentVariables:
1> Using “SetEnv” task from assembly “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Build.CppTasks.Common.dll”.
1> Task “SetEnv”
1> PATH=D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64;D:\Windows Kits\10\bin\10.0.22621.0\x64;;C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.8 Tools\x64;D:\Windows Kits\10\bin\10.0.22621.0\x86;;C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.8 Tools;D:\Program Files\Microsoft Visual Studio\2022\Community\Common7\tools;D:\Program Files\Microsoft Visual Studio\2022\Community\Common7\ide;C:\Program Files (x86)\HTML Help Workshop;;D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin\amd64;C:\WINDOWS\Microsoft.NET\Framework64\v4.0.30319;C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319;D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Current\Bin;C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319;;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\libnvvp;;;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.3\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.3\libnvvp;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\libnvvp;;;;C:\Program Files (x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\WINDOWS\System32\OpenSSH;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files\Intel\WiFi\bin;C:\Program Files\Common Files\Intel\WirelessCommon;C:\Program Files\dotnet;C:\Program Files\NVIDIA Corporation\Nsight Compute 2024.2.1;C:\Users\cpodc\AppData\Local\Programs\Python\Launcher;C:\Users\cpodc\AppData\Local\Microsoft\WindowsApps;C:\Users\cpodc.dotnet\tools;C:\Users\cpodc;C:\Users\cpodc\AppData\Local\Programs\Python\Python312;C:\Users\cpodc\AppData\Local\Programs\Python\Python312\Scripts;C:\Users\cpodc;C:\Program Files\JetBrains\PyCharm Community Edition 2023.3.3\bin;;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\libnvvp;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\bin;C:\Program Files\NVIDIA GPU ComputingToolkit\v11.8\extras\CUPTI\lib64;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\include;;
1> Done executing task “SetEnv”.
1> Task “SetEnv”
1> LIB=D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\lib\x64;;D:\Windows Kits\10\lib\10.0.22621.0\ucrt\x64;;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\UnitTest\lib;D:\Windows Kits\10\lib\10.0.22621.0\um\x64;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.8\lib\um\x64;
1> Task “SetEnv”
1> LIBPATH=D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\x64;
1> Task “SetEnv”
1> INCLUDE=D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\include;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\include;;D:\Windows Kits\10\Include\10.0.22621.0\ucrt;;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\UnitTest\include;D:\Windows Kits\10\Include\10.0.22621.0\um;D:\Windows Kits\10\Include\10.0.22621.0\shared;D:\Windows Kits\10\Include\10.0.22621.0\winrt;D:\Windows Kits\10\Include\10.0.22621.0\cppwinrt;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.8\Include\um;
1> Task “SetEnv”
1> EXTERNAL_INCLUDE=D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\include;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\include;;D:\Windows Kits\10\Include\10.0.22621.0\ucrt;;;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\VS\UnitTest\include;D:\Windows Kits\10\Include\10.0.22621.0\um;D:\Windows Kits\10\Include\10.0.22621.0\shared;D:\Windows Kits\10\Include\10.0.22621.0\winrt;D:\Windows Kits\10\Include\10.0.22621.0\cppwinrt;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.8\Include\um;
1> Task “SetEnv”
1> VSTEL_MSBuildProjectFullPath=D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial.vcxproj
1>Target “SetUserMacroEnvironmentVariables” skipped, due to false condition; (‘@(BuildMacro)’ != ‘’ and ‘$(DesignTimeBuild)’ != ‘true’) was evaluated as (‘’ != ‘’ and ‘’ != ‘true’).
1>Target _PrepareForReferenceResolution:
1> Task “VCMessage” skipped, due to false condition; (‘$(WarnAboutIndividualManagedFiles)’ == ‘true’) was evaluated as (‘’ == ‘true’).
1> Task “Message” skipped, due to false condition; (‘$(_REFERENCE_DEBUG)’==‘true’) was evaluated as (‘’==‘true’).
1>Target GetResolvedWinMD:
1>Target _CheckWindowsSDKInstalled:
1> Task “VCMessage” skipped, due to false condition; (‘$(WindowsSDKInstalled)’ != ‘true’) was evaluated as (‘true’ != ‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘$(WindowsAppContainer)’ != ‘true’ and ‘$(WindowsSDK_Desktop_Support)’ != true) was evaluated as (‘false’ != ‘true’ and ‘true’ != true).
1>Target GetFrameworkPaths:
1>Target “_PrepareForReferenceResolution” skipped. Previously built successfully.
1>Target “GetFrameworkPaths” skipped. Previously built successfully.
1>Target GetReferenceAssemblyPaths:
1> Task “GetReferenceAssemblyPaths” skipped, due to false condition; (‘$(TargetFrameworkMoniker)’ != ‘’ and (‘$(_TargetFrameworkDirectories)’ == ‘’ or ‘$(_FullFrameworkReferenceAssemblyPaths)’ == ‘’)) was evaluated as (‘’ != ‘’ and (‘’ == ‘’ or ‘’ == ‘’)).
1>Target “AssignLinkMetadata” skipped, due to false condition; ( ‘$(SynthesizeLinkMetadata)’ == ‘true’ ) was evaluated as ( ‘’ == ‘true’ ).
1>Target SetCABuildNativeEnvironmentVariables:
1> Task “SetEnv”
1> CAExcludePath=D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\include;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include;D:\Windows Kits\10\Include\10.0.22621.0\ucrt;;D:\Windows Kits\10\Include\10.0.22621.0\um;D:\Windows Kits\10\Include\10.0.22621.0\shared;D:\Windows Kits\10\Include\10.0.22621.0\winrt;D:\Windows Kits\10\Include\10.0.22621.0\cppwinrt;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.8\Include\um;
1> Task “SetEnv” skipped, due to false condition; (‘$(RunMsvcAnalysis)’==‘true’ and ‘$(VCCodeAnalysisUX)’==‘true’) was evaluated as (‘false’==‘true’ and ‘true’==‘true’).
1>Target “EnableIntermediateOutputPathMismatchWarning” skipped, due to false condition; (‘$(RestoreProjectStyle)’ == ‘PackageReference’) was evaluated as (‘’ == ‘PackageReference’).
1>Target _CheckForInvalidConfigurationAndPlatform:
1> Task “Error” skipped, due to false condition; ( ‘$(_InvalidConfigurationError)’ == ‘true’ ) was evaluated as ( ‘’ == ‘true’ ).
1> Task “Warning” skipped, due to false condition; ( ‘$(_InvalidConfigurationWarning)’ == ‘true’ ) was evaluated as ( ‘’ == ‘true’ ).
1> Using “Message” task from assembly “Microsoft.Build.Tasks.Core, Version=15.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “Message”
1> Configuration=Debug
1> Done executing task “Message”.
1> Task “Message”
1> Platform=x64
1> Task “Error” skipped, due to false condition; (‘$(OutDir)’ != ‘’ and !HasTrailingSlash(‘$(OutDir)’)) was evaluated as (‘D:\Craig\Visual Studio 2022\Projects\CUDATutorial\x64\Debug' != ‘’ and !HasTrailingSlash(‘D:\Craig\Visual Studio 2022\Projects\CUDATutorial\x64\Debug')).
1> Task “Error” skipped, due to false condition; (’$(IntermediateOutputPath)’ != ‘’ and !HasTrailingSlash(‘$(IntermediateOutputPath)’)) was evaluated as (‘CUDATutorial\x64\Debug' != ‘’ and !HasTrailingSlash(‘CUDATutorial\x64\Debug')).
1> Task “Error” skipped, due to false condition; (’$(BaseIntermediateOutputPath)’ != ‘’ and !HasTrailingSlash(‘$(BaseIntermediateOutputPath)’)) was evaluated as (‘obj' != ‘’ and !HasTrailingSlash(‘obj')).
1> Task “Error” skipped, due to false condition; ( ‘$(_InitialMSBuildProjectExtensionsPath)’ != ‘’ And ‘$(MSBuildProjectExtensionsPath)’ != ‘$(_InitialMSBuildProjectExtensionsPath)’ ) was evaluated as ( ‘D:\Craig\Visual Studio 2022\Projects\CUDATutorial\obj' != ‘’ And ‘D:\Craig\Visual Studio 2022\Projects\CUDATutorial\obj' != ‘D:\Craig\Visual Studio 2022\Projects\CUDATutorial\obj' ).
1> Task “Warning” skipped, due to false condition; ( ‘$(EnableBaseIntermediateOutputPathMismatchWarning)’ == ‘true’ And ‘$(_InitialBaseIntermediateOutputPath)’ != ‘$(BaseIntermediateOutputPath)’ And ‘$(BaseIntermediateOutputPath)’ != ‘$(MSBuildProjectExtensionsPath)’ ) was evaluated as ( ‘’ == ‘true’ And ‘obj' != ‘obj' And ‘obj' != ‘D:\Craig\Visual Studio 2022\Projects\CUDATutorial\obj' ).
1>Target PrepareForBuild:
1> Task “VCMessage” skipped, due to false condition; (’$(DesignTimeBuild)’ != ‘true’ and ‘$(ConfigurationPlatformExists)’ != ‘true’) was evaluated as (’’ != ‘true’ and ‘true’ != ‘true’).
1> Task “VCMessage” skipped, due to false condition; (’$(ApplicationType)’ == ‘’ and ‘$(DesignTimeBuild)’ != ‘true’ and ‘$(_ToolsetFound)’ != ‘true’) was evaluated as (’’ == ‘’ and ‘’ != ‘true’ and ‘true’ != ‘true’).
1> Task “VCMessage” skipped, due to false condition; (’$(ApplicationType)’ != ‘’ and ‘$(DesignTimeBuild)’ != ‘true’ and ‘$(_ToolsetFound)’ != ‘true’) was evaluated as (‘’ != ‘’ and ‘’ != ‘true’ and ‘true’ != ‘true’).
1> Using “MakeDir” task from assembly “Microsoft.Build.Tasks.Core, Version=15.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “MakeDir”
1> Done executing task “MakeDir”.
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(WindowsAppContainer)’==‘true’ and ‘$(ConfigurationType)’!=‘Application’ and ‘$(ConfigurationType)’!=‘DynamicLibrary’ and ‘$(ConfigurationType)’!=‘StaticLibrary’) was evaluated as (‘’!=‘true’ and ‘false’==‘true’ and ‘Application’!=‘Application’ and ‘Application’!=‘DynamicLibrary’ and ‘Application’!=‘StaticLibrary’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(VCToolsInstallDir)’==‘’ and ‘$(UseEnv)’ != ‘true’ and (‘$(TargetFrameworkVersion)’==‘v3.5’ or ‘$(TargetFrameworkVersion)’==‘v3.0’ or ‘$(TargetFrameworkVersion)’==‘v2.0’ )) was evaluated as (‘’!=‘true’ and ‘D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807'==’’ and ‘’ != ‘true’ and (‘’==‘v3.5’ or ‘’==‘v3.0’ or ‘’==‘v2.0’ )).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(VCToolsInstallDir)’==‘’ and ‘$(UseEnv)’ != ‘true’ and ‘$(PlatformToolset)’==‘v90’) was evaluated as (‘’!=‘true’ and ‘D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807'==’’ and ‘’ != ‘true’ and ‘v143’==‘v90’).
1> Using “CheckVCToolsetVersion” task from assembly “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Build.CppTasks.Common.dll”.
1> Task “CheckVCToolsetVersion”
1> Done executing task “CheckVCToolsetVersion”.
1> Task “VCMessage” skipped, due to false condition; (‘$(CheckMFCInstalled)’ == ‘true’ and !Exists($(MFC_KeyFile)) and ‘$(SpectreLibs)’ == ‘’) was evaluated as (‘’ == ‘true’ and !Exists(D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64\mfcs140.lib) and ‘’ == ‘’).
1> Task “VCMessage” skipped, due to false condition; (‘$(CheckMFCInstalled)’ == ‘true’ and !Exists($(MFC_KeyFile)) and ‘$(SpectreLibs)’ != ‘’) was evaluated as (‘’ == ‘true’ and !Exists(D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64\mfcs140.lib) and ‘’ != ‘’).
1> Task “VCMessage” skipped, due to false condition; (‘$(CheckATLInstalled)’ == ‘true’ and !Exists($(ATL_KeyFile)) and ‘$(SpectreLibs)’ == ‘’) was evaluated as (‘’ == ‘true’ and !Exists(D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64\atls.lib) and ‘’ == ‘’).
1> Task “VCMessage” skipped, due to false condition; (‘$(CheckATLInstalled)’ == ‘true’ and !Exists($(ATL_KeyFile)) and ‘$(SpectreLibs)’ != ‘’) was evaluated as (‘’ == ‘true’ and !Exists(D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\atlmfc\lib\x64\atls.lib) and ‘’ != ‘’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’ != ‘true’ and
1> ‘$(CheckMSVCComponents)’==‘true’ and
1> ‘$(SpectreMitigation)’ != ‘’ and
1> ‘$(SpectreMitigation)’ != ‘false’ and
1> ((‘$(VC_Target_Library_Platform)’ == ‘OneCore’ and !Exists(‘$(VC_LibraryPath_VC_OneCore_CurrentPlatform_spectre)’)) or
1> (‘$(VC_Target_Library_Platform)’ == ‘Desktop’ and !Exists(‘$(VC_LibraryPath_VC_Desktop_CurrentPlatform_spectre)’)))) was evaluated as (‘’ != ‘true’ and
1> ‘true’==‘true’ and
1> ‘false’ != ‘’ and
1> ‘false’ != ‘false’ and
1> ((‘Desktop’ == ‘OneCore’ and !Exists(‘D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\spectre\onecore\x64’)) or
1> (‘Desktop’ == ‘Desktop’ and !Exists(‘D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\lib\spectre\x64’)))).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(VCToolsInstallDir)’==‘’ and ‘$(UseEnv)’ != ‘true’ and ‘$(CheckMSVCComponents)’==‘true’) was evaluated as (‘’!=‘true’ and ‘D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807'==’’ and ‘’ != ‘true’ and ‘true’==‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(WindowsSDKDir)’==‘’ and ‘$(UseEnv)’ != ‘true’) was evaluated as (‘’!=‘true’ and ‘D:\Windows Kits\10'==’’ and ‘’ != ‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(IntDirTrailingSlashWarning)’==‘true’) was evaluated as (‘’!=‘true’ and ‘’==‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(OutDirTrailingSlashWarning)’==‘true’) was evaluated as (‘’!=‘true’ and ‘’==‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘%(CompatibilityIssues.Identity)’ != ‘’ and ‘$(DesignTimeBuild)’!=‘true’) was evaluated as (‘’ != ‘’ and ‘’!=‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘$(IgnoreWarnIntDirSharingDetected)’ != ‘true’ and ‘$(IntDirSharingDetected)’ == ‘true’) was evaluated as (‘’ != ‘true’ and ‘’ == ‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(IgnoreWarnIntDirInTempDetected)’ != ‘true’ and (‘$(IntDirFullPath.StartsWith($(_Tmp), true, null))’ == ‘true’ or ‘$(IntDirFullPath.StartsWith($(_Temp), true, null))’ == ‘true’ or ‘$(OutDirFullPath.StartsWith($(_Tmp), true, null))’ == ‘true’ or ‘$(OutDirFullPath.StartsWith($(_Temp), true, null))’ == ‘true’)) was evaluated as (‘’!=‘true’ and ‘’ != ‘true’ and (‘False’ == ‘true’ or ‘False’ == ‘true’ or ‘False’ == ‘true’ or ‘False’ == ‘true’)).
1> Using “VCMessage” task from assembly “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Build.CppTasks.Common.dll”.
1> Task “VCMessage”
1> Structured output is enabled. The formatting of compiler diagnostics will reflect the error hierarchy. See Problem Details Window - Visual Studio (Windows) | Microsoft Learn for more details.
1> Done executing task “VCMessage”.
1> Task “MakeDir”
1>Target “PrepareForBuild” skipped. Previously built successfully.
1>Target InitializeBuildStatus:
1> Using “ReadLinesFromFile” task from assembly “Microsoft.Build.Tasks.Core, Version=15.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “ReadLinesFromFile”
1> Done executing task “ReadLinesFromFile”.
1> Using “WriteLinesToFile” task from assembly “Microsoft.Build.Tasks.Core, Version=15.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “WriteLinesToFile”
1> Done executing task “WriteLinesToFile”.
1> Using “Touch” task from assembly “Microsoft.Build.Tasks.Core, Version=15.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “Touch”
1> Touching “CUDATutorial\x64\Debug\CUDATutorial.tlog\unsuccessfulbuild”.
1> Done executing task “Touch”.
1>Target “SetBuildDefaultEnvironmentVariables” skipped. Previously built successfully.
1>Target _SelectedFiles:
1>Target CudaFilterSelectedFiles:
1>Target InitializeCudaHostProperties:
1>Target AddCudaCompileMetadata:
1> Building target “AddCudaCompileMetadata” completely.
1> No input files were specified.
1> Assembly loaded during TaskRun: Nvda.Build.CudaTasks.v11.6, Version=7.0.0.0, Culture=neutral, PublicKeyToken=null (location: D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\Nvda.Build.CudaTasks.v12.5.dll, MVID: 3fa2cf38-dea4-4caf-a00e-880d7bd2e5d8, AppDomain: [Default])
1> Using “SanitizePaths” task from assembly “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\Nvda.Build.CudaTasks.v12.5.dll”.
1> Task “SanitizePaths”
1> Done executing task “SanitizePaths”.
1> Using “SplitToItemMetadata” task from assembly “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\Nvda.Build.CudaTasks.v12.5.dll”.
1> Task “SplitToItemMetadata”
1> Done executing task “SplitToItemMetadata”.
1>Target “AddCudaCompileMetadata” skipped. Previously built successfully.
1>Target “InitializeCudaHostProperties” skipped. Previously built successfully.
1>Target InitializeCudaProjectProperties:
1>Target AddCudaLinkMetadata:
1> Building target “AddCudaLinkMetadata” completely.
1> Using “ResolvePaths” task from assembly “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\Nvda.Build.CudaTasks.v12.5.dll”.
1> Task “ResolvePaths”
1> Done executing task “ResolvePaths”.
1>Target AddCudaCompileDeps:
1> Skipping target “AddCudaCompileDeps” because all output files are up-to-date with respect to the input files.
1> Input files:
1> kernel.cu
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\builtin_types.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\channel_descriptor.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\common_functions.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\cudacc_ext.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\device_double_functions.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\device_double_functions.hpp
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\device_functions.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\device_functions.hpp
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\host_config.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\host_defines.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\math_functions.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\math_functions.hpp
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\sm_70_rt.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\sm_80_rt.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\sm_90_rt.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\cuda_device_runtime_api.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\cuda_runtime.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\cuda_runtime_api.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\device_atomic_functions.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\device_launch_parameters.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\device_types.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\driver_functions.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\driver_types.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\library_types.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\sm_20_atomic_functions.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\sm_20_intrinsics.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\sm_30_intrinsics.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\sm_32_atomic_functions.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\sm_32_intrinsics.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\sm_35_atomic_functions.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\sm_35_intrinsics.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\sm_60_atomic_functions.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\sm_61_intrinsics.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\surface_indirect_functions.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\surface_types.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\texture_indirect_functions.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\texture_types.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\vector_functions.h
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\vector_functions.hpp
1> C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\vector_types.h
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\cmath
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\concurrencysal.h
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\crtdefs.h
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\cstddef
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\cstdint
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\cstdlib
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\initializer_list
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\limits.h
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\sal.h
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\stdint.h
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\type_traits
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\use_ansi.h
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\utility
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\vadefs.h
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\vcruntime.h
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\vcruntime_new.h
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\vcruntime_new_debug.h
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\vcruntime_string.h
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\xkeycheck.h
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\xtr1common
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\yvals.h
1> D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\yvals_core.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_malloc.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_math.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_memcpy_s.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_memory.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_search.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_stdio_config.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_wctype.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_wstdio.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_wstdlib.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_wstring.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_wtime.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\crtdbg.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\ctype.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\errno.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\math.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\stddef.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\stdio.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\stdlib.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\string.h
1> D:\Windows Kits\10\Include\10.0.22621.0\ucrt\time.h
1> Output files: CUDATutorial\x64\Debug\kernel.cu-1834041770.deps
1>Target AddCudaCompilePropsDeps:
1> Skipping target “AddCudaCompilePropsDeps” because all output files are up-to-date with respect to the input files.
1> Input files: D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial.vcxproj
1> Output files: CUDATutorial\x64\Debug\kernel.cu.cache
1>Target “WriteCudaCompileTlogs” skipped, due to false condition; (‘@(CudaCompile)’ != ‘’ AND ‘@(SelectedFiles)’ == ‘’) was evaluated as (‘kernel.cu’ != ‘’ AND ‘kernel.cu’ == ‘’).
1>Target ValidateCudaBuild:
1> Task “Error” skipped, due to false condition; (!Exists($(CudaToolkitDir))) was evaluated as (!Exists(C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5)).
1>Target ValidateCudaCodeGeneration:
1> Building target “ValidateCudaCodeGeneration” completely.
1> Using “CountItems” task from assembly “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\Nvda.Build.CudaTasks.v12.5.dll”.
1> Task “CountItems”
1> Done executing task “CountItems”.
1> Task “Error” skipped, due to false condition; (‘%(CudaCompile.NvccCompilation)’ != ‘compile’ AND ‘%(CudaCompile.NvccCompilation)’ != ‘fatbin’ AND $(ValidateCudaCodeGenerationCount) > 1) was evaluated as (‘compile’ != ‘compile’ AND ‘compile’ != ‘fatbin’ AND 1 > 1).
1>Target ComputeCudaCompileOutput:
1> Building target “ComputeCudaCompileOutput” completely.
1>Target PrepareForCudaBuild:
1> Using “CudaSetEnvironmentVariable” task from assembly “D:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\Nvda.Build.CudaTasks.v12.5.dll”.
1> Task “CudaSetEnvironmentVariable”
1> Nvda.Build.CudaTasks.CudaSetEnvironmentVariable: Setting ‘CUDAFE_FLAGS’ to ‘–sdk_dir “D:\Windows Kits\10”’
1> Done executing task “CudaSetEnvironmentVariable”.
1>Target CudaBuild:
1> Task “Warning” skipped, due to false condition; (‘%(CudaCompile.TargetMachinePlatform)’ == ‘32’) was evaluated as (‘64’ == ‘32’).
1> Using “MSBuild” task from assembly “Microsoft.Build.Tasks.Core, Version=15.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “MSBuild”
1> Overriding Global Properties for project “D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial.vcxproj” with:
1> Platform=x64
1> __CompileIn=D:\Craig\Visual Studio 2022\Projects\CUDATutorial\kernel.cu
1> __CompileRelativeDir=
1> __CompileFilename=kernel
1> __CompileOut=D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial\x64\Debug\kernel.cu.obj
1> __ProjectDeps=
1> __Deps=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\builtin_types.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\channel_descriptor.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\common_functions.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\cudacc_ext.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\device_double_functions.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\device_double_functions.hpp;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\device_functions.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\device_functions.hpp;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\host_config.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\host_defines.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\math_functions.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\math_functions.hpp;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\sm_70_rt.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\sm_80_rt.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\crt\sm_90_rt.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\cuda_device_runtime_api.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\cuda_runtime.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\cuda_runtime_api.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\device_atomic_functions.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\device_launch_parameters.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\device_types.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\driver_functions.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\driver_types.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\library_types.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\sm_20_atomic_functions.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\sm_20_intrinsics.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\sm_30_intrinsics.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\sm_32_atomic_functions.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\sm_32_intrinsics.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\sm_35_atomic_functions.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\sm_35_intrinsics.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\sm_60_atomic_functions.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\sm_61_intrinsics.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\surface_indirect_functions.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\surface_types.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\texture_indirect_functions.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\texture_types.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\vector_functions.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\vector_functions.hpp;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include\vector_types.h;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\cmath;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\concurrencysal.h;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\crtdefs.h;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\cstddef;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\cstdint;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\cstdlib;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\initializer_list;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\limits.h;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\sal.h;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\stdint.h;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\type_traits;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\use_ansi.h;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\utility;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\vadefs.h;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\vcruntime.h;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\vcruntime_new.h;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\vcruntime_new_debug.h;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\vcruntime_string.h;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\xkeycheck.h;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\xtr1common;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\yvals.h;D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\include\yvals_core.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_malloc.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_math.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_memcpy_s.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_memory.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_search.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_stdio_config.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_wctype.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_wstdio.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_wstdlib.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_wstring.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\corecrt_wtime.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\crtdbg.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\ctype.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\errno.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\math.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\stddef.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\stdio.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\stdlib.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\string.h;D:\Windows Kits\10\Include\10.0.22621.0\ucrt\time.h
1> __AdditionalDependencies=
1> __SelectedFilesDep=SelectedFiles.{58e7a258-0433-4cfb-9ce7-27f320d678bc}
1> __ExcludedFromBuild=
1> __ExecutionDescription=Compiling CUDA source file kernel.cu…
1> __ExclusionDescription=Skipping CUDA source file kernel.cu %28excluded from build%29.
1> __Api=Runtime
1> __AdditionalCompilerOptions=
1> __AdditionalDeps=
1> __Include=;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include
1> __GenerateRelocatableDeviceCode=false
1> __ExtensibleWholeProgramCompilation=false
1> __NvccCompilation=compile
1> __CudaRuntime=Static
1> __NvccPath=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\bin\nvcc.exe
1> __RequiredIncludes=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include
1> __TargetMachinePlatform=64
1> __InterleaveSourceInPTX=false
1> __CodeGeneration=arch=compute_52,code="sm_52,compute_52"
1> __GPUDebugInfo=true
1> __GenerateLineInfo=false
1> __Keep=false
1> __KeepDir=CUDATutorial\x64\Debug
1> __MaxRegCount=0
1> __PtxAsOptionV=false
1> __SplitCompile=Default
1> __SplitCompileCustomThreads=
1> __Defines=WIN32 WIN64 _DEBUG _CONSOLE _MBCS
1> __Emulation=false
1> __HostDebugInfo=true
1> __FastMath=false
1> __DebugInformationFormat=ProgramDatabase
1> __Optimization=Od
1> __ProgramDataBaseFileName=CUDATutorial\x64\Debug\vc143.pdb
1> __Runtime=MDd
1> __RuntimeChecks=RTC1
1> __TypeInfo=
1> __Warning=W3
1> __AdditionalOptions=
You’ve got so much output in this post now that it is almost unusable. However the verbose output from VS did not indicate the problem.
You may need to work on sorting out the other path I suggested.
I note that you said this:
First of all, when putting code output in these forum posts, please format it correctly. When I look at the raw text in your posting, I see that the "device_launch_parameters.h is missing a quote mark at the end of the file name. It should be "device_launch_parameters.h". I don’t know if that is actually how your code is, but if it is, that is a problem you should fix.
To format multi-line code in these forum posts, edit your text or post, select the lines that are the multi-line code, and then click the </> button at the top of the edit window, then save your posting/edits.
I agree with you with that all of the output I am receiving is unusable. I mentioned the include statements to make the point that the nvcc compiler seems to be failing before it even gets to any source code statements.
I pasted the nvcc command line that Visual Studio generates into power shell. The output is listed below. Based on that output I reformatted the gencode argument that appeared to be incorrect and the command line ran in power shell with no error message but it did not generate an object file. From what I can tell the Visual Studio command line being generated is invalid
“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\bin\nvcc.exe” -gencode=arch=compute_52,code="sm_52,compute_52" --use-local-env -ccbin “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include" -G --keep-dir CUDATutorial\x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -D_DEBUG -D_CONSOLE -D_UNICODE -DUNICODE -Xcompiler "/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -Xcompiler “/FdCUDATutorial\x64\Debug\vc143.pdb” -o “D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial\x64\Debug\CUDAInterface.cu.obj” “D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDAInterface.cu”
At line:1 char:73
  • … VIDIA GPU Computing Toolkit\CUDA\v12.5\bin\nvcc.exe" -gencode=arch=co …
Unexpected token ‘-gencode’ in expression or statement.
At line:1 char:97
  • … ng Toolkit\CUDA\v12.5\bin\nvcc.exe" -gencode=arch=compute_52,code="s …
Missing argument in parameter list.
At line:1 char:1
  • "C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\bin\nvcc.ex …
The assignment expression is not valid. The input to an assignment operator must be an object that is able to accept assignments, such as a variable or a property.
+ CategoryInfo : ParserError: (:) , ParentContainsErrorRecordException
+ FullyQualifiedErrorId : UnexpectedToken
Here is the reformatted command line that ran with producing any messages and did not produce an object file. I expected to see something because I used the --verbose argument.
nvcc --verbose -gencode arch=compute_52,code=sm_52 --use-local-env -ccbin “D:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\include" -G --keep-dir CUDATutorial\x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -D_DEBUG -D_CONSOLE -D_UNICODE -DUNICODE -Xcompiler "/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -Xcompiler “/FdCUDATutorial\x64\Debug\vc143.pdb” -o “D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial\x64\Debug\CUDAInterface.cu.obj” “D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDAInterface.cu”
what happens if you just do:
“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.5\bin\nvcc.exe” --version
In powershell? What output do you get?
Here is what I received from nvcc -version
Copyright (c) 2005-2024 NVIDIA Corporation
Built on Thu_Jun__6_03:03:05_Pacific_Daylight_Time_2024
Cuda compilation tools, release 12.5, V12.5.82
Build cuda_12.5.r12.5/compiler.34385749_0
I tried running CUDA hello tutorial using the windows power shell. Here is what I received from nvcc hello.cu -o hello. Prior to doing that I ran a repair on Visual Studio.
nvcc fatal : Could not set up the environment for Microsoft Visual Studio using ‘D:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.40.33807/bin/Hostx64/x64/…/…/…/…/…/…/…/VC/Auxiliary/Build/vcvars64.bat’
Here is the version information for my Visual Studio Installation.
Microsoft Visual Studio Community 2022
Version 17.10.5
VisualStudio.17.Release/17.10.5+35122.118
Microsoft .NET Framework
Version 4.8.09037
Installed Version: Community
Visual C++ 2022 00482-90000-00000-AA512
Microsoft Visual C++ 2022
ASP.NET and Web Tools 17.10.344.38934
Azure App Service Tools v3.0.0 17.10.344.38934
C# Tools 4.10.0-3.24324.8+04fb39164c99c519832109f21b22630bc9246fce
C# components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Common Azure Tools 1.10
Provides common services for use by Azure Mobile Services and Microsoft Azure Tools.
Cookiecutter 17.0.24064.1
Provides tools for finding, instantiating and customizing templates in cookiecutter format.
GitHub Copilot 0.2.894.62884
GitHub Copilot is an AI pair programmer that helps you write code faster and with less work.
Intel® Advisor 2024 1.3.26
Intel® Advisor 2024, (Plugin Version 1.3.26), Copyright © 2009-2024 Intel Corporation. All rights reserved.
Intel® C++ Compiler 2024.1
Intel® C++ Compiler 2024.1, Copyright © 2002-2024 Intel Corporation. All rights reserved.
Intel® DPC++ Compatibility Tool 2024.1
Intel® DPC++ Compatibility Tool 2024.1, Copyright © 2019-2024 Intel Corporation. All rights reserved.
Intel® Libraries for oneAPI 2024.1
Intel® Libraries for oneAPI 2024.1, Copyright © 2019-2024 Intel Corporation. All rights reserved.
Intel® oneAPI DPC++ Compiler 2024.1
Intel® oneAPI DPC++ Compiler 2024.1, Copyright © 2019-2024 Intel Corporation. All rights reserved.
Intel® oneAPI Menu & Samples 10.10.392.9731
Intel® oneAPI Visual Studio Menu & Samples Extension
Microsoft JVM Debugger 1.0
Provides support for connecting the Visual Studio debugger to JDWP compatible Java Virtual Machines
NuGet Package Manager 6.10.2
NuGet Package Manager in Visual Studio. For more information about NuGet, visit https://docs.nuget.org/
NVIDIA CUDA 11.8 Wizards 11.8
Wizards to create new NVIDIA CUDA projects and source files.
NVIDIA CUDA 12.3 Wizards 12.3
NVIDIA CUDA 12.5 Wizards 12.5
NVIDIA Nsight Visual Studio Edition 2024.2.1.24155
NVIDIA Nsight Visual Studio Edition provides tools for GPGPU and graphics development. Copyright © NVIDIA 2010 - 2024.
•Direct3D® and DirectX® are registered trademarks of Microsoft Corporation in the United States and/or other countries.
•Microsoft Detours is used under the Professional license (Detours - Microsoft Research).
•Gardens Point Parser Generator Copyright 2005 Queensland University of Technology (QUT). All rights reserved.
•Icons from Axialis Software used under the licensing terms found here: www.axialis.com
•NLog Copyright © 2004-2006 Jaroslaw Kowalski (jaak@jkowalski.net)
•zlib and libpng used under the zlib/libpnc license (http://opensource.org/licenses/Zlib)
•Breakpad Copyright ©2006, Google Inc. All rights reserved.
•The OpenGL Extension Wrangler Library
Copyright ©2008-2016, Nigel Stewart (nigels@users.sourceforge.net), Copyright ©2002-2008, Milan Ikits (milan.ikits@ieee.org), Copyright ©2002-2008, Marcelo E. Magallon (mmagallo@debian.org), Copyright ©2002, Lev Povalahev.
•LIBSSH2 Copyright ©2004-2007 Sara Golemon (sarag@libssh2.org), Copyright ©2005,2006 Mikhail Gusarov (dottedmag@dottedmag.net),Copyright ©2006-2007 The Written Word, Inc.,Copyright ©2007 Eli Fant (elifantu@mail.ru),Copyright ©2009-2014 Daniel Stenberg., Copyright ©2008, 2009 Simon Josefsson.
•xxHASH Library Copyright ©2012-2014, Yann Collet. All rights reserved.
•FMT Copyright ©2012 - 2016, Victor Zverovich
•Font Awesome Copyright 2018 Fonticons, Inc.
•ELF Definitions Copyright (c) 2010 Joseph Koshy, All rights reserved.
•Boost, used under the Boost Software License (Boost Software License)
•gsl-lite, The MIT License (MIT), Copyright (c) 2015 Martin Moene, Copyright (c) 2015 Microsoft Corporation. All rights reserved.
•Protocol Buffer, Copyright 2008 Google Inc. All rights reserved.
•ThreadPool, Copyright (c) 2012 Jakob Progsch, Václav Zeman
The full text of the license for the OSS components used in this product is available as part of the Nsight Visual Studio Edition EULA (EULA — nsight-visual-studio-edition 12.5 documentation).
Warning: This computer program is protected by copyright law and international treaties. Unauthorized reproduction or distribution of this program, or any portion of it, may result in severe civil and criminal penalties, and will be prosecuted to the maximum extent possible under the law.
NVIDIA Nsight Visual Studio Edition - CUDA support 2024.2.1.24155
NVIDIA Nsight Visual Studio Edition - CUDA support provides tools for CUDA development and debugging.
Python - Django support 17.0.24064.1
Provides templates and integration for the Django web framework.
Python - Profiling support 17.0.24064.1
Profiling support for Python projects.
Python - VC Project Support 17.0.23055.1
Provides support for launching C++ projects with Python debugging enabled.
Python with Pylance 17.0.24064.1
Provides IntelliSense, projects, templates, debugging, interactive windows, and other support for Python developers.
Test Adapter for Boost.Test 1.0
Enables Visual Studio’s testing tools with unit tests written for Boost.Test. The use terms and Third Party Notices are available in the extension installation directory.
Test Adapter for Google Test 1.0
Enables Visual Studio’s testing tools with unit tests written for Google Test. The use terms and Third Party Notices are available in the extension installation directory.
TypeScript Tools 17.0.30327.2001
TypeScript Tools for Microsoft Visual Studio
Visual Basic Tools 4.10.0-3.24324.8+04fb39164c99c519832109f21b22630bc9246fce
Visual Basic components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Visual F# Tools 17.10.0-beta.24228.1+dd749058c91585e9b5dae62b0f8df892429ee28f
Microsoft Visual F# Tools
Visual Studio IntelliCode 2.2
AI-assisted development for Visual Studio.
So it looks like you have a broken install of CUDA in windows. You’ll need to follow the install instructions carefully. If your system is corrupted or the install history is complex, you may be able to get more quickly to a proper install on a system that has a clean install of Windows. There is a windows install guide available, and numerous questions about it here on this sub-forum. I probably won’t be able to help further.
I’ve reinstalled Windows 10, Visual Studio and the Version 12.6. The compiler still won’t run. Here is what I get when I try it in a Powershell session in Administrator Mode. I enter the command nvcc hello.cu -o hello.obj in the folder where hello.cu is installed.
nvcc fatal : Could not set up the environment for Microsoft Visual Studio using ‘D:/Program Files/Microsoft Visual Studio/VC/Tools/MSVC/14.40.33807/bin/Hostx64/x64/…/…/…/…/…/…/…/VC/Auxiliary/Build/vcvars64.bat’.
The folder referred to the error message does not exist. The vcvars64.bat file is installed in: D:\Program Files\Microsoft Visual Studio\VC\Auxiliary\Build
I created a new CUDA 12.6 Console project in Visual Studio. The nvcc compiler would not run. The build command produced the following error message which did not supply any useful information.
1>D:\Program Files\Microsoft Visual Studio\MSBuild\Microsoft\VC\v170\BuildCustomizations\CUDA 12.6.targets(799,9): error MSB3721: The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.6\bin\nvcc.exe” -gencode=arch=compute_52,code="sm_52,compute_52" --use-local-env -ccbin “D:\Program Files\Microsoft Visual Studio\VC\Tools\MSVC\14.40.33807\bin\HostX64\x64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.6\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.6\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DWIN64 -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -Xcompiler “/Fdx64\Debug\vc143.pdb” -o “D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial\x64\Debug\kernel.cu.obj” “D:\Craig\Visual Studio 2022\Projects\CUDATutorial\CUDATutorial\kernel.cu”” exited with code 1.
The path string in the error message looks like a concatenation of two paths; The front end looks like the path to the Visual Studio C++ compiler cl.exe and back end looks like the path to the vcvars64.bat file. Perhaps the logic that constructs the path is concatenating the two strings instead of instead of correctly using the path to vcvars64.bat.
