**• Hardware Platform (Jetson / GPU) - Tesla T4 **
• DeepStream Version - Deepstream-6.2
• TensorRT Version - 8.5.2.2nvidia-
• NVIDIA GPU Driver Version (valid for GPU only) - 525.85.12
• Issue Type( questions, new requirements, bugs) - Query
I am running my application where I want to composite multiple input streams into a single output window. While I am able to do it using the nvmultistreamtiler plug-in, I cannot set the properties of individual streams if I use this plugin.
I observed that “nvcompositor” plugin can instead be used to composite the streams (while also setting properties like x_pos and y_pos). I tried to run the command " ```
$ gst-launch-1.0 nvcompositor name=comp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=2560 sink_0::height=720 sink_0::zorder=1 sink_0::alpha=1 sink_1::xpos=0 sink_1::ypos=0 sink_1::width=2560 sink_1::height=720 sink_1::zorder=2 sink_1::alpha=0.1 ! ‘video/x-raw(memory:NVMM),format=RGBA’ ! nvvidconv ! video/x-raw ! xvimagesink videotestsrc ! video/x-raw,format=YUY2,width=2560,height=720,framerate=30/1 ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=RGBA’ ! comp.sink_0 videotestsrc ! videoconvert ! video/x-raw,format=RGBA ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=RGBA,width=2560,height=720’ ! comp.sink_1
However, when running the same, I observe the error - "WARNING: erroneous pipeline: no element "nvcompositor"".
Am I missing something? Is the nvcompositor plugin only supported on Jetson boards?
